PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. wanted 3dr grill
  2. few ecos parts needed
  3. Focus RS
  4. Mk4 escort Safety devices cage wanted..
  5. Cosworth Group A Cone filter
  6. RS Cars wanted anything considered
  7. strut brace/cosworth head
  8. 15" + 16" alloys + Tyres needed!
  9. T5 Donor box
  10. escort rs turbo stainless exhaust or back box... outward rolled pipe
  11. 2door MK2
  12. t3 downpipe
  13. Original Cosworth Cd Player
  14. late spec saph bits
  15. O/S fog light lense saff cosworth
  16. 2wd rear diff
  17. 2wd Cosworth Any Colour Apart From White
  18. 1600 cvh block wtd.
  19. alloy tanks cosworth 4wd
  20. Door panels/ wheels/chip
  21. 88 spec front seat and bonnet
  22. wanted t5 box
  23. Help i need 1 0f these but aint sure what its called
  24. 2wd moonstone blue cossie to swap
  25. crank pulley &
  26. cts stage 2 +gearbox wanted
  27. p100 wanted mint as possible
  28. Nova roll cage wanted
  29. 3 door front shocks or coilovers
  30. Cosworth Bilstein Rear coilovers wanted URGENT
  31. Wanted St170 Hubs & Driveshafts
  32. T34/63
  33. bonnet mushrooms and boot springs
  34. wanted peeps !!!
  35. A pillar gauge for facelift saph
  36. Cosworth parts wanted
  37. Cheap Cosworth Engine
  38. T34 urgent!
  39. wanted!!!24v granny, xr4x4 & 4x4 saff.
  40. Rs turbo engine
  41. rs turbo gaz coilovers..
  42. Wrecked MT75 4x4 cossie gearbox please
  43. white erst bonnet
  44. ford racing gauges
  45. scrap blocks and heads
  46. front escort mk3 seat xr3/cab
  47. front saph 4x4 braided hoses...
  48. Uprated Coswort Diff Mount
  49. 2wd Sapphire Cosworth Mongoose Exhaust...
  50. s1 body kit
  51. 2wd Cossie Diff wanted
  52. Set of defi gauges 52mm white
  53. Couple of cosworth parts needed.
  54. Cosworth 4x4 exhaust manifold
  55. rs500 throttle body and elbow
  56. Drivers Side Door Mouldings
  57. p100 has to be mint
  58. Steering Wheel Swap
  59. 2wd Cossie damper bracket...
  60. Wanted Cossie 2wd Front Callipers.
  61. Wanted Fiesta Rs Turbo Parts
  62. MK6 doors
  63. Lockset or drivers door lock and key for a mk5 / 6 escort
  64. pectel t6 wanted
  65. sierra rs 500 wanted
  66. Anything to help my esc s1 fuel well
  67. escort van
  68. t34 turbo
  69. MK5 escort tailgate
  70. 2wd Cossie engine mounting arms
  71. 2wd cossie parts needed ?
  72. FRST OFAB ECU Wanted!!!
  73. Wanted: 3dr Sierra Cosworth
  74. cosworth cambelt cover fixing mounts...
  75. sand blasting cabinet wanted
  76. Rear Head Rests 4 Fiesta Mk4
  77. cheap cheap escort van
  78. Boot Lock for 2wd cossie
  79. Wanted 3 door full lock set.
  80. Wanted RS500 Throttle Body Only
  81. *******COS/FMC Plate Wanted*******
  82. Esc Cos rear bumper
  83. 1.9 American CVH bottom end
  84. saph 2wd turbo wanted
  85. WANTED Kent 5spoke pulleys single or pair W H Y ? any condition considered
  86. escort mk3 rs1600 front spoiler
  87. wanted mint fiesta 3 door shell
  88. Rs Turbo Efi Big Valve/Ported head
  89. Red Fiesta Turbo bits
  90. T4 or T38 Turbo for 2wd saph cossie
  91. White Fiesta RS Turbo / XR2i Rear Bumper
  92. Saph front rubber splitter
  93. sapphire scuttle panel,Manual window winders and more etc
  94. Braided Brake Hoses
  95. rs turbo 220mm 4 paddle clutch wanted
  96. rs turbo 220mm 4 paddle clutch wanted
  97. 3.92 4x4 step off gears and chain??
  98. escos steering colume
  99. zetec turbo engine mounts
  100. Escort rs turbo engine
  101. WANTED: Escort Mk6 Alloys
  102. Lot of group A parts needed !
  103. 215/40/17 x 4 or 5
  104. Cav GSI2000
  105. 500 cooler wanted
  106. RS500 Intercooler with 3" Pipes
  107. sapphire bootlid
  108. 500 intercooler (SORTED)
  109. now sorted
  110. t3 turbo wanted 2wd
  111. fiesta turbo fuel rail
  112. Cosworth Rear Suspension Arms
  113. Wanted Ofab Fiesta Rs Turbo Chip
  114. fast ford mag wanted
  115. RS Turbo or Cosworth Leather...
  116. clutch fork and gearbox pin needed ASAP
  117. Rs500/bumper/rear Spoiler Top And Bottom
  118. 4x4 Cosworth flywheel needed
  119. Focus RS Wheels in need of refurb
  120. Saff cossie bumper
  121. ** Parts for Cosworth **
  122. 4x4 Cosworth Inlet Manifold...
  123. Cosworth parts wanted
  124. series2, 4" exhaust swap for 3"
  125. worn/shagged RS 3&4 spoke steering wheels
  126. Fiesta MK3 RS1800 Parts Needed + Zetec Upgrades!
  127. 2Wd dipstick
  128. A Long Shot I Know
  129. saph 2wd discs...
  130. 2wd Saff Cosworth
  131. 2wd Cosworth 3" or 3.5" Backbox or full system
  132. RSTurbo exhaust housing
  133. Mass air flow meter 2.0 Focus
  134. wanted snap on roll cab and top box
  135. YB engine wanted
  136. 2wd saff cosworth wanted
  137. 1x escort cossy centre cap
  138. 2wd shocks and springs
  139. AP Organic Friction plate for Sierra Cos
  140. 2wd front shocks
  141. capri rear axle or simular
  142. s2 airbox wanted
  143. 17in rondells
  144. Cosworth Parts
  145. rs series 2 alloy...
  146. Megasquirt
  147. Cosworth 2WD sump
  148. 2wd steering coupling needed asap
  149. Wanted, Fiesta Si Exhaust
  150. O/S/R rear brake caliper 4x4 type for vented disc
  151. --DELETE-- Found one
  152. Cheap faulty gearbox's
  153. Group A breather
  154. TSW Imola Centre Caps
  155. Wanted Focus Mp3 Decat Pipe
  156. Series 1 overrider brackets.
  157. Standard 2wd header tank to rad pipe hose
  158. Wanted s2 rs turbo
  159. cosworth level 6 standard chip
  160. 2wd Cosworth throttle body
  161. wanted cheap fiesta rst
  162. Mk6 Escort 1.6 Zetec Gearbox
  163. worn out 200 block
  164. good spec cvh turbo wanted complete or bottom end
  165. Escort RSturbo loom Tank Chip
  166. cosworth cam cover
  167. s1 front seats
  168. mk5 rs2000 door panel
  169. Cosworth parts Needed
  170. Sparco Ford Racing Front Seats
  171. After a freebie!
  172. sierra cosworth 4wd s/s exhaust
  173. 3 Dr Wheels
  174. 2wd brake pad retainer clips
  175. RS Turbo Wheel Bolts
  176. Cossie Parts
  177. Escort mk4 3dr red
  178. Sierra Cosworth Leather Recaros
  179. BMW E36 EVO Aftermarket ECU & loom
  180. Nimrod wheels wanted
  181. Crank
  182. Std Mk5 Escort Boot
  183. wanted....s2
  184. Esc Cos Carpet
  185. rs500 style intercooler wanted
  186. focus RS parts Needed. ASAFP
  187. RS Boss and Cap for Saph
  188. 2wd cosworth crank pulley wanted
  189. wanted alloy vernier pulley for cvh
  190. BBS Centre lock wheels
  191. diesel car or what you got
  192. ported cvh head
  193. New Style Compomotive Mo's 8.5x18"
  194. [WANTED] compomotive wheel MO 8x17
  195. wanted sierra cos brakes to fit escort rs turbo
  196. black/dark sapph ecu cover for dash
  197. rs1800 or simlar engine loom
  198. 2wd engine loom
  199. JENVEY 40mm Throttle Bodies
  200. wanted
  201. escos boot carpet
  202. adjustable tca who sells them
  203. mk5/6 escort disk rear beam
  204. rear beam and trailing arms
  205. Wanted Focus Mp3 Decat Pipe
  206. Wanted Fiesta Rs Turbo Front Bumper
  207. Saff passenger side front AMBER indicator
  208. !!WANTED!! escort cosworth steering wheel
  209. **WANTED** s2 RS Turbo Shell
  210. 4WD Sierra/Escort Suspension Wanted
  211. 2wd Sierra Sapphire Cosworth Parts...
  212. Escort RS Turbo
  213. 1 cosworth injector clip wanted
  214. Standard parts wanted
  215. Wanted Hatch Strut
  216. Original 500 grills
  217. rad hose
  218. mk1 escort atlas diff
  219. FAO rallymen - coilover question
  220. Shagged T34.63 for roller bearing T38
  221. 2wd Rear driveshaft bolts
  222. 3dr Cosworth replica wanted
  223. Saph Parts
  224. cossie parts, water pipe and bolts needed
  225. 2 wheel drive Sapphire lights wanted
  226. 3 Wheel Nuts for Sapphire Cosworth
  227. 909 billies tarmac spec
  228. INNER WHEEL ARCH TRIMS
  229. series 1 turbo or saff cossie
  230. MK5 RS2K
  231. ST escos Plenum & 2wd dipstick/tube
  232. Perspex/lexan/polycarb windows for an escort
  233. escort rs turbo or xr3i,complete rotbox wanted
  234. p8
  235. 2wd Cosworth front metal brake pipes
  236. S2 ERST inlet manifold
  237. YB 2WD Dipstick!!
  238. OZ rally wheels
  239. 1800 Zetec head....
  240. rst mk 4 cab
  241. -31 Actuator for escort S2 Turbo
  242. stage 3 hybrid turbo wanted for ecort turbo
  243. mk4 escort wing/bumper
  244. t25 turbo
  245. WANTE: 16" ford alloys anything considered
  246. standard mk4 bonnet (any colour, no vented)
  247. Fibreglass 3 Door front bumper
  248. Series 1 front grill
  249. A scrap 3 door cossie under bonnet loom
  250. wanted 4x4 rear calipers
