PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. s2 wanted ill swap my cossie for a good one
  2. Escort Cossie Small Turbo Mirrors
  3. Sapphire rear bumper-WANTED
  4. wanted 3 door sierra
  5. complete XR3i MK4 Loom wanted asap..
  6. 2wd inlet plenum spacer, 20mm if poss
  7. 4x4 Cosworth bottom pulley
  8. mk 3 escort pillar pod
  9. piler mount
  10. mk4 escort van tow bar wanted
  11. Sierra 1.8 cvh Crank Position Sensor.
  12. mk3 escort bonnet needed
  13. escort rs turbo diamond cut rims
  14. RS turbo breaknig in the south
  15. Saph cos body parts wanted
  16. >>>>>>>>>>>>>>>
  17. Escort RS Turbo engine everything needed
  18. Fancy a new project. WHY?!!!!!
  19. Fiesta Rs Turbo engine WANTED/ EFI
  20. Cheap S2 Escort Rs turbo or Fiesta
  21. alloy rad
  22. 18" alloys wanted
  23. Car Badges
  24. ESCORT RS TURBO UPRATED GEARBOX
  25. 3-door arch`s
  26. high lift/duration CVH hydrolic camshaft w/ cps pickup
  27. Older Style Comp MO 16"
  28. well specked saph cossy wanted!!!!!!!!!!
  29. 3 door boot lock with key.
  30. esc cos banana pod with dials
  31. TSW Hockenheim
  32. .63 exhaust housing
  33. Original RS500 front bumper
  34. rs turbo multi plug.
  35. COSWORTH OR MK2 ESCORT WANTED???
  36. Fiesta RS Turbo Radiator - used good condtion or new/nearly
  37. t5 box
  38. Cossy 2wd nearside rear swinging arm
  39. Magenta boot lid and spoiler
  40. Cosworth T34 turbo with exhaust housing in 0.48 or 0.50
  41. escort cosworth airbox
  42. Looking for BMW 3 Series Convertable P/X
  43. 4 channel amplifier and speaker please!
  44. saff moretts
  45. Rs500 Throttle body and Drivers Seat 1992 Saff
  46. wantid escort cosworth shell
  47. wanted escort cosworth shell
  48. CRANK PULLEY COS 4X4 1992
  49. Transit van TOW BAR ASAP got a van now
  50. Rs500 Lower rear spoiler
  51. s2 heated front screen
  52. XR2
  53. ERST ADJUSTABLE TCA'S!!!!!
  54. Paddle clutch for S2 Esc??
  55. ERST S2 ENGINE WANTED
  56. Zetec Rocker Cover
  57. 8 or 9 x 18" Mo's or similar Gpa wheels
  58. cheapish turbo wanted
  59. small turbo injectors or st170 injectors
  60. hard to find clips
  61. RS500 turbo damper
  62. fiesta rs turbo or series 1 wanted
  63. s2 tailgate
  64. s2 tailgate
  65. ERST fuel pump
  66. s1 seat
  67. MK6 Escort Cobra Subframes
  68. Sierra Cosworth 3 Door fuel guage sender that fits in tank
  69. Wanted Focus ST170 space saver
  70. cam
  71. 2008 ford radio
  72. uprated breather for cossie
  73. MGF bonnet
  74. Wanted..various standard 2wd Saff parts
  75. standard FRST T2 in mint non smoking condition
  76. Mk5a 92 Escort Rs2000 interior
  77. ERST Standard Shocks & Springs
  78. mk4 drivers side glass...
  79. Escort cosworth amber indicators
  80. wanted mint sapphire passenger rear door.
  81. Koni Adjustable suspension kit or Equiv
  82. Cosworth Cam Belt Cover Posts
  83. delete please
  84. s1 gearbox mount
  85. Mk2 escort wanted
  86. Esc cos Headlights and rear lights
  87. Ford escort
  88. Cheap RS Turbo or 3 Door Replica
  89. rs 5oo alternator drop bracket, horseshoe turbo damper
  90. s1 black rubber bungs?
  91. 15"x7 compomotive mos
  92. t5 gear box rebuilt or uprated one let me no what you have
  93. alloys
  94. Wanted RS FOCUS TURBO GT 25
  95. st150 gearbox needed.....
  96. bike carbs on manifold for 1.8/2.0 zetec needed a.s.a.p
  97. Focus Rs disc
  98. Mitsi Evo 6, 7 or 8
  99. centerlocking wheel adaptors
  100. 4x4 cossie water pump
  101. Group A Coil for a Sierra 2wd Cosworth
  102. Power steering cap Wanted yellow one URGENT
  103. ... Escort Cosworth Grille ...
  104. wanted ofac ecu
  105. S2 Rs Turbo Water,Boost and Ancillary Blue silicones
  106. fibreglass 3dr bumper
  107. wanted
  108. MK6 RS2000 IN WHITE WANTED
  109. Uprated T3 Turbo
  110. Uprated T3 Turbo
  111. s2 engin and gearbox and rad
  112. seat subframe,exhaust manifold,steering wheel
  113. loom
  114. Zetec Carb Setup Wanted
  115. 4 wd cylinder head and 200 block
  116. 3 dr window surround
  117. Mondeo Heater box
  118. 4x4 Cossie Front Pads
  119. Big power Cossie engine or parts
  120. Saph cossy wanted!!!!! swop for EVO 3 well specked
  121. 5th injector
  122. sierra 1.8cvh bottom pulley and cps sensor
  123. BUCKET SEATS, FRST Oil Breather, Full Front Intercooler
  124. ST200 throttle body wanted for ST24
  125. OIL BREATHER/SEPERATOR FOR SAPPHIRE 4X4
  126. SPEC R FRONT STUT BRACE FOR SAPPHIRE 4X4
  127. PUMA 1.7 WANTED!!
  128. COSWORTH WANTED SCOTLAND
  129. WANTED xr3i crank sensor
  130. 4x4 sapph cosworth g'box to front diff drive/prop shaft
  131. delete plz
  132. ford capri 1.6 wanted
  133. SMOKED REARS
  134. gearbox 4 frst wanted
  135. Wanted...
  136. merc grey xr3i
  137. Air to air injectors
  138. Escort Cosworth read door cards
  139. Focus RS parts NEEDED asap!!!!!!!
  140. RS500 Airbox
  141. used GT25 frs turbo
  142. SAPPHIRE FORD MUDFLAPS?
  143. Cosworth parts
  144. Sapphire ECU cover black LHD
  145. 3dr 2wd bare head wanted
  146. P8 ECU WANTED in full working order
  147. 15" MOMO ARROWS MANTED
  148. Flint grey drivers side front door for a Sierra wanted.
  149. 2wd sapph cossie sump
  150. s2 90 spec headrests
  151. small turbo TB throttle body
  152. mondeo st200 rear bumper
  153. Zetec 2.0 silver top dipstick
  154. Autospecialists bling Amal valve cover
  155. Smoked/Red Tail Lights
  156. wanted bd10 ex cam cosworth 2wd or 4x4
  157. s1 clocks
  158. Hi
  159. Sapphire Morette Lenses
  160. WANTED 2wd cossie stainless exhaust
  161. s1 parts needed
  162. Sierra RS500 Wanted to swap with Escos T34 Stage 3..
  163. vernier cam pulleys
  164. S2 top rad hose
  165. Grey ecu cover with rs logo
  166. cossie hose
  167. escort rs turbo amal valve
  168. fiesta turbo radiator
  169. wanted again escos or realy nice 3dr
  170. mk1 or mk2 2dr escorts!
  171. fuel pump holder needed for escort rs series 2
  172. s1 arches wanted
  173. £££££££ RS Cars Wanted £££££££££
  174. escort cosworth bonnet vents
  175. air box to turbo hose
  176. doors for xr2i
  177. ofac map sensor
  178. wanted: Silicon Intercooler hoses for saff, samco or other
  179. 14'' Sierra Focus Escort Mondeo
  180. 4x4 Bigwing sump and other bits
  181. cheap mk1/2 fiesta
  182. 16in Compomtive MO's in Antharite/Black for swaps
  183. 0.25 cossie pistons
  184. CTS STAGE 2+ GEARBOX or quaife straight cut box for rst
  185. cossie modified sump to fit mk1 escort !!!!!
  186. rs turbo wanted
  187. OFAB ECU needed urgent
  188. rs turbo alloy wheels
  189. alloy or ss boost pipe for s1 wanted
  190. OFAC 195 chip
  191. looking for 2 or 4x4wd saph for my zvh and omega. WHY???
  192. Standard T3 swap for T34 & Standard alloys for escos all
  193. front speakers and pods for a 3 door **Sorted**
  194. p100 pickup bed
  195. Focus C Max TDCI under bonnet parts
  196. DELETE PLEASE
  197. WANTED- SAPPHIRE COSWORTH
  198. wanted cosworth!
  199. full system mongoose
  200. engine hoist wanted
  201. FOCUS RS PARTS!!!
  202. mongose downpipe for a 2wd cossie
  203. FIESTA 1.1
  204. 15" MOMOS WANTED
  205. 750cc injectors
  206. RS500..
  207. escort cosworth/Stonedeflector & Splitter
  208. Decent RS 3 or 4 Spoke Steering Wheel - No Boss needed
  209. YB head
  210. ecos interior
  211. Sapphire Cosworth
  212. cosworth cam
  213. MK4 Escy/MK2 Orion EFI air box
  214. frst suspension
  215. Need a center console with no arm rest for a 87 Sierra
  216. Anyone breaking a fiesta rs or xr2i 8 valve needed asap
  217. T34 TURBO
  218. ANYONE BREAKING A RS TURBO SREIS 2??????
  219. Mk6 Escort RS2k Alloys....
  220. X FLOW ENGINE
  221. Cosworth 2wd Turbo oil Drain pipe...
  222. Level 6 ECU for cosworth...
  223. cosworth crank pulley wheel WANTED 2wd
  224. wolfrace voodoo alloys
  225. S2 caliper
  226. mk3 golf towbar
  227. escort mk.5 2 door colour coded handles
  228. ECU - DEEP/DESK/DEWY
  229. Zetec Throttle Body
  230. LOOKING FOR ANOTHER ESCORT RS TURBO
  231. Cosworth Propshaft Donut ASAP!
  232. Cossie head
  233. Turbo water pipes, ERST Braided Oil Hose, FRST Oil Seporator
  234. FRTS/ERST engine
  235. escort mark 4 cabby wanted in middlesbrough area
  236. Escort cosworth twin lights.....the clear ones.
  237. original/ stereo
  238. Decent FRST suspension
  239. :URGENT: Looking for ecsort cosworth T28 rebuild kit
  240. Flint grey Sapphire drivers front door needed
  241. Fiesta front mount intercooler
  242. need a GOOD SOLID rs turbo shell
  243. need a GOOD SOLID rs turbo shell
  244. !!!WANTED!!! sapph leather centre console armrest
  245. cosworth 2wd .5 overbore piston
  246. Zetec Rocker Cover
  247. SAPPHIRE COSSIE 4X4 FRONT BUMPER BRACKETS
  248. Escort RS Cosworth Space Saver Wheel
  249. 4x4 saph cosworth standard airbox.
  250. Escort RS T3
