Log In
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. mk3 escort 1.1 driveshafts
  2. Cosworth 4x4 front outer cv driveshaft circlips
  3. roof rack
  4. 2wd cosworth exhaust,FOUND!
  5. tial wastegate
  6. Shell/project/anything
  7. Saff A-pillar trim
  8. cosworth 4x4 front drive shafts
  9. 2WD standard chip
  10. underlay for my sapph
  11. Rs 3 spoke steering wheel mk4 escort
  12. steel wheels
  13. 3 door strut brace
  14. Cvh sandwich plate
  15. 2wd cosworth oil filler cap.
  16. MK5 RS2000 starter and alternator looms
  17. old worn or mint sierra recaro seat or seats
  18. cosworth parts
  19. various alloy wheels please look
  20. cvh efi flywheel
  21. cheap car wanted for my daughter
  22. Cosworth PF09 TPS
  23. 2wd cossie power steering pipe
  24. Gt2871r garrett or mk1 FRS hybrid turbo
  25. RS1600i Throttle bracket
  26. 4x4 coilovers front wanted
  27. 4x4 front coil overs wanted
  28. mk3-4 escort weld-in cage
  29. Uprated diff mount
  30. swirl pot set up
  31. Zetec alternator pulley
  32. Focus rs mods mk1
  33. ford racing oil temperature gauge white face
  34. Cheap Mondeo/vectra sized car - must be auto
  35. rs turbo bits, cossie wrc mirrors
  36. Cossie bits wanted lv8 and a few other bits
  37. An 16 aeroquip hose (SORTED THANKS TONY RYAN)
  38. WTB: Sierra Front Indicators
  39. please delete
  40. Mk2 rolling shell or escort cosworth rolling shell
  41. RS1600i inlet manifold
  42. 2wd cosworth Gearbox sandwhich plate
  43. WANTED....Mondeo/Jaguar diesel pump
  44. Rs2000 16v induction pipe
  45. Ofac 195 chip or better
  46. forge actuator rs focus
  47. Saph Cossie fuel pump cradle
  48. Pinto turbo exhaust manifold
  49. Wanted - SECS (or equiv)
  50. 24v or I4 or Zetec engine and box for rwd needed
  51. Saff mongoose exhaust.
  52. Saff digital clock and surround
  53. Sierra 2ltr 8v Propshaft wanted
  54. 2wd driveshaft bolts and spacer plates
  55. beemer Diesel
  56. Efi clocks
  57. Old used focus st discs
  58. WANTED: Mk1 Focus Rs
  59. 4x4 rear brake calipers
  60. 2wd front hub & carrier pleeeeeease :D
  61. wanted fiesta rst alloy or good standard radiator
  62. Pair off Mk3/4 Escort manual window winders...
  63. sierra 2ltr prop and 2wd cossie power steering rack needed
  64. Wanted Series 2 RS turbo long pipe from stat housing to bulkhead.
  65. 2wd cossy bits
  66. WANTED: Escort mk5,6 or 7 exhaust
  67. broke l8 ecu
  68. Escort cosworth wanted
  69. Escos T25 parts wanted.
  70. Wanted type 9 boxes 2wd 4x4
  71. late saff Aircon wiring
  72. URGENT!!! Escort cosworth tailgate
  73. Full MFi to EFi Conversion (RST)
  74. wanted 2dr cosworth hubs and bottom arms
  75. Wanted 2wd saff cossy!!
  76. Mk5 fez coil overs
  77. WANTED: sierra cosworth rocker
  78. Escort cosworth alloys
  79. S2 rs turbo gearbox
  80. MK3 DASH
  81. Chrome cosworth lifting eyes
  82. WTD: T25 Escos Std Exhaust
  83. New Escort Cosworth Front Bumper Amber Indicators - NOW SORTED
  84. Wanted erst strut brace
  85. escos nomads wanted
  86. Wanted - of a scrap mk3/4 shell.
  87. wanted cheap cossie or mk2 fiesta turbo rs turbo?
  88. Cosworth paddle clutch
  89. Series 2 clocks
  90. 3 door cosworth arches/bodykit wanted
  91. Mk2 mondeo electric window switch wanted
  92. 2wd manifold plus turbo rated to 400bhp
  93. Team dynamics pro race 1.2
  94. T25 phase sensor connectors
  95. 3dr Door card (passenger side)
  96. MT75 Hybrid wanted.....
  97. WTD: T25 Cosworth Std Recirculation Valve
  98. Single lockup or share of space for one car tunbridge wells
  99. WTD: Escort Van
  100. 4x4 rear Calipers
  101. Ford key with integral alarm buttons
  102. CVH belt tensioner
  103. Fiesta turbo inlet manifold
  104. Sierra 3dr brackets and trim bits
  105. T3 Downpipe - S2/Fiesta Rst
  106. Wanted S2 RST mercury grey mirror casings
  107. wanted mk3 escort items
  108. escos parts wanted
  109. st170 rear caliper carriers
  110. Good focus rs clutch
  111. Iphone 4s in white!
  112. focus rs gear linkage
  113. Old laptop with serial port
  114. Wanted 13" Escort van steel wheels
  115. WANTED! Sharktooth centre caps!
  116. L6 or L8 ecu with pectel board
  117. S2 RS Turbo alloy radiator
  118. rs focus mk1 parts wanted
  119. 140ps Transit diesel lump 2.2 TDCi
  120. 4x4 Mahle pistons
  121. 1800 zetec sump and pick up
  122. Kent CVH32 camshaft
  123. Sierra cosworth downpipe wanted 4x4 standard
  124. Car spit
  125. saph cosworth speaker covers for door cards
  126. Focus 2.0 16v Zetec engine
  127. ST200 parts please
  128. 3dr underbody fuel and brake lines wanted
  129. Wanted mk2 fiesta ghia chrome
  130. Wanted P100 Cosworth
  131. Safety devices bolt in roll cage for mk4 escort
  132. sierra gearbox tunnel
  133. Bonnet vents wanted.
  134. rs2000 parts
  135. 4x4 front struts
  136. Group a wheel nuts wanted
  137. aubergine mk 6 rs 2000
  138. Rs turbo (escort)
  139. grill, front fog light grills, tinted cators, nomads
  140. WTD: Cossie 2wd/3 dr stuff
  141. 2wd cossie downpipe
  142. Comp mo5 wheels
  143. PF09 Wanted.....
  144. Saph gearbox loom!!
  145. 2WD 4 pot Saph calipers
  146. T34 -Black Siemens
  147. cossy 2wd sump and bellhousing wanted
  148. Wanted rear dust shields for a saph
  149. Wanted - S1 turbo small fuel lines.
  150. 2wd t5 cossie box
  151. Escort series 2 turbo, coilovers.
  152. Wanted - 2wd cosworth Oil Cap
  153. cheap fiesta si xr2i
  154. zetec sump
  155. 4x4 parts
  156. fiesta mk5 zetec s foglights
  157. Rollcage for a sapph please!!!
  158. 3dr sierra cosworth trim bits
  159. Wanted service book pack for focus rs mk1
  160. Escort RS Turbo S2 caliper carriers
  161. group a nuts
  162. Rs 1600i oil cap
  163. Ofac ecu and map sensor wanted please
  164. WANTED - RS1600i front anti-roll bar
  165. Sapphire under headlight trim
  166. Clutch pedal pin mk4 escort
  167. 2x 215/35/18 tyres
  168. good square post battery
  169. CVH EFi flywheel
  170. Ford focus st3 engine
  171. Cosworth L8 ECU + PF09 TB 4x4
  172. Zetec Turbo Inlet Area Six or Similar
  173. WANED new heater matrix for cvh sapphire
  174. L6 ECU - *Now Sorted*
  175. 180lbs 200lbs coilover springs
  176. 2wd front coilovers
  177. Wanted - MK1 FOCUS RS ENGINE
  178. cosworth throttle cable and bracket
  179. Strange 1 again lol
  180. Wanted MK4 Escort Windscreen...
  181. 044 fuel pump non return valve
  182. Saff carbon morrettes
  183. Wanted sierra cosworth alloy petrol tank
  184. Standard MK4 bonnet and Black dials
  185. Raceline RL7 17"
  186. s1 escort rst - 6 bolt lsd
  187. Wanted: AP 330 brakes
  188. .55 or .63 rear turbo housing
  189. Escort RST Shell, or non runner / engineless RST please
  190. mk1 escort diff wanted
  191. RS1600i Throttle body
  192. saff rear ambers
  193. Any Focus Cosworths for sale
  194. Sapph Genuine Passenger front amber Indicator
  195. parts to convert my mfi rst to efi
  196. MK4 Escort Quad headlights
  197. Saph rear drivers side door!
  198. 4x4 rear calipers wanted
  199. XR3i MFi Pipercross PK022 induction kit
  200. WANTED FORD FIESTA 1.6 TDCI MK7/8 full front end
  201. Uprated CVH camshaft
  202. fibreglass 3dr arches and others needed
  203. P100 cosworth exhaust
  204. Granada Cosworth Rear calipers!!!
  205. Cosworth ap 2wd bells
  206. Rear seat belt xr4i
  207. WANTED - Genuine Ford As New - Water Injection Bag - NOW SORTED
  208. Wanted 3dr rally sump guard
  209. Wanted Mk4 Escort sunroof deflector.
  210. Rs turbo wanted or turbo cabriolet s2
  211. Heat shield
  212. mk1 slam panel
  213. delete
  214. Puma Gear Linkage
  215. ERST Gearbox
  216. vibratechnics gearbox mount
  217. A nice useable Series 1
  218. Wanted : Escort Cosworth non airbag steeringwheel
  219. 3 door recaro drivers seat
  220. ESCOS rear towing cap cover
  221. Sierra saphire 2wd front abs sensors
  222. Escort Cosworth in tank fuel pump wanted!
  223. 3dr wheels
  224. mk5 fiesta zetec s engine wanted>!>!>!
  225. Fully trimed escort cosworth shell
  226. Escort mk3/4 van or p100 rear lights
  227. Planet gears
  228. Sierra Saphhire boot carpet and carpet underfoam
  229. Kreg saff AC loom
  230. Focus rs mkII seats WANTED
  231. WANTED Rear flanges for 2wd
  232. Gaz golds 2wd
  233. xr4x4 front calipers 2.8
  234. Sierra 3dr passenger wing wanted
  235. 2wd cosworth oil pickup pipe
  236. Sierra lower Steering Coupling
  237. WANTED FIESTA DASHBOARD/AIRBAGS MK 8 2009-Upwards
  238. Wanted focus rs front seats mk ii
  239. Mk6/7 Escort LHD Dashboard
  240. Focus ST spare wheel
  241. A Few 3dr Cossie Parts
  242. Wanted 2.9 12v turbo manifolds
  243. Turbo manifolds 2.8 Capri
  244. S1 / MK3 Escort genuine front wings
  245. Escort or sierra 4x4 front struts
  246. Broken T5
  247. +*+*+wanted+*+*+mk2 cortina/alan mann/sterring rack conversion wanted+*+*+*+*+wanted
  248. need imperial bolts for jag diff!
  249. 2wd stub axles and hubs.
  250. Donno Trackday ticket 30th Dec wanted
