- 88 Spec Rst Clocks
- grp n escos shell
- S1 Bits
- Twin or triple clutch
- Mk6 RS2000 Alloy center cap, URGENT!!!!
- Mercury Grey 90 Spec Spoiler
- s1 standard boost hoses and water hoses complete set
- Ecos rad an fans
- 13" or 14" alloy wheels for mk 1 fiesta
- wanted...mk3 escort estate sports exhaust!!!
- Moonstone 3dr wanted
- escort cosworth and 4wd bits needed
- rs500/3door wide arch bodykit
- Number Plates
- S2 RST Clutch needed ASAP
- cossy parts need
- esc cossie wanted
- omex 100 ignition controller or similar
- Escos Small turbo cam cover
- 9/10in wide split rims
- Escort Cosworth/4wd Sierra Calipers
- .63 housing
- Ecos rad an fans
- Fiesta RS Turbo Bottom Rad Hose
- S1 Parcel Shelf
- switch that dims/brighten dash
- 2wd cossie engine loom
- bucket seats
- Ford racing oil pressure & volt meter 52mm
- Escort rs turbo stainless parts
- escos 4x4
- Sapph rolling shell
- WANTED: a couple of Mk4 Escort bits.......
- s1 rst column and steering wheel
- Escos space saver whhel and cover
- alloy wheels wanted
- s1 ans s2 parts needed
- erst s2 bonnet vent screws
- wanted 7J 15's
- Rs Turbo MFI Head, would take 1 with bent valves!!
- wanted mechanic (bournemouth)
- escort rs turbo standard breather wanted
- Ford KA wheel arch
- Non injection MK4 escort car loom
- sierra/saff boss kit for a momo wheel
- rs turbo series 1 fuel tank sender
- XR3 spats wanted
- frst boost hose and fuel pipe,filter and bracket
- coilpack bracket for a cvh efi
- Escort RS Turbo Engine
- wanted mk4 escy strut boots
- MK1 Orion loom
- fiesta 1600 zetec-s. cams and coilovers
- fiesta rs turbo engine or bottom end
- Galaxy drivers door mirror electric
- Wanted 17x8 sapph fitment tsw imolas
- Mercury Grey Sierra Bonnet
- 4x4 front brakes for saff
- after mk3 escort s-rack steering wheel
- standard sapph cossie lifghts in amber for early saphh
- Saph boot lock
- wanted small van
- Cosworth fuel pump
- escos alloys
- Stack Dash
- Saff Roof Lining
- Bilstein 909 Tarmac Rear coilovers
- 2wd cosworth thermostat housing
- 1300 x flow engine and parts
- Escos Front bumper
- 3 Door cosworth
- tailagte wiring for escos
- mk3 rubber floor mats
- escort cosworth/mk5 vents behind bumper
- help to Denmark www.rallycar.dk
- zvh bottom end
- s2 rs turbo engine
- 3 dr front hub
- mk 6 escort bits
- 500 clocks
- rs 500 clocks
- wanted
- alan bellamy
- shapphire cosworth
- RS Turbo Swirl-pot
- 3dr parts
- Focus rs
- 2wd cossie starter
- wanted 18in alloys with tyres to swap 4 mint set of escort cosworth wheels
- Xr3i Bosch Distributor
- 3 door cossy kit wanted
- Wanted focus rs
- wanted sapphire cosworth bonnet vents
- wanted standard 4x4 cossy CD player
- ST170 Engine
- s2 boot lid in mercury grey
- Wanted! Fiesta rs1800
- fmic grs airtech etc
- Escorts wanted
- escort or fiesta wanted
- koni key
- cosworth gearbox
- Escort Van Mk5 body modifications wanted - and front doors!
- Mint Series One Shell wanted
- GGR Dump valve
- fiesta rs turbo amal valve!
- escort s1 mk3 scuttle panel wanted
- RS Turbo bottom end and gearbox
- standed rs turbo cam
- Oil Catch Tank
- 2.0 pinto injection engine needed
- Escort Mk 4 - Front Shocks & Springs
- WANTED: 4x4 cosworth dipstick tube & dipstick
- Fiesta Mk 1 1.3 Ghia 1983 Digital Clock.
- Xr3i (mfi) Relays
- Range Rover p38 (BMW) 2.5 DSE Crank shaft bottom pulley
- 3 door lock set
- dump valve
- Sierra Cosworth 4x4 Fuel Pump Cradle
- Nice Sapphire Cosworth still wanted
- Saff electric rear window regulators
- Rs500 style intercooler for sapp cossie
- S2 Roll cage in kent /Essex area or where can i buy one
- 18/8 oz super t's
- Inner arch Covers
- Bonnet Pins
- S2 Samco or Uprated Hoses
- rs turbo loom
- Wanted frst stage2/195 chip for OFAB
- Focus rs uprated internals ( pistons ect..)
- ecc iv plenium
- MK5 Fiesta Zetec S front bumper!!
- carcoon
- 9" diff wanted
- mk5 dash
- Swap mondeo alloys for.....
- 90 spec spoiler caps
- 15" Alloys
- rst bottom end
- steel strut brace for s2 rs turbo
- 3-door gearbox cradle (not alloy sapphire one)
- 2wd Rear Beam
- 4x4 sapphire oil pump
- Saff trimmed shell.
- pace intercooler for my large radtec front mount
- Mk4 escort lowering springs
- Wanted Rally Car
- ford sierra morrettes
- Wanted rs2000 x pack nosecone
- 3dr cosworth front hubs
- strut braces for my 2wd
- Escos WRC Intercooler
- wanted fiesta rs turbo shell
- mk4 escort morretes just covers
- Late model Sierra 2Litre wanted
- mk6 escort H.F.S relays needed
- 205 block wanted
- B&M short shift
- escort cosworth crossmember
- escort cosworth .63 housing
- apexi boost controller
- orion exhaust system
- swap my rims
- wanted rs turbo engine
- Sapphire Interior
- mk3 escort ignition switch part
- ecu
- Wanted ford focus st 170 wheels
- Fiesta st alloy wheels
- escort mk3/mk4 non sunroof roofskin
- WANTED: Focus RS flywheel and clutch
- Monte 8"x18" rims
- rs1800 or 2litre cams
- ECOS RAD?
- CVH Standard Cam Pulley
- 4x4 cos engine loom (ecu part)
- bailey breather
- 1.8 zetec alternator
- 3 Door cos grill
- anyone breaking a focus rs?
- 2wd 7 1/2 diff quaife
- Stage 2 T3 please!
- escort cossie wheels
- SPA guages
- 1.8 zetec bottom end
- Saff cossie leather trim
- T3 Turbo + other bits
- mk3 escort cage, bucket seats, harnesses
- sierra cvh bits
- Series 2 rocker cover 88 spec
- S2 or possibly Sapphire Cosworth
- Focus 1.8 petrol middle timing belt cover.
- Bucket seats
- CVH/ZVH Breather
- s2 or s1 escort or rs fiesta
- I desperatley need...
- T5 gearbox ideally in the south
- northern ireland gearbox needed asap
- sapphire electric sunroof motor
- bit of a wierd 1
- dash
- erst fan, xr2 bumper...
- zetec turbo tubular exhaust manifold
- Cosworth Gaskets
- wanted escort s2 turbo alternator Heat shield
- S2 erst mudflaps front & back wanted
- Front inner arch covers
- T3 Turbo wanted for erst
- Rs turbo s2 dash wanted
- frst parts
- where can i get a s2 roll cage in chrome
- Heated front washer jets
- Upgrate Brake Kit for Escort Cosworth
- stacks fuel level gauge.
- xr2 bits
- Cosworth Racing 7.2:1 Std bore piston wanted
- Wanted - Not ford but range rover (P38) parts
- 2wd ex manifold
- 200 block wanted
- one bucket seat
- Sierra 3dr rear spoiler caps
- 3dr sierra front wings wanted urgently
- Black 90 spec front bumper + bonnet
- sierra cossie strut brace alloy OMP wanted
- t3 downpipe for fiesta
- Wanted bd14 exhaust cam
- *WANTED* Escos heated front screen & morettes
- damaged/ wornout t34+ 1 RL7 17in wheel
- S2 front mudflaps
- focus rs.
- wanted mk3 3.5 or frst shell
- I need mk1 sierra LHD glass headlights
- azev a for sale
- Wanted urgent ABS Sensors
- Need Saphire 2WD TCA's
- 2wd downpipe
- Escort Cosworth airbox
- nice set of wheels for the mrs puma
- ofac ecu and frst crossover pipe and fuel pipe
- sapph cos clocks
- Wanted escort mk3
- powerflex
- Saph Skirts
- Series 2 boot mat
- s2 chipped ecu
- 2wd cloth interior and other bits
- Escort Maxi Gearbox
- Wanted Mondeo ST24 Hatchback
