PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. sapphire gear lever tim wanted guys
  2. 2.8 cologne distrubutor
  3. rs 4 spoke wheel
  4. Rs turbo bailey oil Separator tank
  5. Got £500 to spend on a small run around
  6. Cheap 2.0 zetec block + 1.6/1.8 early zetec parts
  7. wanted capri mk1 winter project
  8. Gearbox
  9. E39 m5 wanted!
  10. Sierra 1.8 CVH Pick Up Pipe
  11. Sierra door pins and bumper bracket.
  12. Escort Rs turbo springs
  13. Rouse/RS500 splitter for Saff Cossie
  14. Sierra/Sapph 4x4 LHD rack
  15. Wanted Focus 1.8 Zetec Gearbox & Flywheel
  16. WTD!!!!! 2wd Water hoses
  17. Wanted - MTX75 & Linkages
  18. Sierra steering column
  19. Series 1 rs turbo alloys
  20. Wheel arch liner
  21. Wanted-Mondeo ST200
  22. Mk6 RS2000 Airbag Ring
  23. Wanted RST Chrome/Polished parts, urgent.
  24. Mk1 Focus RS Calipers
  25. 2.0 duratec engine, ecu and keys
  26. MK 1 RS focus gearbox.
  27. WANTED... EFI RS Turbo Engine
  28. WANTED... Gearbox for S2 ERST
  29. S1 ERST ns window motor
  30. Mk2 Focus RS Driveshafts Urgently wanted, even broke ones
  31. Sapphire 4x4 centre console and leather lid
  32. cosworth 4x4 front hub flange
  33. Front and side ambers for a saph
  34. 2wd sump, oil pick up & T5 gearbox
  35. Motec m800 m880 or m400 considered
  36. Old Ford badges
  37. Mint MK3 escort Front Bumper
  38. Wiper motor
  39. 2wd sapph coilovers
  40. WANTED bodykit rails for side skirt
  41. Black fiesta rs turbo front bumper
  42. looking for a s1 s2 or 3rd replica
  43. tail gate wanted for S2 RST mercury grey
  44. sierra spare wheel retaining screw thing
  45. Where to find 4 I biplane spoiler rubber/seal ?
  46. Tsw hock center caps and spring clips
  47. pectel monitor
  48. WANTED cosworth twin air injectors
  49. wanted 1x Ears motorsport RL7
  50. Good condition 80's ford badge
  51. 4/5 Channel Amp
  52. Zetec water pump pully
  53. T34 compressor housing
  54. Wanted Zetec Turbo Engine
  55. mk2 focus heated seat switch gear + bits
  56. Celica gt4 st205 rad needed today cash waiting!!!!!!
  57. Sapphire Cosworth drivers door catch
  58. mk1 sierra loom
  59. A S cossie intake manifold or similar!!
  60. Focus RS mk1 alloys in silver with tyres
  61. Saff rear lights
  62. GpA cosworth Rear Anti roll bar ,Tarmac spec wanted
  63. 2wd cosworth gear stick
  64. YB Cosworth cam cover // Aftermarket needed
  65. 16" wheels Rs turbo fitment wanted
  66. 17" TSW Hockenheims sapphire 2wd fit
  67. escort cosworth steerign wheel and airbag
  68. Siemens 55s or Bosch greys
  69. Trim clips
  70. 2wd intercooler
  71. cosworth 4x4 heat shield
  72. Oil feed pipe for gt30 turbo 2wd.
  73. Cosworth 4x4 cylinder head wanted
  74. Saff cos door // boot seals
  75. Puma Stuff
  76. 96 RS2000 Fuse Box
  77. Pistons
  78. Wanted - Saph bulkhead/firewall
  79. Parts Wanted for Mk5 Zetec S fiesta
  80. Escort Bonus/Popular wanted anything considered
  81. saff cos pillar mounted boost gauge pod!
  82. saff cos bumper mouldings??
  83. S2 Alloy x1
  84. Escort Cosworth Prop Donut
  85. Bucket seat and harness
  86. Focus RS Mk1 or ST170 Drivers door - Reading area
  87. Saff cos 2wd parts needed!!
  88. XR3i Front Calipers
  89. wanted RL7 in 17"
  90. wanted t5 cosworth box
  91. Cosworth T3
  92. Cosworth con rods
  93. Brakes coilovers gauges and more for a sapph!!!
  94. Sapph rear door inner triangle trims
  95. 15in steels
  96. Saff bits
  97. Knackered 2WD rear diff
  98. Transit Connect Drivers Door Lock Mechenism
  99. fork mount puma/fiesta rear beam?
  100. sapphire center console required
  101. Uprated Engine & Gearbox mounts 2wd cossie
  102. ABS diode needed ASAP
  103. Full set of engine to gearbox bolts and starter Cosworth.
  104. Mk2 focus RS ABS module
  105. ST170 cam follower
  106. fiesta turbo and Series 1 parts
  107. series 2 turbo in balck on 90 spec please?
  108. Cosworth 3dr Diff Mount - will pay good money
  109. New shape Focus ST 5DR Panels wanted
  110. Wheels/tyres
  111. Mk2 xr2 N/S/F hub ass
  112. Touring Car spares Wanted
  113. 3dr cossie ball joint rubber boot ??
  114. engine mount
  115. ofac map sensor
  116. Wanted Series 1 Escort RST
  117. 2wd gearbox mount
  118. 2wd braided loom
  119. Mercury grey Rst rear bumper.
  120. wanted mk4 escort part please look
  121. 17" Speedline Turinis
  122. Escort Leather
  123. Puma parts
  124. Saff Cossie 2WD turbo heatshield WANTED
  125. Efi clocks
  126. Ahmed bayjoo springs 4x4 saph
  127. Looking for s2 erst or Frst
  128. RS steering wheel boss for an escort cosworth
  129. Compomotive 6 Spoke old style escort
  130. MK1/2 MCR arches
  131. 1985 Mk3 Escort 5dr... Weather Strips Needed!!
  132. Cosworth front driveshafts
  133. 1.6 or 1.8 silvertop cps and bracket
  134. Focus ST170 6 speed box
  135. Best place to get an rs500 splitter from ???
  136. Mk2 mondeo idle speed control valve
  137. Wanted 3 door or saff cosworth
  138. Focus mk1 saloon rear bumper
  139. Wanting escort mk4 genuine parts and TSW 7J X 15
  140. 2 wd engine rubber mount
  141. XR3i MFi air box
  142. Carcoon
  143. T5 Quick Shift
  144. 4x4 prop doughnut and 4x4 starter
  145. 2 wheel drive sump
  146. Sapphire Shell Wanted
  147. EsCos rear ARB wanted for my Saff 2WD
  148. WANTED: Raceline RL7's (set or single wheels)
  149. Fiesta rs turbo strut tops
  150. Nissan navara pickup wanted ( Got one )
  151. wanted rs500 boost hoses.
  152. Transit connect wanted
  153. 2WD or 4x4 Cosworth ABS Servo
  154. Sapphire rubber floor matts
  155. sapph parcel shelf
  156. T34 front compressor housing
  157. Anyone have a good saph cossie shell lying about?
  158. wanted saph center console in black
  159. Escort cosworth shell
  160. Saff cossie door trim/strip
  161. ***WANTED***exhaust Manifold Heat Shield
  162. Coilovers big brakes and 18" comp th/oz mag for a sapph ASAP!!!
  163. Wanted Mondeo ST220 Alloys
  164. wanted t5 borg warner gearbox
  165. S2 accelerator cable inc mounting bracket to inlet
  166. Wanted ASAP, magnetti 2 bar map sensor
  167. Escort RS2000/ Si mk6, steering wheel
  168. puma/fiesta/ka coilovers
  169. Race technology dash2 wanted
  170. FRST Alloy engine bay parts
  171. 2wd cosworth gearbox sandwich plate
  172. Red silicone boost hose
  173. 3 spoke RS steering wheel
  174. 2 litre silvertop head
  175. 2L Duratec Engine from a Mondeo 2006 Onwards
  176. wanted 044 fuel pump/universal fuel tank
  177. Original Cosworth 3door alloys x2
  178. 17in oz mags comp th
  179. Megajolt
  180. Zetec turbo ofab chip and iw-158 injectors
  181. Saph dash wanted.
  182. Sunroof for my sapph
  183. Good rot free merc grey s2 bonnet
  184. Quaife thick wall casing - cosworth
  185. Focus RS turbo plate and ECU
  186. S2 mk4 windscreen wanted
  187. anyone know where i could find a 15x8 compomotive th ?
  188. Sapphire cosworth rear bumper
  189. cv joint
  190. Old Ford Steelies/alloys with old tyres.
  191. early sapphire cosworth boot badge
  192. cosworth 2wd downpipe / exhaust
  193. AP Racing brakediscs (CP3580-2898&CP3580-2899)
  194. Wanted: Sierra estate
  195. Wanted wanted escort mk6 lights
  196. Escort XR3i EFI Fuel Regulator
  197. momo horn push and bezel
  198. Carbon fibre parts wanted
  199. Wanted s1 arch and skirt kit or cyclone kit
  200. Siemens 55's required ASAP
  201. T5 cosworth gearbox part
  202. sapph side skirts wanted
  203. Saph amber rears
  204. Laguna splitter
  205. Cosworth breather pipe
  206. V6 flywheel and box
  207. wanted cosworth exhaust manifold.
  208. mk3 fiesta dash
  209. Rs turbo piston n rod needed??
  210. 2wd LSD diff
  211. two yellow relays
  212. RS Turbo 90 Spec front seats?
  213. Escort s1/s2 rolling shell
  214. set of 2wd cosworth coolant hoses
  215. body panels, headlight bezels for 3dr cossie
  216. Mk2 xr2 wanted
  217. WTD: Cosworth/Sierra 2wd UJ - Steering coupling
  218. S2 Escort RS Turbo
  219. Coilovers for a 3dr
  220. 3 dr parts needed
  221. Looking for a 2040 CD player ford..
  222. 2wd cosworth front abs sensor.
  223. rs turbo gearknob
  224. Siemens 55lb 3102 urgently required
  225. focus rs piston
  226. escort rs turbo recaros
  227. s1 rs tubo parts
  228. Escort cosworth thermostat housing
  229. Coaworth bailey turbo damper
  230. Zetec escort fiesta efi inlet
  231. Mk4 escort ignition switch.
  232. .
  233. Cosworth bd16 inlet cam 2wd.
  234. turbo hose
  235. Cosworth 3 bar map sensor
  236. Sierra springs
  237. mk4 escort heated windscreen wanted and mk4 parcel shelf
  238. Sierra 3dr drivers side door glass Wanted
  239. cossie cylinder head
  240. anyone got any old 5 stud steels near bromley in kent?
  241. Drive Shafts suitable for a 1600 CVH
  242. Cossie parts needed ASAP please!?,?,
  243. Wanted: YB 200 Block
  244. Eibach 20mm spacers wanted mk2 focus
  245. sierra mk1 front wings & bonnet & mk1 xr4 parts
  246. Supercharger wanted
  247. st2's wanted
  248. Wanted: fiesta RS turbo Bailey oil breather and swirl pot
  249. Series 2 drivers 90's spec door card drivers side
  250. 2WD Cosworth rear hub face wanted
