PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. WANTED: RST calipers
  2. Sierra 4x4 front brake calipers
  3. MK4/5 boot popper switch
  4. 1 Ford Racing gauge white face ideally...
  5. Bailey breather for RS Turbo
  6. Saph headlights
  7. RS Turbo Fiesta
  8. Wanted 3" cosworth downpipe straight
  9. 3dr cosworth replica wanted project etc
  10. Few S1/S2 bits needed
  11. RS Turbo bodykit and 90 spec front bumper WANTED
  12. group a front hubs
  13. Mk1 Focus RS nearside side skirt
  14. Cosworth ABS pump
  15. Accelerator pedal cover
  16. 2wd Cosworth Gaz front coil overs wanted
  17. S2 / XR4i calipers
  18. Rs Steering Wheel Horn Centre
  19. Sapph rear strut brace
  20. S2 bodykit. Needed in good condition.
  21. Cosworth engine wanted
  22. 2wd sapph hubs please
  23. Series 2 RS Turbo idle screw wanted
  24. Cosworth 3bar map sensor
  25. starter for 2wd cosworth
  26. Yokohama AO48
  27. T5 Bellhousing WANTED
  28. 2wd alloy bells & 320/330x28mm rotors
  29. Sierra Cosworth 3dr Door Cards Wanted
  30. urgent has anyone got a fiesta rs turbo rear drivers arch?
  31. Standard s2 turbo exhaust
  32. 90 Spec rear spoiler wanted
  33. Complete Saff interior
  34. 90 spec front bumper
  35. 2wd Saff Cosworth wanted.
  36. bits wanted
  37. Wanted - Standard 4x4 Cosworth Rocker Cover
  38. Saff ford stereo
  39. Sierra battery tray wanted
  40. Mk4 Escort centre cap & wheel clamp wanted.
  41. Escort RS Turbo Series 2 parts wanted
  42. 7.5" lsd diff plus uprated mount
  43. please delete
  44. Standard exhaust 3dr/500
  45. Carbon fibre for sapph!!!
  46. Sierra Cosworth Mongoose 3inch or 3.5 inch backbox
  47. 1.25/1.4/1.6 zetec oil pump
  48. Saph engine bay bolts
  49. hydraulic clutch pipe for Focus RS MK1 slave cylinder
  50. ERST/FRST/2wdSaff
  51. Scrap 2wd oil pump OR just the cover URGENT
  52. n.o.s rs turbo s2 rear stub axles
  53. Number plate light
  54. Cam pulley bolts, front pulley bolt, Dizzy pulley drive bolt and washer
  55. Head light to indicator bolt
  56. 7.5 inch rear beam
  57. Fiesta/escort turbo
  58. Sapphire alloy skirt clips
  59. cosworth 2wd billet diff mount
  60. spacers
  61. Small turbo Escos crank sensor
  62. 4x4 rear calipers
  63. Heated rear or front screen timer relay
  64. wanted s2 90spec spoiler
  65. Refurbed or mint red cam cover
  66. Rl7 saff fitment 17s
  67. Stage 3 chip L6 ecu
  68. Aftermarket steering wheel boss
  69. .55 exhaust housing escort cosworth
  70. Escort Cosworth Carbon Fibre lower splitter
  71. 2 wheel drive cosworth gearbox bellhousing and a propshalf
  72. fiesta mk3 RS Turbo parts wanted
  73. Rs center caps
  74. yb block 205 or 200 damaged un use able
  75. after fiesta st150 bumper
  76. sapphire boot lid
  77. Saff steering wheel
  78. escort cosworth n/s rear quarter glass wanted
  79. Level 8 ECU needed ASAP Please
  80. *sorted* Focus ST170 drive shaft PLEASE DELETE
  81. WANTED - mk3/4 escort COILOVERS
  82. WANTED: L8 Cosworth 4x4 Weber PF09 TPS
  83. 18 inch MO6 wanted
  84. Mk3/4 Escort van
  85. Flint Grey 4x4 Saph
  86. Mk4 escort shell 2door
  87. ford dealer (peacocks ford balham) document folder wanted
  88. 4" scorpion back box for saph cossie
  89. Comp th2's 17" saph figment
  90. Sapphire drivers door with glass
  91. Cosworth 2wd starter motor and 3bar map sensor wanted
  92. r888 tyres wanted
  93. Saph 4x4 door mouldings
  94. genuine fiesta rst bodykit rivets! rear arches + much more
  95. aubergine escort cosworth
  96. WANTED: Plastic trim between bumper and headlights on a saph
  97. 4x4 cossie calipers
  98. Saff rear bumper
  99. Standard MK4 Escort Bonnet
  100. 2wd stainless brake reservoir cover
  101. RS500 lower spoiler
  102. Iphone
  103. Cheap Escos?
  104. Cosworth badge
  105. L6 engine loom wanted
  106. Sierra sapphire cosworth
  107. Sierra 2wd rear arch liner P/S
  108. Saph Cosworth Wanted.
  109. mk5 escort dash
  110. Duratec turbo manifold
  111. RS500 turbo damper
  112. Washer bottle pump
  113. Wanted xr2 mk2 full dashboard
  114. MK4 Escort bits...Sorted thanks to maido!
  115. Wanted sapphire Cossie genuine ambers
  116. Sierra top rear spring rubber thingy...
  117. Single escort Cosworth standard alloy wheel
  118. Sierra Estate
  119. rs turbo shell
  120. Mk 4 escort parcel shelf wanted
  121. WANTED 90 spec Recaros
  122. Mint Escort Cosworth spring pads with all tabs intact
  123. Escort RS Series 2 Dizzy
  124. Power aerial wanted!
  125. 4" Cossie air filter to turbo hose
  126. Cosworth 2wd oil pump
  127. Clio 172 or 182 cup wanted
  128. 2wd Cossie sump
  129. RS 500 fibreglass upper rear spioler
  130. Escort Cosworth Seats and door cards
  131. cosworth group a anti rollbar set up
  132. Yokohama AO48
  133. zetec vernier pulley's
  134. 3dr cosworth replica wanted
  135. Sapp cos bumper brkts
  136. Wanted mk2 fiesta xr2 driveshafts
  137. Heated windscreen 1990 orion /escort
  138. sierra/cosworth 4x4 LHD rack
  139. GGR or Forge Competition Dump Valve
  140. mercury grey drivers door ERST
  141. Coil overs
  142. 3 door cosworth.........
  143. series one rs1600i alloys wanted ??
  144. RS steering wheel
  145. xr2i mk3 fiesta doors ect
  146. RS500 fog grills
  147. please delete
  148. Good pair of 215/40 17
  149. turbo damper
  150. WANTED: Set of decent wheels for a 4x4 saph
  151. T5 2wd gearbox wanted
  152. Saph white rear bumper
  153. Focus RS Mk1 Bits****
  154. 2 escos bits
  155. please delete
  156. wanted large escort rs turbo brakes
  157. WANTED,,,engine management preferrably dta why for zetec turbo
  158. Rondell/Engels
  159. Saff cos boot spoiler
  160. Fiesta Rs turbo ofac map sensor
  161. Front brake hoses
  162. Fuel rail to reg fuel hose...anyone?
  163. Shopping list
  164. Mk3 Mondeo wing
  165. GT28 for a focus rs mk1
  166. escort mk3 windscreen
  167. Sapphire propshaft bearing floor spacers
  168. Wanted: damaged or broken saph headlight and tail light
  169. Rondell 122/ Engell 122 wheel centre caps URGENT!!
  170. 4x4 Cos water feed & return pipes + oil return (TURBO)
  171. Saph white rear passenger door
  172. Saph lock set wanted
  173. 18" compomotive mo6
  174. wanted escos t25 engine loom
  175. Escos BT air box lid
  176. Cosworth 3DR Front Grill Panel
  177. 3 door parts
  178. Saff amber
  179. mk4 orion , escort ghia
  180. escort rs turbo recaros
  181. Rs 4 spoke steering wheel with horn
  182. Fiesta Si 1600 Mk3 Gearbox
  183. Fiesta RS1800 or XR2i 16v Alloys (14inch)
  184. cosworth standard 4x4 exhaust camshaft
  185. Mk1-1.5 steering wheel boss focus
  186. ROOSE OR SAMCO HOSES RS2000 mk5
  187. 86 3dr cos interior front kick panels wanted.
  188. Adrenaline 3 point rear strut brace. WANTED
  189. Escos rear arb bushes
  190. Wanted focus mk1 rs intercooler
  191. St205 gt4 decat needed asap
  192. Rear door cards
  193. Cosworth engine lifting eyes.
  194. Leather interior
  195. Focus 1.8 / 2.0 Petrol Zetec Driveshaft Bearing Bracket
  196. Black samco 4x4 cos hose full set for swaps
  197. st220 alloy
  198. Mk2 Focus RS turbo (K16) wanted
  199. Puma wing and bumper
  200. Escort RS Turbo N/S Driveshaft.
  201. Siemens 55 injectors
  202. focus rs mk1 front dics
  203. 17" Cosworth Alloys
  204. 3dr cosworth Adjustable TCAs
  205. YB rocker cover required
  206. Side exit exhaust for cossie (909 or copy)
  207. Need sierra inner wing urgent!!
  208. mk1 focus rs/st170 spoiler
  209. NOMADS
  210. Accessory steering wheel wanted
  211. 17" Compomotive CXN's
  212. few cosworth parts
  213. Rs2000 wanted mk5 or 6 4x4
  214. cosworth 4wd exhaust
  215. 3Dr Cosworth panels in White Wanted
  216. Banana pod & gauges
  217. Saff back box
  218. Mk4 bits.
  219. wanted escort s2 rs turbo drive shafts
  220. 2.1zvh engine
  221. 2.0 Silvertop Zetec engine
  222. Mercury Grey S2 Drivers wing mirror
  223. 4wd cosworth exh manifold and 2wd cosworth gearbox cradle/mount ***parts now acquired
  224. Focus 2.0 Gear Linkages MK1
  225. Zetec turbo engine
  226. Sierra 3 door Drivers side (O/S) front wing
  227. Granada 5 x 112 PCD Hubs
  228. 4x4 big winged sump, fuel rail
  229. Fiesta ST Mk.6 Pre-facelift O/S light cluster
  230. 3dr cossie wanted anything considered
  231. Rs turbo bailey breather tank
  232. puma headlights
  233. 7.5" 2wd Cosworth 108mm Diff Flanges
  234. Industrial steam cleaner
  235. Escort RS Turbo (S2) Gaz Coilovers & adjustable TCA's wanted.
  236. S2 bumper
  237. 4X4 cosworth JIC fitting fuel rail
  238. Stainless Steel 2wd BRAKE RESERVOIR COVER
  239. Focus RS Mk1??
  240. escort series 1 RTS
  241. Level 8 & PF09 TPS
  242. 88 spec s2 interior sill trims wanted
  243. S2 bonnet
  244. fuse box
  245. Escort Cosworth Wheels Comps etc
  246. Bonnet catch
  247. Mt75 box
  248. sierra sapphire scuttle panel wanted !
  249. 1990 ORION 1.6 inj gearbox
  250. 17" RS 7 Softlines for S2 ERST wanted.
