View Full Version : Cars & Parts Wanted.
- MK3 XR3i stainless exhaust system
- sapph wanted to swap for wrx v limited
- Wanted Escort RS Turbo
- Mark 4 escort cabby drivers door glass
- good escort rs turbo s2 early drivers seat
- Pectel monitor
- Escort MK6 White Front Bumper + White Wing Mirrors
- series one air box rubber ring
- 3 door cosworth alloys
- Wanted: Complete sunroof for m3/mk4 escort - QUICK!
- recaro seat
- diesel turbo
- Wanted. Your broken or cheap 2wd or 4x4 rear diffs
- Moonstone blue rear bumper for Sierra Cosworth
- Bailey Oil Breather Kit for S2 Escort RS Turbo....
- mk6 bonnet
- rs2ooo4x4 swap for series2
- roll cage for 3dr sierra
- Reverse lift for cosworth 4x4
- idle speed for anti lag
- escort mk 6 items
- cosworth t3 needed - after a knackered one!
- 1 cosworth ht lead needed, mines split...
- Passengers and drivers Door cards
- 2000 FOCUS 1.8 ZETEC STANDARD EXHAUST
- Sierra Saff Cosworth Shell NEEDED PLEASE IN WHITE
- T34 compressor housing needed
- MK 5 ESC CAB ELEC ARIEL.
- rs1600i spoilers
- Front leather door cards for a saph pls!!!
- Rear passenger door
- sapphire cosworth body parts rqd
- crossflow mainfold needed
- Cill to side skirt clips required
- Old Sparco bucket seat
- focus collection front bumper wanted
- pre 83 xr3 top mounts
- cossie management&good spec cvh/zvh engine
- series one resto project
- 17 inch alloy wheels
- 2wd discs
- chrome roll cage
- Wanted ASAP: Fiesta 4 Spoke 14" Alloy
- door cards 2 wd sierra cosworth
- derv of some kind, vag prefered
- ERST Engine Wanted
- sierra 4x4 bits
- 1 x 17'' diamond cut 7 spoke
- cosworth front brakes
- Focus ST170 rocker cover
- fiesta mk 2 front clear indicators
- 90 SPEC S2 WANTED.
- cos wing 3dr
- stack dash wanted for saph
- s2 lsd box
- Cosworth 2wd sump wanted
- escort cosworth morettes required
- stage 3 big valve head required for my erst any help most ac
- Series 1 rs turbo
- pair of 2wd cossie cams
- Escort rs turbo full loom
- MK3 or 4 Genuine Ford Escort Rubber Mats.
- Focus Rs Engine + Gearbox + ECU
- ERST fuel distributer and dizzy
- swap my e30 for........
- 3inch > 2.5inch silicone hose reducer
- 5 spoke 8x17 comp mo
- Merc Grey E plate XR3i wanted...
- 17" comp mo's wanted
- s2 caliper conversion bracket ( to take 2wd discs)
- Couple of bits needed.
- defi control unit II
- Escort or Fiesta Rst..
- CARCOON WANTED SIZE 4
- diff bolts
- Fiesta Mk3 Turbo/Xr bodykit (any colour or condition)
- mk2 xr2 wanted
- Escos, sierra rear subframe wanted
- Escort MK6 White Front Bumper Wanted
- series 2 rst bonnet vent plate wanted
- RS Locking Wheel Bolts
- RS Turbo coilover suspension !!!!
- Compomotive Alloys and Cosworth Conversion Bits
- 17" 5 stud wheels for sierra with granada hubs
- cheap cosworth or rs turbo whilst refurbing 3 dr over winter
- wanted 15" softspoke style alloys
- Sierra Cosworth Bonnet Vents
- Pectel T6 wanted
- Mercury Grey ERST
- 200 Block std bore
- 2WD Swan Neck part of Exhaust Manifold Required
- cossie parts wanted
- RS 200 plenum
- cheap ford mondeo
- ofac 19 frst chip
- frst bits....
- Eccort mark 4 Roll cage
- ford ka cd player
- WANTED rs1800 air mass meter
- e rst oil seperator and chrome rocker and inlet manifold
- Red Silicone Top Hose (coolant)
- WANTED: Stainless backbox (Sierra)
- mk4 escort dash surround
- my list of saff cosworth parts wanted.
- cheapy cheap cd player
- OSR opening qtr glass for a FRST
- RS 7 DIAMOND CUT ALLOYS
- v6 cologne sump!!!
- fiesta turbo map sensor needee!
- header tank, oil separator image style , turbo damper
- 4x4 bodyshell - XR/RS
- rs turbo engine and clutch
- rs turbo or 3i breaking in bristol
- 3 door rollcage wanted
- Escort Cosworth Amal Valve
- 4x4 or 2wd Cosworth Cylinder Head
- FOCUS RS bumper grill
- Balck saph cossie wanted
- kit suspension escort rs turbo
- Magenta.Cossie>bootlid
- 3dr arch liners wanted
- 1 Ears RL7
- 88 or 90 spec erst front seats (dont have to be mint)
- Escort GTi or RS2000 MK6 Dials wanted.
- VW passat wheels
- Front Ford Mudflaps for MK1 Focus
- Escort MK5 RS 2000 Stainless Steel Exhaust??
- 2wd crankshaft pulley
- fiesta turbo engine
- Wanted RS500 fibreglass panels
- 1 only escort cosworth wheel
- cossie intercooler
- Interior Clock
- 1.6cvh (na) and 4branch manifold
- Cheap!!!! Cosworth Req whilst 3 door having a refurb!!!
- escort elecy mirror blanking plug
- ford escort rs2000 lhd continental headlights 91
- escort mk4 rollcage and s2 alloys
- 2wd bellhousing wanted.
- Profshaft bolt...!!!
- 2wd saff cosworth diff and 2wd head
- WANTED Sierra 3 DR COSWORTH
- Esc Cos 023 uprated fuel fump fitting kit
- wtd S1 non custom front door cards front seats parcel shelf
- WANTED: Brembo 355 x 32 discs
- Fiesta Turbo Stainless steel exhaust
- pectel T2, autronic, emerald or equivalent
- Sapphire Cosworth parts
- sapphire RS cosworth odds and ends
- Escort RST Series 2 Coilovers
- morettes for escoz
- 2wd Sump Gated Baffle assembly , 4wd Race Head Wanted
- Cosworth 3dr/Sapphire Shell...
- Escort cosworth amber bumper indicators.
- Clutch kit
- T34 actuator bracket to fit 2wd set up.......
- one 5 spoke mo
- sorted
- MK6 coil overs + after market management
- Escort GTI fuel tank
- No Longer Available from Ford? :(
- Wolfrace Voodos Wanted
- mondeo st220 / st-tdci front buper wanted
- azev a [mint]
- Drivers side leather recaro
- NO LONGER NEEDED ( GOT ONE )
- saph cos fog light surrounds wanted
- Nintendo DS Lite WANTED
- escort rs turbo carpet
- 1.8/2.0 Zetec engine
- FRST Alternator Bracket - Desperate
- MK3 Escort - Rolling shell / Blown engine
- SERIES 1 FRONT MOUNT AND FRONT BRAKE UPGRADE
- WANTED 3 DR COSWORTH.
- T5 cossie box
- 2wd Cossie Front ARB Bolts + Brackets
- engine crane
- wanted 205 crankshaft bottom pulley please
- cosworth 2wd t5 gearbox GOT 1 NOW CHEERS
- Series 2 front mount
- wanted 90 spec front bumper
- koni adj and s2 alloys!
- Wanted Black handles and door pockets for 2wd raven interior
- cosworth crank pulley
- FIESTA 1.25I GHIA REAR HEAD RESTS
- caged saph shell
- single RL7 17x8 alloy needed-sapp fittiment
- CROMODORA 8x18 need 1
- steering wheel
- front grill for a 3 door cossy
- 18" Cosworth Alloys!!
- ERST wiring loom
- mk2 fiesta wanted!
- Wanted 3 DR Cosworth .
- xr3i alloys
- Fiesta Rs1800 front splitter
- Cheap T3 turbo, does not have to work
- Drivers side mirror for R Reg Escort needed
- Tall order, part worn tyre needed
- bass tube
- 8 pot brembos
- MK1 Fiesta Full Roll Cage
- .48 exhaust housing
- escort cosworth left wheel drive
- FRST Front Bumper Red
- GT30 Turbo
- mk2 fiesta ignition barral
- COSWORTH CONE FILTER
- Focus Collection Front bumper
- I'm after a set of standard saff cossie alloys
- FRST OFAC MAP SENSER CASH WAITTING
- Escort Dials
- pinto fuel rail+ inlet plenuem
- ESCORT COSWORTH OIL PRESSURE SENDER WANTED
- wiring loom
- 2WD Throttle Body + 4WD TPS
- defi/spa oil pressure gauge
- plastic handled dip stick for 4wd cossy
- 1800 Zetec water rail
- I want a CRACKED (don't ask) Mk3 Escort/Mk1 orion dash!!
- rs turbo bottom boost hose
- L8 ECU
- UT T38 Turbo
- escort cosworth air box small turbo
- FUSE BOX NEEDED
- 3dr sierra cos shell
- Wanted 530d Sport
- S1 Radiator & Intercooler
- cosworth 4x4 front driveshaft
- Series 1 Body kit
- WTD: Pair of Escort Wing Mirrors (Pepper Red)
- BLACK FACED BOOST & OIL PRESSURE GUAGES
- 1 diamond cut 17'' 7 spoke alloy
- one mo 5 spoke wanted
- saff strut brace twin type please[front]
- fiesta si or any mk3 shell
- loom
- escort s2 rst standard exhaust front pipe
- 3dr central locking motor
- WANTED MK3 ESCORT ANY MODEL
- rwd diesel upto £1500 light and oldschool preferably
- ofac 195 frst chip!!
- Cheap van!
- top mount
- mk4 escort popular/bonus 1.1 or 1.3 3dr
- Alloy Dump Valve blanking plug TWO NEEDED
- Mk3 Escort Fibreglass Tailgate?
- Wanted Escort m4 Combi van (diesel)
