PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Sapphire cosworth 2wd parts wanted
  2. Cosworth crank
  3. airtec front mount
  4. 3dr Cosworth front grill
  5. Escort Cosworth fibreglass tailgate
  6. Rs turbo interior
  7. Sapphire Cosworth Ambers.....
  8. Rs turbo radio loom with speaker loom
  9. Mk3/4 van one piece rear bumper, body kit.
  10. Escort cos ST oil pressure switch.
  11. Wanted any and all WRC YC Cossie Zetec engine parts
  12. Cosworth wasted spark HT leads wanted
  13. Sierra cosworth rear brake caliper wanted
  14. Wanted: Battery box for in my boot
  15. Indicator stalk 4x4 1991 cosworth
  16. Audi quattro estate wanted
  17. Zetec RWD Exhaust manifold/Full system MK2 Escort?
  18. Zetec E.C.S module and loom
  19. cosworth 4x4 oil pick up pipe
  20. 1 x motorsport alloy any fitment
  21. 2ltr pinto clutch
  22. 2wd engine mounts
  23. Wanted sierra 4x4, carrier & slider pins
  24. 909 air injectors wanted
  25. Cosworth 4x4 rear brakes and 2wd drive shafts
  26. Escort shell or project wanted
  27. Saff 4x4 Cosworth under bonnet bling wanted
  28. 4x4 sharktooth alloys and tyres
  29. s2 thermostat water pipe?
  30. cosworth twin plate clutch and flywheel
  31. 4x4 Cosworth Gearbox
  32. 3 door sierra windscreen wanted
  33. 3dr parts-ford stereo,hanbrake cover & boot carpet handle
  34. MK4 Escort/Orion/RS Turbo Fader/Balance controls dash blanking plate.
  35. Split rims 17" comp cxn or image split rims for a 3dr cossie
  36. deep, desk or dewy 2.0 ecu wamted
  37. S2 rs turbo wheel bots/lockers
  38. Vernier pulley an kent cam for 2ltr pinto
  39. cosworth sierra 3 door front bumper
  40. please delete
  41. delete please
  42. Delete please
  43. frst ecu chip and engin loom
  44. Cossie blower motor plastic cover
  45. 2wd bell housing and starter motor
  46. saph bumper number light holder
  47. 2 ford sierra lattice centre caps
  48. escort cosworth alloys
  49. 8x18 compomotive 6 spoke et42 new style
  50. 8x18 compomotives et32
  51. Optimate motorbike battery charger
  52. Gen 3dr cossie shell with id
  53. wanted: Mk1 orion boot catch and solenoid
  54. escort rs turbo 4 paddle ap clutch
  55. Sierra Pinto 4-branch manifold
  56. Sapphire 2wd shell
  57. 3 door shell ? 1.6 or cosworth any will do will px 2wd
  58. sierra dash clocks
  59. Series 2 ERST Bonnet Wanted
  60. Wanted ears Motorsport alloy wheel !
  61. Alloy Adjustable top mounts
  62. WANTED:top boost hose in red s2
  63. pinto head wanted, ported etc
  64. Escos front amber indicators
  65. cosworth accelerator cable
  66. 3dr cosworth alloy header tank WITH sensor take off?
  67. St170 cat
  68. 2wd standard fuel rail.
  69. Phase 1 Clio panels
  70. 16 inch Borbet C's
  71. 16 inch OZ Hydra's
  72. Series 1 front anti roll bar and geabox
  73. Sierra xr4x4 speedo clocks
  74. Wanted ; 215 40 17 tyres x2 or 205 40s
  75. 3dr boot carpet Wanted
  76. 2.3 duratec engine
  77. Delete
  78. ERST Parts Needed..!
  79. Sapphire Cosworth Sunroof
  80. couple parts
  81. mk2 FRS Recaros/interior
  82. WTD; FRST gearbox with LSD
  83. 2.0 zetec block
  84. WTD ALLOY WHEELS 17 or 18s
  85. 2wd standard exhaust
  86. 215/35/18 Tyres
  87. PF09 TPS
  88. 4x4 rear brake shields please delete
  89. Cossie Clutch
  90. Sapphire gauge holders
  91. throttle body to intercooler pipe rs500
  92. 2wd fuel pressure regulator or RS500 item.
  93. 3 door parts
  94. 1x focus rs wheel
  95. Front mount intercooler for a s2
  96. Mk4 escort rear quarter window rubbers
  97. 3dr cosworth front bumper brackets
  98. Turbo damper bracket.
  99. Wanted OFAB or OFAC Loom & ECU
  100. Decent compact digital camera
  101. Cosworth throttle body wanted
  102. Some nice seats for my focus
  103. single wiper kit
  104. good t3 turbo 2wd
  105. siemens 55's or bigger & nomad rears/front grills
  106. Cosworth Amal valve plug
  107. Wanted Mk1 Escort Door locks
  108. Wanted series 1 bits
  109. WANTED - Brake pads F + R
  110. wanted escort mk4 new servo
  111. 4x4 drive coupling donut
  112. Sierra / saph cosworth fan switch plug
  113. rear anti rl bar brackets
  114. Fiesta rs turbo bonnet
  115. Ropey 2wd box
  116. offside mk2 focus trailing arm
  117. looking for pistons
  118. 2wd cossie alloy radiator
  119. 2wd clutch fork
  120. wanted s2 breather pipe with non return valve
  121. fiesta mk2 windscreen
  122. Mk5 escort/escort cosworth tailgate
  123. Ford racing gauge! Not boost or oil pressure
  124. 2wd power steering rack
  125. black nsr door 2005- 2008 focus
  126. set of scrap wheels and tyres wanted
  127. wanted 2wd t3 actuator bracket!
  128. .50 4x4 pistons
  129. Wanted mk1 focus RS
  130. focus 2.0 driveshaft bracket
  131. 4x4 saf gear box flange bolts (3)
  132. ford racing oil gauge fitting
  133. PF09 TPS
  134. Wanted- damaged 200 Block & head
  135. Focus 18" ST2-3 alloys
  136. very good con ford badges
  137. s2 rear wishbones
  138. Wanted cvh cam belt cover/discs
  139. Uprated fiesta rst front brakes, mondeo master cylinder
  140. Group a rally inserts compomotive
  141. mk 3 fiesta drivers door
  142. Briggs & Stratton
  143. Cosworth T34.63 Exhaust Housing Wanted
  144. 90 spec front bumper
  145. imperial blue focus tdci sport 3 door
  146. 044 Fuel Pump
  147. XR2i or XR3i EFI block
  148. charge air temp gauge..
  149. Wanted 3 Door Parts
  150. rs turbo spots
  151. WANTED - Escort Cosworth Parts
  152. sierra cosworth wanted.
  153. plz delete
  154. WANTED - Escort Cosworth Rear Lights -
  155. rs2000 mk6 alloys?
  156. s2 / 4x4 cossie rusty bonnet and vents
  157. wanted, uprated evo 5 front disc and calipers
  158. uprated or tough front diff for escort cosworth
  159. T3 Turbo Elbow
  160. Escort Rs Turbo Front Coilovers
  161. 3.9 cwp
  162. sT170 5door interior wanted!
  163. Wanted 18 Rondell Alloy Wheels
  164. Jenson Interceptor wheel nuts
  165. wanted s2 chipped ecu,silicon coolant set,
  166. tidy escort van
  167. Escort Rs Turbo seats
  168. RS Turbo engine wanted
  169. Escort cosworth spare wheel carpet
  170. Escort Mk4 XR3i polybushes
  171. Wanted! Zetec Alternator Pulley!
  172. Wanted Sierra 2wd Coilovers
  173. 3 door shell
  174. Wanted 500 style front intercooler
  175. ST170
  176. Mondeo ST 220/TDCi Puddle Light Mirrors
  177. Escort Wheel Spacer Kit
  178. 2wd cossie diff wanted
  179. Plastic packing crates
  180. 2wd gearbox mount
  181. 2wd gearbox mount
  182. Variable rpm switch
  183. Escort cosworth banana pod
  184. cosworth mongoose or scorpion system
  185. Cosworth sump
  186. Siemens 55's
  187. Gaskets
  188. 6 degree rear beam for Saph
  189. T34 compressor housing
  190. WANTED: 4x4 rear diff
  191. Cosworth throttle body cable bracket-cossie air temp adaptor
  192. 2wd oil pump top / cap / lid
  193. cosworth 4x4 bellhousing bolts
  194. 3door tca
  195. T34 & Injectors (YB COSWORTH)
  196. Rs turbo master cylinder
  197. Trashed YB head 2wd or 4x4
  198. Gripper diff wanted
  199. OFAB loom
  200. WANTED T3 Turbo S2 RS Turbo
  201. 2wd saph Mongoose exhaust
  202. WANTED: 16" scooby speedlines
  203. rs turbo bailey breather
  204. cosworth kent cam bd14 wanted
  205. wanted 3 dr stainless sill/cill scruff protector
  206. 2wd cosworth T3 turbo
  207. 3dr scuttle panel
  208. alloys 17x8 et15 escort cosworth
  209. Ford Escort Mk5 Xr3i Engine Bay Loom / Zetec Turbo Loom /Etc
  210. cosworth oil spray lets WANTED
  211. Wanted s2 mongoose or scorpion exhaust
  212. O/S rear light cluster for 3dr cossie
  213. FRST inlet to servo pipe
  214. Wanted s1 roof lining
  215. FRS Mk1 RS Floor Mats & Leather Wallet
  216. mk2 focus bits..
  217. Sapphire grill strip without wiper holes
  218. Wanted; rs turbo radiator
  219. WTB - 3DR Alloy Wheel Center Locks or Caps
  220. 3 door sierra cosworth interior parts wanted
  221. 200 Block with damage/ overbored
  222. S2/mk4 escort lighting parts
  223. Escort cosworth wheels wanted
  224. Sierra Sapphire...
  225. White escort cosworth!!!
  226. Mk3 mondeo heated seat switch
  227. escort rs turbo strut brace, front, back or both
  228. Cambelt cover bolt, the centre one below cam pulleys!
  229. Long shot, but anyone got a Kahn RSR 18x7.5" ford alloy?
  230. 45 gallon drum wanted
  231. Fiesta turbo center cap
  232. 3dr smoked rear lights, Wanted
  233. Late spec 4x4 cloth front seats wanted
  234. series 1 rolling shell project
  235. Escort 90 spec boot spoiler
  236. 18" Rondell/Engle's
  237. Genuine 3 door bonnet vents
  238. centre box
  239. Need 1 x 83lb Siemens Injector
  240. t34 for a 4x4
  241. Bit of a long shot but... A decent telescope???
  242. MK4 Escort Flocked Dash
  243. RED front bumper
  244. compomotive centre caps
  245. Sapphire Roof Trims
  246. Cheap rollover jig
  247. std 2wd heatshield fitting kit
  248. mt75 2wd gearbox output shaft
  249. Focus RS Mk2 Front Seats - WANTED
  250. Pioneer remote
