PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. escort cosworth wheels
  2. saph cosworth front splitter
  3. Escort Cosworth Front mounts NEED NOW!!!!!
  4. Cheap Xr3i
  5. Downpipe / front section
  6. ford 17" seven spoke diamond cut rims wanted
  7. cheep parts
  8. s1 front seats or half leather ones anythig considered
  9. 2door wanted
  10. looking for s2
  11. diamond cut rs seven spoke
  12. front drive shaft for 4x4 saf
  13. Alloys Wanted, Preferably 17"s but will consider anythi
  14. Series 1 Wiper Arm Nut Cover
  15. frontmount cooler ERST
  16. Any car for £500 or less
  17. anyone got any 803 green injectors in good nick?
  18. orange frt saff indicators
  19. Stub Axle/Hub/Bearings for Orion Mk2 (Escort XR3i/RST)
  20. Alloys 13 inch / 14 inch
  21. s1 rs turbo standard ford exhaust system HELP!!!!!!!!!!!!!!!
  22. pair of saff 4+4 rear calipers and hangers
  23. stainless backbox 4inch rolled out for escort mk4
  24. S2 springs
  25. Big brakes for escort cosworth!
  26. good cam recorder for a little bmxer lol
  27. ford focus mp3, or st170 wheels
  28. 3 door dash
  29. Alloy wheels wanted
  30. escort cosworth steering wheel
  31. mk3 escort panels
  32. 2wd crank pulley
  33. S1 rs turbo gearbox & 2.0 zetec engine
  34. a new hybrid turbo for a renault 5 gt turbo
  35. jacking point cover
  36. sierra cosworth bumper
  37. blue/red/blue or blue/red/white chipped s1 ecu required...
  38. Rs turbo brake servo WANTED
  39. 2wd Cosworth bits needed..
  40. tyres wanted 215 45 17
  41. Ford fiesta zetec S wanted
  42. erst rear bushes and also hubs
  43. escort window reg and motor
  44. zetec oil pump and valve stem oil seals
  45. alloy wheels
  46. ERST boot seal..
  47. ESRT washer bottle wanted,,
  48. mk6 fiesta seats
  49. l8 ecu and loom wanted
  50. 1.6 Zetec Sump and Pick Up Pipe
  51. S1/S2 SHELL OR CAR WANTED, DESPERATE.
  52. water pump to matrix tube 2 please
  53. u bolts that hold the rear leaf sprins together asap plz
  54. 2wd Coilovers
  55. stainless rear box
  56. Focus St170 6 speed gearbox...
  57. Sapphire Cosworth Wheels...
  58. wanted morrettes
  59. Crystal Morette lamps
  60. Kent Cam
  61. 2wd cosworth
  62. L8 ECU and cossie hub bolts-pic
  63. CARBON HEAT SHEILD
  64. CARBON HEAT SHEILD
  65. 4-2-1 manifold for escort gti
  66. COSWORTHS AND RS TURBOS WANTED.
  67. cos parts wanted
  68. rwd escort...
  69. WANTED!!!!
  70. reverse charge pipe rs turbo
  71. Alloy S2 rad
  72. sierra cosworth front anti-roll car mounts
  73. Standard Escort Cossie Large Turbo Actuator
  74. ACT Gauge please
  75. mondeo st220 wheel wanted
  76. Rs turbo bonnet raiser's
  77. s1 bits
  78. fiesta turbo rear arches wanted
  79. fiesta morette lights
  80. wanted turbo damper !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  81. sorted, cheers
  82. Escort GTI Alloys
  83. Wanted xr2 engine, crossflow or cvh let me know
  84. very high spec engine wanted
  85. Escort rs turbo black bumper strips
  86. osr bodykit arch rs turbo
  87. n/s heated mirror
  88. st fiesta side skirts
  89. N/S heated door mirror for 4x4 saph cossie.
  90. focus rs manifold
  91. escort turbo parts needed
  92. Mondeo ST24 RSAP bumpers.......... now got.
  93. escort cosworth side skirt clips
  94. wanted!!
  95. sierra cosworth 2wd standard exterior door handles
  96. Wanted:- Rear bumper
  97. Light blue injectors
  98. what i need
  99. 2wd rear drive shaft stubs
  100. escort cosworth fuel pump
  101. Escort cosworth front mountings.. (Picture)
  102. wanted Escort RS Cosworth
  103. escort cosworth body parts (damaged and cheap)
  104. Erst rails for side skirts
  105. saph cosworth 2wd or 4x4
  106. none
  107. fiesta rs turbo engine loom and ecu (ofab)
  108. morrettes for saph cossie
  109. S2 RS TURBO PARTS
  110. L8 ECU and Loom
  111. escort rs turbo recaro
  112. Drivers side Front Driveshaft coss 4x4
  113. rs turbo wanted
  114. map sensor frst
  115. 90spec front bumper
  116. WANTED cosworth 4x4 turbo compressor wheel
  117. GT30 turbo
  118. escort rs turbo exhaust manifolds and turbos wanted
  119. escort mk1 must have all the right bits
  120. mk 5 escort /cosworth rear stealth shelf
  121. coss 4x4 engine mounts
  122. what mod deleted my spit post and why ?
  123. Wheels Wanted - Focus ... 17/18 inc comps...
  124. roll cage
  125. Escort GTi or Puma Leather Steering Wheel
  126. 3d Cosworth rear bumper
  127. cosworth 750cc injectors
  128. Genuine Hocky Stick
  129. RST washer motor
  130. restoration project or tatty RS turbo any year
  131. front coilovers 4x4 cos
  132. looking for rs soft spokes i got wheels 4 sale
  133. want mongose stainless for s2
  134. Escort Cosworth in PX for 51 plate BMW M3
  135. Twin weber 45's !!!
  136. SAPPHIRE CLEAR REAR LIGHTS
  137. fiesta 02-04 tdi 1.4 van pref silver?
  138. erst gearbox
  139. frst engine
  140. WTD t34 downpipe
  141. esc cos nomad half smoked rear lights
  142. series one parts wanted
  143. Cosworth cambelt cover
  144. Zetec Turbo Steel Rods, Pistons + any other conversion bits
  145. bailey oil breather for saff 4x4 wanted
  146. Wanted! T34.48 needed urgently
  147. 2WD Cossie Exhaust manifold (smaller part)
  148. wanted morrete twin headlights 4 sierra saph
  149. 4" ERST BACKBOX WANTED ASAP
  150. Rs Mud Flaps
  151. s1 or s2 rolling shell for re-shelling wanted - CASH WAITING
  152. 4WD Sapphire Intercooler wanted
  153. 4WD Intercooler wanted
  154. Escort Turbo Exhaust system
  155. cosworth engine wanted
  156. 90 spec s2 buckets
  157. Gear box flange
  158. .............
  159. -31 aculator
  160. Carbon Heat sheild
  161. Series 2 Head!
  162. Cossy heat shield
  163. Wanted Sapphire Cosworth Twin A Pillar Pod
  164. amal valve ERST
  165. idle speed control valve
  166. 1980 RS2000 Headlights
  167. 4X4 THROTTLE POSITION SENSOR
  168. Focus shell 3 Door
  169. SERIES 1 EXCELLENT CONDITION
  170. Cosworth Rocker Cover
  171. s1 rs turbo standard exhaust
  172. Escort Rs Turbo Aerial
  173. Power Steering Pipe Sierra Cosworth
  174. XR2 Turbo Wanted
  175. is there anyone on here
  176. Cam cover 2 wheel drive
  177. 2wd Crank Pulley (3 belt type)
  178. want s2 intercooler
  179. ... Escort Cosworth Seats + Door Cards ...
  180. cossie bonnet
  181. want comp mo wheels
  182. 17" RS7 Spokes Diamond Cut
  183. Saph Morettes with or without lenses
  184. xr4x4
  185. fiesta mk3 coilovers
  186. delete
  187. escort diesel (may consider petrols...)
  188. 2wd Quickshift.
  189. flywheel/branch manifold
  190. 4x4 ecu wanted
  191. delete
  192. mk4 fiesta or even a mk3/4 escort, mk1 fes
  193. 1.8 zetec from escort/fiesta
  194. sorted
  195. S2 rs turbo 3" bore mongoose/aftermarket exhaust
  196. Zetec Turbo Rods and Pistons + T 34 Turbo.......anyone??????
  197. Wanted
  198. tom tom go 700
  199. 4x4 200 block
  200. PARTS WANTED
  201. Cosworth Engine
  202. Escort Front bumper....
  203. 1 x GpA Brake Bell Cp- 2494- 556
  204. t3 outlet flange
  205. crossover pipe
  206. looking for a 2wd sapph for a swap/px on my 2.1zvh s2...
  207. rs500 airbox
  208. needed frst loom
  209. cossy down pipe
  210. fiesta rs turbo/xr2i parts
  211. 2wd koni adjustables
  212. Focus Rs Front Seats and Carbon bit
  213. Superchip OFAB Fiesta RS Turbo
  214. full set of recaro escort rs turbo seats
  215. ... Escort Cosworth Bonnet ...
  216. ... RS2000 - mk5 or RS2000 4x4 - mk5b ...
  217. RS 1600I rocker cover
  218. 90 spec passenger seat, mint please!!
  219. door locks with central locking motors mk6
  220. S2 Alloy intercooler...............
  221. Escort Cosworth Trim
  222. mk2 fiesta
  223. lookin for a economical (diesel) car for my s2 2.1 zvh...
  224. wanted rondell wheel
  225. rs turbo dizzy and rad needed
  226. sorted now
  227. Wanted XR3
  228. RS Turbo Coilovers or good suspension setup
  229. 4WD Quad Wanted
  230. Turbo to Airbox hose T34 in BLUE!!!
  231. 044 pump for my 3 door
  232. pair of bucket seats and harness's
  233. (((series 1 silver fuel pump wanted)))
  234. Split Rim Go Kart Wheels Needed
  235. WANTED mint MK6 RS 2000 2WD
  236. xr2i front bumper n rear bumper
  237. Fiesta mk3 stealth shelve
  238. Escort Rs Turbo
  239. Lowering blocks, ASAP, Midlands/SouthWest area.
  240. escort rs turbo parts wanted
  241. 2 litre black top zetec mk2 mondeo head needed
  242. I NEED ONE OF THESE
  243. 2wd saff for swap/px impreza
  244. my mint xr3i cab for swap , looking for erst.
  245. escort s2 rs turbo wheels
  246. Mk 3 Escort / Series 1 Turbo Parts needed - urgently!!!
  247. old schoolpioneer keh 9300 rds radio cassette
  248. 2WD COSWORTH GEARBOX
  249. wanted3dr cosworth front bumper
  250. ESCORT GTI ESTATE WANTED
