View Full Version : Cars & Parts Wanted.
- Dummy
- ST170 285 cams.
- esc cos sound deadening
- 2 x Sharktooths plus 4 centre caps
- 7.5" scrap diff or just the diff carrier and vc
- Wanted: Standard 2wd Saph Cosworth splitter
- 200 block engine & L8 ECU
- Cosworth 4x4 standard brakes
- T35 turbo coolant pipes
- Sierra 3 door shell wanted
- Bailey or forge dump valve
- Wanted 4X4 exhaust cam
- Cromodora wheels and Compomotive wheels
- Now sorted
- Smoked aric rear lights Rs turbo
- WANTED: 17" Compomotive TH Alloys for a Saph Cosoworth...
- Parts required to finish off my sapphire resto
- WANTED: Genuine Saph Amber Indicators
- Wanted sapph stainless exhaust
- Wanted 18" comp mo 6 alloys for sapph, et35
- 3 Door Window Rubbers
- 2wd sierra cosworth NON vented bonnet or a pre 1990 sapphire bonnet
- AFR digital wideband kit
- 4x4 sapp/esc flywheel wanted
- wanted escort cosworth small turbo oil pick up pipe.
- Ecos fibreglass pannels
- Decent Rs Turbo complete meteing unit wanted and 90 spec spoiler
- Wanted Oil breather seperator
- Sapphire drivers side headlight wiper arm
- T38
- p8 pectel baby board
- Escort Cosworth Morettes
- Now sorted
- Shifter and boot
- Double din headunit
- Escort cosworth BT knock sensor
- Mk1 escort door
- Sierra PAS bottle
- focus rs mk1 bonnet
- L8 ecru and throttle position sensor
- WANTED T5 front bearing cover
- 3 door sierra intercooler deflecter plate
- MK4 Escort bits and pieces (clips etc)
- St170 full leather recaros wanted
- Wanted T34 Turbo Compressor Housing
- Wanted Ford Capri steering wheel
- need one part off sierra abs unit
- Now sorted
- Sapp steering column shroud
- sierra rwd mt75 propshaft wanted
- cosworth 4wd engine
- Yb 200 block main caps
- Cosworth Sharktooths
- Mk1 focus RS
- WANTED Cossie 4x4 or XR4x4 Coilovers
- s2 escort rs turbo rear anti roll bar
- Escort cosworth rear Prop & other escort parts
- Large turbo escort cossie fuel rail
- Escort Mk4 1.3 hcs alternator
- Escort Cosworth Hose
- Compomotive 18x9 et15
- Sierra 3dr bumper chin rubber
- Wanted Imperial Blue Big Turbo Escort Cosworth
- Good YB Crank
- Yb 4wd head..ported
- Sierra Sapphire 2.0
- Mods please delete
- RS Turbo rear hub's and flanges req'd
- Escort Cosworth Alloys
- Mk4 escort A post weather strips
- 3 door glass.
- C-Max rear caliper carriers
- Sierra 2wd Cosworth front brakes, discs, pads
- 3Door Bosworth wheel arches. Urgent!
- Mk4 Escort HFS Switch
- Zetec turbo inlet manifold
- Escos Spec r intercooler
- MK1 FRS Gearbox
- 2.0 Zetec blacktop head wanted!
- Mk3 Fiesta shell wanted
- Wanted
- Wanted 1x 8x17 th1781
- Series 2 sideskirt fitting strips
- Please delete
- Boa engine loom wanted
- Series1 cold start wanted
- Sierra Cosworth Gearbox Bolts **Wanted**
- WANTED: Cheap sapphire, almost any model considered
- Compomotive wheels wanted 18" 4x4 saph (TH, not MO)
- Saph cossie front bumper wanted
- RL7"s 18" wanted
- Wanted,2wd sierra front hub grease cap
- MK1 FRS Fuel rail and injectors
- 4x4 cosworth head wanted
- p8 baby board wanted
- 3dr cosworth door cards
- Wanted series 1 rs turbo
- Mk1 focus rs wanted!!!
- ST Escort Cosworth parts.
- Wanted - 38mm external wastegate
- Late model 4x4 parts interior required
- Anyone selling spot lamps
- cosworth p8 ecu
- crankshaft wanted
- cosworth /pinto main bearing caps
- Focus US rear lights
- mk1 fiesta xr2 parts wanted
- 1.7 Puma Sump Pan
- Sapph cosworth window switches
- Totally Standard Low Miles Mk1 Focus RS
- 4x4 saff cos gear selector
- S2 heated screen wanted
- good S2 tailgate wanted
- Ford sierra cosworth parts
- Dizzy cap asap as local as poss to sw15
- Mondeo mk4 sports body kit
- fiesta rs turbo fuel pressure regulator*got one now*
- Wanted door cards
- Sapph Cosworth rear beam pref 2wd
- Good 2wd saph heatshield wanted
- 83lb injectors
- O/s rear chassis leg
- WANTED: Saph cosworth (as cheap as possible)
- Wanted please
- BT Imperial Blue Escos
- Wanted
- ST170 engine- Low miles!
- Wanted - english diff 3.89 or 4.1 ratio
- Wanted - 3DR hubs.
- s2 spot lamp brackets
- Collins monitor
- quaife front diff
- Wanted: Compomotive TH2 in 18"
- Wanted 2wd cosworth shafts/stub ends/bolts
- Cosworth yb head, block and turbo
- S2 Rs turbo smoked rear lights
- 3 door , door strips ( mouldings) protectors
- 2wd Saph Drivers side rear light?
- Saff 4x4 top hose
- 3dr boot carpet handle
- Sapphire column plastic shroud
- -8 overbraided rubber hose, 1meter
- Escort Estate
- 3 Bar map sensor
- hubcentric wheel spacers focus st225/mk2 rs fitment
- 2WD Oil pick up
- Rs turbo reverse charge carrier/cross over pipe
- 2WD rear brake disc dust shields
- cossie 4x4 power steering
- Escort mk3/4 sleeper wanted
- Philloy single bar strut brace
- escort mk 6/7 3 door opening rear q lights windows
- L6 chip for Siemens 55lb injectors
- WANTED
- Wanted: Cossie 2wd cylinder head
- 4x4 cosworth brake servo unit
- 1.6/1.8 zetec silvertop oil pump
- Wanted
- Escort Cosworth for project
- Black ecu cover
- Sierra cosworth parts,rear spring pad,bump stop and genuine track control arms needed
- Saff cos mt75
- Wanted ECU and loom
- Heat shield for sapphire cosworth
- S2 Escort Rs Turbo Drivers door window (green) will collect
- need these bolts urgently cosworth rear diff mount
- Wanted - light blue or grey injectors
- ka rollcage
- Fast ford magazine May 2011
- Track car/race harnesses
- Series 2 rs turbo loom
- Mk1 focus rs rear spoiler wanted!
- 2wd cosworth manifold and spacer & K&N filter and silicone elbow for GT3071
- Rs turbo bonnet & tailgate mk4
- Sierra bolt in cage wanted
- Ford 9006 stereo
- RS500 lower rear spoiler
- Wanted: mk1 focus rs grill
- Saff 4x4 bonnet
- wanted escort rs turbo fuel tank sender
- Wanted ASAP
- Late 4x4 front fog light switch, gear stick surround
- 3dr cosworth
- Cosworth rear stub axles- 2wd/108mm
- 17" Alloy Wheels
- yb engine and box wanted.
- gt30
- saph fog light
- 52mm gauges wanted
- os esc cos bodyskirt
- Standard mk2 FRS intercooler
- Wanted CD player 2028
- 88 spec door cards s2 rs turbo
- series 2 rs turbo radiator wanted
- Cosworth T5 box and prop wanted
- mk5 escort clutch pedal wanted
- Wanted: Escort Cosworth Rims
- A few mk4 XR/RS parts
- Group A engine mounts
- New weber pf09 tps
- Escos Sierra normal escort bits required
- Sierra/ saff parts
- Rs Turbo metering head(metering unit) WANTED asap plz
- Wanted focus rs mk2 parts !!!
- Wanted down pipe 2wd front splitter
- .36 exhaust turbo housing
- bolts
- Supra diff side mounting brackets Sierra axle
- Wanted XR4i rear spoiler rubbers
- ABS Relays
- Elite seq gearbox wanted
- t38 ball bearing turbo
- Cosworth 2wd steering coupling
- Escort or Sierra Bias pedal box
- Cosworth 2wd uprated diff mount/ gearbox mount
- Wanted adjustable top mounts for Sierra
- Ford Scorpio 2.5 td diff WANTED!!
- Wanted Haltech pro 2000 ecu. Iq3 dash wiring
- WANTED T5 speedo gear clip.
- Series1 shark grey speaker pods
- fiesta mk1 steering wheel boss
- Sierra Cosworth replica
- Ford Racing Water temp or Volts gauge.
- 3 bar map sensor
- cosworth hoses
- 4 spoke RS steering wheel wanted. (For S2)
- Sapphire plastic heater motor blower cover.
- escort rs turbo backbox wanted
- Granda Cosworth LSD Diff. 7.5" 100mm flanges
- Gen webber marelli 3 bar map sensor
- Focus rs/St 2.5 management ecu
- Mk3 escort fibreglass wings
- Turbo wanted 500hp
- Saff brake master cylinder or equivalent upgrade
- rs500 map sensor bracket
- Sorted.
- Escort cosworth parts
- Revolution Millennium 17 inch wheels for Saph.
- URGENT mk4 escort/xr3 sunroof catch
- 2wd goodies wanted
- escort cosworth washer bottle
- straight 90 spec boot sloiler
- cosworth 4x4 proshaft
- Sierra spare wheel well
- 2wd cosworth driveshafts long
- Wanted Escort mk4 header tank
- Boost Gauge
- ap brakes wanted 2wd
