PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Cosworth ISCV & TPS
  2. series 1 passenger fornt arch - unmolested !!
  3. 4x4 cossie crank pulley
  4. rs turbo mfi head wanted
  5. big brake front setup for saff 4x4
  6. Racetech oil pressure gauge and fittings
  7. Escos interiour
  8. Wanted-Escort Cosworth
  9. Cosworth 4x4 propshaft coupling (doughnut)
  10. 2wd Cosworth horn push
  11. boost gauge.
  12. Cossie Power Steering Bottle Bracket
  13. cvh engine asap scotland
  14. Metering Unit bottom half.
  15. wanted 3dr parts
  16. Series 1 Rs Turbo Stealth Shelf wanted
  17. Silicone hose
  18. sapphire cosworth 4X4 GEARSTICK SURROUND
  19. mk3 fiesta roll cage
  20. rst plastic windows
  21. escort rst boot hinges
  22. Wanted cosworths good,bad or ugly
  23. Sapphire Cosworth Lattice 14" and 15"
  24. iveco beavertail recovery truck
  25. Escort mk5/mk6 injectors (stock) needed!
  26. xr4i/2wd cosworth engine mounts!
  27. comp mo5
  28. Ford KA
  29. Series 2 Rear Anti Roll Bar
  30. HEEEEELLLLLLLP Cosworth rear ARB bush to body brackets desperately needed
  31. S2 RS Door windows and Plastic from under steering wheel
  32. focus rs interior wanted
  33. new cosworth gaz gold coilovers,ford scuff stickers,ap brakes,what you got?
  34. WANTED Corner weight scales
  35. 17" flat faced comps wanted....
  36. Sierra Cosworth 2wd floor pan section
  37. Late sierra 4bolt fusebox
  38. 1.8 silvertop zetec dipstick and tube
  39. please delete
  40. Spurs vs AC milan tickets wanted
  41. Mk 3 escort/ RS1600i Body Panels Wanted.
  42. exhaust flange rs turbo
  43. Grp A brakes
  44. Headlight Ballast
  45. escort brake servo
  46. boot hinges from mk3/e esc ort boot or same as?
  47. FUEL CELL
  48. saph cos minus running gear
  49. 3dr cosworth propshaft
  50. FRS Gearbox mounts/brackets
  51. xr3i exhaust
  52. 4x4 cosworth
  53. gearbox plate (between engine and box) for cosworth or pinto
  54. Escort cosworth bonnet vents
  55. cosworth rad
  56. interior
  57. mk1 fiesta panels
  58. spax adjustable knob wanted
  59. cosworth 4x4 throttle body
  60. Cosworth 2WD Gear knob
  61. 17" rs7 diamond cut
  62. Mk4 escort headlight protectors
  63. Ford cd player and jack/wheelbrace
  64. Wanted escort cosworth undertray / stone guards
  65. Mk4 Escort Clear Indicator
  66. Heat shield etc
  67. Cosworth Koni bumpstops and boots
  68. Rs16i/mk3 escort fan
  69. Boost Controller
  70. a solid clean mk3 escort drivers door
  71. URGENT - ST170 INNER CV JOINT (passanger side)
  72. XR3i MFi silicone hose set
  73. Escort RS Turbo Radiator
  74. 4x4 Fuel Reg??
  75. Mk1 Focus RS stainless exhaust...
  76. Mk4 xr3i brake servo pipe
  77. 4 ford matching rear drums
  78. 0.48 Turbine Housing for RST T3
  79. YB cambelt cover brackets
  80. cosworth fuel pump
  81. delete
  82. Saff cos rear bumper. A nackerd one
  83. Any body got
  84. Rs turbo
  85. Spare Pistons anyone?
  86. mk6 escort gti parts
  87. light blue injectors
  88. Weber IW-058 injectors
  89. Ford CD player wanted
  90. 200/205 complete bottom end?
  91. sierra heater matrix
  92. Saph NSR Chassis Leg
  93. nackered saff front bumpers
  94. Blue Escort RS Turbo lighting relay
  95. mk4 escort engine mount
  96. mk1 focus xenons
  97. 3-door coss gearbox cradle metal not alloy
  98. 1600 X-Flow inlet manifold to suit 45's
  99. RS 7 spokes 14 inch with big cap in middle
  100. Alloys and various Mk5 bits
  101. Wanted - Fiesta RS Turbo Pro Alloy radiator
  102. Rs turbo engine wanted for rebuild
  103. **WANTED** Fiesta Mk1, Mk2 Zetec or Mk3 RS turbo Zetec
  104. **WANTED** Fiesta Mk1, Mk2 Zetec or Mk3 RS turbo Zetec
  105. ** Sump and TB Needed **
  106. mondeo mk3 zetec wheel please
  107. sierra spoiler
  108. Escort injectors and Brake servo
  109. v6 / v8 engine block
  110. Management for Zetec Turbo
  111. Any nackard yb 2/4wd head
  112. Carbon canards varis or similar all considered
  113. Amber indicators
  114. cosworth belt cover fixing
  115. 2wd rear beam and arms.
  116. puma tow eye cover
  117. Anyone about to scrap
  118. Cosworth T5 Input Shaft
  119. Drivers side front black leather door card
  120. 500 cooler
  121. Mk2 focus rs stailess exhaust
  122. WANTED: S2 rear bumper and heater box cover
  123. idel speed valve
  124. Focus RS manifold
  125. Chip
  126. tailgate and bumper
  127. Ford Escort 1.6 Zetec Manual Gearbox Starter Motor Rear
  128. S2 fuel pump relay (pink one)
  129. XR3i Mk4 gearbox
  130. Escort XR3i or Rs Turbo 90 spec bumpers
  131. Innovate XD16
  132. focus rs cd player
  133. S2 fuel accumulator bracket
  134. S2 Fuel sender loom
  135. WANTED Escort Cosworth Rear Brake Stone/Dust Guards Needed for restoration ASAP
  136. mondeo st parts
  137. Boost controller
  138. Cosworth tps - pf09
  139. ERST Alloy Radiator
  140. Good 4x4 s,s exhaust
  141. escort dials
  142. S2rs front speaker bracket
  143. 3DR indicator stalk , central locking relay .
  144. sierra cos 2wd gear stick
  145. 2wd rear drive shafts with stub shafts
  146. Escos parts
  147. Saff washer jets
  148. focus bits
  149. Zx volcane or xsara coupe dturbo In the UK
  150. Wanted cosworths good,bad or ugly
  151. esc cos front wheel arch liner's WANTED!!
  152. Injectors wanted
  153. XR3i/Mk 4 bonnet (without vents) near Perth?
  154. Sierra Cosworth 2wd front Hubs
  155. vito seatbelts
  156. 2wd big wing sump
  157. Wanted cosworths good,bad or ugly
  158. mk2 fiesta battery tray
  159. S2 Turbo/XR3i 90 spec parts
  160. spoiler
  161. 2wd T34 cosworth boost hoses
  162. Decent S2 Rolling Shell Wanted.
  163. CVH Lower Cam Belt Cover
  164. 2wd cosworth sump & oil pick up
  165. Focus RS mk1 coilovers
  166. Rear Door card(s) for a 3 door cossie.
  167. mk4 escort rear seat belts
  168. mk 3 passenger wing URGENTLY !!!
  169. anyone breaking a mk3@mk4 escort, roof wanted
  170. MK4 Escort Heater Fan Speed Knob
  171. Cosworth throttle body
  172. WANTED : Tyres
  173. Wanted : Black Samco Hose Kit
  174. focus rs rear bumper and front wishbones wanted
  175. 90 spec front bumper
  176. 4x4 saff standard breather pipes
  177. bunper
  178. cossie / cvh oil drain pipe???
  179. Sierra Rear Caliper Sliders
  180. fiesat rs turbo front hubs
  181. 1.6 Zetec SE BlackTop Engine Required
  182. Sierra rooflining
  183. 205 block required
  184. Cabriolet s2 parts wanted
  185. 2l pinto
  186. YB WRC head gasket
  187. Wanted Transit Connect Alloys
  188. Indicators
  189. wheel spacers
  190. Cossie Exhaust Cam
  191. sunroof and windscreen
  192. 2wd sump & oil pick up piper, Pair vernier pulleys
  193. MSD Coil Pack Loom - (now sourced)
  194. Cheap car wanted
  195. S2 RST Engine loom needed!
  196. mk3 escort poly windows, digital dash set up, bucket seats
  197. rs 1600i front spoiler
  198. Mk 1 Focus rs project
  199. WANTED: Mondeo st tdci induction kit
  200. Escort RS Turbo S2 chipped ECU wanted
  201. fiesta turbo green stripe set
  202. 4x4 box input shaft
  203. focus rs rear bumper
  204. Escort s2 cts stage 2 gearbox
  205. 2wd front calipers
  206. s2 window seals for doors
  207. 88 spec front bumper pref in white
  208. *please close*
  209. ERST Suspension
  210. Mk1 Focus RS Drive shafts
  211. Wanted MT75 gearbox, RWD please
  212. Wheel spacers & bolts
  213. efi throttal position sensor
  214. S2 rs turbo
  215. Pair of YB vernier pulleys, 2wd sump & oil pick up
  216. focus rs bits
  217. Oil return pipe
  218. rear lights
  219. Saff front and rear bumpers
  220. Rs 4 spoke mk4 rs turbo boss
  221. ford focus gearbox
  222. 90spec 5dr door cards wanted
  223. 12'' Slimline Fan
  224. mk3/4 rwd shell
  225. Cosworth sapphire lattice alloys
  226. Mint low miles escort cosworth wanted.top price paid
  227. FRST breather
  228. WANTED Cosworth engine complete with loom gearbox for kit car
  229. saph fog light surrounds
  230. Wanted Escort Wing
  231. 06 plate transit engine
  232. Mondeo ST200 or Focus ST170 4 alloys wanted
  233. Subaru impreza wrx front brakes
  234. Bonnet
  235. fiesta/escort rs turbo
  236. Merc ml alloys 20"+ preferred Audi q7 all considered
  237. wanted 4x4 cosworth coilovers
  238. esc cos front wheel arch liner's please.
  239. 7.5" Diff Output Flanges
  240. Wanted 18inch comps
  241. 7" cossie rear diff pref dead !
  242. HELP NEEDED - trying to source a merc sprinter engine ???
  243. S2 stealth shelf
  244. ACT Gauge
  245. gt30
  246. HELP! I need a seat base to fit my Recaro..
  247. Wanted escort cosworth alloys
  248. Sierra Saph Cossie 4wd
  249. standard ford saph radio
  250. cosworth throttle body
