PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 2wd dipstick.
  2. ST EEC Escos throttle body
  3. group a fitment 8jx17 et33 wheels
  4. escos banana pod.....
  5. s2 rear brake setup
  6. 1 18 escort cosworth
  7. Wanted - s1 loom, cooler, good metering head.
  8. s2 rs turbo stainless front strut brace wanted
  9. T5/2wd Clutch fork + 2wd Downpipe, stainless
  10. Leda Suspension Escort Mk4/RS Turbo
  11. WANTED: mk4 escort S2 rs DOORS
  12. wanted rs turbo seats / interior 88 spec
  13. Saff centre console trims
  14. S2 rst black clock dials (non peeling!)
  15. Leather 3 spoke RS steering wheel..
  16. Fiesta RS Turbo Panels
  17. Fiesta RST air charge temp sensor
  18. escort cosworth wheels
  19. OFAB running gear?
  20. Wanted Escort MK4 RS Turbo Van Petrol tank
  21. 2wd cossie 4 pots wanted
  22. Cosworth ISCV
  23. MK4 Scuttle Panel anyone?
  24. Adjustable top mounts
  25. Wanted: S2 rs turbo .5 oversize pistons
  26. wanted fiesta rs turbo as cheap as poss and dont mind work/welding
  27. 3 door front arches wanted - colour not important but must be VGC and OE Ford
  28. OFAC map sensor
  29. 3.9 front & 7.5" 3.9 rear crown wheel and pinions for cosworth
  30. Wanted escort s2 rst doors
  31. escort mk 4 cossie or wrc front bumper wanted
  32. Big Turbo Airbox
  33. Saph underlay
  34. wtd: FRONT WING, driver side Mk4 Escort RS
  35. Qep zvh water pump plate.
  36. WANTED:-pinto 4 branch manifold
  37. 3 bar map sensor
  38. -34 Actuator in very good / new condition
  39. 3Door front bumper
  40. Air injectors
  41. 2wd silicon water hoses
  42. Map sensor
  43. Anyone got any damaged UT Escort Cosworths they want to sell?
  44. 2wd exhaust manifold
  45. Anybody got a rotten saph I can cut a part out of?
  46. recaro sportster cs seats ( mk 2 focus rs !! )
  47. Sierra cosworth fuel tank
  48. blacktop zetec + other bits wanted!
  49. Saph front ambers
  50. st170 recaro interior wanted
  51. transit van
  52. Sapp Rear ARB Mounting Panel
  53. Cosworth throttle body
  54. mk 5 escort base model car loom
  55. Mk3 mondeo 16" steel wheel x1
  56. RST rear wishbones
  57. level 8 stg3 chip needed for 803s
  58. Turbo oil return
  59. Sierra bits
  60. Leda suspension XR3i /RS Turbo
  61. T3 bottom boost hose
  62. Mk2 fiesta
  63. Mt75 gear linkage
  64. 18" Wheels to suit Escort Cossie Wanted
  65. Misc 2wd bits required if anyone can help :)
  66. series 1 exhaust
  67. wanted genuine 18inch bmw mv2 alloy
  68. 4x4 front coilovers wanted please
  69. BBS style wheels for audi
  70. combi van rear bumper
  71. Wanted : Mk3 escort Ghia
  72. WANTED cosworth exhaust front pipe stainless
  73. 2wd starter, motorsport leads, and lead separator. WANTED
  74. bd14 ex or inlet cam
  75. 1k looking at golf gti, rs2000 xr2/3 Clio sport ect
  76. Wanted:GGR Escort Cosworth water swirl pot.
  77. Wanted : Escort cosworth
  78. Wanted : Escort cosworth
  79. 2wd Cosworth Parts
  80. cosworth GGR breather system
  81. cosworth GGR breather system
  82. tsw centres
  83. Sierra sapphire rear valance/panel
  84. n/a cvh highlift cam n pulley
  85. uniroyal rainsport 2 195 45 16 X4
  86. stage 3 t3
  87. xr3i fuel relay
  88. cosworth BD14 inlet cam
  89. cosworth mahle pistons +.5
  90. Silvertop zetec turbo engine/bottom end
  91. p8 pectel board must be mtb or mtc
  92. ap 6 pot calipers for 370m discs
  93. Omex 710 ecu and semi loom
  94. T34, which needs a rebiuld
  95. Erst rear springs
  96. 255/35/18 Tyres please
  97. 3 door front hubs/longer wheel studs
  98. Flint grey saff cos bumpers
  99. Wanted - 2wd Crank pulley
  100. 18x8 6 spoke comps
  101. rot free s2 boot lid.
  102. St 170 fog lights
  103. crank sensor bracket
  104. red pipes needed for pinto engine ( vaccum pipes )
  105. WANTED Chassis welded engine mounts
  106. New bolts
  107. external waistgate trouser section.
  108. Old Knackered 355x32 and 330x32/28 discs
  109. s2 boss, mk4 carpet and soundproofing for van or car, passenger seat runners
  110. cosworth 2wd plated or atb diff
  111. Rotten/MOT failure RS Turbo S2
  112. wanted 2wd gearbox
  113. Escort Cosworth 4x4 Starter Motor
  114. Siemens 83lbph Fuel injectors. Low Impedance.
  115. Throttle cable bracket for cosworth
  116. Cosworth starter motor 2wd
  117. Wanted plug leads motorsport type/ separator bung thing
  118. Plug Lead Cover & Cam Heatshield FRS
  119. EEC4 windage tray.
  120. 17" 6 spoke comps or rl7's
  121. 2wd/grpa dished brake bells
  122. 3 door/Saph (non Cosworth/XR)
  123. t4 exhaust housing wanted
  124. Cosworth t3 .48 exhaust housing
  125. Pro Alloy Fuel Tank
  126. Wanted...crossover pipe...Focus RS Mk2
  127. Few cossie bits saph bumper inserts ??
  128. cosworth yb head
  129. cosworth 4wd exhaust manifold
  130. Wanted: T3 flange turbo
  131. WANTED PCP air rifle (Sunderland area)
  132. Genuine Mk4 Escort wing and front panel
  133. Fibreglass rs500 front bumper
  134. 3 Door Cosworth
  135. Std Hose for DV on FRS Mk1
  136. RS Turbo S2 T3 turbo unit
  137. parts for mk6 escort
  138. block
  139. Sierra bulkhead grommets
  140. Standard 4x4 exhaust cam
  141. alloy wheels to fit my escort mk4 van
  142. Standard 2wd or 4x4 Cossie throttle body and ISCV.
  143. cam belt drive pully
  144. Rs turbo wanted
  145. Wanted 4x4 cosworth shocks
  146. MK5/6 Escort 1.4 PTE EFI Top Radiator Hose
  147. Tail housing for MT75 escort cosworth gearbox
  148. Wanted Alcon clutch and cover plate
  149. T34 .48 turbo for cosworth .
  150. 355mm discs & pads for ap 6 pots-4wd application escos
  151. 3 door front hubs
  152. 4*4 Cosworth Clutch needed
  153. ford escort mk4 zetec for sale???
  154. RACETECH Voltage gauge
  155. WANTED - series 1 shell
  156. Need a Sapph bootlid & spoiler in the London area.
  157. WANTED - series 1 rs turbo rolling shell
  158. escort cabriolet rear panel/valance
  159. Cosworth iscv wanted
  160. 235 or 245/40/18 Tyres wanted
  161. 3 door dash wanted
  162. Escort fusebox
  163. Wanted- Cosworth fuel gauge sender & float, 4x4 water pump pulley, idle control valve
  164. Uprated fan loom
  165. Rs turbo ACTUATOR
  166. Steering wheel boss and horn push.
  167. ofac chip
  168. Wanted 15" slicks
  169. 3 gauge holder and bits
  170. mk1 sierra rear panel
  171. 2wheel drive front brakes
  172. escort rst s2 goodridge brake hoses.
  173. Escort mk4 brake fluid resovoir
  174. St escos original boost & water hoses
  175. Orignal st escos turbo heatsheild
  176. St ecos original 2 radiator & 2 heater martix hoses
  177. t5 clutch fork and gearbox mount
  178. Sapphire Shadow Cloth Trim
  179. s1 parts needed
  180. t5 bell housing
  181. saff cos rear bumper
  182. 2 front door windows rs turbo near Lanarkshire
  183. 4x4 cossie front rubber donut ring
  184. fiesta rs turbo brand new brake servo wanted
  185. S2 dash clocks plugs off loom 90 spec
  186. 3door cosworth ariel
  187. Sapphire Cosworth Jack Wanted what you got
  188. Big brake rear kit 4x4 Cossie
  189. Weld in cage for 2wd sapphire cosworth
  190. S2 15 inch diamond cut/polished alloys x2
  191. Pair of rs500 grills wanted
  192. Sierra RS Cosworth badges wanted
  193. L8 ecu loom
  194. Block and tackle
  195. Escort Cosworth Replica Front Bumper
  196. MK4 Escort parts wanted
  197. 2wd Startermotor & throttle cable bracket + more wanted
  198. Alloy fuel tank preferrably 10-12gal
  199. Rs turbo bailey header tank wanted
  200. wide rims for trike wanted
  201. rs2000
  202. S1 rs turbo gearbox
  203. fiesta rst ofac chip
  204. cortina pinto fusebox
  205. MT75 transfer box casing
  206. L8 ECU
  207. cosworth kidney breather
  208. cosworth 2wd inlet pleunm cover and 90 deg elbow ..
  209. Old inner/outer trailing arm bushes - cosworth
  210. std bore cosworth/pinto block
  211. zetec 1.6 se engine wanted
  212. 2x8" spal fans
  213. Cosworth Steering Joint
  214. Wanted, type 9 gearbox
  215. WTD: 5th Gear Puller For IB5
  216. project wanted
  217. Escort cosworth rear anti roll bar clamps
  218. Wanted Escort cosworth rear anti roll bar
  219. 2wd saff front roll bar
  220. please delete
  221. Cosworth rocker cover
  222. wanted ofac wiring loom
  223. RS Turbo T3 Turbocharger
  224. cosworth bayonet type oil cap.
  225. WANTED Air Injector Gen Ford
  226. zetec 1.6 se rocker cover
  227. few zetec bits
  228. Focus RS front end parts...
  229. wanted cossy 2wd crank pulley
  230. wanted siemens 83lbs injectors
  231. Road bike wanted - for winter training!
  232. siemens 55lb injectors
  233. WANTED: intermediate shaft for 4x4 (the one through the sump)
  234. gas mig welder
  235. Escort RS2000 PAS power steering pump load sensor.
  236. twin 40's or webbers for a 2.0 pinto sierra
  237. mt75 gear cradle rubber gaiter
  238. Mk4 Escort Leda or GAZ coilovers
  239. 2 bar map sensor
  240. st170 driveshaft spider bearings
  241. Fiesta rs turbo/xr2i coilovers
  242. Wanted - Late 80s/early 90s CD headunit
  243. mt75 clutch lever/cable cover
  244. S2 dashboard & std clocks
  245. 90amp sierra alternator
  246. focus rs front discs and 4be braided lines
  247. cosworth PAS tank cap
  248. brembo piston
  249. t4 actuator bracket wanted
  250. p100 truckman roll bar
