Escort RST s2 Turbo options
Hi.
I'm wondering what options there are for replacing the standard Garret T03 Turbo with some other instead of upgrading the original to a 2/3 hybrid, no one seems to have the turbo in stock, so they need you to ship it to them and due to where i live, the turbo has to be shipped out of the country and the shipping alone is insanely expensive.
The goal is around 220-230 bhp (with all the typical upgrades)
Cheers.
Cheers.
Any turbo change will also require spark/fuel tuning etc to suit.
If you are prepared to adapt some parts to make a different turbo fit, then there are thousands of options
Something like a GT2860 would probably work well.
This would normally be a T25 flange, but your manifold could likely be drilled/tapped to suit and you'd need to remake some pipes.
Or even a small Hoslet is pretty cheap https://www.stavtech.co.uk/home/stav...-and-downpipes
https://www.speedingparts.co.uk/p/tu...BoCpWEQAvD_BwE
There will literally be hundreds of similar options
