PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. TURBO TO FIT SERIES 2 ENGINE
  2. 3DOOR COSWORTH FRONT BUMPER WANTED PLEASE! :O
  3. WANTED: RS1600i front ARB setup....
  4. S1 id Required
  5. zetec 2.0 blacktop piston wanted or 2.0 blacktop bottomend
  6. 2.0 saff
  7. frst intercooler
  8. mk1 xr2 bits needed
  9. Wanted - Moonstone Blue/Magenta 4x4 Sapphire Cosworth
  10. FOCUS WRC PARTS WANTED.
  11. 2wd cosworth greens 3 bar and chip
  12. 3door cossy dash clocks
  13. cossie engine bits
  14. Vernier Pulley
  15. Cosworth ABS / Teves Unit
  16. escort turbo front uprated shocks and springs
  17. cosworth ignition amp
  18. Unfinished projects
  19. Sapphire Spoiler
  20. BUMPER
  21. ofac 195 frst chip
  22. Exhaust Manifold 2wd Cosworth
  23. T3 ESCORT TURBO WANTED IN WORKING ORDER! :(
  24. escort rs engine dress up parts
  25. escort cosworth alloy's
  26. fuel cell for rs turbo
  27. Stack Tacho or similar
  28. 2wd crank pulley
  29. Mk2 orion rear seat belts
  30. MK 1 Mondeo bump strips
  31. t34 hose
  32. Focus RS wheels with tyres if poss
  33. sapphire trim parts wanted
  34. WANTED,, RS1800 FIESTA, ESCORT RS2000,
  35. wheels
  36. inner wing required
  37. Distributor for Series 2 RS Turbo
  38. Need A Shell
  39. ERST or FRST needed
  40. Series 2 RS Turbo Loom
  41. window regulator
  42. Auralis blue esc cos
  43. koni rear shocks for s2
  44. rs turbo kit
  45. reverse charge carrier ? series 2
  46. S1 drivers seat in any condition
  47. Coilover spring cups
  48. frst bonnet
  49. S1 Loom
  50. T5 gearbox wanted in ireland
  51. Standard Sierra Amal Valve
  52. speed sensor bracket on 2wd sump
  53. Remote oil filter housing
  54. ford fiesta 1.4cvh or rs turbo cvh sump! s2 escort!
  55. PICKUP WANTED PLEASE
  56. magenta spoiler?
  57. 2.8 engines wanted
  58. Escort MK4 driveshafts/CVs/Boots - Mods please delete!
  59. Front spot / fog lights
  60. escort cos wheels
  61. magenta spoiler
  62. 2wd speedo
  63. Escort MK5 Coilovers And Rs2000/XR3i Rear Beam
  64. RS turbo parts
  65. escort estate
  66. Ford Duratec 2.0 Engine With Gearbox And Wiring
  67. Series 1 RST WANTED
  68. standard 4x4 exhaust cam pls...
  69. light blues and a .55 housing
  70. 1.3 ohv 4speed gearbox and flywheel and starter
  71. biege injectors, 195 ofac chip, uprated fuel pump
  72. s2 tps
  73. O/s/f s1 wheel arch bodykit
  74. 1.3 mk3 fiesta ohv engine
  75. T34 Maram shaft .55
  76. Escort mk 3 gearbox casing
  77. mk4 escort interior
  78. S1 bodykit
  79. not car part but still wanted lol
  80. 2wd parts
  81. 2wd sapphine cosworth front hubs
  82. 2wd stainless downpipe
  83. T3 Manifold and Standard Exhaust Flange Escort S2
  84. MT75 box
  85. S2 erst LSD gearbox
  86. .63 ex housing
  87. t34
  88. s2 rst
  89. mk2 xr2 wanted
  90. mk2 xr2 bits
  91. Proper Group A diff mount
  92. oil pressure switch adaptor
  93. 1.8 zetec sump?
  94. wanted cheaper cosworth in px for 3 dr sierra cosworth plus
  95. 195 ofac chip...oh and some beiges if there at decent price!
  96. rs500 Front Bumper
  97. 2.4 duratorqu transt engine
  98. Exhaust Cam 2wd
  99. Esc Cos oil pressure switch/block union
  100. ford racing puma front sparco seats
  101. 2wd rolling shell
  102. Cheap Sapphire cosworth in px for a 3dr plus cash my way
  103. Sierra Cosworth 2WD Heat Shield Pref Alloy!!!!!! Cash Waitin
  104. door mouldings for 3 door
  105. zetec engine/ or parts
  106. series 2 rs turbo or rs1600i
  107. 4 point harness wanted
  108. my old car
  109. sapphire cosworth rouse sport rear spoiler
  110. ford escort mk4 project car
  111. Wanted: Mk2 XR2 Parts
  112. FIESTA RS TURBO BEIGE INJECTORS,SUPERCHIP WANTED !!
  113. Fiesta 1.3 Endura Engine Wanted
  114. 2WD Sapphire / Sierra Cosworth for running gear.
  115. l8 ecu
  116. Parcel Shelf, 4 spoke RS steering wheel and mint bodykit S1
  117. focus st brakes
  118. 3dr Cosworth Front Grille....
  119. Fiesta or small car
  120. 4x4 cossie crank pulley needed!!!
  121. POWDERCOATED RS 1600I ROCKER COVER
  122. Set of s1 alloys....
  123. s2 (water cooled) T3 Turbo + pipes
  124. Series 2 Silicone Boost Hoses & Oil Breather Kit
  125. Escort Cosworth Quad Lights
  126. 2wd or 4wd cossie rims, or others
  127. MK3 FIESTA BODY PANELS WANTED
  128. cosworth wanted
  129. cam belt cover fitting????
  130. series 1 rear sturt brace
  131. s2 chipped ecu
  132. escort coswoth
  133. rs turbo engine ( good condition or rebuilt )
  134. Stage 1 Chip for 2wd sapphire
  135. Escort cosworth shell..!
  136. rs turbo s2 parts wanted...alloys cooler. breather
  137. series 2 rs bonnet (black preferd)
  138. bumper scoop
  139. cosworth wanted
  140. xr4x4i or xr4i wanted
  141. cosworth engine wanted!!
  142. Ford Escort MKII - The cheaper the better!
  143. Koni adjustables for s2
  144. Need escort cab MK6 seats
  145. 2wd cosworth oil cap!
  146. Saff rear wheel arch liners wanted
  147. crankshaft pulley saff 4x4
  148. escort cosworth with out uunning gear!
  149. Sapphire cossie backbox wanted
  150. Bleed valve
  151. sierra cosworth parts wanted
  152. 90 spec front seats
  153. saph cosworth swop for my pulsar gti-r
  154. XR2
  155. T4 actuator bracket
  156. rear anti roll bar in ireland needed
  157. rs turbo wanted without engine
  158. 2 Bar Map sensor needed asap
  159. SCORPIO ESTATE TURBO DIESEL OR 24V LPG
  160. Big power escort or fiesta turbo
  161. Frst Rolling shell/non runner/blown engine etc
  162. Looking for new project mk3
  163. 3dr parts
  164. series one parts wanted
  165. escort cosworth front spoiler wanted gen ford
  166. fuel cradle 2wd cossie
  167. focus collection kit
  168. 17" wheels for rs turbo
  169. Focus RS
  170. saff front bumper
  171. mk3/4 escort koni/spax
  172. gear stick surround
  173. Cheap Mk3 Escort/mk1 Orion with T&T **FOUND ONE!**
  174. 4x4 suspension
  175. £££££££££££££££ RS cars wanted cash waiting ££££££££££££
  176. rs1600i rev counter
  177. BMW E36 Convertible Wanted
  178. 4wd Front Brake Calipers
  179. Escort Cossie Grille
  180. rs turbo engine
  181. steering surround and dip stick 2wd sapp cooie
  182. 2wd Saph rear Diff...
  183. frst ofab engine harness
  184. HELP!! Need one of these ASAP.
  185. 4x4 cossie Engine mounts
  186. 2wd paddle clutch plate
  187. Cossie Engine Wanted
  188. mk3 mondeo st side skirts
  189. 4x4 saph front driveshafts needed
  190. rs2000 rotten wanted for project
  191. rebuilt head and cam.....t3 hybrid!! wanted!
  192. XR2i / RS Bodykit.
  193. KA Sport
  194. rs 1600i front and rear bumpers 2 bolt suspension
  195. Mk4 Escort n/s Window motor
  196. 2002/2003 Civic Type R
  197. looking for mk1 or mk2 rs2000/mexico
  198. 2.0 mondeo
  199. rollcage
  200. mk3 escort cab seat and couple of other things
  201. s2 turbo wanted
  202. escort mk3 bits
  203. A Rollcage for a Series 2
  204. Wanted Series 1 or 2 RS Turbo. ( I Have a px )
  205. !!!!!!!!!!!!!!!!!!!!!!RS500 BOOST HOSES!!!!!!!!!!!!!!!!!!!!!
  206. door mouldings
  207. rs500 splitter
  208. 2wd steering couplings
  209. GTI Sideskirts
  210. escort rs turbo in scotland
  211. cosworth turbo damper spring and bolt asap
  212. cosworth turbo damper spring and bolt asap
  213. Escos Standard MAP sensor
  214. t3 water return pipe **urgent**
  215. rs turbo top boost hose
  216. Racing puma
  217. cosworth low comp pistons
  218. 4 Gudgeon pins
  219. wanting a stage 3 saff must be mint
  220. Wanted!!!
  221. xr3i/xr2i/rs turbo efi throttle position sensor (tps)
  222. Original Orange/Amber rear lights for 2wd Saph please
  223. Saph cossie
  224. 4x4 cos std turbo wanted
  225. MK6 RS200 interior
  226. 2wd heatshield required would prefer alloy bling one
  227. rs2000 mk5
  228. 2nd hand cossie ht leads
  229. Fiesta turbo inlet manifold
  230. zetec 2.0l piston ring needed ASAP
  231. Wanted
  232. COSSIE THROTTLE BODY REQUIRED PLEASE!!
  233. 3dr Cos Front bumper/grille/bonnet
  234. COSSIE PARTS
  235. Wanted: Power steering supply hose - 4x4 sapph cossie
  236. Sapphire cos splitter
  237. erst box, or diff
  238. !!!!!!!!!!!!!!!!!!!!!!!!!!turbo!!!!!!!!!!!!!!!!!!! !!!!!!!!!!
  239. rs turbo oil breather, one in rocker cover(standard)
  240. cosworth boot release
  241. rear bumper
  242. RS500 Boost Hoses wanted
  243. Apex'i 2,5bar boost gauge
  244. MK6 RS2000 or Good Spec Mk5
  245. 3dr headlights
  246. 16" ford fit wheels for a fiesta turbo
  247. 2wd saff centre section
  248. smashed/damaged S2 turbo
  249. donor 4x4 cosworth gearbox
  250. White FRST BONNET!!
