PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 4wd, turbo oil return pipe
  2. Saff hand brake lever
  3. 3dr Cossie back panel & Drivers wing wanted
  4. Granada cosworth BOA engine and loom wanted!!
  5. Cosworth alt heat shield
  6. Wanted. Series 1 rs turbo wheels
  7. L6 ecu standard chip or stage one required please.
  8. Wanted Series 2 RST lower radiator hose.
  9. Saph 4x4 or escos bonnet vents
  10. st170 spoiler
  11. Escort mk4 van, 4 dr or Orion front door cards
  12. RS Turbo S2 caliper carriers
  13. Fiberglass bonnet and tailgate Mk4 Escort
  14. Cosworth 3dr/2wd sump wanted
  15. Cosworth downpipe
  16. 1988 ford escort rs turbo s2 help needed
  17. Mk5 RS2000
  18. FRS/RS1800 inlet
  19. Escort RS Turbo Single Pass IC
  20. sierra 4x4 bonnet vents
  21. sierra heater box
  22. Fiesta 1.4 2005 engine wanted
  23. Standard l6 ecu wanted.
  24. Mk4 escort roof lining (without sunroof)
  25. toyota hi lux alloys wanted
  26. 2.8 cologne us mustang inlet manifold
  27. saff light grey door card
  28. Any 17" Compomotive Alloys ***Got some now***
  29. Escort mk4 cabriolet turbo
  30. Spark plug leed holders
  31. 4x4 cosworth front shafts with good cvs
  32. morret headlamp glass can you get them separate
  33. Cvh starter
  34. Yb phase sensor wire wanted
  35. saff cossie airbox, and grill wanted
  36. After a Turbo for a Series 2 RST. Standard T3 will do!
  37. S2 RST Radiator wanted
  38. Boost controller
  39. Wanted 2wd saff rolling project!!!
  40. Sapphire Electric sunroof
  41. Saph cosworth rear bumper ASAP
  42. Spec-R RS500 damper
  43. 3dr sierra petrol cap
  44. In need of a headlining
  45. Sierra mt75 2wd gearbox mount (picture inside)
  46. Rs steering wheel boss for mk2 escort
  47. 3 Door Grill Seal
  48. V6 type 9 gearbox
  49. Wanted mt75 hybrid
  50. Wanted mk2 fiesta ghia off side rear quater chrome window
  51. Wanted: Bucket seat, corbeau, cobra, ect why??
  52. Wanted: Mint 4*4 sump
  53. 2.0 Zetec Silvertop uprated engine/parts
  54. wanted escort cosworth clock?
  55. wanted sapphire cloth recaro interior without front seats
  56. wanted sapphire strut braces and mint escos wheels
  57. Cosworth Sapphire rear bumper
  58. group a nuts x16
  59. Stage 2 or 3 hybrid turbo for escort rs turbo
  60. Cosworth s/s downpipe
  61. Mk3 escort genuine n/s wing
  62. 2wd ecu
  63. 4x4 Diff and Shafts or 2WD Rear End
  64. 1.6 se engine
  65. Turbo coolant pipe + mk4 front door cards
  66. mk5-6 rs2000 inlet
  67. Cosworth L6 chip
  68. A few parts needed!!!!!
  69. Wanted... P100 4speed gearbox
  70. RS2000 Roose or samco induction hose
  71. Jacking point front covers for mk6 escort
  72. cosworth centre exhaust section
  73. Wanted :) Comps MH600's.....
  74. Sierra 3.14 diff
  75. WANTED 2WD beam and mint doors
  76. Cosworth 4wd bits wanted... Adj TCA's, gaz front coilovers
  77. Wanted: 2WD brakes, and diff
  78. New standard Cosworth clutch
  79. Wanted: 3/4 Spoke RS steering wheel
  80. Cosworth R and D frontdiff with shaft
  81. After a nice set of wheels for rst
  82. es cos exhaust
  83. S2 turbo water coolant pipe
  84. RS Turbo T3 turbo CHRA
  85. Wanted 5 spoke Kahn alloys.
  86. sierra 3dr rally parts roll cage etc wanted
  87. 2WD Big brake kit
  88. Wanted mint 2wd engine loom
  89. Wanted: Escort MK4 Front Passenger Side Anti-Roll Bar Bracket
  90. Wanted sierra cosworth rally car
  91. Carbon fibre for escort Cosworth
  92. sorted
  93. 3dr sierra rear quarter windows
  94. s2 gear box with lsd
  95. single Conrod from a 200 block needed
  96. Cruising Estate wanted...
  97. After a few S2 RS Turbo interior parts
  98. Turbo water return 2wd cosworth
  99. Clear square repeaters
  100. Pinto crank wanted with a rod 200 block
  101. 17" possibly 18" alloys wanted
  102. Mk4 escort washer bottle pump
  103. 2wd rear konis
  104. Silicon hoses for a s2 rs turbo
  105. 2wd front coilovers
  106. cosworth breather
  107. 2wd cossie bits and bobs...
  108. RS500 Original Boost Hoses
  109. Escort mk4 rear bumper
  110. cosworth head
  111. Pinto bits wanted
  112. Bottom intercooler hose
  113. Standard rs turbo turbo
  114. Any Condition Cosworth ISCV
  115. 3'' bore rs turbo mongoose with 4'' outward rolled tailpipe
  116. s1 rs rs turbo wirnng loom wanted and parts?
  117. WANTED 2.9 cologne
  118. Ford RS7'S WANTED - SWAP DEAL WITH COMP'S???
  119. Sierra 3dr/RS500 Door Cards.
  120. Clutch Release Fork.
  121. part worn toyo r888 205/40/17 wanted
  122. Series 1 RST Arches & Skirts Wanted..
  123. cosworth 4x4 front coilovers
  124. Sapphire roof lining-NON sunroof
  125. 2wd Cosworth T5 Speedo drive bolt & Locating washer
  126. Fiberglass / Kevlar Saff bonnet
  127. 4 wheel drive front shocks
  128. s1 rs turbo body kit wanted
  129. cvh oil return fitting
  130. es cos exhaust
  131. Ford RS7'S WANTED - SWAP DEAL WITH COMP'S???
  132. cossie 2wd Crank Pulley and 4x4 front driveshaft
  133. Cosworth NA or Turbo engine wanted
  134. OZ super leggers 19" Escos fitment
  135. MK1 XR4i / Cossie ambers & Fog clips Still looking 15/09/13
  136. Sapph rear shelf speaker covers or shelf complete
  137. Cosworth rear beam hoop
  138. Mk1 Focus Rs wheels wanted
  139. cvh turbo engine
  140. B5 Audi RS4 Avant parts wanted to fit B5 S4 Avant
  141. T34 Turbo
  142. Wanted 90 spec cloth interior for s2 escort
  143. 90 spec rear tailgate wanted complete with spoiler
  144. Fiesta MK2 clear lights
  145. AC wiring
  146. clutch release bearing
  147. WTD: Chain driven diff for a trike
  148. Rear beam and arms wanted
  149. early 16i wheels
  150. Cosworth 4x4 oil pump pick up pipe
  151. Wanted fiesta rs turbo top boost hose
  152. 2WD Sapphire / Sierra Cosworth for running gear.
  153. Uprated turbo for s2
  154. PF09 TPS
  155. Mk4 escort outer weather strips
  156. Cheap banger wanted
  157. Sapph rollcage and harness needed ASAP!!!
  158. mitsubishi evo 6
  159. 3 door Sierra cosworth door cards
  160. XR2 pepperpot center cap
  161. Sierra Sapphire cosworth bumpers wanted
  162. S2 RS Turbo cheap, needed for parts
  163. valve spring cap
  164. rs1600i or mk3 xr3i loom
  165. wanted fiesta rs turbo body kit
  166. wanted t3 turbo
  167. S2 rst turbo water coolant pipe wanted
  168. 3dr skirts and archs needed
  169. Carcoon, air chamber, Cair o port etc
  170. Turbo exhaust housing .63
  171. Wanted mk3 supra diff
  172. 90 spec door cards needed front and rear
  173. Need an engine loom for my L8 4x4 saph, choices?
  174. Zetec Turbo Parts to suit FRST
  175. 2wd Saph cosworth parts wanted
  176. S1 RST Ariel
  177. 6 degree rear beam wanted
  178. 3 door sierra car loom
  179. Sierra Cossie LSD flanges wanted
  180. Mk4 mondeo titanium x alloys
  181. Ears m/sport 7 spoke alloys 17" wanted
  182. 2wd cos steering coupling
  183. ford focus 2001 TDDI 90bhp engine
  184. WANTED strut braces for cvh sapphire
  185. sapph bits needed a.s.a.p why peeps
  186. Cosworth fuel pump bracket
  187. wanted pinto four branch and electronic ignition
  188. MK3 Escort brake pedal pivot bar bush
  189. WTD: Mk1 Sierra Grille brackets + Misc
  190. WANTED: 2WD Cossie Alternator
  191. S1 fuel pump cradle wanted
  192. Yamaha pw50 wanted
  193. tyres
  194. Trimmed escort cosworth shell
  195. Cheap cossie or audi s4 biturbo wanted!
  196. standard 3 door parts !!!!!!!!
  197. Boot Lock Wanted
  198. Mondeo mk2 rear lights
  199. WANTED: BBS Three Piece Split Rims.
  200. set of wheels/tyres
  201. erst engine wanted
  202. Cosworth 4x4 exhaust manifold. Std clean yellow injectors.
  203. cossie downpipe
  204. hydrolic handbrake and other bits coilovers
  205. Urgent 2.0 pinto or twink Manchester
  206. Fiesta MK3 tailgate
  207. delete
  208. WANTED: YB alternator heat sheild
  209. Wanted: Escort rs cosworth lowering springs
  210. escort cosworth diff mount
  211. Saph Drivers Wing in flint grey wanted!!
  212. Landrover 90 Defender wanted
  213. 3 door cosworth exhaust - original
  214. 16x8 et 32or35 wheels
  215. Cosworth Parts Wanted to get 380+BHP
  216. TH2 compomotive wheels
  217. Wanted escort cosworth rear section exhaust
  218. wanted cosworth 24v boa wiring loom
  219. 2wd cosworth sump, gear box
  220. 3dr piller pod single or double
  221. escort cosworth wheels or comps wanted
  222. 1993 Sapphire Cosworth Aircon wiring loom/engine loom
  223. 17" comp th
  224. Focus ST rims (18in)
  225. sierra cosworth rear arch liners
  226. Escort MK5B/MK6 REAR LIGHTS,STRUT BRACE
  227. rs turbo lsd Wanted
  228. Looking for some parts for my escort cosworth
  229. WANTED cossy rods and pistons for pinto turbo
  230. WANTED 4x108 to 4x114 adapters or 5x112 hub swap
  231. FRST Bonnet wanted
  232. PF09 TPS
  233. 3 door wheel centre locks
  234. WANTED pinto turbo parts
  235. 2wd Sapph Cosworth starter motor
  236. escort mk4 undercarpet soundproofing, van or car, drivers doorcard
  237. Mk1 FRS flywheel
  238. rs turbo gear box
  239. URGENT 3 door drivers bonnet vent needid
  240. standard rs 1800i exhaust wanted
  241. 3 door wheels centres and locks
  242. Uprated radiator for 2wd Saff. Airtec etc.
  243. Flint grey Saph cossie front bumper
  244. Race spec 1.6 CVH engine or parts
  245. Fiesta turbo scorpion backbox
  246. Decent alarm for a 3 door cosworth
  247. Gt3076 external gate 82 rear housing
  248. escort cosworth ronal 16s (originals)
  249. 3 door jack cover in boot
  250. Sapphire rear bumper/jacking point covers..
