View Full Version : Cars & Parts Wanted.
- any 3 door splitter
- T34
- 2L mondeo ecu (deep, desk, dewy)
- Escort Rs Turbo Wanted
- RS LSD Box
- Rs turbo tailgate
- Cosworth 6 Paddle Clutch and Reyland Hydraulic Clutch Conversion
- 3 door cos sunroof glass.
- Amal valve bracket
- focus
- Needed Cossy T5 Gearbox damaged
- T34/48 turbo wanted
- s2 water inlet pipe
- monte wheels or 16"compomotive th`s
- Fiesta mk1 xr2 drivers door and back panel
- please delete
- -31 Actuator
- Turbo technics front arb
- 3dr tailgate and door moulding s
- series 2 RS turbo rear disc conversion set up
- RS Cars Wanted Cash Waiting
- 3dr fibreglass bonnet and tailgate
- mint escos doors and morrettes, baileys bits
- 2wd saff dash parts
- Old Van, Luton Box?
- cosworth idle valve retaining washer
- zetec valve springs
- 2 x 195/50/15's
- Uprated rear diff mount for 4x4 saph
- Escos rear anti roll bar
- WANTED: Passenger side Sapphire jacking point covers
- Alpine Cd player or dvd player
- MK6 Escort steering wheel boss
- Escort mk4 bc final drive gear
- Wanted Mk6/7 Escort Bumpers RED
- +++90 spec rear seat brackets WANTED+++
- escort rs turbo in need of work
- escort turbo shell
- wanted a car near essex
- 2wd cosworth suspension wanted
- wanted suspension for a 2wd saff all things considered
- wanted, Single Cossie CONROD
- needed! 1.8 zetec flywheel
- wanted: 3 door cosworth standard wheels
- wanted: any 3 door bumper splitter
- Wanted - Fiesta XR2 Driveshaft
- O/S 3 door fog light
- wanted: 2wd front brake setup
- cross memeber 2wd engine mounts
- cosworth ignition amplifier
- Saph trim bits.
- escort mk4 rear wishbones and hubs
- fiesta mk3 door and boot locks with keys
- Standard 3 door Downpipe wanted
- Bucket seat
- seat/audi/vw 4pots
- Wanted good 4x4 cossy front drive shafts, st170 driveshafts
- Fiesta recaro subframes.
- WANTED: 4x4 cossie front prop
- MK2 XR2 bits
- Wanted: set of TSW Hockenheim for 4x4 sapphy
- S1 gearbox
- Astra engine
- standard 2wd parts
- 215/40/16or 225/40/16
- 7.5" rear beam, 4x4 crossmember
- 2wd saphy engine
- 2wd saph spring kit
- puma bits
- ford focus zetec 1.8 cams wanted
- **WANTED MK3 FIESTA PASSENGER SIDE DOOR (3dr)**
- Mint Escort Rs Turbo 1990 mfi wiring loom
- sierra sapphire morettes
- Sapphire Cossy ID wanted
- wanted 4 paddle clutch for escort s2 rst
- RS 500 block
- WANTED T4 actuator & damper brackets
- 3dr seats
- mk5 escort fusebox
- Wheel Studs, Spacers and Nuts Wanted
- focus mk1 2litre rear brakes wanted to convert 1.8
- 4x4 Sierra Cos.
- 4x4 engine
- 4x4 cossie rear calipers/discs
- 17" momo arrorws
- escort mk3/4 fiesta mk1/2 front lowering springs
- 2wd sapphire cossie TCA
- Escos bits
- please delete
- speedo cable
- sierra bottom cover (timing belt)
- 15" Motorsport style rims/tyres
- cosworth 2wd disc's[fronts]
- S1 bodykit+ other mk3 Escort parts
- [Wanted] Escort Cosworth / 4x4 Intercooler
- 4x4 floor pan & strut tops
- monte wheels
- Unsaged/ all mounts intact sapphire Front bumper
- STD 2wd Cossie alloys
- **2.0 Zetec Wanted**
- 2.0 Silver top con rods.
- Wanted 3 door front bumper **mint**
- ST170 VVT Solenoid - wanted!
- 3 Door Grille Badge Wanted
- Guitar Hero - World Tour - Band Bundle for the Wii
- escort cosworth shell wanted
- WANTED: Mongoose centre section for 4x4 saph
- 3dr heater fan/blower
- 205/40/17 x4 just need to be legal
- S2 RS Turbo Parts
- Sports steering wheel
- Wanted cheap good spec 2wd saff
- Sierra 3 Door Boot lock
- rs turbo gearbox
- Saph Leather Door Cards
- 90 spec front bumper
- 2WD prop shaft wanted
- rollcage for xr4i wanted
- 3dr cosworth wheels wanted
- 2.0 1.8 zetec bottomend
- 3 door Cossie wheels,
- 701 beiges and samcos
- s2 front speaker grill clips wanted
- escort rear drums
- mk3 escort mirror back plate/cover
- RST Front Bumper
- 2wd front discs
- Cosworth arp heald nut and bolt kit
- Escos Rear Bumper
- 1.6 or 1.8 zetec water pump pully
- azev a 17" any condition or rondells any condition
- 2.0 Silver top
- fiesta zetec s 1.6
- 2WD Cosworth Sump
- Small piece of 13mm ID samco hose
- S1/S2 RST Gearbox
- Front Driveshafts for 4x4
- Decent cheap fishing stuff....
- 2wd turbo heat sheild
- 4x4 saff set of koni,s
- Wanted 4x4 cos stainless exhaust
- 2wd saph master cylinder
- saff electric windows switches
- early saph rear lights and indicators
- escort cosworth shell rolling/track/road why cash waiting will consider full car
- Escort Rs turbo S2 Oil cooler
- Sierra 3 Door Map sensor Bracket
- Late as poss saph shell
- 3 door Windscreen
- cosworth engine
- 4x4 box needed
- rs turbo bottom end timing belt pulley
- Wanted, ERST bottem end
- wanted ap 6 pot callipers
- cossie fuel pressure reg, inlet trumpet section
- Pas banjo
- saph 4x4 timing belt cover
- saph 4x4 or esco heat shield
- wanted 2wd sapphire cosworth asap
- ####### wanted 215 35 18 tyres #######
- 2x Front Seats - Saph Cossie
- NEED ASAP Turbo Gaskets!
- WANTED fiesta mark 3 shell in good nick
- Set of white motorsport alloys 17"
- escort rs turbo suspension
- Anthracite 6 Spoke MO's in 17
- MFi Head Wanted...
- Frst /efi stage 2/3 head wanted
- .55 t34 cosworth back housing
- A few saph cossie bits
- MK6 RS/Si Rear bench
- Need Konis & Bumper!
- Mk5 escort 3dr roof panal wanted.
- free money
- rear inner arch liners for saph 2wd
- escort rst s1 samco
- rally car
- 2wd coolant hoses(blue)
- F150 Lightning wanted!
- Uprated 2wd rear diff
- standard frst wheels
- Escort Cosworth Side Lights ??
- 3DR parts wanted
- 2wd .63 housing
- renault 5 turbo
- t3 turbo
- escort cosworth plenum
- Dump valve
- sapph c pillar trims
- t2 turbo
- Mk1 Focus Bits. 16'' zetec wheels, rad etc.
- sorted
- Uprated diff mount and Ahmed springs
- 4x 205/40/17
- Air injectors
- RS Turbo fuel tank & sender
- tyres to fit escos rims
- wanted sierra bit's
- Wanted: 195 40 16 tyres
- rst konis, ofac map sensor rst parts
- RS 3 spoke s/wheel
- escort cos door aperture seals
- Saph Jacking Point Covers
- Not ford but mk4 astra gsi front bumper
- mongoose or blue flame sierra 4WD
- saph cossie spoiler caps wanted
- 4x4 saph cossie mongoose exhaust middle section
- focus rs passenger rear quarter pannel
- WANTED 1.1 Fiesta Carb
- rs500 style intercooler
- Escort RST S2 sunroof glass with seal
- EFI wiring loom with ofab ecu, sensors etc etc
- mk3 mondeo zetec s front bumper wanted
- mondeo 16inch 5spokes
- 4.4 cwp for 2wd
- Wanted 530/525d Early E60 (sport would be nice)
- 5stud st220 or focus st wheels .
- Twin air to air injectors
- Escort Van wanted - dead engine preferred!!!
- MT75 gearleaver cradle
- rst limited slipp diff wanted...
- Cosworth rocker cover
- mk4 escort engine mount zetec!!
- 3dr sierra gearbox mount wanted
- T34 turbo, rear lowering springs 4x4 saff
- Fiesta ST Front Brake Setup
- have now got
- 17" slick tyres
- ecos gear stick
- mk4 escort front arch liners
- rs7 diamond cuts 17" cash waiting
- radiator
- Cossie Leather front seats.
- 25mm dump valve plug
- SOLD
- escort rs turbo S1 header tank wanted!
- ### WANTED### Mint cosworth screw type rocker cover
- MK3 ESCORT wanted ====>
- Focus tdci sport
- 3dr plenum to throttle body part
- saph cossie dash peice.
- MK3 mondeo front brake calipers
- Mondeo Mk3 Boot Spoiler Wanted **
- saff 4x4
- Cvh piston rings ??
- Corsa bits
- focus rs caliper, twin piston dump valve
- upgraded diff hanger
- rear escort mk3 bumper
