PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. metal backs to series 2 rear seats
  2. LHD Escort Cosworth Steering rack & column
  3. 165 or 195 chip for ofac
  4. sierra cosworth fuel regulator piping
  5. wanted! rubbers seal's for the back rear windows for my s2
  6. Focus 16" wheels.
  7. mk5 or mk6 escort cvh engine mount
  8. Fuel pump bracket
  9. rouse turbo wanted
  10. weber frst fuel pressure regulator [cash waiting]
  11. 2wd sapphire cosworth or 3 door wanted must be good no rot
  12. Cos bootlid and spoiler and back bumper
  13. wanted saph rear bumper
  14. Rs turbo engine
  15. carbon/stainless/alloy bits
  16. Strut brace for cosworth 4x4
  17. spoiler/ gearbox urgent
  18. 1.8 zetec sump
  19. water temp sensor housing
  20. does anyone no of any fiesta rs turbos for sale ?
  21. hockey sticks
  22. gti exhaust
  23. st170 cam
  24. cosworth parts
  25. Gen ford escort cosworth fuel pump
  26. Fiesta rs turbo OFAC ecu superchip 165 or stage one
  27. erst rear aint roll bar set up
  28. pectel monitor for cosworth l8 ecu must be working
  29. 4x4 front calipers & 2wd front discs!!
  30. mk5 escort shell rolling or complete car for escoss rep why
  31. FOCUS RS WANTED
  32. S2 gearbox!!
  33. ERST 90's spec recaros.
  34. *RACELINE RL7's WANTED 17 or 18"*
  35. CLIFFORD ALARM
  36. Escort or orion rs gearbox
  37. Rs500 style cooler for sierra cosworth
  38. t3 turbo + manifold and frst ofac 195 superchip
  39. CAM BELT COVER!!!
  40. Focus Rs Front Seats or Rs Focus Wheels!
  41. 2wd cosworth
  42. .63 exhaust housing
  43. Air Injectors
  44. Pectel Monitor
  45. T2 turbo for fiesta rs req..............
  46. *** FORD RACING BOOST GAUGE WANTED ***
  47. S2 boost hoses
  48. Pre 90 spec RST S2 or XR3i MK4 Door cards
  49. Sparco Bucket Seat
  50. MK2 orion
  51. please delete, wrong section
  52. 2.0 zetec bottom end
  53. fuel pump external cossy or 044
  54. Escort RS turbo side skirts and archers
  55. s/s exhausts for s2 rs turbo
  56. Fuel Relay For S1
  57. 185/55/14
  58. turbo heat shield to protect starter motor!
  59. ALLOY BELLHOUSING –For Hydraulic Clutch
  60. WANTED MK6 ESCORT RS2000 ALLOY WHEELS
  61. frst or XR2i 8v ...
  62. 2WD Cos Turbo water banjos and some rst parts
  63. Escort Cosworth Small Turbo Engine
  64. Wanted 17" Rondells
  65. escort cos wheels or swap
  66. mk5 RS accessory side skirts
  67. FRST Charge Carrier
  68. ... oops, plz delete
  69. 5 bar map sensor
  70. Fiesta RS Turbo EFI Inlet Manifold - complete
  71. Oil Drain Gasket
  72. focus rs Manifold
  73. rear strutbrace 4x4
  74. 3 bar map sensor
  75. escort cosworth sideskirts
  76. Set of series 2 RST front seat runners
  77. s2 skirts and arches
  78. s2 gearbox please
  79. series 1 back lights
  80. Uprated diff front diff needed
  81. blue samco main water hose
  82. Fiesta rs turbo Management
  83. Engine Needed!
  84. Focus RS Coolant Samco/Roose Hoses
  85. escort cosworth leather interior + standard alloy's
  86. swop 1.8 16v fiesta (pics added)
  87. **modified cylinder head for s2rst wanted**
  88. fuel rail for -6 hose
  89. A good Hitman
  90. frst/xr2i arches and sills bodykit
  91. WANTED Sierra sapphire RS Cosworth
  92. 3dr cos rubber steering coupling
  93. 3dr cos drivers front wheel arch spat
  94. Ford Sierra Sapphire Cosworth Parts Moonstone Blue
  95. vauxhall omega diesel estate
  96. Wanted saff alloys!!!!!!! std 16" 17" what you got
  97. ful ecos engine needed
  98. wanted rs 17" soft spokes
  99. FRST ROLLING SHELL WANTED
  100. cheap koni adj or any ova dampers for s1
  101. wanted 2nd hand cosworth pisons and rods
  102. Urgently need
  103. Cosworth Alloy Radiator
  104. 90 spec front bumper + standard s2 springs
  105. Cossie 2wd thermostathousing
  106. s2 complete engine loom
  107. frst around derbyshire/staffordshire wanted
  108. mk4 escort bonus or whateva rolling shell or complete car
  109. ZETEC FLYWHEEL 1800CC
  110. Mk1 Sierra estate n/s rear door
  111. snap on tool box /roll cab
  112. frst/erst running gear
  113. SPOLIER
  114. 2wd cosworth front abs sensor
  115. Series 2 Jacking point cover, 90spec rear spoiler.
  116. FRST / ERST & XR3i EFi Parts Wanted ! Engine & LSD
  117. saph shell
  118. TSW Wheel Nut Covers and Centre Nuts
  119. FIESTA RS TURBO FAN MOTOR
  120. need BREAKE SERVO AND MASTER CYLINDER
  121. L8 Baby board or pectel board ribbon
  122. ST170 Cylinder Head
  123. CD Changer to suit ford 5000 headunit
  124. Servo Brake Pipes
  125. Fuel Pump Bracket
  126. standard 2.0 zetec crank
  127. Need a cossie shell A.S.A.P!!
  128. escos front splitter and hocky sticks in carbon fiber
  129. cos parts
  130. fezzy turbo standard fuel pressure regulator
  131. 2wd cosworth power steering pipe
  132. Saff bootlid and standard spoiler.
  133. LOOKING FOR RS TURBO RUNNING GEAR!
  134. S2 RS Turbo Jacking Point Covers..... Urgent!!!
  135. 3 door front hubs
  136. RACELINE RL7's wanted
  137. couple of bits
  138. Piston Needed ASAP
  139. rst shell
  140. roll cage for 2i
  141. 17 or 18 inch wheels too fit saph coz
  142. cosworth 4x4 uprated breather system
  143. Imperial or Late Pacific Escort Cosworth
  144. Series 2 RST polybushes and suspension
  145. :50 mahaul piston
  146. Wanted Escort RST
  147. *** 90 Spec Recaro Drivers Seat *** (CASH WAITING)
  148. 2wd Engine
  149. 3dr Cosworth Original Alloy wheels wanted
  150. wanted saff heated windscreen
  151. xr3i efi throttle pedal
  152. 2wd throttle body with ICV, L8 ECU
  153. rst lsd gearbox in essex/ suffolk area
  154. t34 turbo for 4x4 cos
  155. Air-ducting of air filter
  156. washer pump
  157. 3dr coswrth standard alloys must be mint
  158. mondeo
  159. ap 4 paddle clutch
  160. 9x18 compos six spokes
  161. Looking for BBS RS or Compomotive CXN
  162. 200 block
  163. s1 rear lights
  164. series 2 fuel lines
  165. s2 metering unit
  166. S2 RS turbo Orange front indicators
  167. CARELLO front spot lights for S2 RS turbo
  168. T5 Gearbox
  169. Management for zetec running 40`s
  170. long shot
  171. MFI fuel metering exit hose
  172. rs trbo brake servo
  173. Still wanted: Saph cossy bumpers
  174. mk4 Escort Suspension
  175. zetec flywheel
  176. 4x4 plenum cover+throttlehousing
  177. mk4 EFI escort rev counter
  178. Mk3 Fiesta, SI Bumpers... Front & Back!
  179. Sierra Sapphire 4x4 Cosworth
  180. MIG Welder
  181. X pack Bodykit (admin pls delete)
  182. Original Series 1 door decals
  183. 2wd gearbox
  184. rs sierra three door parts needed!
  185. rs1800 exhaust system and de-cat
  186. couple of things....
  187. WRC/Grp A 9 inch viscous diff
  188. mk 4 rev counter for Efi
  189. cam caps for a yb
  190. fiesta mark 3 pacifica blue door and boot
  191. Looking for a nice mk1 RS2000/Mexico or something oldskool
  192. safety devices bolt in roll cage rear section for esc cos
  193. Motec ECU
  194. Blue silicone hose for cossie t34?
  195. 90 spec top recaro
  196. 7x13 revolution rfx
  197. Saff right morette
  198. Escos fuel rail big turbo
  199. sierra cosworth standard parts!
  200. 3dr wanted preder moonstone blue with low miles.
  201. RS TURBO
  202. s1 front anti roll bar clamp!
  203. rs turbo stage 2 quaife box
  204. Wanted Urgent P8 ECU
  205. SAPPHIRE COSWORTH 4x4 METAL FUEL LINES
  206. 17´s
  207. Fiesta RS Turbo any condition poss p/x with ERST
  208. RS turbo parts
  209. cheap wheels for saff!!!!!!!
  210. 1992 K Sapphire Cosworth 4x4
  211. *******3 Door wanted anything considered*******
  212. 2WD Cossie Turbo Damper Required
  213. Megasquirt
  214. sorted
  215. rs turbo parts needed urgently
  216. RS 3 spoke steering wheel boss.
  217. cos 2wd drive shafts
  218. Saff 4x4 parts wanted
  219. Turbo heat shiels (polished)
  220. Paddle clutch
  221. center caps for the s2 escort rs turbo wheels
  222. bumper kit
  223. standard saff cos wheel 15inch with good tire
  224. strong s2 gearbox needed
  225. Still Wanted: Sierra Sapphire Cosworth Front & Rear bump
  226. Rear coilovers (2wd saff)
  227. Engine wanted!!!!!!!!!!
  228. Escort Cosworth throttle body in very good condition
  229. boost gauge
  230. Rs turbo 5th injector kit
  231. s1 or s2 rst
  232. 16" or Larger Alloys Wanted For 3 Door
  233. Escort Window rubbers
  234. S2 heater centre vent/Panel...GOT ONE NOW!!!!
  235. Nos Purge Kit
  236. Moonstone 3dr Cossie
  237. ESCORTS AND EXPLORERS WANTED!!!!
  238. 2wd throttle body with ICV, L8 ECU,
  239. wanted tsw evo's for 4x4 saph..
  240. Cloth cover for s1........?
  241. 3 door crank pully / big wing sump
  242. WANTED !!!!!! SIERRA SAPPH COS OSF WING MOULDING
  243. P8 Chip for Light Blues T34
  244. 2wd boost hose....
  245. WTB Bunch of parts!!!!
  246. im still desperate for a S2 backbox with 4" tail outwar
  247. FRST S/Ford boost hose
  248. Stage 3 chip for L8 ecu
  249. metal window runner
  250. series 1 clocks or dials and paddle clutch s1 s2
