PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 2wd uprated front brake discs
  2. t4 size boost hose
  3. mk1 focus rs turbo
  4. 2wd dust plate for gearbox
  5. Saff 2WD drive shafts ASAP
  6. 2wd saph bits
  7. Boost Controller
  8. R888's or A048's in 215 45 17" or similiar
  9. 2wd Coilovers and sapphire rear bumper
  10. sierra 2.0l twin cam
  11. front bumper needed
  12. cosworth vernier pulleys
  13. WANTED White Fiesta RST
  14. Wanted-Escort Cosworth
  15. Sierra Saph Scuttle Pannel
  16. pf01 throttle position switch
  17. S2 amal valve
  18. Modeo Mk3 St Grille
  19. Rear coilovers for a saph cosworth
  20. Fiesta Black edition for sale
  21. Wanted:half width intercooler for a s2
  22. mk4 escort parts wanted
  23. cage
  24. 2wd gearbox, pedal box and steering column
  25. Cosworth 4x4 calipers
  26. Rear Diff wanted
  27. Escort van needed quick
  28. Magnex tail pipe
  29. Defi Gauges...
  30. 2wd saph
  31. focus rs uprated charge cooler or intercooler set up & turbo oil return pipe
  32. Saph Bits
  33. sapphire roof bars/ rack
  34. 3 door shell
  35. Exhaust Valve
  36. Good Condition Saph Scuttle Pannel
  37. 4x4 Sapph boot lock and key
  38. 2wd cossie sump wanted
  39. 2wd sapp compression strut kit/coil overs
  40. Wanted: S2 genuine ford headlight protector
  41. davies craig ewp80/115
  42. Vernier pully
  43. escos bumper and skirts
  44. STACK
  45. Scuttle pannel and Bonnet Hinges Before Combe
  46. 2WD Hose set Black or Blue Samco - Roose - SFS etc
  47. Wanted 2wd sapp compression strut kit/coil overs
  48. ERST Baileys Oil Breather
  49. Series 2 RS Turbo Parts Wanted
  50. series 1 wanted
  51. RS Turbo: Turbo Water Pipes
  52. Saff Fibreglass bumpers/bonnet/boot
  53. T5 cosworth Bellhousing
  54. BMW E36 M3 Evo Engine
  55. Wanted 2wd sapp compression strut kit/coil overs
  56. Sierra Diff
  57. cosworth main crankshaft cap bolts wanted
  58. Wanted: 5th injector kit for a series 2
  59. S2 bits needed.
  60. compomotive mo 6 spokes - 8x18 et35
  61. Saph Scuttle Pannel
  62. Saph bonnet hindges
  63. 8x18s wanted sierra fitment comps or revos
  64. ERST S2 Pink fuel pump relay
  65. Cosworth dizzy cap cover
  66. White rear bumper sapphire
  67. wanted for focus rs
  68. mk2 escort dashboard
  69. mk2 escort dash and steering rack
  70. White 90Spec Bumpers.
  71. Couple of bits for mot
  72. 1.8 zetec sump wanted
  73. saff fuel cradle bracket and bushes wanted.
  74. no longer needed
  75. Galaxy 2002
  76. cossy turbo heatshield
  77. Single bucket seat;
  78. Standard sierra cosworth wheel nuts x16
  79. Puma Exhaust
  80. 3 door cosworth indicator stalk and rear fog lamp swich wanted
  81. Cosworth 200 block please
  82. Focus RS gearbox
  83. Rs 7 spoke wheels wanted
  84. Help.. BARE BLOCK NEEDED
  85. Cosworth t3 turbine/ exhaust housing
  86. Escos wheels
  87. 4x4 SAPH BONNET FLINT GREY AND SCUTTLE
  88. wanted rs500 fuel rails
  89. Recaro seat part (3 door)
  90. 2.0 or 2.3 Duratec Engine
  91. 4.4/4.6 c.w.p for 7.5" cossie diff
  92. Cosworth cam cover top bolts/rubber support
  93. 2x Focus / Mondeo / transit connect wheels
  94. yb 200 block
  95. Need a fiesta turbo CO POT
  96. 3DR Cosworth bonnet hinges Wanted
  97. cosworth headbolts
  98. s1 turbo side trim bodykit covers
  99. saf fron door cards leather any condition
  100. t4 exhaust housing wanted
  101. MK5 Escort Tailgate
  102. What can i buy for £3000-£3500
  103. Sparco Rev (Or similar)
  104. fiesta turbo vents
  105. 1 fiesta zetec s wheel (large cap)
  106. turbo heat shield wanted, 2wd saph
  107. 0.63 exhaust housing for a t4
  108. Standerd cossie MAP sensor
  109. Sierra steering column wanted
  110. 2wd Cossie Parts...
  111. 102mm air filter trumpet wanted
  112. Aftermarked dash wanted stack? what have you got
  113. Wanted s2 black bonnet
  114. 3 DOOR
  115. XR2i 16 valve wanted
  116. escort cos big turbo air box
  117. BRAKE KIT
  118. 2008 onwards Focus running gear Wanted ,St or RS
  119. sierra sapphire indicator stalk switch
  120. Escort Rs Turbo parts wanted
  121. 4x4 oil return pipe
  122. bulk head mat for sapphire
  123. scrap cozy t3 turbo
  124. white faced oil pressure guage 52mm
  125. WANTED: fiesta zetec s grill
  126. Am i allowed to put a WANTED COOKER in this selection?
  127. Wanted Escort Cosworth BT
  128. Wanted-Escort Cosworth BT
  129. 2wd Level 6 ECU wanted
  130. 2wd Power Steering Rack
  131. 2wd turbo water pipe
  132. Magnex tail pipe
  133. Motorsport Developments 25mm twin piston dump valve
  134. rs turbo intercooler, drivers seatbelt
  135. WANTED:2wd fuel rail
  136. Rear coilovers for 4x4 saph
  137. transit connect
  138. S2 black body parts
  139. Escort Cosworth Front Tow Eye Cover
  140. puma wrc spolier
  141. mk4 escort gearbox cradle
  142. no exactly a car or car part but i need a push bike
  143. X1 mk1 focus Rs 18 inch alloy wheel must be straight
  144. ST170 parts needed
  145. Escort RS Turbo S2 parts needed
  146. Ldv pilot minibys or crewcab
  147. 4x4 cossie front hubs
  148. 1x 16" RS 7-Spoke Alloy Wheel
  149. Wanted. Weller wheels
  150. Black faced decent boost gauge wanted
  151. Wanted RS500 airbox
  152. MK4 Esort Fuse box holder
  153. Escos Headlight Bulb Holder/Clip
  154. Cossie 2wd sump
  155. mk4 escort n/s door weather strip
  156. 90 spec escort efi fuel cut off
  157. 3 door cosworth shell
  158. 3 door cosworth doors
  159. 2wd saph boot rubber/stop
  160. erst drum backing plates
  161. focus rs push start
  162. Focus RS mk1 alloy wheel centre caps x4 or 1 or 2 why
  163. Turbo
  164. Found one... please delete!
  165. 2wd diff
  166. 2wd diff
  167. Pectel style braided cosworth engine loom
  168. Wanted Girling Reservoirs, MK2 escort
  169. 1997 escort drivers side elec regulator (3dr)
  170. ford focus o/s/r window reg electric
  171. Compomotive MO blue centre caps wanted
  172. 18" Wheels
  173. saph 2wd front arb
  174. Escort Cosworth Wanted!
  175. mk1 focus RS under engine/front bumper tray
  176. cossie t5 gearbox
  177. trigger wheel sensor bracket
  178. Indicators mk 4
  179. S2 Alternator Brackets
  180. 17 oz superleggera alloy wheel
  181. Level 8 ECU WANTED
  182. NS sapphire headlight wiper assembly
  183. 1st phase saph boot bump stop rubbers
  184. fan switch plug
  185. Oldskool's for sale
  186. Odd request - scanner!!
  187. Series2 rs turbo with lowish miles
  188. Cosworth list of bits, updated
  189. 3 door sierra cosworth or fiesta turbo
  190. mk5 cab parts
  191. wanted 2wd cosworth front arb
  192. cosworth down pipe
  193. Rst brake servo....
  194. Upper half of sierra steering column
  195. !!fiesta carbon parts !!
  196. escort rs turbo bonnet
  197. ERST front wheel hub.
  198. Escort bits
  199. Wanted saph cos
  200. Sierra 4x4 front struts
  201. WANTED : 2wd alloy header tank
  202. saph cossie 044 pump
  203. cosworth vernier pulleys wanted
  204. erst/frst efi block or engine wanted
  205. 2wd cosworth manifold
  206. fiesta and escort turbo parts wanted
  207. Single 52mm guage pod/holder
  208. SINGLE 52mm guage pod holder
  209. Cosworth Adjustable 4x4 rear beam
  210. Good ERST Radiator to collect at FITP
  211. 2wd flywheel
  212. looking for a 2wd L6 ecu
  213. Wanted pink fuel pump relay
  214. wanted koni or similar front suspension for a 4x4 cosworth sierra
  215. SECS Monitor
  216. Escort cosworth sidelghts
  217. wanted 4.1/4.4 c.w.p
  218. wanted 16inc mondeo 5 spokes
  219. Wanted ST170 Passenger Drive Shaft
  220. multi plug
  221. 1800 duratec engine
  222. escort rs turbo coilovers
  223. Cosworth rocker/cam cover wanted
  224. alarm
  225. L8 greys chip
  226. 3DR Parts WANTED, T34 K&N Trumpet, LOCK SET, 2WD SUMP
  227. Bailet turbo damper long allen bolt required
  228. Speedo cable bracket for 3dr cossie
  229. Ignition amp bracket for a 3dr cossie
  230. RS Turbo T3 Turbo - Cheap
  231. CP5200 4 pot AP calipers
  232. return pipe
  233. rwd Escos prop
  234. fuel sender
  235. 4x4 Cossie bottom radiator hose WANTED-Black Samco
  236. wanted escos alloys please
  237. Cosworth K&N filter trumpet
  238. 3dr Fibreglass or similar bonnet and tailgate!
  239. Large Cair-o-port or size 5 Carcoon wanted
  240. COMPOMOTIVE centre caps wanted in blue
  241. cossi lowering springs all sorted, got -20mm
  242. Wanted: 2wd cossie diff
  243. S2 90 Spec Front Bumper
  244. S2 bits wanted
  245. escort s2 frount mount intercooler
  246. cosworth 4x4 front calipers
  247. WANTED / NEEDED cash waiting!!!
  248. ERST RAD
  249. Fan switch
  250. fiesta rs turbo radiator hose
