PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Please delete
  2. Broken cossie 4x4 gearbox
  3. Wanted - AFR Wideband
  4. Mk2 fiesta/ xr2
  5. Low pressure fuel pump
  6. Rear beam bushes
  7. Xr3 Turbo parts wanted
  8. 2wd Rear Driveshafts wanted
  9. xr3i efi loom
  10. 2wd saph turbo heatshield inner wing fixing
  11. Wanted 1 x sharktooth alloy
  12. 2wd Cosworth steering rack wanted
  13. 2wd stainless exhaust needed asap!!!!
  14. RS500 upper and lower rear spoilers
  15. mk4 escort ghia loom
  16. bucket seats
  17. Exhaust manifold and down pipe asap
  18. cvh efi flywheel and rs2000 alloys
  19. Focus RS Mk1 Front Arch Liners
  20. Sierra, saff rolling shell
  21. Any Early MK5 Escort grill in radiant red
  22. aubergine fiesta si
  23. saff under carpet sound deadening/drivers door card 2wd early
  24. chrome lifting eyes and turbo damper for cosworth
  25. 3dr cosworth wheels
  26. 88 spec rst interior wanted
  27. escort cosworth centre caps
  28. Escort Cossie Shell wanted
  29. S2 bailey header tank
  30. 2wd saph cossie front caliper bolts! NOW SORTED
  31. T34 turbo needed..
  32. Mrk 1 Focus Rs gt28 turbo wanted!!!
  33. **WANTED** Oil Separator tank
  34. Standard 3dr Gearbox & Diff mounts
  35. 7.5" 2wd diff wanted/needed!
  36. Rs turbo conrod
  37. Series 1 Fuel Sender
  38. 24v boa engine loom
  39. Big brakes.
  40. 3 door cossie standard 4 pot calipers
  41. Saph Cossie 4X4 bonnet vents
  42. S2 rear coilovers
  43. 7" 3.62 LSD Cosworth
  44. wanted black boost hose
  45. sierra 3dr cosworth bucket seats and cage
  46. anyone got a mk3 escort 2door estate for sale?
  47. Escos bt air box
  48. Cosworth cam cover with screw oil cap
  49. Solid beam mounts
  50. rear caliper ecos 4x4
  51. 909 Air injectors and Isky Valve Springs.
  52. Wanted - 88 Spec RS Turbo/XR3i clocks,
  53. 3dr Turbo to header tank pipe clips
  54. escos exhaust
  55. Split rim inner 6 1/2" 30 hole 16"
  56. Cossie 4x4 plenum, fuel rail and regulator wanted
  57. Cosworth yb vernier pulleys wanted black or blue
  58. S1 Chargecooler/Intercooler
  59. Windows 7 disc??
  60. escort rear lights
  61. Cosworth Workshop Manuals
  62. 3dr cosworth gearbox mount
  63. Wanted escort mk3 sunroof
  64. Standard cosworth rocker
  65. Sierra 2wd power steering pipes!
  66. rst bits... rs2000 inlet for bodies, cams
  67. Car trailer
  68. 4x4 hoses
  69. sapph cosworth pillar pod
  70. delete, got some steel wheels now
  71. MFI RS Turbo Bottom End Wanted
  72. 3dr Bulkhead sound deadening mat WANTED
  73. wanted mk 3 or 4 shell/car 3 door
  74. TCA Clamp bolts
  75. 88 Rs turbo rear spoiler caps
  76. Cosworths wanted ( cash payments )
  77. Mondeo driveshaft bearing mounting bracket
  78. Escos rad fans with wiring plugs uncut
  79. MT75 Gearbox Wanted
  80. cosworth 4x4 opligger gearbox
  81. Rl7s 17 or 18
  82. 2wd drive shaft flanges
  83. Escos fuel sender
  84. Escos parts wanted
  85. few s2 bits
  86. 3door cosworth door cards
  87. Sport/Street Ka fuel injector
  88. Drivers rear quarter glass trim for 3dr WANTED
  89. 2wd Drivers stub axle WANTED
  90. RS2000 4x4 rear suspension caddle
  91. Fiesta mk4
  92. carbon cambelt cover
  93. 2wd standard gear knob
  94. mk2 mondeo v6 powersteering pipe
  95. Ofab map sensor
  96. mk3 escort 5 speed non lsd box wanted
  97. 3dr mk4 escort
  98. Wanted ASAP mint sapphire 4x4 cos radiator
  99. fiesta turbo exhaust
  100. Ford Focus MK1 MTX-75 Gear Cables (Possibly Mondeo MK2?)
  101. mk1 focus 3 door moondust silver door strips and side skirts
  102. Gt30 wanted
  103. Cossie 2wd tps & icv (got them now)
  104. 3dr cage and fibreglass kit Wanted
  105. Escort cosworth rear bumper decal
  106. saph ambers
  107. Wanted s2 rs turbo engine
  108. WANTED - ST170 front bumper in panther black or primer
  109. Wanted: Lattice alloys etc
  110. Cosworth fuel rail
  111. Fiesta rs turbo map sensor
  112. Pug 205 GTi upgrade bits - wheels / shocks / suspension stuff ...
  113. MINT 4x4 cosworth front bumper
  114. WANTED: Sapphire Cosworth bumper brackets
  115. Sapphire rear ambers
  116. Escort rst clutch fork.
  117. Escort RST or Mk4 Escort/Mk1/2/3 Fiesta Uprated Gearbox mounts
  118. Saff grill and door mirrors
  119. fiesta mk3 roll cage
  120. saff cosworth wanted
  121. Cosworth Private plate wanted
  122. 2wd O/S rear caliper
  123. rs turbo ap clutch, mk5 pedal and quadrant
  124. fiesta rs turbo coilovers for front wanted
  125. Wanted - Pectel t2
  126. urgently wanted saph exhaust brackets
  127. Wanted - mk6 fiesta zetec s/ fiesta st front bumper in black
  128. T28 wanted
  129. fiesta rs turbo front lowering springs
  130. Sierra cosworth splitter
  131. Sapphire Cosworth wing moulding
  132. Escort/sierra cosworth 4x4 rear calipers
  133. 2wd grey dash and centre console
  134. 4wd Cossie rear brake set up & Rear disc guards/sheilds
  135. Rs turbo brake compensators
  136. Sapphire Cosworth carpet
  137. Cosworth 2wd T5 Gearbox needed
  138. WANTED : mk1 Rs front seats
  139. Pectel board for l6
  140. Rs push button horn
  141. Escort RS turbo lower boost hose and turbo oil drain hose
  142. Pectal board for L8 wanted
  143. T34. .63
  144. cosworth manifold bolts
  145. Genuine s2 rear amber lights.
  146. 2wd cosworth lattice wheels
  147. Alloy wheels wanted
  148. Focus rs mk1 alloys
  149. Escort rs turbo s1 for sale
  150. S2 90 spec front bumper & rear spoiler
  151. Saff Rear Amber Lights Required.
  152. YB Valve Collets and Circlips
  153. 2wd rear beam and arms and 3" down pipe
  154. Standard focus Rs brakes
  155. B&M ShortShift for Escort RS Turbo
  156. ST170 front hubs
  157. oversized cosworth pistons
  158. 2wd cosworth
  159. Various saff bits wanted
  160. Ford amplifier
  161. MINT Sapphire 4x4 black carpet
  162. 4x4 sapphire engine loom
  163. RS500 Fuel Pressure Regulator
  164. 2wd cosworth gearknob
  165. Engine lifting eyes for a cossie
  166. Granada 24v cosworth (BOA) ECU
  167. Team Dynamics Pro Race - 17"
  168. Sierra Base car loom
  169. 2.0 focus gear linkage
  170. Delete please
  171. OZ SUPERTURISMO 17"x7", ET48 Ford fitment 4 stud...
  172. Wanted... sierra 3.77 diff
  173. Has anyone got one of these old Sony Graphic equalizers lying about?
  174. XR4i/XR4x4/granada engine arms
  175. 2WD Sapphire cosworth rolling shell
  176. 3dr lower spoiler
  177. 17" Rondells or RL7's Wanted
  178. Various Cossie engine parts...
  179. 4x4 cos exhaust manifold
  180. RS1600i Mk3 Escort front anti roll bar
  181. SWB Transit
  182. Mondeo Mk2 Tailgate
  183. Escort cosworth reverse switch mt75
  184. 4x4 rear callipers wanted please with carriers
  185. Escort Cosworth Lower Dash Panel
  186. Sapph Cosworth Rainbow Cloth
  187. 7.5" diff bolts
  188. Anyone selling a spit/rollover jig?
  189. Wanted Fiesta mk5 Ghia or Freestyle
  190. 2wd sapphire wanted
  191. Wanted EsCos T28
  192. L8 ecu wanted
  193. Boost controller
  194. Recaro seat plastic cover
  195. Saphire lock set
  196. 3 dr cossie c/locking door solonoid
  197. cvh efi flywheel wanted
  198. S2 90 spec front bumper..
  199. Cossie ISCV clamping ring
  200. mk 2 fiesta o/s door
  201. sapphire 2wd cosworth wanted
  202. Ford sierra rubber mats
  203. Xr4i seats or cloth
  204. Xr8 ronal 15" wheels
  205. (another) new car required
  206. Fiesta ST Engine
  207. 3.9 supra diff
  208. Fiesta mk3.5 seat sub frames
  209. MK5 Zetec S
  210. Ofac Chip Wanted!!!
  211. passenger front saph leather door card
  212. 3 door door card
  213. Anybody got a rolled tip back box?
  214. Escort Cosworth Front ABS sensors
  215. pro alloy 500 cooler
  216. very late saph a piller trims
  217. crank pulley
  218. Sierra Saph 2wd bonnet and orange lights
  219. Cosworth 4x4 L8 ecu
  220. xr4 stainless exhaust
  221. S2 mongoose backbox
  222. Found..
  223. stranded yb pistons and rods
  224. S2 Chrome fuse box and wiper motor cover
  225. Genuine ford later (mk4) cvh oil pump WANTED
  226. S1 crank required
  227. Escos front brake setup wanted
  228. WANTED 4x4 Cossie front hubs
  229. Twin pillar pod
  230. MK1 Focus RS drivers seat
  231. wheel tracking turnplates
  232. ..
  233. MK4 xr3i EFI LOOM ***WANTED***
  234. donor or resto cossy 4x4 wanted
  235. S1 skirts and arches
  236. Adjustable fuel pressure reg. Sard, Aeromotive, Turbosmart, Fuelab W.H.Y
  237. 3dr Cosworth TCA's
  238. 3dr hubs, escos rear arb..
  239. **WANTED** MK4 XR3i EFI Full Wiring loom!
  240. S2 90 spec trim and lock set
  241. Wanted: sharktooth alloys
  242. Escort cosworth wanted
  243. Sierra/Granada 2.8/2.9 v6 gearbox sandwich plate!!
  244. 9in rear diff 3.62 and R&D front diff to suit
  245. MK Motorsport Billet Throttle Body
  246. Escort cosworth replica wanted!
  247. Pair of 2wd 108mm stub shaft
  248. YB 3 bolt exhaust downpipe flange
  249. Michelin pilot tyres wanted
  250. Sierra sapphire cosworth 2wd lights
