View Full Version : Cars & Parts Wanted.
- SAPPHIRE COSWORTH FUEL PIPE
- 1pc Alloy wheel OZ Chrono 7x16
- S1 Gearbox
- rs500 front bumper
- escort cossie with or without engine
- Mk5 Escort RS2000 alloys
- side mounting
- Standard Dials/Clocks
- 2wd Saph Cosworth...
- mk1 fiesta
- *******************COS Plate Wanted********************
- Rs500 Throttle Body Wanted
- 17" Rondells Wanted
- Saph bonnet vents
- L8 with or without chip. [found]
- fiesta turbo bits
- mk3 Mondeo ST200 lower grill
- Mk4 n/s Window motor - ANYONE??? :(
- Focus RS
- Sunroof for Mk3/Mk4 Escort Slide and Tilt - (all the parts n
- some nice wheels 18s 17s got around a grand to spend
- MK1/MK2 Escort 4door or 2door
- ROOF HANDLES for cabriolet - STILL BUYNG LOADS
- 3.9 front diff
- 2wd saph cossy door mouldings
- Escort zetec n/a 4-branch manifold
- Mk 3 or 4 escort 3 door
- fiesta rs turbo engine
- l8 ecu wanted
- mondeo bumpers
- New Toy wanted.. Swap/Px for my Mondeo ST24
- ignition module
- 3dr Bonnet Vents/ front Grille
- crank v pully for ecos
- Turbo for Escort RS Turbo
- *SORTED NOW*1600cc CVH Head Early Type
- Few 4x4 cossie bits req'd
- RS 1600i WANTED.PLEASE HELP!!!
- saff cosworth wanted
- Cosworth Large turbo exhaust manifold
- RS2000 MK5 WITH GOOD ENGINE AND RUNNING GEAR
- 2wd Turbo Heatshield and other 3 door bits to finish project
- Escort cosworth 16v head
- Silver top zetec high lift cams
- GEN FORD BRAND NEW S1 THROTTLE CABLE
- 2wd cosworth rocker cover with breather
- 2007/2008 Radio and 2040 Dcplayer wanted
- Manifold
- beige injectors and ofab ecu and loom
- 4wd coz large front brakes wanted
- sorted
- escort mk5 91-93
- wanted orion rs turbo rear bumper
- Rotten series 1 shell for winter project.
- Wanted Sapphire
- RS Focus Front Disc
- 4X4 THROTTLE BODY
- 2 puma repeaters
- mk3 fiesta doors 3dr
- T4
- Cheap RS turbo wanted
- cosworth back box
- orion
- ESCOS BANANA POD - CENTRE CONSOLE & ESCOS RIMS
- cossie rims
- 4wd cosworth big brake parts/kit
- Starter Motor
- cossie 4x4 head
- S2 RST GEARBOX
- 3 door cossie parcel shelf support panels
- wanted rs turbo
- fiesta rs turbo std downpipe
- Twin carb inlet manifold for pinto...
- MINT MK5 Cortina Wanted
- bottom pulley for 2wd saf cos and rear strut brace
- 2.1 or 2.0 zetec bottom end ready for high boost?????
- cossie strut brace
- rst cylinder head
- s2 koni's
- Wanted Sierra Cosworth Rolling Shell
- 2wd 3dr konis found mods please delete!!!!!!!!!!!!!!!!!!!!!!
- Sky Gnome!!!!!
- efi cvh
- ported cossie head
- Pinto engine
- Ford fitment wheels needed...
- rs turbo part urgently needed
- ESCORT RS2000 MK5 INTERIOR
- fiesta rs turbo petrol tank
- DEEP ECU and Fiesta SI Interior Loom
- 4X4 cosworth ECU
- S1 RST ECU
- Escos RHD dash, centre console and cheapish wheels wanted
- wellers..... for mk2 XR2
- 2wd crank pulley wanted
- WANTED!! ESCORT RS TURBO/FIESTA RS TURBO WANTED!!
- 2wd thermostat housing wanted
- quad Wanted !
- WANTED COILOVERS
- FORD ANGLIA 105E
- S1 escort rs turbo fuel pump relay
- mk3 fuel pump
- Escort gti interior, excluding front seats
- URGENT! mk1/1.5 focus bonnet
- mk4 escort parts
- Series ! wanted £3-4k
- mk5 fiesta zetec-s front bumper
- SAPH DASH
- Sapphire bonnet (vented or non vented)-scotland please
- 1.6 cvh carb engine
- oil pump high pressure
- Wanted Mondeo 16" alloys
- Air injectors NOW SORTED
- Sapphire Cosworth 4x4 rally shell
- 17 5 spoke mo's
- Wanted Escort Cosworth REPLICA
- dark green cossie injectors???
- cosworth rs 3door front bumper brackets
- 4x4 heatshield
- Metering head needed
- 3 door Cosworth parts urgently needed to finish project
- s1 blue wter hoses
- mondeo key
- cheap rst, xr2, rst'd xr2, xr4i, capri and similar
- 1800 zetec sump and pick up pipe
- mk3 escort sunroof winder handle
- standart parts for WM Escort Cosworth...
- ESCORT VAN BACK DOOR LOCK
- 1400 Zetec Engine
- Scorpio Estate Rear Cross Member
- 2wd Sapphire lowering springs wanted
- a pillar gauge pod
- cosworth breather system with catch tank
- 19" OZ superleggra 8J ET42 108
- XR4I parts needed
- 2.0l DEEP ECU and MAF. 1.6 Fiesta SI Looms
- rs500 front splitter
- sierra cosworth (2wd) door mouldings
- Radiator - Escort RS Turbo Series 2
- ***wanted*** mk5 xr3i rear seat and door cards
- L8 ecu
- Focus Rs Turbo units wanted
- fiesta turbo replica
- Mk3 escort front O/S door rubber
- Early mk3 escort engine rubber mount....
- S1 turbo fuel tank
- cosworth not a car a spliter some one must have one
- cosworth splitter 3dr or 500
- 3dr parcel shelf
- mk5 xr3i spoiler - please delete as found!
- FIESTA RS 1800 PROJECT
- s2 rs turbo spotlights (dont need brackets)
- escort mk 3/4
- uprated front axle
- Urgent! Bonnet release cable and petrol cap with key. s2erst
- Wolf alloys
- 4x4 oil pump
- 5th injector or aftermarket management for rs turbo
- brand new inner sill'smk3 escort.
- series 1 interior.
- fiesta xr/rs drivers side rear arch moulding
- rs turbo efi (ofac) chip!
- Wanted Series 1 RST
- side exit exhaust...
- wheel hub
- Ford Fiesta Alloy Wheels MK6/7
- 2wd caliper mounting bolts
- BMW M3 Evolution Convertible
- Black Painted Sierra Saffy Bumper (non cossie)
- any1 want 2 swap a rs turbo for my 2.8 capri?
- 2wd Exhaust manifold and rear driveshafts
- fiesta Mk3 RWD or 4WD anything considerd
- COCWORTH ISCV VALVE NEEDED.
- rs 500 style splitter for saph bumper
- frst top hose wanted
- not a car but a good clean 4 wheel drive
- silver mk4 escort bootlid
- ignition amplifier
- Mk2 XR2 Radiator Hose
- rs turbo front coilovers
- good price on a cosworth 6 paddle clutch
- 2wd front coilovers
- full uncut xr3i wiring loom
- sierra 4x4
- Focus RS Alloys
- rs 500 replica splitter for saph bumper
- T34 wanted
- steering rack
- Escort Turbo
- brand new mk3 or 4 escort shell
- Cossie YB Head
- rocker cover for 1.9 fiesta rs turbo.
- COSWORTH SPLITTER
- erst alloy cooler, fiesta 195 or aftermarket chip (ofac)
- series 1 radiator
- focus rear lights
- Fiesta turbo inlet manifold
- Escos aircon radiator
- XR3i + RST fuel injection parts
- AP Brake, Hydro Handbrake, GrpA Square beam, Side exit zorst
- splitter
- beige injectors for fiesta turbo
- springs
- Wanted 1x 4X4 Cosworth Con Rod!
- 3 dr cossie inner wing
- efi bits
- 3door
- Xr3i Distributor (bosch)
- Modified idle speed control valve??
- series 2 oil return hose and abs plastic pipe
- Cosworth 200 block needed
- Escort Cosworth Front Bumper and Bonnet
- looking for engine, wheels, shell, dash and 90 spec seats
- a small list of ERST parts wanted
- ERST S2 engine wanted
- burton stainless steel valves
- fiesta turbo scorpion exhaust
- fiesta rs/xr drivers side rear arch moulding
- s2 engine needed
- parts wanted for cossie NO LONGER REQ-PROJECT CANCELLED
- Header Tank
- ESCORT SUN ROOF
- Black rear window trim
- Cheap XR2
- gearbox for fiesta diesel P reg 1.8D
- water feed
- GpA Escort cosworth Shell , rolling or bare
- Series 2
- stage 2 turbo
- WRC 8 inj INLET MANIFOLD
- escort gearbox
- 195 Ofab Chip
- xr2 mk2 full body kit
- Sierra RS Rear Seats
- 90 spec erst front bumper
- 3dr cosworth distibutor
- s2 engine
- 3 DR front bumper genuine
- top engine mount for a mk4 escort zetec conversion
- mk4 escort springs needed asap
- fiesta rs turbo loom
- Escort 5/6 rs2k or sierra xr4i/4x4
- anyone breaking a cabriolet (mk4 escort)
- £££££ CASH WAITING £££££
- MK4 Fiesta parts
- front bumper fog light brackets for a 3 door of escort.
- cosworth 63 housing
