PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. FRST oil returns/feeds wanted
  2. 2wd(71/2") adjustable beam
  3. Exhaust Centre Section
  4. Nearside rear suspension arm
  5. White S2 RS Turbo
  6. Twin air injector short loom.
  7. Escort Cosworth (big turbo)
  8. mk6 escort front bumper wine red
  9. HI AFTER S2 LOWERING SPRINGS AT LEAST 40ML
  10. Anybody Seen This Mk5 Turbo?? Pix Inside - Please Look
  11. Cosworth crank
  12. mk4 front splitter
  13. sierra cosworth or vectra gsi or subaru impreza wrx or turbo
  14. ford escort 1.8 zetec ECU
  15. Desperate
  16. Sapphire 4x4 Starter Motor - Urgent - Liverpool area
  17. Red Ford Emblems
  18. 4x4 saph cosworth HT/coil leads
  19. a bucket seat...pref recaro :)
  20. Escort Cos Front bumper Mounting Bars....
  21. Fiesta MK3 Parts
  22. WANTED: Fuel pump mounting cradle for S2 RST/XR3i
  23. recaros
  24. WANTED COSWORTH 4X4 MANIFOLD
  25. Any one have turbo timer for RS Turbo
  26. WANTED ESCORT RS TURBO S1 LOWERING SUSPENSION KIT
  27. idle speed controll valve wanted
  28. LEVEL 8 ECU COMPLETE WANTED
  29. s1 cold air charge temp sensor plug
  30. HELP.......WANTED.......Turbo Diesel Fuel Pump
  31. wanted both cams for 1.6 escort zetec 1998
  32. race steering wheel
  33. Steering wheel
  34. 4x4 cosworth idle speed control valve
  35. S2 RS Turbo fuel accumulator
  36. rs500 throttle body
  37. Cossy bits needed ASAP
  38. s2 rst gearbox
  39. cos private plate wanted!
  40. Power Steering stuff
  41. mk5 escort engine loom (cvh efi to run zetec turbo)
  42. good spec cvh or zetec turbo/focus rs engine
  43. Wanted Urgently! Small Turbo Escos ECU. (COSY)
  44. RS 1600i Interior
  45. series1 air charge temp plug
  46. escort parts
  47. Good 205 Block Pref 0.5 Bore and ready to build up
  48. escort mk4 60mm springs...
  49. Ofab EFI parts
  50. Sapphire sunroof wanted
  51. WANTED REAR KONI SHOCKS AND LOWERING SRINGS
  52. Escort Cosworth wireing loom
  53. cossie 2wd hoses and swirlpot
  54. Sierra Cosworth 2WD Wanted
  55. xr4x4 rear calipers
  56. Any one got S2 rear mudflaps?
  57. Sierra RS Cylinder Head
  58. Escort Cosworth uprated fuel pump
  59. Concours Series 1/Series 2
  60. Rear Bumper Cosworth
  61. Sierra CVH Rocker Cover
  62. WANTED FOCUS RS PERFORMANCE CHIP DS OR BF
  63. chip and board
  64. big spec 3 door wanted
  65. xr3i rear door cards + mk4 escort manual mirrors
  66. 3dr cosworth front drivers arch & 52mm black oil pressur
  67. 2wd saff front tow eye cover and steering wheel can be 4be 1
  68. ABS hub sensors, 2wd front subframe, 3dr window switchs
  69. coilovers anyone?? (4wd saff cossie)
  70. Mk1 Escort Hazzard Switch
  71. wanted escort combi/estate interior and roof lining
  72. granada rear calipers
  73. puma racing gearbox
  74. Sump,oil pick up and Saph cos vents
  75. Series 2 Escort RS Turbo wanted
  76. Cosworth Crank shaft wanted
  77. WANTED vag gearbox with the code DLP
  78. mk3 xr3i/ rs turbo elec window switches req'd
  79. 16" alloys wanted
  80. 4wd t34 turbo and manifold wanted??
  81. fuel sender unit
  82. 1.4 or 1.6cvh engine or even cheap car wanted....
  83. 3 DOOR COSSIE
  84. 3dr cossie grill wanted
  85. efi flywheel wanted, from an xr2i xr3i frst........
  86. Scuttle panel, 3 door
  87. Stage 3 CVH Head & Cam
  88. saff cossy boot spoiler
  89. Wolfrace Voodoo 2 wheels wanted
  90. Mondeo ST Tdci or Zetec S Tdci
  91. Mondeo Zetec alloy's
  92. magenta cosworth wanted must be 4x4
  93. 4x4 ecu cage
  94. Ford cd Changer and Cable
  95. o2 xda/i-mate kjam
  96. A.C.T Guage wanted
  97. Escort cosworth steering wheel
  98. ST200 hatch / estate
  99. piston rings
  100. escort lowering springs mk4, rears only
  101. Chipped ECU for RS Turbo S2
  102. bottom en for a erst
  103. granada 4x4 5 stud hubs
  104. mk4 escort xr3i aftermarket exhaust
  105. damaged cossie or s1 wanted
  106. Set of alloys to fit s2 escort rs turbo (17")
  107. 0.48 cossie exhaust housing needed, Crack Free
  108. wanted T4
  109. escort xr3i efi car loom and a 195bhp ofac chip
  110. alloys wanted looking to part ex.....
  111. escort cosworth interior plastic trim wanted
  112. 1988 Sapphire Cosworth Wanted
  113. wanted - ofab ecu with loom and sensors plus 195 chip
  114. Big Turbo Escort Cosworth Air Box
  115. Want a 1.8blacktop sump?????and
  116. escort van swap for 2.0 16v nova.
  117. 18" five stud mondeo alloys
  118. Silver Top Engine
  119. Escort MK3 XR3 Interior
  120. 4x4 cosworth water pump ASAP!
  121. mk6 escort cabby rear bumper (radiant red)
  122. WANTED ESCORT S1 RS SCUTTLE PANEL
  123. sapphire sideskirts
  124. Intercooler to a Fiesta rs turbo
  125. Sierra Sapphire Cosworth or Trade
  126. metering unit
  127. track day bits mk4 escort
  128. Wanted Old 4x4, (suzuki, Daihatsu, Etc)
  129. 2wd cosworth turbo heat shield wanted
  130. Mk3 Fiesta Tailgate
  131. Sapphire 4x4 front shaft
  132. wrc mirrors for escos
  133. saph steering cowling
  134. looking for rst s2 90 spec rear spoiler
  135. Sierra 3 dr front drivers arch and black 52mm oil pressure g
  136. wanted front sapphire towing eye cover and a lattice centre
  137. mk4 escort loom
  138. drivers side lower dash for sapph
  139. Rs500 Lower rear spoiler
  140. escos monte alloys
  141. steering parts new needed for my cosworth
  142. wanted escort cosworth moretts
  143. Wanted erst s2 fuel computer wire loom.
  144. Damaged Sierra 4x4 Bonnet.....
  145. CVH Anti-Pump Lifters / Followers / Tappets.
  146. rs 7 17" diamond cuts wanted
  147. Zetec turbo engine wanted...
  148. Ka airflow meter
  149. mk 3 dash
  150. 2wd Sandwich plate (Gearbox)
  151. Escort Cosworth knock sensor
  152. good semi / restored ERST shell wanted
  153. Ford Fiesta mk3 Passenger Side 3dr Electric Window Assembly
  154. ST200 bumper and tailgate
  155. mk3 vented bonnet
  156. 2WD Saph Cossie Wanted!!
  157. erst recaro headrests?
  158. frst
  159. 1300 X-flow oil pump for a mk4 escort?
  160. RS Turbo Loom
  161. escort cosworth ecu
  162. Airbox lid...
  163. Interior bits / tailgate / s wheel Erst s2
  164. XR2 MK1 part wanted
  165. 3bar map sensor
  166. moonstone 3dr cosworth
  167. chip
  168. Wanted Genuine Mint 3Dr Cosworth HT Leads
  169. .63 exhaust housin for t3 turbo
  170. Series 2 Shell
  171. rs500 front bumper
  172. cosworth rocker cover
  173. 3-door doors
  174. 3-door sunroof
  175. 17 BY 7J TSW EVO R WANTED FOR S2
  176. escort rst t3 bottom intercooler hose
  177. fiesta rs turbo car mats
  178. Sapphire Cosworth 92-93 parts
  179. EFi CVH Head or MFi/EFi adaptor plate
  180. SAPPHIRE BITS PLEASE LOOK
  181. Black 52mm oil pressure gauge
  182. 3dr bodykit front drivers side arch
  183. Please delete
  184. mk3/series 1 turbo bits
  185. 17" rs 7 alloys
  186. WANTED FORD SIERRA RS COSWORTH (1986 /1987 CASH WAITING
  187. 2wd saph cossie alternator
  188. White 3dr Escort GTi or poss RS2000
  189. Mk 4 escort EFI wiring loom.
  190. wanted 17by7j for s2
  191. Cosworth front engine cover wanted
  192. RS 500 parts wanted
  193. pair off mint grey saph 2wd coz seats
  194. Towing Eye Cover
  195. MK2 Ford Mondeo Zetec-S
  196. WANTED Sierra Cosworth 4x4 parts
  197. 2wd rubber engine mounts wanted
  198. Cosworth crank wanted
  199. 2wd cosworth sump wanted
  200. mint red mk3.5, 1.1/1.3 etc
  201. **wanted mk2 xr2**
  202. Cossie t3 turbo
  203. mk4 escort rear cage in any condition (paint wise)
  204. wanted: s1 or s2 RST ,rs1600i - cash or px for impreza
  205. S2 white 90 spec tailgate, parcel shelf, boot carpet,WYORKS
  206. WANTED 2WD CHIP Stage 3
  207. escort 1.4cvh wiring loom & escort mk4 efi header tank
  208. Grp A cosworth air filter
  209. escort cosworth gear box wanted
  210. anyone who can produce vynil stickers
  211. silicone hoses
  212. sierra saff lock set
  213. saff exhaust bumper heat shield
  214. erst s2 bare block near to HULL
  215. mk 5/6 escort bumper with fog lamps
  216. WANTED 2WD BIG BRAKES 330MM TO GO UNDER 17'S
  217. vr6 splitter?
  218. cosworth engine
  219. series one front seats
  220. series 1
  221. mk5 rs2000 wanted or possibly mk5 xr3i
  222. escort rst wanted
  223. Series 1 arches
  224. saph backbox...cheap alloys..
  225. Series 2 diognostic/tuning software
  226. t3 turbo
  227. help
  228. Fiesta 2000 zetec s interior
  229. OT: lost series 3 dvds
  230. Wanted, sierra 3dr cosworth L1 stage 1 chip 280bhp
  231. 3 door cossie bits wanted
  232. Escort MK3/4 Roll cage
  233. escort xr3i mk3
  234. WANTED : Escort RST S2 rear anti roll bar
  235. abs sensors
  236. escort van
  237. steering cowlings (all cars)
  238. Escort Cosworth Lamba Sensor? (3 pin type)
  239. Non ABS FRST brake fluid reservoir
  240. Mk6 Fiesta 5 spoke alloy wanted
  241. FRST WANTED 1900 CVH.
  242. WANTED saff 4x4 cossie parts
  243. standard 2wd cossie map sensor
  244. saph 2wd rear calipers and sliders
  245. Saph 4x4 cossy fuel tank
  246. Two 15inch alloys, with or without tyres
  247. saff cossie rear bumper wanted in white and 4 doors in white
  248. RS Turbo Series 1 passenger side front arch.....
  249. DISTRIBUTOR wanted
  250. Please delete.
