View Full Version : Cars & Parts Wanted.
- rs turbo exhausted 3" bore
- Sierra 7 x 15 RS alloys
- I HAVE A GRAND WHAT HAVE YOU????
- ECU for 2ltr zetec
- ESCORT TURBO T3 WATER PIPE
- ERST S2 Rear Wishbones
- Exhaust manifold for Zetec XR2 Conversion
- 1 4x4 sierra cosworth alloy wanted
- Sierra Cossie wanted
- escort rs turbo t3 return rubber hose wanted!
- rs turbo parts wanted!!!
- ERST downpipe & 90 degree elbow required
- S2 escort rs turbo bonnet (with vents)
- something to take mk4 running gear [][][] mk4 cab wanted too
- Escort Mk4 Green tint front winderscreen not heated
- Pair of 4x4 Bd10
- Car Transporter Trailer Wanted
- 803 green injectors +3 bar mapsensor
- quafie diff cossie
- efi conversion bits
- Full Puma lockset
- focus rs
- Polybushed rear wishbones or (VGC standard) RST
- Saph cossie side strips
- Recaro's and T3 bits
- AP Rotors 330mm x 28mm with 12 bolt fixings
- Wanted New or VGC Rear Wheel Well Liners for a MK I Sierra
- wanted mint s2 rs turbo
- escort cossie
- Efi conversion parts
- Mondeo 2001/2002 Drivers side bonnet hinge
- T34 .63 Turbo
- Intercooler Rs500Typ for SAPPHIRE 2rm
- Vectra GSI estate
- Escort Cosworth T25 Loom
- sierra 4x4 cos backdoor wirings
- Sierra wanted must be sapphire
- cosie hoses
- 1.8 zetec bottom end
- gti rear seats
- 2.0 Zetec
- wanted roof handles mk3 cabrio
- Wanted TURBO t3/t4
- cosworths and rs turbos wanted
- 2WD Diff Needed
- AP Brake, Hydro Handbrake, GrpA Square beam, Side exit zorst
- 225 40 18's
- Replica RS500 Splitter (fibreglass?)
- -31, alloy front cooler and rad, decent chip (efi rst)
- 4x4 cos calipers and discs
- .63 exhaust housing
- cossie bits wanted-cheap as poss!
- please help
- fiesta si front bumper fog surrounds
- 88 spec ERST charge carrier
- 2wd cossie, s1 or spec'd s2 for my E30 bmw convertible SWAP!
- Saph shell with roll cage
- Fuel Pump and Swirl Pot for Zetec Conversion
- cheap average or poor conditon front recaros
- Mk5 RS2000
- ERST Gearbox Parts...
- decent clutch for 200+bhp and front mounted cooler
- New project wanted (Cossie rolling shell etc...) under £2k
- MK5 RS2000 cat
- series 1 cts stage 2+ gearbox
- Escos Fuse box
- focius tdci lowering springs wanted
- rs turbo engine and all running gear...
- calipers
- cheap 15 inch alloys
- Mint rear bumper for sapph
- 1969 ford fairlane
- 2wd saff cossie wanted
- escos front splitter
- 3 door rear seat clips
- CVH new or excellent condition cam belt cover
- sorted now thx
- Series 2 rad
- 4 long studs (urgent)
- 1800 sierra bottom pullley
- fiesta or escort rs turbo
- Small turbo bottom pulley
- 4x4 saff snokflake rims
- alloys for mondeo
- rough bodied sapphire cosworth wanted
- ESCORT RS TURBO REAR SPRINGS
- -31 actuator fr s1
- wanted escort cosworth morettes
- water hose
- rs turbo engine (everythink for a conversion)
- 2wd crankshaft pully
- Turbo oil feed T piece.
- swap 2.0l fezza for 1.6 escort
- sorted
- bottom radiator hose for frst
- s2 alloys (diamond cut?)
- r s turbo s2
- WANTED COSWORTH GEARBOX 2WD T5
- cheap rs
- wanted big bhp 3 door
- 2wd Sapphire Cossie Steering Cowling
- front coilovers
- FRST Parts wanted
- I am after a Series 1 RS Turbo
- 7.5" 4.1:1 CWP needed
- -34 actuator for a 2wd saph
- Sierra interior bits wanted
- Series 2 rs turbo, crashed, MOT failure, engine failure etc
- T34 Turbo with Maram Shaft for anti lag!
- any body got a 3 door cosworth 4 sale (may be rs500)
- Urgently wanted ofab supressor
- 1x OZ Superleggera 15" ET37
- anyone breaking a 4b or 4wd cos
- escort mk3/4 drivers door pillar
- FRST speedo cable and rear driver side hub
- Uprated 2wd cossie diff wanted BAD
- Escort cabriolet NS door and roof (1997)
- MK5 Fiesta Bumper and Driver's Wing
- cosworth cam/rocker covers
- Sierra quickrack
- Centre Caps
- Managment to run twin 40`s on zetec.....
- Mk3 Fiesta Parts - i guarantee someone will have them here!
- wiring loom
- ***rs turbo s2 coilovers*******
- xr3i 1990 efi air filter box
- T4 for standard turbo anyone??
- mds stage3 evo chip
- Atlas Diff CWP
- decambered leaf springs mk6 escort van
- Turbo Pre Filter Wanted..
- 1.8 zetec 16v
- DELETE ME !!!
- S1 loom
- One Comp MO needed
- t3 stage3 rst s2 *******WANTED******
- escort rs turbo cambelt Tensioner
- Saff lowering springs
- Saph Leather door cards and black plastics!
- 3DR FIBREGLASS PANELS
- cossie steering boss
- gti side skirt
- garret t2 water feed pipe
- cosworth 4x4 plastics
- 4x4 COSSIE ENGINE
- tyres
- 7 x 13' revolutions for a MK2 Escort, any condition.
- Escort Cosworth bodyshell - damaged OK
- RS Turbo Oil Pump
- MK5 Cortina Wanted
- Masitaly Vt5's or the Kahn rsr's
- escort gti estate
- Split rims
- 3dr id
- Coilovers for 2wd Saff
- alloys.......
- mk1 escort steel wheels
- Escort RS Turbo s2 Standard Radiator
- mk2 fiesta or mk4/5 escort van. :thumb:
- Boot seal for 3 door cossie
- 2litre 16v zetec engine
- swap or w.h.y
- swap
- spec-r strut brace
- Black Leather, Luxury Ka Steering Wheel In Good Condition
- 3dr cosworth aerial
- COSWORTH 2WD THROTTLE BODY
- Sapphire lock set
- drivers side front door in silver 3 door (puma)
- S1 front seats
- saf and hatch little things
- Sierra Gls 2.0ltr in mercury grey
- URGENT - 5th Gear wanted for 3dr Cosworth
- front wings for S1
- mk5 escort morettes wanted midlands area
- Escort Cosworth Standard Wheels
- for 2wd sapphire, wanted 3dr hubs... ALSO 4x4
- roll cage
- cossie 4wd to 2wd conversion parts wanted
- Crankshaft 1,9l CVH
- Rs1600i parts/MK3 or maybe MK4 doors
- wanted new light blue ford badges and pass side indicator s1
- S1 ECU
- rs turbo coilovers
- efi flywheel ,bottom pulley , cps sensor, coil pack.
- escos super Ts wanted
- RS 500 INTERCOOLER WANTED
- RS turbo Accelerator cable
- Fiesta RS Turbo/Rs1800/XR2i Front Bumper
- WANTED ASAP!
- group a coil
- WANTED: 2WD Saph Cossie Adjustable FPR
- Mk5 Fiesta Zetec S Cat-Back Exhaust
- Wanted Rs1600i
- RS Turbo Rear Arms
- wanted saff 4x4 power steering rack
- fiesta rs turbo interior
- Back box wanted
- Shell
- front bumper
- 2wd rear calipers
- Wanted mk5 rs2
- OFAB ecu
- XR2 BITS
- Water Pump
- 97 escort GTi jacking point covers
- Lower spoiler Esc Cos
- WANTED BIG BHP ESCORT S1 OR S2!! NO SET BUDGET! MUST BE MINT
- Series 2 Flywheel
- Rust Free 3 door Mk4 Escort Shell
- ESCOS GENUINE FRONT BUMPER AND BONNET W/VENTS
- 2wd boost hose (intercooler to inlet)
- 4x4 cossie front calipers
- s1 parts wanted
- carbon door mirrors escos - urgent for ford fair !!!!!!
- escort s2 petrol pump holder needed
- RS500 frontsplitter wanted
- I would really really like.......
- servo vacum tube and fitting for rs turbo
- TOW BAR for my transit 120
- especially clean escort
- 306 d turbo
- cosworth 2wd diff
- 200 block
- yellow injectors
- Wanted fiesta RS turbo
- steering boss
- alloy tubing
- sierra saff auto wanted
- Standard 2wd Cosworth Clutch Cover/Pressure Plate
- sorted
- proper fuel tank
- s1 wheels and good tyres needed asap¬
- Original Esc S2 Radio..
- Gear stick wanted 2WD
- gear gaitor surround 4wd cossie
- sorted now
- Front bladed anti roll bar,4x4 BD14's,uprated mounts.
- mk3/s1 parts needed asap!!!!!
- Wanted escort series one rs mint 200bhp +
- ofac loom and map sensor
- sorted now thx dave
- Search a 1,9l CVH Crankshaft
- ERST S2 ENGINE WANTED
- wanted s2 rs turbo
