PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. good spec 2wd saph wanted
  2. wanted 2.4 transit engine??
  3. 18inch wheel et35
  4. Wanted series 1 turbo
  5. blacktop zetec rods
  6. Sierra rear hub complete
  7. oil cooler
  8. S1 gearbox
  9. T4 exhaust housig 0.63
  10. 2wd big wing sump
  11. engine wanted
  12. light blues 400s cosworth
  13. Escort rst downpipe
  14. Wanted wheels
  15. Escort suspension tops & throttle cable bracket
  16. rs500 T4 0.63 exhaust housing wanted
  17. 3dr rear door cards
  18. 2wd Cosworth L6 ECU
  19. Cosworth L6 ECU wanted
  20. Gearbox s1
  21. t3/34 exhaust flange stud
  22. wanted twin piston bailey dump valve
  23. rs turbo bonnet
  24. Escort RS turbo locking fuel cap
  25. oz racing
  26. Mk5 Escort XR3i Full exhaust - S/Steel or Standard
  27. ST es cos inlet manifold
  28. WANTED: Cheap laptop must be wireless?
  29. Driveshaft stub (left hand thread) and nut
  30. cosworth 4x4 exhaust
  31. Sapphire cosworth 4x4 exhaust manifold
  32. mk3 fiesta van panels
  33. mk1 xr2 bodykit
  34. gear stick
  35. 4wd cosworth coilovers
  36. 3:54 diff
  37. ford badges
  38. i phone 8g 16g 32g
  39. S2 ERST parts wanted for 'Project wedding car'
  40. saph 4x4 power steering cap
  41. roller bearing t4
  42. cossie alloy header tank 2wd
  43. MK4 1.8 diesel Engine mount and bracket
  44. Iphone 3gs as above
  45. erst engine
  46. P8 ECU wanted
  47. 2wd driveshaft nut
  48. front bumper square rubber mounts
  49. Centre caps for 17 inch polished RS7 spokes
  50. MK5 Escort XR3i engine loom wanted.
  51. 15in tsw hocks
  52. Level 8 ecu WANTED
  53. Black 2wd hoses
  54. fiesta mk7 parts needed
  55. Rs 7 spoke
  56. Mk1 Focus 2.0 Dipstick Tube Needed
  57. EsCos Bonnet Required
  58. Standard Fiesta RS Turbo Suspension
  59. xr4i rear bumper and trim
  60. Wanted 4x4 saph cossie coilovers,URGENT HELP PLEASE
  61. Quite a few cosworth bits
  62. Focus rs mk1 ns front wing
  63. ABS block bracket
  64. cosworth hexigon thing that holds cambelt cover and screws into rocker
  65. 90 spec bumper
  66. Wanted rear koni adjustable for a series 2
  67. amal valve/3 bar/and -31 wanted
  68. Wanted dead or alive - fiesta mk3 manual window setup.
  69. Focus RS mk1 exhaust manifold
  70. 4x4 cosworth pressure reg bolt in type sierra cosworth
  71. Cossie cam cover.
  72. Wanted: Fiesta RS1800 Inlet
  73. wanted cheap turbo lump
  74. mk4 escort/orion front door card
  75. t5 clutch fork
  76. cosworth running gear
  77. Sorted
  78. 195 chip ofac
  79. zetec / cvh exsaust manifold adapter
  80. wanted series 2 car cover
  81. SECS monitor wanted
  82. 3dr headlights, 500 spoilers, tailgate
  83. WANTED: 2 Post car Ramp/Lift
  84. Mountune ALS valve
  85. Scrap Cosworth Engine Parts
  86. 2wd bailey header tank
  87. Tools
  88. YB Head Bits Needed...
  89. S2 gearbox
  90. Red cossie top hose + more
  91. Two 8 x 17 Grp A Fitment Alloys
  92. WANTED-URGENT! 1.6 zetec se engine
  93. cheap run about wanted upto £500
  94. mk2 st24 suspension kit
  95. Focus MK1 RS LSD wanted
  96. wanted fiesta cvh alternator bracket
  97. -31 actuator
  98. S1 rst lock set!
  99. 2wd saph gearbox mount/cross member
  100. Stage 3 t3
  101. DEEP, DEWY OR DESK 2.0 Mondeo ECU and Fiesta SI engine loom.
  102. Floor carpet
  103. Used 2wd cossy front discs!!!!!
  104. Wanted - 15" Raceline RL7's
  105. Mega cheap car with MOT and Tax
  106. fiesta van blanking panels
  107. escort cosworth small turbo exhaust cam ?
  108. Mk3 Fiesta ignition barrel/steering lock wanted!
  109. 2wd cossie coilovers
  110. Fuel pressure reg
  111. cosworth crank mint std/std
  112. bailey breather system and fitting pipes please
  113. mk3 escort n/s inner wing /chassis ( 2 fixed bolt type)
  114. Car transporter/trailer
  115. Cossie fuel pressure reg
  116. cosworth v6 boa downpipes
  117. sapphire fuel flap rubber seal
  118. Mk4 petrol cap.
  119. 1.6 cvh turbo pistons
  120. S2 Parts Needed
  121. Wanted: Heater matrix plastic cover
  122. escort cosworth aurails blue
  123. 2wd airbox
  124. lamba sensors for mk3 ford focus
  125. slim line rad fans
  126. 18inch Esc Cos Rims...
  127. saph splitter
  128. fiesta turbo
  129. Focus RS Pistons and rods
  130. fiesta turbo
  131. Cant find a decent XR3i anywhere!
  132. Cortina mk3/4/5 front sub frame
  133. S1 or RS1600i arb wanted
  134. Looking for turbocharger for Rst
  135. Erst upgraded brakes
  136. Small turbo Escos fuel injectors
  137. 4x4 front coilovers cosworth xr4x4
  138. Rouse or 500 splitter for a sapphire
  139. Polished alloy or black strut brace for sapphire cosworth
  140. Avo coilover spanner and key for adjusting height and dampness
  141. Rs 7's
  142. Escort cosworth front wings
  143. Sorted
  144. cosworth replica or something cheap and fun
  145. Rear Escort MK3/4 lowering springs
  146. Saff door seals...that bolt to rear doors
  147. WANTED: T3 for a 4x4 Saph
  148. NSF sapphire sierra headlamp
  149. Wanted various rst si parts look!
  150. wanted s2 90 spec centre console
  151. cosworth suspension caps
  152. Escort Rs turbo alloys
  153. mondeo parts mk1 needed urgently
  154. Mk4 Escort parts asap
  155. Rs500 inlet or wrc 8 injector set up and all parts required
  156. Driver side 3dr seat runners.
  157. Starter motor
  158. Escort cosworth front wings
  159. Frst bonnet plus few other bits plz
  160. Good standard escort rs turbo T3 that i can collect ASAP??
  161. rs turbo s2 fusebox relays
  162. sapphire outer window seals
  163. focus rs clutch cover bolts
  164. rough body/damaged sapph cos.
  165. Cosworth dark grey door cards x 4
  166. escort cosworth wrc spoiler wanted!!
  167. Coilovers for saff cosworth avo/gaz
  168. Transit Wheel & tyre wanted !!
  169. Cold start injector plug with wiring for a s2
  170. Sierra Sapphire rs500 or rouse front splitter what you got
  171. S2 90spec mercury grey front bumper and bonnet
  172. Standard Cossie Map Sensor.....
  173. metal turbo coolant pipe
  174. Any Ford Salesman? New Fiesta TDCi wanted
  175. Ford focus mk1/mk2/RS boot spoiler
  176. 5 point racing harnesses wanted
  177. 4 centre caps for 17" diamond cut rs 7's
  178. xr4x4
  179. some parts from a saph shell thats getting scrapped
  180. 2WD Front Coilovers
  181. fiesta rs turbo engine
  182. 1 escort GTI 15" rim or 4 mondeo 16" si rims!
  183. ap 6 pot pads
  184. Cosworth Oil Cap Bayonet Type Wntd!!
  185. 2WD Sapp Rear Arms
  186. Various parts required RST + Basic spec
  187. Heater Matrix
  188. 5.1 sierra diff
  189. Wanted new n/s fog lamp for escort cosworth
  190. 3door or escort cosworth n/s fog lamp
  191. need help on my shopping list
  192. Upratted engine mounts
  193. escort cosworth 4x4 front konis
  194. *WANTED* Series 2 Escort RS Turbo Gearbox
  195. P8 ECU NEEDED :protect
  196. P8 ECU WANTED:protect
  197. Escort Cosworth T34 Oil return pipe
  198. mk4 escort (rst) seat sub frames
  199. saff cossie diff bolts
  200. sapph cossie 2wd front shocks and springs needed a.s.a.p
  201. few frst bits please
  202. zetec bits
  203. 3dr cosworth doorlocks
  204. ZVH cam
  205. 4x4 cosworth fuel rail & reg
  206. need a p100 anyone selling
  207. Wanted frst bumpers!
  208. Red Escort mk6 Bootlid spoiler & rear bumper
  209. wanted cossie 3dr fog lights and door cards
  210. Escos wheels, stage 3 t3, grs intercooler.
  211. Mk 1 Fiesta Rs Steering Wheel Boss
  212. Ford ka 1.3efi crossflow
  213. Wanted left hand smoked mk 4 rear light
  214. 3dr heater motor/box cover(centre bulkhead panel
  215. Stage 3 setup
  216. Wanted GT3071r
  217. Saph morretes
  218. cosworth 3dr/RS500 alloys wanted
  219. 17" compomotive cxn split rims wanted...
  220. Good standard escort rs turbo T3
  221. s2 brakes
  222. cosworth l6 or l8 ecu
  223. ST170 engine bay plastics
  224. Twin A-pillar pod (3dr)
  225. clips
  226. 2wd Thermostat Housing
  227. 4x4 Saff Cossie Alternator
  228. Sierra Sapph cosworth 2wd front hubs
  229. WANTED auto gearbox for mk2 mondeo
  230. 2wd sapphire cosworth fuel tank sender unit
  231. MK4 Escort head cloth wanted
  232. focus rs gearbox
  233. Bmw Mini
  234. Cossie Stainless dipstick handle
  235. I'm after an st170 decat pipe
  236. Saph Cosworth Front bumper
  237. WANTED MONDEO ST TDCi
  238. rs turbo s2 parts
  239. T34 wanted
  240. t34 actuator bracket
  241. Standard 2wd turbo heat shield
  242. Escort LSD Box wanted!
  243. Escort Cosworth Alloys 8jx16"
  244. MK 4 Escort Rear Tailgate (Boot lid?)
  245. Anyone got some standard 2wd sapph suspension ????
  246. st170 magnum grey d/s mirror
  247. MK2 fiesta spax shocks
  248. St170 gearbox to engine plate
  249. 205 block
  250. Couple of Cosworth bits needed.
