PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. smart car shell wanted
  2. WANTED ESCORT SERIES 1 RS TURBO BIG BHP
  3. 3 Door Parts
  4. wanted mark 3 escort turbo parts
  5. 2WD thermostat housing
  6. pinto oil pick up pipe
  7. track car bits mk4 escort
  8. FRST charge carrier
  9. Cosworth 2wd Turbo Compressor Wheel and Compressor Housing
  10. wanted pr escoz doors pref white
  11. turbo heathsheild
  12. late mk4 xr3i injection tank and the larger fuel line...
  13. trade oz super ts for a set of comp mos 18" esc cos fit
  14. Sierra Group A Wheel nuts
  15. 355mm brake kit wanted for 4x4 cos
  16. Mk 1 fiesta parts
  17. 1 cossie alloy wheel
  18. wanted 200 block and
  19. Cossy engine, Box & Running Gear
  20. ERST driveshafts and Steering column, with NO play
  21. .25mm oversize lowcomp pistons WANTED
  22. ecos banana pod / midle section of the centre console
  23. Valves wanted x4 cossy
  24. 4WD COSWORTH REAR ARMS & ARB POWDER COATED
  25. WANTED any carbon parts for a saff?
  26. WANTED black silicone hoses, full set, 2wd cossie.
  27. WANTED 2wd brackets to fit AP cp5200 calipers
  28. FRST Mongoose System + FRST Alloy Intercooler
  29. Series 2 Front Mount Intercooler
  30. 330 x 28 ap front brake discs
  31. 3 door lockset
  32. Sapphire Cosworth Clocks
  33. cosworth kit (sapphire)
  34. WANTED - REAR N/S LIGHT CASING FOR ESCORT MK5B/6/7
  35. cvh cylinder head - !found - please remove mods thanks
  36. WANTED: RS500 Fibreglass bits....Spoiler(s) bumper kit etc..
  37. xr2 front struts
  38. Red Mondeo ST24 / ST200 Front Grille
  39. WANTED:Series 1 RS Turbo
  40. need a gear box and diff for 3dr cosworth
  41. Sierra 3dr Cosworth
  42. Sapphire boot striker pin
  43. Ford badges bootlid n bonnet
  44. cossie door
  45. shagged t5
  46. Wedding car
  47. wanted 4 wd saphire cosworth
  48. Cosworth fan switch connectors
  49. VENTS WANTED
  50. RS1600i Rocker cover & FRST Inlet complete wanted !!!!
  51. Cosworth, Saph or 3 door must be NICE !!!
  52. cosworth coilovers
  53. ERST oil return stub..
  54. Wanted Orion 1.6 mk3 1993 performance Exhaust Back box
  55. Saff stainless exhaust wanted swap
  56. samco's wanted for saff
  57. Mk2 Focus ST Calipers
  58. FORD FOCUS LOWERING SPRINGS
  59. standard fiesta rs turbo injectors wanted
  60. Sierra sunroof wanted urgently
  61. 3 door starter motor
  62. 2l zetec bottom end
  63. Cosworth 4x4 head parts
  64. 2wd exhaust
  65. WANTED:S2 Parts..
  66. ABS/Fluid Level Sensor
  67. single FOX evo 3 17" multispoke alloy
  68. cone filter wanted
  69. Pirelli P6 or P600 tyres
  70. Bolts etc
  71. WANTED *** Collins Monitor - Powerchips ***
  72. Fog lights
  73. A pillar twin gauge pod for saph in grey
  74. .5 cossie pistons.
  75. Focus RS alloys
  76. turbo needed
  77. compomotive centre caps
  78. Cosworth valve set
  79. Mondeo Boot Spoiler
  80. 4" Rolled back box cossie
  81. rs2000 clear indicators
  82. Saph Parts
  83. escort rs turbo half roll cage
  84. Parts i need for Escort RS Turbo mk4
  85. Passenger side central locking motor for saph cossie
  86. some 17" alloys in white i may px rs7's
  87. turbocharger escort rs
  88. 3 DOOR PARTS
  89. Focus RS Passenger Headlight & Grill
  90. Ford Fiesta RS Turbo Passenger seat wanted!!
  91. Cheap escort rs turbo
  92. Escort Cosworth pop out seals... both side please
  93. fiesta turbo parts needed
  94. centre cap for 15" early saff lattice wheel or wheel if
  95. mk4 escort drop skirt
  96. Azev wheels
  97. high impendance injectors 4-500cc?
  98. Granada 2.8i splitter wanted
  99. 2.0 zetec block
  100. orion 1.6ighia back bumper
  101. ORION MK2 GHIA DRIVERS DOOR CARD
  102. Cosworth downpipe
  103. Saph Cossie Spoiler
  104. t34 wanted for 4x4 saff
  105. vernier pulley
  106. ecos grill, front spilter, bonnet hings...
  107. 2wd cosworth front brakes and konis
  108. Orion MK3 1993 Custom Rear Bumper Wanted
  109. Saff front tow eye cover and steering wheel please!!!!
  110. S1 Turbo fuel tank + Washer bottle....
  111. Front pipe for Sierra Cosworth
  112. 4" outwardly rolled exhaust
  113. 2WD Parts wanted
  114. fiesta turbo beige injectors needed asap
  115. CHEAP 4x4 rear beam wanted
  116. comp fr
  117. SERIES 2 EXHAUST
  118. S2 GEARBOX
  119. MK6 Doors, Need a Pair, off of a 3 Door Car
  120. 3pc, 17" BBS/compomotive/image style rims...
  121. alloy rocker cover for rs turbo
  122. A laptop
  123. rolling escos shell
  124. saff 4x4 whole car..???
  125. t34.63 housing needed asap.
  126. Khan rsr 6.5X15 Ford fitment
  127. mk3 fiesta 1.1
  128. Lancia integrale slow idle valve(cosworth remote mount iscv)
  129. 4x4 turbo oil return pipe
  130. FOCUS RS THROTTLE BODY
  131. escos small turbo rqd
  132. standard escort rs turbo camshaft wanted + vernier pulley
  133. Ford Racing Puma Passenger seat
  134. WANTED! SAPPHIRE COSWORTH CARBON CAM COVER
  135. Escort rs series 1 rear window blind
  136. 3 door cosworth tailgate struts
  137. saff outer rear window surround ( new )
  138. WHERE TO FIND THIS GEAR KNOB
  139. 2wd oil feed block and oil line(line must be new)
  140. XR2i or FRST Head
  141. S2 Gearbox
  142. 106 s2 diesel 3dr or van
  143. s2 alloy rad
  144. 3 Door Bumper
  145. sunroof for sapphire cossie
  146. mk3 escort 5 speed linkage, cossie downpipe/ flange to turbo
  147. standard map sensor for a 2wd Sapphire Cossie
  148. RS500 exhaust
  149. blue flame exhaust cat back of st170 also fits 18 20 new
  150. 3DR Cossy ABS BRACKETS
  151. 15 inch alloy or full set
  152. RS500 GROUP A BBS CENTRE LOCK WHEEL CENTRES
  153. GROUP A RS500 LONG NOSE BELLHOUSING WANTED
  154. st170 inlet
  155. series 2 t3 turbo needed asap no smokers !!
  156. Wanted Escort mk 4 hub
  157. WANTED - 15", 16" or 17" Alloys (MUST be 8&qu
  158. wanted 3dr cossie or s1
  159. T3 / T34 to handle upto 280-300bhp
  160. WANTED!!! FIESTA RS TURBO DOWNPIPE FOR T3 CONVERSION
  161. Ford escort mk3 or mk4 wanted
  162. 4x4 cossie manifold wanted
  163. FRST Doorcards
  164. wanted: RS Turbo vernier pulley & uprated oil pump
  165. rst parts needed, quads
  166. CVH EFi inlet manifold
  167. Sapphire Cosworth front bumper in flint grey
  168. Big spec Escort Rs Turbo wanted
  169. saff jacking point covers and tow eye cover
  170. needed for my mk4 escort
  171. cosworth cam cap
  172. t3 water in/outlet elbows
  173. fiesta t3 prts
  174. st170 shit shield on gearbox
  175. 2.0l 16v zetec stage 2-3 cams and pullys head wanted HELP
  176. t3 metal waterpipe
  177. chip for rs1800 or xr3i 130 and other parts
  178. 18 inch compromotive new shape 6 spoke et 35
  179. Steering UJ needed
  180. Silvertop sump
  181. Rs Turbo Series 2 Rear Window Demister Switch
  182. Escos fitment (et15) 18" rims wanted. why?
  183. MK5 Escort rear window rubbers
  184. Top spec Kenwood Head Unit.
  185. MK4 escort cvh engine mount needed NOW
  186. escort mk4 60mm springs...
  187. S1 mechanical injectors and metering head..
  188. S2 RS Turbo alloys
  189. S1 RST parts.
  190. 4wd hose set
  191. S2 RS Turbo Wanted
  192. can you help IM AFTER REAR KONIS FOR MY S2
  193. 2wd cossie front crank pulley
  194. Focus RS Pillar Pod?
  195. mk3 escort doors series 1
  196. cosworth 4WD bonnet for a french guy
  197. erst black tailgate complete
  198. please remove
  199. escort cosworth pop out windows and fixings
  200. pass side mk4 escort headlight protector
  201. body kit and spoiler wanted for mk2 xr2
  202. body panels wanted for mk2 fiesta
  203. WANTED - STAINLESS EXHAUST
  204. Mitsi Evo 1,2,3 15" alloys wanted
  205. mk4 escort van tow bar wanted.
  206. rs turbo petrol cap and key
  207. few parts needed asap!!!!! help lol
  208. Sapphire Cosworth N/S/F jacking cover and wing moulding
  209. IN NEED OF FIESTA RS1800 INLET MANIFOLD HELP!!!!!!!!!!!!
  210. Rs Turbo S2..White/Black
  211. custom sticker
  212. 2wd saph rear brake sliders
  213. In need of S2 gearbox that can handle 200bhp
  214. WANTED: Orion/Escort 5dr carpet (86-90)
  215. sorted
  216. 4X4 SAFF KONI
  217. Focus RS Body Panels
  218. zetec turbo
  219. Recaro Pro racer SPA, possible swap
  220. In need of an escos!
  221. CONVERSION NUTS
  222. frst ofab ecu
  223. mk4 escort STANDARD spoiler
  224. s1 genuine bodykit
  225. mk3 escort boot lock
  226. rs 7's
  227. escort mk4 1.6....
  228. saph cosworth top half off dash
  229. MK3 Escort 5 Speed Linkage
  230. mk6 escort front strut brace
  231. Wanted Bailey cossy oil breather/separator
  232. Sierra parts wanted
  233. wanted useable s1 rs turbo,swapfor evo 2 lancer
  234. fiesta rs/2i rear beam
  235. p100 wanted.
  236. Actuator
  237. Escort s2 rst dash trim choke plug
  238. s2 escort rst petrol cap
  239. escort rs turbo rad + sump
  240. Cosworth ABS Sensor
  241. 3dr front bumper
  242. Sierra cosworth rwd rear bumper needed
  243. 4wd cossie parts please
  244. 2wd sapphire steering rack
  245. ECU
  246. oz 8 x 18 super T
  247. T3 TURBO
  248. Cosworth 3" S/S down pipe
  249. XR3i Stainless manifold and exhaust
  250. fiesta turbo xr2i front bumper in red!
