PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 3 bar map sensor required
  2. Sapphire NSR chassis rail WANTED
  3. 3dr Cosworth Firewall/Bulk Head Sound deadining..
  4. Hydraulic clutch conversion + Clutch
  5. wanted s2 rst drivers side drive shaft
  6. BMW CD Adaptor
  7. Escos rear anti roll bar wanted
  8. *WANTED* esc cos nomad rear lights!
  9. xr3i loom
  10. 2WD YB Cam Cover - WANTED!
  11. 2wd cosworth clutch cable new please
  12. escort rear holder
  13. Cosworth Braided Rear Brake Hoses
  14. 1.8 Zetec Blacktop
  15. L6 & L8 ECU / 2WD YB Cam Cover - WANTED!
  16. efi loom
  17. 2 w/d diff
  18. 2wd cossie turbo water pipe needed
  19. damaged, salvaged, rotten saff wanted
  20. sapphire gear box cradle
  21. roll cage (wanted)
  22. Tunnel bulkhead
  23. Dump valve RST escort MFI (double piston type)
  24. ecos tool kit + front mount
  25. fiesta mk2 coilover suspension
  26. mk3/4 escort rear axle stub x 1
  27. saff door mouldings
  28. mk1 frs front bumper
  29. gauges wanted
  30. RS500 Upper Fuel Rail
  31. good condition mk5/6 RS2000 wheels WANTED
  32. Saphire Cosworth Rubber Splitter
  33. desperatly need st170/ mk1.5 focus front end parts
  34. ford motorsport rocker cover (wanted)
  35. Rs steering wheel boss (wanted)
  36. Piper Vernier + Mondy 5 spoke wheels
  37. cosworth head
  38. parts needed
  39. adjustable strut brace
  40. Cosworth 2wd flywheel ;)
  41. Cosworth beam solid mounts
  42. Fiesta mk6 headlining
  43. Sierra front suspension tops
  44. Escort RS2000 MK5 Cage WRC/Track Part, Performance Upgrades, Sparco Evo Seat + more
  45. Standard Escort cossie intercooler
  46. mk2 xr2
  47. in need of good runner RS Turbo engine
  48. std Sierra NON PAS Steering shaft
  49. Cosworth 2wd front Coilovers
  50. wheels
  51. focus
  52. S1 Top boost hose STANDARD
  53. Stage 3 Kit for 2wd 1990
  54. wanted 4x4 saff bonnet !!
  55. cosworth accelerator pedal
  56. Sierra Shell
  57. 3 door focus
  58. essex v6 engine WANTED please
  59. autometer pro comp gauges
  60. cosworth knackered bonnet
  61. cosworth wheels
  62. 2wd cosworth sump
  63. ford anglia
  64. 4x4 damaged cossy
  65. 2wd Big brakes
  66. fmk2 fiesta roof rack/carrier
  67. Escort small turbo plenum cover
  68. cosworth clutch fork ball pivot. help.
  69. I4 DOHC crank pulley
  70. Anyone got a clutch for a 1998 escort cvh in fife???
  71. e30 diff
  72. Wanted Nice Fiesta RS Turbo
  73. pistons for zetec turbo
  74. Any engine & aux bolts needed ;)
  75. standard sapph cos clocks
  76. mk4 escort headlamp protector
  77. Mondeo 2.0 zetec power steering cooler
  78. Focus RS or ST170 reare brake calipers
  79. 2wd Saph idle control screw
  80. Oil Breather tank
  81. Wanted chipped OFAC FRST ECU
  82. cossie crank needed std/std
  83. 2wd rear end parts
  84. wanted door catch for saff 4x4 cosworth
  85. Wanted: Fuel pressure regulator for 2WD Cosworth
  86. 4x4 bonnet vents
  87. Toyota Yaris T Sport Wanted
  88. apexi avcr wanted!!
  89. cosworth crankshaft needed, on std sizes
  90. Escort RST throttle body
  91. 17" RL7's
  92. Old school tsw evo not evo r
  93. Focus Zetec Alloys and tyres
  94. 2wd Sapphire "Lattice" style wheels x4
  95. 2wd Sapphire Orange indicators + rear light
  96. Damaged/rolling fiesta zetec s wanted
  97. Wanted Stage 2 T3.48 Turbo 360 Degree for 2WD Cosworth
  98. esc cos nomad rear light's and cossie tb please
  99. 3 door parts
  100. old style comps, saff offset 18's
  101. S1 turbo rear seat hinges and catches
  102. Need ASAP escort s2 rst dizzy
  103. NOMAD rear light cluster's for mk5 escort
  104. ecos wheel nuts
  105. Wanted 2WD Cosworth fuel pressure regulator
  106. ICV in the birmingham area
  107. Wanted 2wd cosworth Bilstein front dampers
  108. Cosworth proflex Wanted
  109. ONE Front Koni Adjustable shocker
  110. 3dr rear door cards
  111. l8 pectel board
  112. .48 housing for 4WD T34
  113. RS 3 Spoke steering wheel wanted for 3dr
  114. cossie 4 spoke
  115. Escort s2 mk4 passenger side headlight protector
  116. escort rst engine
  117. OFAB 195 chip
  118. defi gauge
  119. White Faced 60mm defi Boost gauge
  120. ford sierra Immobiliser
  121. cosworth 4x4 throttle body, even better if modded for ALS
  122. cosworth tunnel/bulk head an turret tops!
  123. Standard 2wd cosworth exhaust heat shield please !
  124. dump valve with the filter on it..
  125. steel wheels to fit saph cos
  126. 17' alloys for saph cossie
  127. standard cosworth lattice wheels
  128. ohv engine hose..fuel pipe.. 1.3
  129. cossie 4x4 uprated front and back diff
  130. turbo wanted
  131. 4x4 shell
  132. 4x4 cosworth fuel regulator
  133. Focus rs rods wanted for cheap zetec turbo build
  134. saph elec sunroof mounting plate
  135. twin pump set up
  136. **WANTED** Escort S1 Rocker Cover.
  137. Escort Cab Power hood relays
  138. Wanted: Focus RS Parts
  139. mk5 fiesta zetec rolling shell wanted
  140. wanted escos standard stereo and steering wheel
  141. mk 4 rear wheel drive cosworth shell wanted
  142. L8 ecu wanted
  143. 2wd sump and selector fork
  144. wheels reqd
  145. fiesta 1.6 zetec s engine wanted
  146. 4x4 cosworth inlet manifold (just the injector manifold section)
  147. Air Box Wanted
  148. escort cosworth banna pod
  149. Sierra 3 dr roof/head lining
  150. mk1 or mk2 rear spring hangers and u bolt clamp
  151. Ally Tank and 13 x 7 Wheels....
  152. Focus RS Wanted
  153. efi flywheel
  154. Stuff needed for my RS500, door trims, parcel shlelf etc
  155. Rs 1600i rocker cover wanted...
  156. T34 water pipes please
  157. diamond cut rs7's
  158. Escort mk 3/4 rear wheel drive shell
  159. escort cossie tailgate
  160. mk 3 granada 5 stud hubs f&r
  161. Series 2 T3 Turbo
  162. anyone got any kicking about??
  163. sierra 3dr header tank - not worried about condition!
  164. please delete
  165. wanted saff cage
  166. Big Brake Kit for ERST S2
  167. sierra 3dr header tank wanted!
  168. Small turbo throttle body
  169. Wanted: 245 35 17
  170. 4x4 Rear ARB
  171. after market ecu
  172. ECOS mod parts wanted
  173. saph cosworth wanted
  174. P8 wanted
  175. mk3 fiesta shell/welder
  176. radiant red colour tag plate for slam panel
  177. 3 ford mud flaps
  178. .
  179. ap/tarox 4pots cosworth
  180. s2 erst sunroof seal.
  181. new gudgeon pins cosworth
  182. ford racing boost and oil pressure guage
  183. Defi Gauges...
  184. 205 YB block
  185. 18in comps for a saff
  186. Need some cossie front shafts asap please
  187. Wanted 4x4 Cossie front drive shafts
  188. Small turbo rocker cover
  189. 3 door plastic parts
  190. .
  191. Nos set up
  192. escort rst s2 sill
  193. Escort Turbo S2 Dials
  194. focus rs pistons and rods
  195. sapphire 2wd steering wheel cowel
  196. 2wd discs wanted!
  197. wanted mk3/mk3.5 fiesta shell please
  198. Sapphire Exterior C pillars
  199. 2wd Cosworth T5 Gearbox
  200. defi gauges and controller
  201. rs turbo cts stg2+ gearbox
  202. Need engine Wiring and sensors
  203. rs 500 front grills for escos
  204. Cosworth 2wd sump and other parts
  205. Fiesta xr2i external door rubber passenger
  206. suspension kit wanted
  207. Standard S2 Top boost hose
  208. crossflow engine wanted
  209. Escort Rs Turbo Suspension Bump Stops
  210. 2wd Front Cross Member and 2wd T5 Gear Box (Good Condition)...
  211. saff 4x4 comps
  212. Audi A4 / Vw Passat - estate TDI wanted
  213. Twin weber carbs
  214. 17" alloy (just one)
  215. Kit Car wanted ......
  216. MK3 Escort / S1 URGENT ASSISTANCE PLEASE
  217. cosowrth engine brackets
  218. escort cossie front splitter wanted
  219. nomad white face oil pressure gauge
  220. CVH Steel H section Rods, Farndon, Pec, etc...
  221. *** few mk2 xr2 bits urgently wanted***
  222. mocal 13 row oil cooler
  223. Wanted saff shell
  224. Cosworth Touring Car Spec Head
  225. saff bits ( heater control) asafp
  226. Ford RS500 BBS 16" Alloys
  227. RS1600i Tappet Spanners.
  228. Escos small turbo inlet/plenuim & throttle housing
  229. 4x4 dip stick tube and bracket
  230. Red Samco
  231. mk1 fiesta bits (engine etc)
  232. Wanted 17"oz superleggera alloy wheel
  233. 4x4 Saphire Cosworth parts......
  234. mk3 fiesta please
  235. LHD 52mm cossie saph pillar gauge holder
  236. Racing bucket seats
  237. ST24 starter motor
  238. Saph Cossie 2WD Alloy rad.
  239. Saph foglights
  240. 4x4 sapphire abs sensor
  241. WANTED - Morette Twin Headlight
  242. Wanted - MK3 Fiesta front heated windscreen and wiring
  243. Cosworth 4x4 big winged sump
  244. cosworth 4x4 fuel reg wanted
  245. Looking for a FWD RS2000
  246. 3 door handle, passenger side
  247. s2 turbo
  248. Clutch wanted.
  249. amal valve jets/inserts
  250. Wanted 17' oz superleggera alloy wheel
