PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. WANTED air filter box
  2. mk4 escort
  3. Mk3 escort cab
  4. cossie 8j centre caps
  5. T3 or T34 in the south east
  6. Escoss parts wanted
  7. strut brace 2wd sapphire + alloy header tank
  8. * Fiesta Mint Pass Door, Bonnet, Boot Lid In Mercury Grey *
  9. 1.8/2.0 zetec engine
  10. 3 door Auxillary loom
  11. 52mm Water Temp Gauge
  12. Small turbo escos Dizzie wanted
  13. cheap saff cosworth
  14. S2 25mm Master Cylinder & Servo. URGENT!
  15. PAS PUMP to steering rack pipe
  16. towing aye cover
  17. zetec 1.8 sump needed quick
  18. mk3/4 escort adjustable struts
  19. Sierra CVH Exhaust manifold & downpipe.
  20. 2wd cossie flywheel
  21. Mk2 Escort Wiring Loom
  22. Escort Cosworth Carpet wanted
  23. Mk3 Fiesta Tailgate
  24. WANTED mk3/4 escort estate or combi
  25. Strong cvh turbo bottom end
  26. Central locking module
  27. Front Fiesta MK3 Hubs (Manchester)
  28. F + R Bumpers Escort Mk6 White
  29. uprated 71/2 inch rear cos diff
  30. Wtd: Cosworth YB engine & box complete
  31. dump valve for frst
  32. wanted t3 turbo
  33. escort twin head lamps
  34. Left hand RS500 grill
  35. Cosworth parts wanted
  36. Where to get an S1 Fuel Tank ?
  37. wolfrace voodoo's wanted
  38. S1 RST Parts Wanted...
  39. 2WD (T5) fork plastic retainer (clutch)
  40. cossie head...
  41. Sierra 3 Door Cosworth Radiator
  42. Escort Cos Door Cards
  43. 4x4 saff fuel pressure reg
  44. 3 door cossie £5 -6k why
  45. saph fuel filler cap
  46. 1.8 Zvh Decompression Plate Needed
  47. RST Pistons or complete block ASAP!!!
  48. escort cosworth alloys
  49. cosworth rear diff
  50. Zetec Thermostat housing (alloy)
  51. actuator bracket
  52. cosworth wanted
  53. rst forged pistons
  54. escort cosworth bumper
  55. cheap set of pepperpots for mk1 fiesta
  56. 2wd sump, and bolts
  57. impriza
  58. (urgent) Cossie Bulk Head Ecu Rubber!!
  59. 4x4 uprated engine mounts
  60. S2 Rs Turbo Coilovers And Other Parts
  61. anyone breaking an E36 Evo M3 ?
  62. Chip for grey injectors
  63. esc cos rear bumper retainers
  64. t5 clutch lever retaining clip
  65. Series 1 inlet & exhaust manifolds
  66. Rs turbo spot light brackets
  67. black passenger side a pillar trim (saph cos)
  68. Sapphire Cos Boost Hose
  69. mk1 bubble arches
  70. CVH custom inlet
  71. 3 door parts - flame trap and genuine standard exhaust(complete).
  72. cossie parts wanted
  73. 909 diff mount
  74. 3 bar map sensor
  75. Rs Turbo Bits
  76. Rs Turbo Bits
  77. rs1600i boot spoiler?? anyone got one??
  78. mk4 escort xr3i efi clocks
  79. alloy wheel centre cap for a sapph
  80. Co2 Adjuster anyone?
  81. 4x4 cossie rear trailing arm bushes
  82. Cosworth Alloy Boost Pipes
  83. Esc Cos rear bumper
  84. GpA Tarmac Strut bodies wanted
  85. Racetech Oil pressure gauge & line wanted
  86. Sapphire door badges and ambers please
  87. cvh solid lifters
  88. lsd rear diff,
  89. Fiesta Mk3 + Escort MK5 - Rear Disc/Coilovers/Powerflex/4Pot Fronts + More. *ASAP*
  90. a bit of a long shot
  91. Mk3 Escort Shell Needed
  92. RS Turbo (Mk.4) Fuel Pump Relay
  93. Series 1 RS Turbo Parts Wanted
  94. desperately need a S2 bottom end!!!!!!!!!!!!
  95. good rst bottom end
  96. series 2 rs turbo vibra technics
  97. Wanted Crystal Blue Shell
  98. 3 door cossie shell
  99. Cosworth amal valve
  100. 2wd front pipe & front brakes
  101. WANTED escos towing eye
  102. Cossie Rear Spoiler Caps
  103. boost hoses and other little bits
  104. escort mk3 convertibe roof cable....where can i get one?
  105. cosworth shell
  106. mk3 escort bits needed
  107. T34 wanted
  108. rear coilovers for escort cosworth
  109. Wanted 2wd sapph cylinder head
  110. cossie 4x4 parts needed ie cloth trim/dump valve comp mo's 8/18 ???
  111. Fiesta RS Turbo Front bumber wanted
  112. 2wd saff abs sensors, 2x rear.
  113. saff exhaust non restrictive
  114. FRST Uprated\ESCOS Fuel Pump
  115. cosworth rocker cover
  116. Escort rs turbo dark roof lining
  117. Rs Turbo Wiring Loom
  118. 2wd saph egsaust
  119. Complete Recareo Interior (S2 RS Turbo)
  120. Throttle Cable
  121. A Pillar Trim
  122. 2x 17" alloys
  123. Cheap Set Escort Cosworth Alloys Wanted
  124. 17" Rondells or Azev A's
  125. 3 dr wanted
  126. escort mk3/4 60mm rear springs
  127. 2 x rs turbo vernier pulleys
  128. * Wanted - RS 500 Alloys *
  129. uprated coil lead wanted
  130. breather adapter needed
  131. Escort Estate Parcel Shelf (Mk5b)
  132. wanted 2wd heat shield
  133. T34 turbo
  134. alloy rad for S2 rst
  135. s2 rollcage
  136. Scorpion 4 inch
  137. Wanted Cosworth
  138. Wanted Set of Alloy Pullys
  139. sorted
  140. sorted
  141. Escort RS Turbo (Mk.4) Fuel Pump
  142. * WANTED * RS500 Alloys
  143. Escos BT badges for tailgate
  144. alloy header tank for 2wd sapph
  145. 17 inch comp or bbs split rims
  146. Ka parcel shelf, wheeltrims, grille
  147. wrc mirrors
  148. cossie bits needed
  149. Sapphire parts wanted.
  150. group a wheel nuts
  151. sierra leather recaros
  152. WANTED RS500 spec rear end
  153. WANTED cossie 2wd gearbox bracket
  154. *****COS/FMC Plate Wanted*****
  155. 17" Rondells
  156. sierra cosworth 2 1/4" coilsprings...
  157. RS Turbo bits
  158. **URGENT** Parts Needed For MOT! (Fiesta MK3 + Other) Upgraded parts needed also!
  159. Decent Karcher pessure washer!!!
  160. Cossy stainless heatsheild
  161. Air con pump Bolt
  162. 4x4 std exhaust cam
  163. 2wd 7.5" Cosworth rear diff....
  164. Cosworth Rear Abs Sensors
  165. Escos Quaife Rear Diff
  166. Escort Cos Turbo Heatshield
  167. WANTED!!
  168. 3 door Cosworth wanted
  169. fiesta rs turbo, t2 unit! FFS no leaks or smoke!
  170. sierra saph front coilover springs...
  171. WANTED: S2 RST alloys....
  172. s2 radiator
  173. knackered 2wd Cossy Gearbox wanted
  174. Pillar Pod Mount
  175. Broken MT75 gearbox (Cosworth 4x4)
  176. Escort cossie wanted..
  177. washer fluid/3dr header tank water level sensor
  178. Brake Bias Valve
  179. 3 Dr Cambelt Cover Wanted
  180. Saph Cos REAR Bumper wanted
  181. Compomotive Mo - 18x8
  182. escos mud flaps
  183. saff bumper stripes/mouldings
  184. cossie cambelt cover fixing mounts
  185. iscv ?
  186. Cossie 4x4 Bonnet Insulation thingy
  187. t34 turbo
  188. 9 inch diff
  189. 15" sharktooth Sapphire cosworth alloys
  190. 2wd Trailing Arms
  191. t34 turbo for my 3 door
  192. t3 elbow
  193. 2x escort rs turbo alloys
  194. Genuine saff side body mouldings.
  195. Roof Console
  196. rs500 lower spoiler,rs500 grills
  197. 3 door alloys and group a nuts
  198. broken 2wd gearbox wanted
  199. 7/16th thread bonnet pins
  200. 2wd stuff needed
  201. 90 Spec Rs Turbo front bumper
  202. saff 2wd steering column
  203. sand/grit blasting cabinet wanted
  204. cheap cheap escort van
  205. .29 o/s rst pistons
  206. Gti front bumper
  207. Escort Cos Hockey Stick & Turbo Heat Shield
  208. 18inch comp mos for a saph. any colour considered
  209. Cosworth Bling
  210. Escort Cossy Airbox lid
  211. 5/16UNF stainles countersunk bolts
  212. Escos parts wanted.
  213. Old 2wd Heatsheild - SORTED
  214. t34.55 or .63
  215. standard 3dr wheels
  216. Escos rad
  217. 90 spec Bumper and spoiler
  218. frst breather pipe, crankcase side + t-piece.
  219. 3 Door Header Tank plus any other NEW 3 door parts
  220. Throttle body for 400bhp cos
  221. Wanted Saff Coss 4x4 Parts
  222. mk 6 escort front lowering springs
  223. 2wd Cossie bellhousing wanted
  224. head
  225. T6 ECU
  226. 2wd Cossie Quaife box wanted
  227. Air to Fuel Ratio Guage
  228. springs for my escort cab
  229. RS Steering Wheel
  230. 3dr/Mk1 Door and tailgate wiring rubbers
  231. rst 88 spec rear bench
  232. t34 turbo with .48 exhaust housing.
  233. 909 Diff Mount
  234. 1600 cvh block
  235. needed asap 4/4 rear calliper
  236. block union
  237. s1-16i wheels
  238. Needed S1 Turbo Tail Gate Must Be Mint
  239. Coilover suspension for 2WD cosworth
  240. Rs500/3door Parts Wanted
  241. Cosworth twin headlamp part wanted
  242. recirc dump valve
  243. standard saph stereo have amp uncoded pls
  244. RS 500 cooler
  245. nice s1 rs turbo , or saph cosworth
  246. Cheap run around
  247. WANTED! rotten 3 door MK3 Escort
  248. Parts for light restoration of a 3 door Cosworth
  249. Cosworth wanted- Escort, saff or 3 door
  250. Fiesta Mk5 parts ( zetec-s)
