PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. wanted a mig welder!!
  2. 4x4 saph e/m switch housing and p/s blank needed.
  3. 2wd ignition amp bracket
  4. s2 top boost hose
  5. decent 6x9 speakers
  6. efi to mfi adapter please
  7. 2wd saph sump plug
  8. Escos turbo heatshield
  9. escort mk3 clear rear lights
  10. Escort mk 6 RS Grill & Rear strut brace
  11. Rs Turbo S2 Front Mount Intercooler
  12. Sapphire cosworth front bumper bracket or damaged bumper
  13. 4" scorpian cossy backbox
  14. L6 and 803 greens + CVH vernier
  15. cosworth sapph rear bumper
  16. escort rs t3 plus exhaust housing!!!!!!!!!
  17. 3dr bulkhead sound deadning
  18. Cossie head gasket
  19. mk 5 escort gearbox an drive shafts
  20. 2wd engine
  21. Wanted s2 rear..
  22. Gauges
  23. FIRE TRAP
  24. wideband afr gauge
  25. Good 2wd Clutch
  26. I want another xr4x4
  27. mk 4 escort uprated suspension
  28. 2wd cossie
  29. 4x4 Saph Crank Pulley, Any Guise!!
  30. nice steering wheel
  31. T3 trumpet for cone filter
  32. T4 samco
  33. cossie
  34. rs turbo 90 spec spoiler
  35. sierra cosworth 4x4 Fuel Pressure Regulator
  36. clear indicators.. for saff
  37. Headlamp or headlamp lense
  38. anyone scraping a sierra shell ?
  39. Escort Mk 6 RS Grill
  40. offside fog light surround
  41. 17" RS 7 spoke alloys
  42. wanted!
  43. HT Leads
  44. 4x4 head / small turbo head
  45. efi cvh throttle cable bracket
  46. MK3/4 Escort Panels
  47. Pinto/2WD YB pulleys for PAS conversion
  48. actuator
  49. megasquirt db37 plug
  50. white mo's
  51. grs intercooler
  52. anyone got some 14 or 15inch wheels + tyres for sale?
  53. hard boost pipe
  54. escort rs t3 return pipe
  55. 205/40 or 45/17" tyres
  56. Anyone got 2WD saph front seats and carpet there needing rid of?
  57. WANTED: 4x4 Cossie 'Sharktooth' alloys
  58. carbon splitter and h sticks for es cort cosworth
  59. r888
  60. cossie steering wheel centre
  61. 3dr downpipe
  62. cosworth flywheel!
  63. needed asap!
  64. white van wanted
  65. Charge Cooler / Intercooler Series 2
  66. wanted..under tray and engine mount heat sheild
  67. escos or rs2000 fuse box
  68. Ford racing volt gauge !!wanted
  69. escort t3 turbo
  70. escort mk3/4 drivers quarter panel 3 door
  71. mk3 dash board
  72. Orion mrk 2 rear bumper
  73. Rs 500 style splitter for s2
  74. Scorpion exhaust for s2!!!
  75. escort cossie downpipe
  76. WANTED:- Turbo from a Focus RS
  77. Wanted - Carpet for Ford Ka in black
  78. 90 spec efi fuel filter pipe work
  79. Black and grey relays cossie pass side
  80. cozzy bits
  81. ofab ecu and frst air temp sensor reducer
  82. cheap fiesta mk2
  83. RS1600i coil bracket
  84. Momo Horn Push And 2wd boss
  85. cvh inlet studs
  86. .63 exhaust housing, bailey breather
  87. 4x4 sapph scuttle panel *MINT COND*
  88. 3 door parts wanted
  89. 4x4 Cosworth Rear Diff
  90. 2wd turbo heatshield??
  91. rs 500 splitter for saph
  92. saph roof rail trim clips
  93. 88 2WD saph loom behind dash
  94. Sapphire pillar pod
  95. Cosworth parts wanted!urgent
  96. 4x4 head
  97. cosworth bits
  98. mk4 escort tailgate
  99. Cvh efi flywheel
  100. 16"alloys
  101. one red fuel hose for rs turbo.look.
  102. CVH EFI TPS and Throttle Cable
  103. Sapphire WHITE rear bumper & doors
  104. Cosworth exhaust cam wanted
  105. efi turbo engine, loom, s1 scorpion system and parts to do mk3 esc conversion
  106. Escort inner wing Brass T peice
  107. 701 beiges
  108. T5 gearbox
  109. Rear Cards for escos leather
  110. st170 passenger headlight urgently
  111. T3 Turbo. New or Re-Con
  112. Dv silicon hose.
  113. Wanted escort s1 rs turbo shell
  114. sierra morette headlights
  115. Wanted,new carello spotlights.
  116. ***Wanted Cosworth Racecar , Sierra or Escort ***
  117. #
  118. Sapphire cos LF leather door card
  119. Efi manifold wanted.
  120. Anyone selling a Pedal Bike???
  121. alloy wheels wanted
  122. 3 door springs
  123. fiesta / escort alternator pulley
  124. escort mk4 rear top shock absorber mounts and fuel cap surround
  125. turbo heat shield wanted for bt escos
  126. Alloy wheel Center caps
  127. Garden Toys
  128. aluminuim in car petrol tank
  129. escort cosworth fuel pump (std)
  130. Has anyone got......................
  131. 4x4 Saph Cosworth Heatshield Bracket
  132. 2wd cosworth poly diff mount
  133. escort cosworth why ???
  134. t34.48...2wd
  135. series one/ mk3 escort spotlight brackets......
  136. carcoon or similar wanted
  137. RS 7 Spoke alloys?
  138. 3 Door Front Grill
  139. rs turbo strut brace
  140. found please delete
  141. 3 door back bumper
  142. Clifford concept 50x alarm
  143. WANTED: 3 door Cos' centre cap locks
  144. Flint grey passenger front door wanted
  145. Camshaft bearing,oil gallery bung
  146. Old Style Comps MO with Escort Cosworth fitment
  147. rwd for swap with rst?????
  148. ST-3 focus in orange wanted
  149. std 2wd fuel rail
  150. Clio Sport 172
  151. 2wd sierra front brakes
  152. koni/spax suspension
  153. escort van roof caps
  154. engine for mfi xr3i,xr2 carb engine etc
  155. camshaft
  156. wanted escort series 2 sunroof
  157. 215/35/18
  158. Wanted Cossie 4x4 AP brake kit 330mm or over
  159. Wanted: Main board out of L8 ECU.
  160. Wanted rs7 softlines
  161. Cosworth bottom end
  162. need parts for a subaru legacy gtb estate w reg
  163. Sierra
  164. alloy wheel nuts
  165. WTD - fiesta rs turbo engine
  166. Sapph rear door corner trims
  167. t4 boost hoses and actuator bracket.
  168. 3 Dr cossie crank pulley
  169. 2wd saff cosworth clutch kit
  170. 3 door Cosworth warning lamp thingy...
  171. beaver tail transit wanted, swap for xr2
  172. Flocked dash and other bits
  173. close ratio t5 gearbox
  174. Cossie crank sensor asap
  175. 63 exhaust housing and 4x4 inlet cover
  176. t34.48...2wd+L8 STG 3 CHIP
  177. series 2 radiator
  178. S2 Dizzy Cap (autospecialists blue)
  179. WANTED: S2 Fog Light Switch
  180. WANTED: S2 Dash Blanking Plate
  181. 7" with gripper/quaife
  182. JDM Civic/Integra DC5 & E46 M3 Wanted !
  183. C20let pistons
  184. mk4 escort outer door handles
  185. Escos ST amal (Lektron) valve needed.
  186. 2wd dipstick and tube bit
  187. S2 headlights
  188. Escos Wheels
  189. Escos Clocks
  190. escos interior
  191. 3 dr front hubs
  192. ST200 Gear Box needed please
  193. very cheap s2 turbo
  194. WANTED: 1.1 or 1.3 HCS engine
  195. cosworth ecu and loom wanted
  196. WANTED: 2.0 Zetec or ST170 engine
  197. S2 BLOCK
  198. T4
  199. Cosworth breather kit
  200. Pectel board for L8 ecu
  201. few cosworth parts needed
  202. Diff Mount Wanted
  203. GRS Intercooler
  204. escort rs turbo radiator
  205. Mk4 Escort/Mk2 Orion Glass & Window Winder
  206. 3 door cosworth panels
  207. 2wd sierra cosworth sapphire sump
  208. cosworth throttle body
  209. Bara or Quaife Diff for 2wd cossie?
  210. fiesta rs turbo engine mount
  211. s1 rs turbo
  212. s1 rs turbo parts.....
  213. Wanted Clean MK3 Escort Shell
  214. 3 Door Cosworth Grill
  215. Standard 3 Door exhaust
  216. 2wd cossie rear beam
  217. 2wd t3 turbo water cooler pipe...
  218. Wanted.. RsT gearbox with LSD or other gearbox with lsd
  219. t34.48...2wd
  220. 2wd Cosworth rear lights
  221. **Wanted MK3 Escort**
  222. Wanted - Mondeo 16" 5 Spoke Alloys
  223. mk5 rs 2000 badges please!
  224. s2 88 spec rocker cover
  225. engine stand
  226. gauges
  227. restored S1 wanted, cash waiting
  228. RS cars wanted
  229. 3 Door Fan Loom
  230. s1 rad and fan
  231. 3 door head bolts urgent
  232. 15 inch slicks wanted
  233. cosworth block
  234. exhaust
  235. escort cos rear bumper mounts/grp-a zf pulley
  236. t5 gearbox
  237. zetec engine
  238. Last few bits for the cos...D/V & speedo drive
  239. cosworth engine
  240. saff light cloth rear seats..
  241. Cheap 16 or 17 inch wheels
  242. Xbox game : rugby 06
  243. series1 escort rear anti roll bar
  244. Series 2 Horn Assy
  245. 16"-17" Ford Fitment Alloy Wheels
  246. 2WD 3" Stainless Steel Exhaust Down Pipe
  247. S1 Parcel Shelf
  248. 4x4 gearbox modified
  249. grey injectors
  250. Focus rs pistoms
