PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. p8
  2. mk3 escort shell 3dr
  3. WHITE SAPPHIRE COSWORTH WANTED SWAP/PX WITH M3
  4. genuine back box for sapphire
  5. S2 boost hoses
  6. Sierra or Sapphire front indicators wanted
  7. Escort Cosworth fuel tank straps
  8. Fiesta Alloys wanted
  9. RS1600
  10. escort cossie intank fuel pump sender unit assembly
  11. Sierra Seat Runner
  12. C.T.S Stage 2+ RST Box
  13. 3dr cosworth plastics and parts
  14. s2 rs turbo
  15. Farm quad wanted,
  16. Escort mk3 steering column.
  17. erst bottom end
  18. 4x4 big wing sump wanted
  19. stage 1 small turbo
  20. 3 Door Lights
  21. Needed! S1 windscreen rubber &Carpet & soundproofing
  22. xr4x4 front diff
  23. 4x4saff petrol tank
  24. XR2i Engine Mount (Driver/Side) desperate!!!
  25. mambrane for Aeromotive Fuel pressure regulator
  26. sierra front recaros
  27. FRST engine
  28. escort mk3 wing mirrors
  29. Focus ST Parts Needed (225 Volvo T5 Engine)
  30. wanted s2 wiring loom
  31. 1 x mk3 or 4 spot light & mk3 brackets.
  32. Wanted escos
  33. RS Turbo Throttle Body/Butterfly
  34. escort rs turbo s2 top boost hose
  35. Mk4 Escort/Mk2 Orion Dials
  36. escort cosworth ecu
  37. escort mk 4 1/4 panel
  38. long shot
  39. Lotus Elan Seats Wanted
  40. 3 door cossie grill in vgc
  41. t3 turbo wanted
  42. mk 6 escort bodykit
  43. frst radiator
  44. RS 1600i Rocker cover
  45. Fiesta Turbo Alternator bracket and arm wanted!!!
  46. rs 500 3dr wheels wanted
  47. ESCORT COSWORTH PARTS NEEDED
  48. st220 seats
  49. cossy 2wd motorsport leads,grpa cam belt,spark plugs etc,
  50. wanted,cossy 6 paddle x cover x bearing also 2wd bellhousing
  51. MK6 RS2K Cat or decat pipe
  52. lowering springs for mk2 xr2
  53. Puma 1.7 Engine
  54. wanted: escort cosworth caliper carriers
  55. 17 Inch diamond cut alloys wanted
  56. Need A Cheap Ford
  57. mk3 s1 back pannel original or patten
  58. Focus RS Front Seats
  59. mint S2 shell
  60. wanted RS1600i or maybe series one turbo
  61. Wanted fiesta rs turbo
  62. Rear brake disc protector
  63. Excellent full 90spec loom
  64. MK3 Escort Front Crossmember
  65. S2 Tailgate
  66. Set of standard saff 4x4 wheels or comp mo's
  67. escort cosworth alloy
  68. Gearbox
  69. Cortina mk3 rear wheel arch
  70. Escos Rear ARB
  71. mint mk4 bonnet
  72. wanted mk3 escort over riders
  73. Series 1 Body kit
  74. Cosworth mirror image breather tank
  75. GOOD 3 DOOR REP OR A O.K S2 TURBO
  76. standard s2 alloys or 16" mondeo si alloys
  77. 4x4 Cossie paddle clutch
  78. Escort s2 t3 turbo
  79. Ford KA Shell/Car
  80. 2.0 Zetec Bottom End OR 2.0 Pistons
  81. cosworth wanted up to 3k let me know what you got
  82. I WANT a L6 ecu
  83. koni suspension escos
  84. mondeo zetec-s alloys
  85. CHIPPED erst ecu wanted
  86. 3 or 4 steel wheels needed in coventry area. (Warwick Uni)
  87. Swedish Plenium Wanted
  88. Cossied mk1/2 Escort
  89. saff 4x4 coilovers
  90. S1 wanted
  91. nintendo wii
  92. s1 bonnet
  93. T3 turbo
  94. focus splitter
  95. Anyone breaking a fiesta rs turbo
  96. 3 door shell mint
  97. escort cossy front diff
  98. look wot happend to me, need some bits or mint cos shell
  99. Wheel for Street KA
  100. need these asap.. for 2wd saph
  101. I need a front screw in toe eye for an escos?
  102. escort or fiesta turbo rep
  103. mk2 xr2 drivers rear arch(kit) excellent Cond PAY ANYTHING
  104. fiesta or escort rs turbo rep
  105. Mk3 Escort Boot lock
  106. St200/24 Parts
  107. Ford Probe cylinder head
  108. mk3 cabbie stub axle
  109. Mk3 escort spotlight brackets.
  110. 3 door parts please help
  111. MK5 Escort Parts (Standerd + Upgraded)
  112. Series 2 RS Turbo Bonnet Needed urgently
  113. Square GpA beam wanted
  114. PAS cooling pipe clamp rubber ...
  115. Sapph Cossie part
  116. MINT White RS S2 Bonnet.......
  117. mini wanted
  118. B&M Alloy gear knob
  119. Fiesta RS Turbo Head and inlet manifold
  120. Wanted airfilter to fit direct onto t34
  121. centre caps
  122. Ford Escort RS turbo s2
  123. T34 Turbo
  124. cossie stage 3 bits needed.
  125. s2rst uprated clutch wanted
  126. s1 or s2 stainless exhaust system
  127. t5 2wd gearbox.....
  128. Blade type front ARB for cossie
  129. COSWORTH 24V BOA PERFORMANCE PARTS WANTED N/A NOT TURBO
  130. .63 housing
  131. leather saph door cards
  132. clutch
  133. 2wd rubber engine mounts needed new or 2nd hand
  134. wanted 2wd saff
  135. all sorted,mods,please remove
  136. Cossie numberplate
  137. white s2
  138. *******T34 2WD*******NEEDED******
  139. frst tep switch multiplug
  140. Anything considered about £500
  141. very cheap project car sought after.
  142. Wanted 2WD saff
  143. Pipes off a turbo for water cooling
  144. lookin for granada. Cash waiting...
  145. focus 2.0 (turbo supercharged)
  146. Escort 1.8 Clutch kit
  147. cvh rocker cover (PE+??)
  148. delete
  149. rst s2 wire tube covers boot
  150. 4x4 cossie dizzy cap, Map bracket, donations please
  151. Sapphire cosworth 2wd interior parts
  152. fiesta turbo wanted
  153. sorted
  154. Pectel T2 ECU
  155. 90 spec bumper
  156. low comp piston
  157. Mk1 or Mk2 Fiesta with Zetec conversion
  158. escort rs t3 oil return metal pipe +rubber pipe!
  159. Beige injectors
  160. Escort cos fuel pump for RS turbo [Got One!]
  161. WANTED!!..........
  162. L8 ecu
  163. Renforced MT75 gear box wanted
  164. Race specs engine wanted
  165. focus RS bits needed!!! asafp!
  166. sapphire cossy bottom end
  167. 88 spec sierra saff rear lights!!
  168. 2.9 Strut Brace
  169. wanted : RS1600i front lip spoiler
  170. LHD Escort cosworth Windscreen scuttle & splitters
  171. clear indicator
  172. Focus RS Engine
  173. 2.0 pinto plus g/box
  174. rs turbo engine.
  175. few rs turbos bits wanted
  176. help needed
  177. Rs turbo gearbox needed.
  178. fiesta rs turbo wanted
  179. swap for my escort cab
  180. wanted 3dr cossy wheels,gold or black
  181. Mk5 Escort 3dr
  182. lombo doors
  183. rs turbo S2 radiator!!!!
  184. Raceline RL7's
  185. FRST engine.........IGNORE, IVE GOT ONE THANKS!
  186. Sierra Cosworth turbo parts
  187. Wanted Sierra 4x4 facelift (92-93) parts
  188. Escort Cos bonnet
  189. Small turbo Cossy plenum
  190. alloy wheels for sapphire cosworth
  191. engine's needed
  192. s2 engine wanted
  193. ERST Bonnet And MK4 rs caby spoiler
  194. 2WD Bells 4 AP Disc,s wanted
  195. any cheap car
  196. Rondell 122 cup
  197. .63 or .55 housing for t34
  198. 17" comp`s,rl7 or speedline
  199. rs1600i parts
  200. ESCORT COSWORTH WANTED
  201. FORD 2008 CASSETTE PLAYER+FORD 2028 OR 2040 CD PLAYER
  202. 17's for 4x4 cossie
  203. L8 + 4X4 INLET MANIFOLD
  204. 2wd cossie sump wanted
  205. 2wd brakets and bells wanted
  206. clutch for escort S2
  207. Engine wanted ERST S2
  208. 4wd Cossie cam shafts
  209. FRST Alternator Bracket + Ajuster
  210. Saph cozzy parts
  211. ST24 Complete Engine
  212. FOCUS ST 170 ALLOYS.
  213. Wanted
  214. RS 2000 high lift cams
  215. Xr3i efi wiring loom
  216. mk3 rst intercooler and radiator....front mount?
  217. turbo needed asap
  218. mk4 escort towbar
  219. .48 rear housing for T34
  220. 4x Oz rally wheels 8x16
  221. Badges
  222. T3 saph cos 4x4
  223. Front cover off a Cossie engine
  224. Zetec Turbo Parts
  225. escort mk6 front bumper must be complete
  226. rs turbo samco/sfs hoses
  227. 4wd windage tray and bolts
  228. Escort cosworth quad lights
  229. Original rear lights
  230. fiesta turbo roof lining
  231. Escort Cos Small Turbo Ecu, Turbo Heat Shield, Rondells
  232. Fiesta mk3 fog switch
  233. CHEAP RS2K
  234. mk6 escort van front lowing shocks and springs
  235. 14" 15" Alloys ford fit with tyres
  236. Tamiya TA01/02 RC car
  237. Bumper Guard / Protector
  238. T3 downpipe for fiesta rst
  239. Mk4 RS Turbo O/S Wing
  240. wanted xr2i or xr3i
  241. sports cars wanted
  242. saph cossie wanted swap with m3 convertible
  243. 1800 zetec bottom end
  244. 2WD Saph Cossie Wanted
  245. ST 170 engine and loom etc......
  246. S2 RST Shell Wanted
  247. AIR 2 AIR /LW FLYWHEEL
  248. Heated window repair paint - any good?
  249. Escort Mk4 Green tint front winderscreen not heated ANYONE
  250. Group A and WRC parts
