PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Leather Recaro Driver's Seat Only
  2. 3dr mk5 esc seatbelt
  3. XR2 Lights
  4. saph cosworth fuel pump
  5. sapphire cosworth steering boss
  6. Secs monitor
  7. 4+4 cosworth bonnet vents and mount cut from bonnet
  8. leather steering wheel/seats wanted
  9. wanted:mk3 escort
  10. t3 turbo
  11. Sierra Sapphire Cosworth Front Lower Splitter
  12. wanted: Full RST ENGINE & Loom
  13. rs turbo dip stick
  14. 2wd saph wanted good spec
  15. Escort Cosworth heatshield bracket
  16. st170 sump needed asap
  17. MkV petol cap??
  18. rs splitter
  19. Cvh Breather And Cossie Water Temp
  20. 1.6 rs turbo engine
  21. cheap seat cover
  22. Wanted, MK3 Escort 3 or 5 Door,
  23. Wanted sierra steering wheel boss aftermarket
  24. Wanted - horn centre push for RS steering wheel
  25. 3dr lock set with key
  26. Cosworth Lamba sensor
  27. 2wd GGR Header tank
  28. WANTED - Series Two Escort RST H Plate for Restoration Project
  29. WANTED: ST170 Xenon POWER PACKS
  30. Escort mk4 drivers carello crome top headlight new
  31. Sierra xr4x4 / saph 2.9 or 24v conversion WHY?
  32. Lead for the foglights
  33. Recaro seat cover
  34. mondeo mk2 15inch steel rim
  35. turbo techinics anti roll bar
  36. Fiesta RS Turbo Wanted
  37. 2wd vibratechnics engine mounts
  38. Needed Defi Egt Gauge
  39. t34
  40. MK3 Fiesta XR2i 16v Parts wanted...
  41. escort mk4 front rs bib
  42. 17 Inch Alloys
  43. .48 exhaust housing
  44. bd14 exhaust cam
  45. air injectors
  46. secondhand or new
  47. ***WANTED*** ERST 90 Spec Front Bumper
  48. 2wd manifold joining studs/nuts
  49. rs boss kit for escort.fiesta
  50. WANTED Escort s2 RST Shell
  51. Escort RS Turbo Leather Interior
  52. Front drivers wing skirt piece sapphire cosworth
  53. After standalone-ideally E48
  54. S2 RST centre caps
  55. CVH EFi Flywheel
  56. Washer bottle cap for facelift saph cossie
  57. Urgently Needed
  58. Sapphire Cosworth Rear Jacking point
  59. Wanted- Good condition Cosworth 2wd RWD rear beam
  60. sapph door handle surrounds(now sorted)
  61. ERST Bonnet Vent Covers
  62. ERST LSD Gearbox
  63. bmw 328i or rs turbo s2[wanted]must be cheap]
  64. wanted Ford RS Escort Cosworth OZ Racing Mag Wheels
  65. sapphy parts
  66. 2wd Oil Pump Top
  67. 205 gti or similar wanted
  68. Cosworth Billett Fuel Rail
  69. rs turbo t3 actuator "bracket"
  70. RST gearbox
  71. front mount intercooler wanted
  72. S2 Rst Shocks & Springs
  73. xr3i part for sale
  74. T25 inlet plenum + throttle body
  75. Cossie idle valve, fooked preferably as............
  76. Bailey (or equivalent) breather/seperator please!
  77. Anyone got a 9" diff for a 2wd Saff?
  78. Stage 1 or Stage 2 T3 Turbo please!
  79. wanted 1 new escos alloy asap!
  80. T3 Turbo
  81. Zetec Gearbox Wanted...
  82. wanted rs 1600 or xr3 front bib and rear quarter windows for mk3 escort
  83. WANTED; Drivers side door mk5 escort, in black
  84. Wanted Mint 90spec Rst
  85. ST cos inlet plenum cover
  86. needed escort turbo bits
  87. Rebuilt N/A 1.6 CVH Bottom end
  88. frst bottom end must be mint! cvh/zvh? URGENT!!!
  89. 4x4 Saph Donut
  90. Mods delete please
  91. Heater Control Panel RS TURBO S2
  92. 3 Door Car Loom
  93. locking wheel nut tool
  94. RS Turbo rear coilovers
  95. Focus RS Alloys, Focus RS Brembos, Escort Cabriolet Mohair Roof, Escort Rear Leather
  96. WANTED: Sierra Saph Cosworth
  97. erst rad, cheap pace cooler and breather kit
  98. anyone got a escort RST t3 metal oil return pipe?
  99. yb rocker cover with breather outlet
  100. MK2 Mexico wanted
  101. wanted zvh 2.1 pistons?? plus cozzy managment
  102. RS turbo mud flaps
  103. 4x4 cos box needed
  104. cosworth 2wd t5 speedo drive
  105. escort td non coded pump
  106. samco water pipes
  107. Desperatly needed!!!!
  108. Power steering pump bracket
  109. 2.1zvh Building, Need To Get Pistons Any Ideas
  110. 2.1zvh Building, Need To Get Pistons Any Ideas
  111. 2.0 blacktop engine wanted
  112. after a cosworth head!!!
  113. 2ltr pinto lump asap
  114. 2.0 Zetec intake and throttle body..?
  115. Cosworth inner wing..??
  116. Recirculating piston dump valve.
  117. Cosworth Engine
  118. Group A Size Air Filter
  119. cosworth 200 block
  120. FOCUS RS standard turbos
  121. Wtd: t34, .48 housing etc etc
  122. ST24/V6 IMRC good working order
  123. .43 exhaust housing for t34
  124. escort rs turbo bits
  125. WANTED ESCORT VAN MK3 or MK4
  126. zetec gearbox
  127. MINT S2 RST arch trims wanted, plus skirts
  128. 2wd crank pulley.
  129. S2 ERST 90-spec spotlight brackets.
  130. Focus ST front brakes
  131. Billstein rear coilovers for 2wd wanted
  132. Wanted RS2000 4x4 cash waiting
  133. OFAB cylinder head
  134. Sapph Nsf leather door card
  135. Wanted - Standard RS Turbo rods and pistons
  136. nice Sapphire Cossie wanted
  137. gti alloys
  138. 3dr Front Bumper
  139. Parts for a 3 door cosworth
  140. A Long Shot
  141. 195 OFAB superchip
  142. T34 Actuator Bracket
  143. Escort RS Turbo 90 Spec Spoiler!
  144. Black Harness (securon etc)
  145. Ford Pacifica Blue Aerosol
  146. 3dr Gearbox crossmember/mount
  147. Alternator
  148. fiesta turbo actuator
  149. Earth/Battery Cable
  150. crackle black rs turbo parts
  151. 83lb Injectors
  152. 1.6 carbed engine?
  153. tsw hockenheim silver centre cap
  154. Aftermarket ECU
  155. 2 WD Paddle clutch
  156. mk6 escort parcel shelf
  157. RS Turbo OFAC ECU
  158. blue samco or roose bottom water hoses
  159. cvh EFI turbo engine rebuild bits.
  160. EFI cvh uprated cam (preferably cvh 34)
  161. cheap alloys 15 16 or 17''
  162. A good welder in bristol
  163. escort front anti roll bar
  164. Actuator :P
  165. leaf springs
  166. Saph Cosworth Filler Neck
  167. cosworth down pipe
  168. 0.48 0r 0.63 2 wd turbo housing
  169. t5 gearstick wanted
  170. top mounts
  171. s1 arches and skirts
  172. Sapphire spoiler
  173. Mk4 fezzy drivers side door handle
  174. female fog light plug
  175. ford track car wanted and trailor
  176. Escos power steering pipes
  177. 1.8 cvh alternator bracket
  178. Wanted:- t34 Downpipe .63 exhaust housing
  179. 1 cosworth conrod-pref knackered
  180. Puma Millennium/ or Black Leather Full Interior
  181. mk5 Fiesta Zetec S skirts - massively urgent
  182. standard fiesta mk4 alloys
  183. Wanted Focus Rs Airbox
  184. roll cage
  185. Tyres
  186. anyone got a escort RST t3 metal oil return pipe?
  187. tidy FRST
  188. standard speakers
  189. stage 3 or 3 t3 turbo
  190. ONE 3dr cossie rim
  191. 4x4 Cosworth Head, STD cosworth Crank + Cam cover.
  192. cheap track car
  193. Sierra Cos 4 X 4 Rear Prop
  194. CAPRI
  195. cheapish first saph cossie wanted
  196. Wanted Rear Mudflaps
  197. type 9 gearbox
  198. 175/50/13
  199. Merc Grey S2 doors
  200. Sierra propshaft rubber
  201. sierra 1.8 pinto block/engine/car W.H.Y?
  202. Series 2 GEARBOX
  203. s2 erst fuel metering unit wanted.
  204. Big Spec Rst Wanted
  205. XR2i or frst turbo engine wanted
  206. Wanted a pair of 3door rear light clusters
  207. ERST Water Banjos + Bolts
  208. escort rs bumper 88 spec with rs extension
  209. escort mk3/4 roof 4 convertible
  210. mk3 fiesta xr2i driveshafts
  211. 90 Spec Escort Rs Crossover Pipe
  212. Wanted genuine 3 door turbo heat sheild and cam belt cover.
  213. 17 azev a alloys wanted(4 or 5)
  214. IGNORE
  215. series 2 koni suspension kit
  216. Escort Cosworth Passenger Vent Piping from Heater Box
  217. xr2i parts
  218. AP/Helix Organic Clutch, rst
  219. oz super t wheel
  220. ford sierra 20l pinto manual
  221. Sapphire Cossie
  222. Couple of saff parts
  223. Big rev counter/tacko...
  224. PF mag September 2000
  225. Genuine Ford Lambda Sensor
  226. Cosworth Adjustable 6 deg Beam
  227. mondeo st24
  228. escort cab mk4 parts
  229. Wanted: -60mm Springs or Shocks and Springs for mk6 escort 1.8 (S reg.) Please
  230. WANTED 3dr front bumper and grille
  231. Steering wheel boss mk2 escort
  232. AP Racing 6 Pot Calipers
  233. nice clean xr4x4 wanted
  234. wanted rst escort front mount intercooler
  235. 200 bhp rs turbo
  236. Cossie wanted
  237. escort gti rims
  238. CVH Bottom end complete
  239. 2wd cosworth engine
  240. fiesta st alloy wheels
  241. high tensile bolts.any traders etc help?
  242. Help Needed
  243. bucket seats wanted!!!
  244. wanted focus roll cage 3dr
  245. Bilstein 41mm Inserts 500/225
  246. red rs2000 bulge bonnet
  247. 4x4 cosworth front driveshaft
  248. Quaife Front diff wanted
  249. cossie lattice rims
  250. Wanted: Leather Gaiter To Fit Rs Turbo
