4wd windage tray and bolts
Almost there!
Rich, possibly a long shot - but ill speak to Martin on friday when i see him.
mines been taken apart to be big winged and to have a mountune baffle plate fitted inside - if Martin has kept my origonal windage tray from the sump then your more than welcome to it
yes it goes front to back under neath the crank
does not bolt to the sump
you can still run one with a big wing sump as its above the sump
the one you take out the sump you dont run when you us ea big winged gated andbaffled sump as the gates and baffle replce the std item
I assume you are talking about the plate in the sump, not the one that bolts under the crank on the main cap bolts, as only small turbo engines have this?
If it's the normal 4x4 sump baffle ,brand new from ford these are Ł10.48 + Vat
Finis code is 6844115
99% sure it is only small turbo, never seen a big turbo escos engine stripped, but seem loads of late 4x4 saffs, and they don't have them. Do your maincap bolts have extra threads on the heads to accept the nuts for them?
My small turbo has the tray you are talking about and as such has no sump baffle plate apart from one small one that hooks over the driveshaft x-member
hmm
no my caps dont have the threaded bit on them
now thinking about it im wondering if its the v6 24 v i stripped that had and im getting my wires crossed
the only tray i have bolts insde the sump abover the shaft as you say
think ill just leave it sure it wont do no harm
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
