PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 [79] 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. mk1 xr2 or supersport
  2. 3 door cosworth alloys wanted
  3. cosworth rad, Gearbox mount plate, and hose
  4. Headlight tab that clips onto the wing--RS TURBO
  5. rs turbo s1 wanted
  6. Fiesta RS Turbo bottom end
  7. wanted sierras any condition 4 breakin 4 race car spares
  8. Escort Cossie EECIV Inlet manifold
  9. Fiesta Turbo intercooler/chargecooler
  10. sierra and pinto spares wanted
  11. FRST Pace/Pro Alloy Intercooler + LSD GearBox HELP!!
  12. turbo wanted
  13. Mk1 xr2 plastic headlight surrounds NEEDED
  14. morrete twin headlights
  15. 4wd front calipers in good condition...
  16. S2 escort rs turbo tailgate
  17. sierra boot lock from a hatch..pls
  18. rs turbo pistons wanted
  19. BARE UNSKIMMED EFI HEAD
  20. S1 bits needed
  21. Replica RS500 front splitter
  22. WTD 1.6 Zetec Escort Mk5 (95) Backbox
  23. 17" - 16" alloys for s2 erst
  24. T4 ACTUATOR BRACKET
  25. Wanted - ST170 Front Brakes
  26. fiesta rs turbo oil feed bolt needed! URGENT!!
  27. Stage 3 ERST turbo
  28. escort mk4 cabrio red doors
  29. turbo!
  30. looking for a 2WD saph must have long mot and good tyres
  31. mint condition rs/xr31 sunroof
  32. cold start injector erst
  33. 3 door cosworth alloys wanted
  34. Ford Escort RS Turbo Series 2 Wanted
  35. alloys
  36. Fuel swirl pot
  37. Silicone Hoses in Blue
  38. Series One Header Tank
  39. s2 loom for a conversion
  40. WTD: Fez MK3 RS EFI standard (T2) Top right hand hose?
  41. complete oil cooler kit for 4x4 cossie
  42. MOONDUST SILVER SAF COSWORTH
  43. rs turbo px
  44. Fiesta RS Turbo Wanted Redditch/Brum area
  45. Esc Cos Small Turbo YBP plenum and lower pulley
  46. Escort RS Turbo
  47. pectal loom for ecos 4x4
  48. samco top boost hose
  49. WANTED - Escort Cosworth Monte(FOUND ONE)
  50. Escort Cosworth Headlamp Protectors!
  51. escort rs turbo, turbo unit t3
  52. 3 Bar mapsensor
  53. escort cosworth fuel pump wanted
  54. wanted fiesta mk 1 o/s wing
  55. Escort Cosworth
  56. SORTED SORTED SORTED...........
  57. MK2 XR2 WANTED
  58. rs500 style intercooler for sapph cossie
  59. 3dr Cosworth Bonnet hinges ..
  60. Sapphire Quad lamp covers ,pair of ...
  61. spoiler clips
  62. RS Turbo Crossover pipe
  63. 3 Door Cosworth Needing Work
  64. Mk6 escort bonnet in white
  65. sierra rack
  66. WANTED! Uprated Rad for Series 2 RST
  67. 4x4 saph prop shaft complete inc rubber doughnut
  68. bottom rad hose
  69. Getrag GpA parts wanted,
  70. Swap My K reg Escort RS Turbo for a Cosworth
  71. S2 RST Black, Grey or Red...
  72. 17' alloys to suit s1 rst
  73. free or cheap 195 50 15's
  74. 88 spec erst rocker cover
  75. New mfi bosch injectors
  76. Wanted escort rs turbo series 2 upgraded clutch
  77. NO LONGER WANTED - Mint 4x4 Saff Cossie - AS I'VE BOUGHT ONE
  78. cosworth 2wd diff must be gripper or quaife new or second
  79. S1 front speaker grills
  80. 4x4 saff fuel tank &strap in good condition
  81. cossie grey injectors wanted
  82. GRP A Wheel Nuts
  83. help dunno where to put it???
  84. X-Flow Burton Rocker cover
  85. 15inch rs alloy centre caps.
  86. Front Gaz shock
  87. sapphire 4x4 calipers with carriers
  88. STEEL WHEELS
  89. Pace intercooler brackets....
  90. Wanted Sapphire Morette Quad Headlamps
  91. mk3 fezzer ingnition...
  92. S2 maybe S1
  93. cibie covers
  94. Plastic cover ....
  95. RS Turbo parts wanted-Metering head, Konis, springs ect
  96. Saff N/S fog light, please
  97. Series 2 passenger door
  98. escort cosworth fuel pump wanted
  99. Escort RS Turbo (just bought 1 thanks)
  100. s1 body kit/arch!!
  101. rst bootlid
  102. erst t3 turbo
  103. Escort spoiler
  104. jenvey t/b's
  105. Paul Plumridge High Wycome
  106. 3 DOOR COSSIE
  107. EFI conversion bits
  108. wrc long con rods
  109. cosworth cone filter
  110. rs turbo cabby swap for saf cosworth
  111. list of s1 bits i need
  112. wheelnuts
  113. Stone Deflector wanted
  114. Small teardrop type clip to hold injector in on S1
  115. WANTED anti rattle plates of 2 wd 4 pot cossie calipers
  116. Cheap Saph Needed
  117. Pinto wanted
  118. WANTED RS ROCKER BOX
  119. Wanted 283 mm cross drilled grooved discs of a 2wd cossie...
  120. saff shell
  121. escort cosworth wanted
  122. wanted adjustable track control arms
  123. 52 plate fiesta
  124. T25 Escort Cosworth plenum / throttle
  125. t3 or hybrid t3 wanted
  126. Need a Sapphire 2wd Cosworth Crank Pulley
  127. Ford Mondeo Mk2 Trip / Fuel Computer
  128. Ford Mondeo Boot Release Solenoid
  129. escort cosworth water pump
  130. Series 1 Rs Turbo wings, front panel and front bumper.
  131. Bonnet Vent
  132. bernie box cash waiting
  133. Needed - cossie map sensor bracket
  134. Wanted! Clean Sapphire Cosworth Front Doors + Front Splitter
  135. cosworth running gear wanted
  136. cosworth engine wanted
  137. still in search of a vry scary escort turbo
  138. carbon fibre sheets
  139. 4 spoke RS steering wheel
  140. big rear brakes
  141. low miles cosworth or rs turbo s1 or s2 for deal with subaru
  142. mk4 90 spec parts in scotland
  143. WANTED! T3 DOWNPIPE FOR FRST
  144. 2wd Cossie Bits
  145. 3dr interior...
  146. 2wd cossie rear springs
  147. s2 good working engine
  148. Power Steering set up for mk 4 escort
  149. carello s1 spot lights, must be mint
  150. Pair of 2wd Cosworth Engine mounts , uprated if possible
  151. P8 bits
  152. M3 evo convertible
  153. erst s2 centre vent gauge pod
  154. WOLF PARTS WANTED
  155. wolfrace Voodoo 17inch alloy wheels
  156. Mk3 Escort back lights
  157. 4x4 cossie head
  158. Urgent Part Required
  159. Diamond Cut RS7's wanted
  160. S1 rear bumper....
  161. Escort Cosworth wheels...
  162. RS 1700
  163. CHEAP 4x4 intercooler
  164. MK3 Mondeo Zetec S 18in 5 spoke alloy wheel
  165. Moonstone 3dr parts !!!wanted!!! please look.
  166. AN R6 FOR SWAP WITH MY S2
  167. REVO RFX RIM
  168. efi flywheel....
  169. ESCORT COSWORTH FUEL TANK!!
  170. Cossie cam followers anyone?
  171. Secs Monitor
  172. Pair new front track control arms for series 1 rs turbo
  173. RS1600i original front spoiler
  174. Rubber mat support for '90 spec recaro's
  175. ap front calpers
  176. pair of cosworth standard 2wd cams
  177. gti escort wheels cossie style
  178. Escort Cosworth Monte Carlo
  179. Does anybody have........
  180. Turbo for s2 erst
  181. S2 erst drivers electric window switch
  182. frst ofac ecu wanted
  183. RST EFi head and Metering Head........
  184. sofa (what have you)
  185. 3dr rear arch screw cap
  186. stage 2 bernie box
  187. escort MK6 drivers window mechanism wanted!!!
  188. frst springs wanted
  189. frst spring
  190. FRST T3 DOWNPIPE
  191. Focus RS
  192. S2 ERST BITS
  193. escort rs turbo series 2 bits
  194. Steering wheel
  195. esc cos leather rear seat
  196. i need a chip for my mk4 rs combi
  197. A set of last of the line MK4 XR3i 14" lattice alloys
  198. omex,pectel dta etc management
  199. left hand drive cosworth
  200. Cosworth FLINT GREY REAR BUMPER
  201. Mk4 Escort Rs Turbo dash board
  202. escort cosworth morettes headlights wanted
  203. cage for mk5 escort
  204. cosworth flint gray frount bumper
  205. cosworth exhaust housing
  206. fiesta mk3 front wheel bearings, new only
  207. 4wd Gearbox Mount
  208. Series 2 Standard alloys GOT SOME PLEASE DELETE
  209. WANTED pace intercooler for series 2 turbo escort
  210. Drivers side door seal
  211. Front mount intercooler for S1, must fit with std hoses!
  212. injectors
  213. moved
  214. level 8 baby board
  215. lower spoiler
  216. standard s1 boost hoses
  217. 2wd cosworth fuel pump & fuel filter holder
  218. group a fuel pump
  219. escort turbo
  220. escort
  221. cheapo quadlamps for escort s2
  222. FRST Uprated Fuel Pump And ERST LSD Gearbox
  223. original sapphire cossie rear lights (not smoked)
  224. XR4i Wanted
  225. tsw imola
  226. uprated radiator, intercooler etc
  227. FORD ENGINE/BULKHEAD LOOM GROMMET,,,URGENT
  228. mk 6 GTI side skirts (5 door)
  229. Escort RST or Fiesta RST/XR2 Car now found!!!
  230. erst rear tie bars needed
  231. 3dr cossie parts
  232. Wanted Focus ST170 Alloys
  233. saph cosworth 4x4 gearbox including transfer box
  234. fiesta trim parts
  235. ESCORT COSWORTH GRILLE
  236. 2wd coilovers
  237. Fiesta turbo exhaust system wanted!!!!!
  238. looking for a cheap s1, s2 or fiesta..
  239. wiring loom
  240. 4x4 cossie front hubs
  241. WANTED DRIVESHAFTS FOR FRST
  242. cheap s1 wanted for project !!Cash Waiting here on my desk!!
  243. 4x4 Cossie dipstick and dipstick tube
  244. wanted, px d plate s1 or combi van for 2wd saph
  245. Mint 4x4 saphire cosworth wanted
  246. Wanted RS2000 parts for track day project
  247. Vehicle speed sensor
  248. rs turbo/mk2 fiesta shell under £300
  249. 3dr Main Car Loom Wanted.
  250. *WANTED*
