PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Saff sunroof
  2. hi guys im new im after a puma vvt engine bay loom
  3. 4x4 cossie power steering pipes WANTED.
  4. 5x108
  5. 1.7 puma engine bay loom
  6. mo 6
  7. 2wd flame trap
  8. dash blanking plate
  9. 10" and 11" x 18" Ford GpA fit wheels Wanted
  10. Wanted... rs turbo engine in good condition
  11. Escos pro alloy 500 cooler
  12. 18" monte wheels
  13. blue ali compomotive center cap
  14. escort mk4 top cups
  15. xr2i wanted
  16. Granada front hubs
  17. mk4 efi pedal
  18. waterpump
  19. Sapphire parts
  20. Cosworth Amal Valve
  21. Car transporter trailer wanted, GOT ONE NOW
  22. focus st 18 inch alloys wanted
  23. cossie fuel pipe
  24. power steering hose - thicker one.
  25. 4 switch elect window and rear light connector
  26. escort s1 bodykit wanted
  27. Escort cossie wheels
  28. Rs2000 mk6 wiring loom
  29. Wanted Essex V6 Sump
  30. Cosworth Yellow injectors
  31. ERST master cylinder and servo
  32. 4x4 cossie sequential gearbox wanted
  33. S2 brake caliper retaining clip
  34. Inner outer sill for sierra sapphire
  35. WANTED: Compomotive TH2
  36. t6 ecu and loom
  37. ST24 Fog and Surrounds
  38. escort cosworth gearknob
  39. Urgently wanted ,inner GpA Camber links,long ones !!
  40. wanted Sierra 1989 on Mercury Grey
  41. Escort RST Fitted Sub-Box
  42. escort rs dip-stick and tube and oil filler cap
  43. 3 door bumper,indicators,wheel bearings plus more wanted
  44. Bronze tint 3 door escort glass
  45. 90 Spec Recaro's
  46. Collins or vibro 2wd engine mounts
  47. anybody near oulton park? desperatly need a set of big end bearings
  48. Rollover spit
  49. 2wd saph parts needed
  50. cosworth parts
  51. FRST coil pack
  52. Rs Turbo Radiator
  53. 2wd Oil Pickup...
  54. 1.3 sr nova inlet manifold
  55. 330mm brake rotors and 2wd saff cos steering rack
  56. Escos tailgate wanted, edit; got one
  57. 2wd cossie steering coupling arm
  58. Autoart WHITE 3 Door Cossie
  59. Wanted Mk3 Escort
  60. Radio 1 big weekend tickets
  61. mk4 escort auto manual
  62. s2 wiring loom
  63. Parts Wanted
  64. set of saff sideskirts
  65. parts needed for 3 door cossie
  66. 1.6 se engine wanted
  67. 2WD Cosworth Power Steering Pump
  68. XR3i EFi Mk4 alloys
  69. 7.5" output shafts
  70. Cossie clutch
  71. Ka boot in fiberglass and some perspex windows
  72. some transit parts
  73. 2wd cosworth Drivers side front Hub
  74. OLD pair of 2wd front discs
  75. Slim line fans
  76. L8 ecu with weber board preferably
  77. S1 Skirts and Arches wanted
  78. 18" rl7
  79. RS Turbo's Dead Or Alive
  80. Zetec S or Puma gear linkage
  81. sapphire rollcage any1?????
  82. T34 compressor housing,
  83. 205 or 215-45-16 tyres x 4
  84. ST Fiesta alloys & tyres
  85. mondeo st220, zetce s or ghia x 18 wheels
  86. Parts needed to get my Escort ZT on the road
  87. mk5 rs2000
  88. RS2000 4x4 decat
  89. WANTED cossie 4wd front brake calipers
  90. wanted 2.0 silvertop zetec engine / mondeo
  91. sorted
  92. Monte wheels or Compomotive TH
  93. Urgently Wanted T34.63 turbo
  94. cossie 4x4 prop shaft needed
  95. Saff front fog surrounds
  96. i need some 330mm disks for 4x4 saph
  97. escort rs turbo magnex downpipe
  98. escort cosworth osf window reg
  99. Saph lockset..
  100. 3 door central looking motor
  101. Sapphire Cosworth front bumper....
  102. Focus rs exhaust and dump valve wanted
  103. cobra side mounts.
  104. escort cosworth rs tailgate badge
  105. ET35 17 inch Wheel
  106. 2wd Fuel Regulator Bracket
  107. saff power steering cap
  108. Cosworth coolant hose on back of head tyne and wear area
  109. cossy 2wd front anti roll bar wanted ASAP
  110. 2wd cosworth rack...
  111. FRST efi to chargecarrier hose
  112. Ford Sierra Base model
  113. Cosworth 4x4 oil pump pick up pipe/spray bar
  114. 4x4 Bonnet
  115. escos small turbo cylinder head
  116. Sapphire cossie
  117. tail gate 3dr
  118. Wanted MK3 ESCORT 2dr anything considered
  119. S2 diamond cut alloys wanted
  120. Wheels
  121. Cossie turbo damper bracket
  122. Sierra Cosworth fuel lines
  123. micrometer wanted
  124. S2 RST heater panel
  125. Sierra Coilovers - Pairs or full set!!
  126. Sierra Cosworth 2wd front Hubs
  127. Max Power - End of an Era FINAL ISSUE
  128. Rondell 122's
  129. Wanted door and wing moldings
  130. mk6 escort rear bumper
  131. WANTED T34 4x4 turbo!!!!!
  132. focus rs plugs
  133. Ford Racing gauges volts, water temp or why??
  134. Cosworth engine mounts wanted asap
  135. S1 Radiator
  136. 2wd cosworth turbo heatshield
  137. 16 sapphire wheel studs
  138. 2ltr zetec turbo wrc esc cos rep breaking
  139. erst windscreen
  140. Escort XR3i or Rs Turbo 90 spec bumpers
  141. sierra filler neck grommit
  142. S2 Rear spoiler
  143. 2wd cosworth speedo cable
  144. escort s2 radiator
  145. XR2 and RS Turbo parts needed asap
  146. Series 2 bodykit (just front arches) wanted
  147. escort s2 radiator wanted
  148. Fiesta st front seats
  149. Focus RS MK2 wheels
  150. Cosworth Fuel Pump Wires
  151. Good saff or escos shell wanted?
  152. 4x4 sump speedo drive cog assembly
  153. xr3 dashboard cluster - sorted thanks
  154. mk4 efi xr3i to 2.0 zetec parts required
  155. Wanted: B&M MT75 quickshift
  156. MK3 XR3/XR3i Rear spats
  157. XR3i Mk4 alloys
  158. Racedata Vbox Lite
  159. gearbox and diff
  160. es cos rear abs sensors
  161. 2wd Arb, front hubs, steering joint...
  162. escort mk4 bumper skirts , rs motorsport
  163. Escos wheels, rs 7 spokes or comps?
  164. Diamond white 2WD Sapphire Bonnet
  165. 235/40/17 tyres wanted
  166. stack speedo and tacho
  167. Escort Mk6 Morette Masks
  168. escort mk4 top cups
  169. 2wd cosworth wanted
  170. Escort Cosworth Big Turbo Clocks
  171. RS Turbos Dead Or Alive
  172. sapp cosworth 4x4 t3 turbo
  173. focus mk2 ST alloy wheels wanted
  174. Rs turbo actuator
  175. T34 Actuator bracket
  176. 2wd radiator wanted
  177. Mk1 Focus RS engine
  178. Sierra Cosworth PF01
  179. msd 380 chip and injectors wanted
  180. passenger window series 2 rs turbo
  181. 4x4 front hubs wanted
  182. transit turbo
  183. s2 sun roof
  184. Mercury Grey Paint
  185. rs turbo coilovers
  186. 2.0/2.1 Pinto
  187. Rs2000 mk6 4x4 wing badge
  188. inlet boost hose 4x4 cosworth
  189. 285 35/40 22 all considered or similar
  190. 4x4 sapphire cosworth 3" system....
  191. complete Zetec H O Inlet
  192. Escort S2 Suspension - Koni's or Coilovers
  193. CVH steel rods`
  194. st170 front hubs
  195. 52mm Oil temp gauge
  196. Superchip for RS2000
  197. ST225 O/S Caliper and carrier
  198. little rubber mounts s2
  199. 2WD Uprated engine mounts
  200. Mk4 Golf wheels pref 18"s??
  201. RS Turbo jacking point cover
  202. ST170 interior
  203. OMP / Sparco Steering wheel
  204. 3 Door Sierra/Escort Cosworth Fog Lights
  205. Wanted: 2WD Sapphire Doorcards
  206. Standard cossie crank
  207. 3dr passenger side mirror cover
  208. Bought already: Ford Sierra Cosworth 4x4 LHD non-kat
  209. Wanted - RS500 lower rear spoiler
  210. cosworth 3bar map sensor
  211. 3dr alloy washer tank/ps tank
  212. rs 2000 4x4
  213. 3dr cosworth interior & front axle
  214. Fancy S2 rs turbo parts
  215. 90 Spec Rs Turbo Front Bumper
  216. T5 Gearstick/AVO rear top mounts
  217. 3 Door Sierra Rear Light Unit
  218. Spare MAP Sensor anyone??
  219. 2wd Cossie MAP Sensor
  220. Mondeo Mk1 RSAP ST24/ST200 bodykit
  221. cosworth 6 paddle clutch plate
  222. Boa cosworth air flow meter
  223. Cosworth idle control valve
  224. GpA front Hub flanges wanted
  225. L6 ECU Wanted
  226. S1 body kit
  227. Ps3
  228. Ps3 60gb wanted
  229. focus rs gearbox
  230. Anti roll bar washers.
  231. Wanted S2 Rs Turbo
  232. CVH Lean Burn Head
  233. ford ka fully clear rear lights and smoked rears
  234. escort turbo lowering shocks and springs
  235. focus rs clutch cover
  236. Stack EGT and wideband gauges
  237. T3 wanted
  238. escort mk6 rs2000 headrest
  239. Wanted: 2wd standard webber fuel reg
  240. A list of parts NEEDED for my erst
  241. Has anybody got a cheap air compressor for sale ?
  242. 1.6 cvh
  243. Escort Fusebox wanted
  244. 3 Door/RS500 or 2wd Sapphire Gear Knob
  245. Leather doorcards for sapphire
  246. Power steering reservoir
  247. Cosworth Fuel Pump & RS Turbo Cradle
  248. Standard springs!!
  249. Cossie Tcas, worn/ failed/trashed
  250. 2wd Cossie turbo heatshield
