PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Pioneer remote
  2. focus rs battery cover and rear boot handle
  3. Wanted s1 shell :-)
  4. sapphire floor mats wanted
  5. Standard width bucket seat
  6. Cosworth 4x4 big brakes
  7. 2wd cos Koni front struts or coilovers wanted
  8. 2wd rear shaft stubbs
  9. Focus Rs mk1 drivers foglight
  10. Wanted s2 turbo radiator
  11. saph door cards
  12. wanted mk4 escort rollcage
  13. Tsw hockenheim alloys
  14. mk1 rs focus box
  15. 2wd cossie diff
  16. MINT passenger side leather recaro seat wanted
  17. Grey Injectors
  18. sapphire cosworth door cards
  19. wanted s1 rs turbo metering head
  20. wanted saph cos 4x4 fuel tank
  21. S1 rear braided hoses
  22. Focus Rs bells and discs
  23. cvh timing belt cover
  24. Fiesta Mk3 Rear Tail Lights Wanted - Pair
  25. WANTED: cossie 4x4 bigtooth box or equivalent
  26. WTD: Granada / Sierra Trailing Arms and Anti-Roll bar.
  27. 4x4 saph power steering tank cap
  28. Escort mk5 Tailgate wanted
  29. WTD mk2 Focus petrol
  30. 195 40 16 tyres x4
  31. 2wd saph ambers wanted
  32. s1 rs turbo bumpers
  33. WANTED: Gear lever to linkage pin (4x4) urgent!
  34. poly rear diff mount
  35. escos parts, wing etc
  36. 3.5 / 4inch mongoose
  37. Cosworth engine wanted
  38. WTD: 4x4 Cossy Rear Bearing Carriers
  39. Electric Oil Pressure gauge wanted
  40. Black leather corner sofa
  41. WANTED: Standard 2WD turbo heatshield
  42. 3dr Tailgate. 500 lower spoiler perhaps
  43. WANTED : 1 x 17" Raceline RL7
  44. Fiesta mk3 roll cage wanted
  45. xr3
  46. Cosworth rear AP brake set up
  47. help needed in the north east area sunroof blew out of my sierra cosworth saph
  48. T3 Turbo
  49. Wanted - MT75 gearstick and knob
  50. Cosworth YB head
  51. 2wd exhaust an bailey header tank
  52. Plated 7.5" Diff (may consider ATB)
  53. early zetec injector/sensor loom
  54. Escort Cosworth Engine loom and L8 ECU.
  55. WTD: Cosworth 4x4 coolant water swirl pot...
  56. Masitaly Centre Cap
  57. Cossie 2wd Oil Pump
  58. Zetec Turbo Parts needed
  59. coilovers for a 2wd sierra saph
  60. Wanted: Sapphire shell (cheap as chips)...... or good floor panels
  61. Rs turbo cam and lifters
  62. Clear glass front windows for rst.....
  63. Mercury Grey 90spec front bumper wanted
  64. WANTED Vibra Technics Gearbox mount MT75
  65. 3 x 52mm gauges wanted
  66. 3dr sierra/ cossie rep??
  67. sorted please delete
  68. Gt30/71r wanted
  69. Escort Cosworth Amal Valve
  70. coil pack brkt/fuel filter brkt
  71. Fiesta RS1800 inlet wanted
  72. Esort Cosworth Parts, adjustable rear beam
  73. Small Turbo Cossie Head Gasket
  74. A Pillar boost gauge mount. MK3 escort
  75. cosworth 4X4 coilovers.
  76. Wrc rear cradle/complete set up
  77. Mk6 gti radiator, bumper etc
  78. ap 6 pots
  79. escort cosworth rear propshaft
  80. 044 fuel pump wanted
  81. 2wd Crank Pulley
  82. Tsw hockenheim
  83. focus mk1 Rs discs pads and calipers
  84. S2/MK4 escort rubber seals wanted
  85. 80spen non sunroof - roof lining
  86. Cosworth back box
  87. Wanted: 2wd sapphire front hub, side irrelevant
  88. Mk1 or MK2 Escort - 4door
  89. 2 wheel drive front brakes
  90. 3dr Cosworth Caged shell Race or Rally
  91. Genuine Amber Front Indicators (Sapph)
  92. Sapphire mint carpet wanted
  93. escort rs turbo s2 90spec fusebox an loom
  94. Two bucket seats CHEAP for off roader
  95. 4x4 power steering cap
  96. RS turbo fuel pump cradle/bracket
  97. digital micrometer wanted
  98. stainless exhaust box 3 inch bore.?
  99. Need original Rubber over mats
  100. New/mint saff scuttle panel
  101. cosworth parts
  102. sorted cheers peeps
  103. WANTED GPA front driveshafts
  104. Sapphire cosworth Sunroof
  105. 2wd Saph cossie wheels
  106. Sierra / Escort Cosworth drivers side front indicator
  107. Wanted wrc grp a billet track control arm
  108. 15"x7 comps et15
  109. wanted sport ka rear bumper
  110. Saph parts wanted ,Amber's , original headlights
  111. 7.5 cosworth diff
  112. Help parts needed
  113. wanted wrc rear spoiler
  114. Sapphire COSWORTH WANTED!!
  115. Escort mk5 roof or skin without sunroof and tailgate
  116. not needed
  117. escort mk2 2 door wanted may do a deal for my cossy
  118. wanted fiesta rs turbo ofac amal valve
  119. WTD:Sapphire Cosworth 4x4 rolling shell
  120. Escort Rs Turbo front Konis or Avo's
  121. looking for a Bailey Mirror image breather tank ....
  122. 3 bar map sensor wanted
  123. cosworth gaskets and shells
  124. 3dr wanted
  125. 88spec roof lining XR3i/RS Turbo
  126. Cars and Car Conversions Magazine - June 1996 Issue
  127. fiesta mk5 zetec s parts
  128. Wanted mrk 1 focus Rs side skirts
  129. Cambelt cover bolts needed
  130. Wanted Area Six zetec turbo inlet manifold
  131. sierra cosworth wanted
  132. rs turbo t3 4psi actuator
  133. Standard Ford CD Player - Single DIN
  134. mk3 escort shell
  135. 4x4 front discs
  136. charge air temp gauge wanted..
  137. 2wd rad hose in blue wanted..
  138. 3 door Cosworth parts wanted
  139. sierra 3 door windscreen wanted
  140. (stockport or Manchester Area) Sierra Cosworth 4x4 Bottom Radiator Hose
  141. genuine driverside heated mirror glass
  142. Cossie Alt Heat Sheild
  143. Wanted - Cosworth PAS pump
  144. Escort cossie shell wanted
  145. Vernier pulley + cam for pinto sierra
  146. 4x4 Cosworth fuel pressure reg required
  147. Escort RS Turbo S2 MFI Fuel Pipes
  148. Cam
  149. Mk4 escort rear inner arches
  150. XR2i wanted
  151. Series 1 carello h4 headlights
  152. Plenum for cosworth yb
  153. mk4 escort roof panel-anyone scrapping theirs
  154. sapphire cosworth cloth interior wanted
  155. mk 5/6 escort coilpack bracket
  156. Wanted front bumper
  157. Cosworth/sierra seat runners
  158. RS1600i Interior/ Seats
  159. WTD: Granada / 4x4 Cosworth Complete Rear Beam
  160. smart phone wamted
  161. Pump cradle and pipe work
  162. Side exit exhaust
  163. sorted thanks
  164. 2WD Saff AP Racing 4 pot 330mm brake kit
  165. WTD: 3 Door Cosworth Bumper Brackets - Part Number?
  166. 2wd Front Anti Roll bar clamps
  167. Sierra rear calipers for atlas axle
  168. parts wanted
  169. S2 efi inlet to mfi head adaptor plate
  170. mk4 escort estate rs turbo
  171. T34.48 exhaust houseing
  172. 2wd cosworth abs sensor & pas pump
  173. WTD: Sierra Door Hinge Pin
  174. Cosworth Slimline fans needed
  175. s2 ambers
  176. 2wd Rear brake compensator
  177. 3dr front arch liners
  178. 3dr front amber indicators
  179. Escort Mk5 Xr3i Wiring Loom Or Similar to suit Zetec Turbo
  180. wheel nuts
  181. Saph Amber indicators
  182. Hybrid/uprated turbo for my s2
  183. Saff cloth rear seats
  184. Mk 1 Focus RS WANTED!!
  185. Mondeo auto dimming rear mirror wiring
  186. Wanted GpA tarmac Rear Axle Complete
  187. non cracked cossie .48 exhaust housing wanted cash waiting.
  188. mk1 focus rs
  189. pair of cosworth driveshafts,
  190. 3 door interior
  191. Leather/ cloth arm rest
  192. up rated clutch for an escos bt
  193. Wanted s2 radiator
  194. Mk 3-4 escort sunroof apature wanted
  195. rolling saff shell
  196. S2 rear lights
  197. Coopers ring gasket
  198. Mk1 sierra xr4x4 wanted
  199. 2wd p/s rack
  200. *WANTED* S1 RST Interior + more
  201. Saff mirror image breather/catch tank
  202. Focus RS disc's
  203. Late Scorpio 4.27:1 ratio diff
  204. 909/group a door mirrors for my saff
  205. *WANTED* 3door windscreen-4x4 steering rack
  206. S2 rs turbo steering boss
  207. WANTED-front 4x4 sapphire cosworth suspension-hubs-tcas
  208. Seat runners for mk5 escort
  209. Compomotive MO's
  210. Sierra Cosworth 2wd gear knob
  211. 2wd steering rack
  212. MK4 escort fuel filler neck panel
  213. Wanted big spec rwd sapphire or 3dr
  214. saff cossie rear bumper crystal blue
  215. 185-60-14 track tyres.
  216. escos 3 door smoked indicator lenses
  217. Cossie 4x4 cam belt cover fixings
  218. Mk1 Focus rs wanted
  219. Focus MK1 rear spoiler
  220. Wanted Fiesta RS turbo steering wheel
  221. sorted cheers
  222. Rs turbo front bumper
  223. xr2 bits.
  224. 2.0 zetec block
  225. saff cosorth shell
  226. dump valve and fitting kit
  227. sierra quick rack steering rack
  228. GRS Front Mount Intercooler
  229. Wanted 3 door or 500 fiberglass rear spoiler
  230. alternator for 2.3 galaxy
  231. rs turbo/engine
  232. cosworth sapphire front tow cover
  233. Samsung Galaxy S Phone
  234. 2wd Saph Cossie Used Front Koni and lowering springs
  235. Sierra Ghia GLS Cossy loom
  236. Turbo to intercooler hose
  237. wanted: rs2000 mk5 or mk6?
  238. Wanted carbon fibre door cards
  239. 2wd oil modine + 4x4 front diff driveshaft circlip
  240. Small turbo escort Cosworth icv
  241. cossy 2wd front subframe
  242. blacktop zetec aux belt tensioner
  243. WANTED Magenta Saph bonnet
  244. Series 2 ERST Flocked Dash Wanted
  245. s1 rs turbo wanted
  246. rs turbo intercooler
  247. Compomotive Flat Spoke
  248. english 3.77 diff
  249. STD 2wd saph exhaust system
  250. series 2 wheels
