2ltr zetec turbo wrc esc cos rep breaking
the time has come, i'v had enough and i need to fund my gas course so i can work for myself finaly ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
there's lot's of nice bit's on the car so have a good read through, i dont really want to start breaking the car until the engine and shell have sold, but if i get enough name's down for everything else i will just start breaking it.
all price's do NOT include postage as i would rather people come and collect in person from eastbourne, that way you can see the part your buying befour any money change's hand's...
however, i will put a postage price next to the item's i can post.
i am open to sensible offer's on everything, but i wont let thing's go for peanut's so please, no stupid offer's...
there's picture's of most part's in my project thread here:
https://passionford.com/forum/restor...7-02-11-a.html
i'l post some pic's at the bottom of this for sale thread aswel.
anyway here goes...
1. 2 litre blacktop zetec engine, forged bottom end, JE piston's, eagle rod's, acl race bearing's, new water and oil pump's, std crank, oil return for turbo stabbed in front of the block and breather stabbed in the rear, 2litre standard head and cam's (fully stripped and rebuilt), blue adjustable cam pully's, uprated KENT valve spring's and titanium retainer's, black powder coated rocker cover with 2 breather's, focus wrc spark plug's. £1150 ono collection only or arrange your own courier.
2. xr3i 130/rs2000 MTX-75 gear box, fitted is a ford torsen LSD and the gear ratio's have been played with in order to atcheive 180MPH (was fitted to 'christian&beckys' old s2) £750 colection only or arrange your own courier.
3. rover m16 inlet manifold (this is the bigger rarer one) modified to allow fitment of a cosworth throttle body, cosworth green injector's, adaptor plate to fit to zetec head, fuel rail with -6 fitment £350 + £16 p&p
4. one off tubular exhaust manifold with external wastgate, typical t3 style fitment, part heat wrapped, £225 + £10 p&p
5. t34 turbo, .48 housing, very good condition with very little play in shaft £300 + £12 p&p.....denis_wiseman SOLD
6. TTV racing flywheel, to suit rst or zetec, hardly used when fitted to christian&becky's s2 £100 + £10 p&p
7. focus rs AP racing clutch, the side's of the pressure plate bit have been ground down to allow fitment to the zetec engine and mtx-75 box, but doesn't effect the working of the clutch atal! £250 + £10 postage
8. mk5/6 bailey header/pas tank setup, no pas cap, but has header tank cap, no crack's,hole's etc £150 + £8 p&p
9. alloy oil breather/seperater with little breather filter £60 + £5 p&p
10. sard feul pressure regulater, -6 fitment £125 + £5 p&p
11. feulab feul filter -6 fitment (black) £100
12. -6 feul line's and aerouip fitting's, black nylon line's, will have to get a pic of what's what with these... £50 + £5 p&p scoobypete
13. 19 row mocal oil cooler (jic style fitment) come's with take off sandwich plate, 2x -10 black aeroquip 45's and 2x -10 black aeroquip 90's and 2x black nylon braided line's roughly 1.5 mtr in length (each) £150 + £10 p&p
14. alloy sierra/escort cosworth rad, brand new, only ever fitted to the car, never used, £125 + £15 p&p
15. 2x 10" rad fan's, brand new, fitted to rad but never wired in a used £40 + £7.50 p&p
16. front mount intercooler measure's 600mm long by 300mm tall, universal style fitment, brand new, fitted but never used. £100 + £17.50 p&p
17. MSD coil pack and red MSD lead's, brand new, fitted but never used. £90 + £10 p&p.....C6 CYA SOLD
18. track design's front mount alternator kit for blacktop zetec engine, brand new, fitted but never used £115 + £7.50 p&p
19. modified engine mount for mk5/6 escort to suit the blacktop engine £10 + £7.50 p&p
20. blue samco coolant kit for mk5/6 escort with zetec engine, brand new, fitted but never used, £215 + £12 p&p
21. OMEX 600 ecu and loom £600 + £10 p&p
22. s/s exhaust downpipe, heat wrapped, this is made to fit my car so may need altering to fit other's? £30 + £8 p&p
23. esc cos intank feul pump made into mk5 sender unit £30 + £6 p&p
24. ford racing boost and oil pressure gauge's £60 each + £5 p&p for each
25. escort cosworth replica shell, the shell used to be a mk6 si, but has been converted to mk5, and the correct esc cos wing's have been fitted so the rear quarter's meet the spoiler and the front wheel's sit nicely in the arch's, the shell will come with.... door's with loom's, interior loom, carpet, dash, sunroof, head lining, boot hatch with wireing, all glass, rear esc cos rep bumper £400 i can sell it rolling but a price will need to be discussed.... muz
26. rs2000 rear disc beam powder coated blue with yellow anti-roll bar, fully poly bushed, new shoe, cylinder's, grooved disc's, new pad's and painted gold caliper's £180 collection only or arrange your own courier.
27. rs2000 front subframe powder coated blue with yellow anti-roll-bar, arb is poly bushed aswel. £80 colection only or arrange your own courier
28. 325mm gold HI-SPEC's, brand new, fitted but unused, slight surface rust on disc's from being sat around on the car £850 + £26 p&p
29. GAZ gold coilover's, fully height and damping adjustable, virtually new, only been used for a couple of hundred mile's £350 + £20 p&p
30. front e-tech strut brace to suit mk6 strut top's £50 + £5 p&p
31. rear sparco strut brace, was mk5, but also drilled to suit mk6, powder coated black. £50 + £5 p&p
32. WRC spoiler, was fitted to danny from EP track esc cos, proper one that sit over's rear quarter's, fibre glass, upper wing is removable. £200 collection only or arrange your own courier.......richie SOLD
33. WRC front bumper, been cut at the bottom to allow my oil cooler to be fitted, but easily patched up, also has mk6 morette's indicator's fitted £75 collection only or arrange your own courier
34. one off rs2000 buldge/bubble bonnet, the bonnet has been cut and a scoop/vent formed into it, no stick on crap, done properly! £120 collection only!
35. aero catch lockable bonnet pin's, brand new and still in packaging £35 posted
36. mk5 rs/xr morrette head lamp's, inner lamp have been removed and air duct's put in there place, will come with all wireing £200 + £12 p&p
37. NOMAD half smoked rear light's, proper one's, not crap spray tint jobby's £150 + £10 p&p
38. escort cosworth HEX cloth interior, front + rear seat and front + rear door card's, good condition, but need a clean, 1 rear card is broken, but back seat cover's it... £350 collection only!
39. mk5 alloy clutch quadrant, used as an upgrade for rst's apparently? £50 + £3 p&p
40. mk5 steering wheel boss £20 + £5 p&p
41. esc cos banana pod (no clock's) £25 + £5 p&p.....gemmap1984 SOLD
42. nomad twin pilla pod gauge holder, all in one thing, not screw on one £50 + £4.50 p&p
43. 17x8 compomotive MO's et35 iirc will have to double check, but i think the tyre's size's are as follow's.... 2x 215/45/17's and 2x 205/40/17's, all tyre's are toyo t1r's and all have plenty of tread because i only used them for 3 month's on my old saph, all wheel's are mint! and havnt seen a road since being powder coated black!! come with blue centre's £600 collection only.
44. DTM wing mirror's to suit mk5/6 escort, brand new, only trial fitted a couple of week's ago £20 + £5 p&p
45. WRC fibre glass grill, brand new, but been chopped down abit so it would fit above the front bumper properly, still look's the part though, no mesh fitted, £35 + £6.50 p&p
46. rear rs2000 gearbox mount £17.50 posted.... massivewangers
there's plenty more that's i'v proberly forgoten, but once i start to break the car i will update with pic's and price's etc.
i would prefer collection on all the above idealy because i find it hard to get time to go to the post office to post thing's, so you may have to bare with me if your wanting something posted, i will do my best to post thing's as quick as i can though!!
here's a few pic's of the car and a few part's, i can get pic's of individual part's on request if need be....
![](http://i102.photobucket.com/albums/m106/tezmanian_devil/escort%20project/fa9e7818.jpg)
![](http://i102.photobucket.com/albums/m106/tezmanian_devil/escort%20project/5252e361.jpg)
![](http://i102.photobucket.com/albums/m106/tezmanian_devil/escort%20project/e7dc880c.jpg)
![](http://i102.photobucket.com/albums/m106/tezmanian_devil/escort%20project/8bd0eb2a.jpg)
![](http://i102.photobucket.com/albums/m106/tezmanian_devil/escort%20project/fbdfc5c8.jpg)
![](http://i102.photobucket.com/albums/m106/tezmanian_devil/escort%20project/96e490d6.jpg)
![](http://i102.photobucket.com/albums/m106/tezmanian_devil/escort%20project/thb1629fef.jpg)
there you have it, i really am gutted to be doing this, but i really need to sort my life out and get my career sorted, if i could afford to do my gas course aswel as get this finished i would, but unfortunetly i cant atm so need's must, only a car at the end of the day eh![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
like i said above, all price's are ONO so sensible! offer's are welcome.
thanx for looking.
anyway here goes...
thanx for looking.
yeh, im sooo gutted, but the time has come for me to grow up and sort my life out, 24 now with a fiance and a 21month old daughter and not having a proper career and relying on my dad for work has to stop
not all bad though, once i'v done my course and im qualified i can set about having a go with something else, maybe a proper esc cos next time?
where has my comment gone? lol is it the black -6 fittings in the build page your selling? will you sell without pipe as i wouldnt need that, pete
aka Turbosailorboy
https://passionford.com/forum/ford-r...-breaking.html
Posted for sale thread in 2 rooms to confuse us
ahh im a fukking tool lol
