PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Cosworth T3 Turbo
  2. 2wd 3" downpipe in good condition
  3. silly saph parts wanted, anyone scrapping/breaking a saph???
  4. s2 sunroof?
  5. Escos front splitter and water hose
  6. cossy inlet plenums
  7. escos bottom end
  8. Focus RS Cam Cover
  9. Focus 2l Zetec Head
  10. Bit of a long shot
  11. a pillar trims
  12. st170 linkage, gearstick, shafts, billet flywheel and paddle
  13. Small MIG Welder (FOUND ONE!)
  14. s1 radiator!
  15. escort cosworth lower boot spoiler
  16. WANTED, saff cossie full cloth interior
  17. 8x17" GpA Track wheels wanted , M.o's etc...
  18. escort rs turbo front bumper and rear bumper in white
  19. wanted rs turbo exhaust.scorpion or mongoose,pace intercooler,beige injectors
  20. 3dr interior boot light/bulb cover
  21. Wanted series 1 smoked rear lights
  22. very good spec saph cossy wanted
  23. early zetec loom
  24. defi water temp gauge wanted
  25. Idle control valve... that works!!
  26. mercury grey s2 turbo bonnet
  27. 89+ auto granada prop(escos 2wd coversion)
  28. mini fit trailer wheels 10" or 12"
  29. DTA Ecu, any model, exp48 / p8 pro / s60 / s80 etc
  30. Water temp reducer/converter
  31. Saph Black carpet
  32. MTX/Zetec 2 litre flywheel
  33. pug 306 gti6 2.0 16valve engine
  34. Saff cossie n/s mirror capping needed...
  35. Standard Green Rocker cover 4x4 And Cam Cover
  36. CVH lower Cam Belt Cover Please!
  37. Compomotive MO 18'' Old style
  38. Escos Headlamp
  39. Knock sensor and .63 exhaust housing wtd
  40. RST charge carrier 88
  41. Turbo to manifold bolt
  42. Series 1 Grill
  43. sierra v6 sandwich plate xr4x4 etc
  44. Comp mo 10x 18" , Damaged or bent
  45. cosworth T3 actuator bracket
  46. compomotive mos,rl7s etc for coss
  47. L6 Chip
  48. Bilstein 41mm Casings wanted , 2 & 4wd
  49. diamond cut rs7's wanted why.
  50. s1 turbo or mec grey 90 s2 why
  51. cosworth 4x4 sharktooth wheels
  52. tca,s
  53. rs turbo series 2 sunroof
  54. wanted some 803 greens.....NOW SORTED
  55. Map sensor in bristol
  56. 3dr Cosworth Bonnet in WHITE
  57. FRST door pockets + speakers
  58. WANTED: Sierra or Granada
  59. new mk6 fiesta shell or cheap cheap mk6 fiesta complete!
  60. Anyone breaking or know were a mk2 fiesta is?
  61. Vauxall astra mk4 front bumper and bonnet
  62. rs turbo wanted any condition
  63. T6 2000 ecu
  64. few st170 bits, hydralic clutch set up, baffled sump
  65. .63 housing, Amal valve, knock sensor, ign amp
  66. Saph Cossie Turbo Heatsheild Bracket
  67. 2WD Koni's Shock Absorbers
  68. escort parts (mk5/6)
  69. escort t3 oil feed pipe
  70. cossie iscv
  71. 3dr quarter windows and trims
  72. Mint 3 spoke cossie o/e steering wheel
  73. cosworth stage 3 setup wanted.NOW SORTED
  74. 4 wd front bumper saph cos 4wd-must be very good
  75. Wanted-2wd drivers seat, light cloth recaro
  76. good run around wanted
  77. 3dr hub's and tca's
  78. escort series 2 lsd box wanted
  79. 205/40/17 R888s
  80. l8 ecu wanted any spec really
  81. 2WD Rear Dampers & Springs
  82. Cosworth .5 oversize pistons 4x4
  83. Focus RS box
  84. WANTED: Sparco Pro2000
  85. Mondeo TDCi for my BMW E39 V8 Sport!!!
  86. 4x4 exhuast hanger from Gearbox WANTED
  87. Samco hose wanted!
  88. 4x4
  89. focus rear lowering springs
  90. looking for a mfi engine for my xr
  91. Standard T3 Escort Exhaust Housing
  92. escort rs turbo rear arms
  93. fiesta st rear bumper trim
  94. Dark greens cheap
  95. Rst S2 Amplifer Surround
  96. 2.0 silver top zetec engine required
  97. Escort mk2
  98. 2WD Cosworth Gearbox needed
  99. 2wd stainless exhaust
  100. mk3 escort series one rs turbo fuel tank urgently...
  101. ford racing boost gauge
  102. Phase sensor
  103. Urgent need a cossie part
  104. Any one want to sell a cvh bottom end?
  105. 17" Azevs
  106. Compomotive FR 16 inch rims
  107. T34 0.63
  108. pioneer deh p9400
  109. yb bottom end complete & saff cloth front seats
  110. Aircon Compressor 03 Mondeo TDCi
  111. Cosworth Standard airbox
  112. cossie crank pulley/36-1 trigger wheel
  113. Escort Rs Turbo centre console bracket
  114. s2 gearbox
  115. escort mk3 rear panel wanted
  116. mongoose exhaust wanted
  117. Electronic Boost Controller
  118. 2wd cossie fuel pressure regulator
  119. 2WD fuel rail
  120. Escort mk2 rollcage
  121. cosworth amal valve
  122. *Cosworth parts wanted*
  123. Wanted 2wd saff cosworth
  124. Mk4 escort adjustable tca's
  125. 90 spec Bumper and spoiler
  126. 2wd cosworth bailey expansion tank,blue vernier pulleys
  127. wanted discovery
  128. Wanted group A air filter cosworth
  129. Wanted escos turbo heat shield
  130. rs bits
  131. ps3 or 360
  132. Half decent battery...
  133. Lego pirates
  134. saff cloth seats
  135. t34 actuator bracket and turbo damper
  136. t34 actuator bracket
  137. RS Turbo head gasket
  138. **RS Turbo 3" downpipe WANTED*
  139. cosworth 2 or 4 wd or RST 3" Downpipe
  140. WANTED: 2.9 24v BOA engine
  141. t34 turbo
  142. mk2 rs2000 headlight rings
  143. Rear disc covers/sheilds for a 3dr Cossie
  144. Jack cover for 3 dr
  145. mfi to efi adapter plate
  146. Sierra 2WD Exhaust
  147. 18's
  148. 2wd ISCV and yellows
  149. mk6 escort bits, 4x4 cossie brakes, lowering springs
  150. mint esc cos headlining
  151. Esort RS Turbo Mater Cylinder
  152. fiesta oil feed pipe t2
  153. s2 b and m quick shift
  154. kenlowe fans
  155. Rear strut brace for escort GTI or mk 5 ?
  156. rs turbo 0.5 pistons wanted
  157. rs turbo bootom end wanted
  158. A way of moving a shell
  159. 4x4 standard front shock absorbers
  160. Jam sport rs turbo manifold
  161. 4x4 turbo water return fitting
  162. escort xr3i or xr2i engine needed
  163. Standard 3 Door Parts
  164. 2wd speedo worm drive and mounting plate/box
  165. Box of Wispas & a Crate of Strawberry Yazoo
  166. wanted escort cos fuse box
  167. black samco t34 boost hose
  168. sapp jacking covers
  169. blue comp mo centre cap's and 2ltr zetec engine
  170. Full Standard 4x4 Bottom End
  171. escort mk4 3 door project wanted!
  172. Wanted - Sierra pedal box & brake servo
  173. inlet
  174. Series 1 smoked rear lights
  175. Stainless Tank
  176. wanted front sapphire bumper
  177. wanted L8 chip for 803's
  178. Left hand drive Ka steering column
  179. rs turbo s1 or s2 as project car
  180. 2wd cos gear gaitor
  181. saph clock
  182. cossie 2wd flywheel in good condition
  183. autronic sm2 loom
  184. escos under tray and bt steering wheel
  185. Amal valve for cosworth
  186. Cosworth rocker cover
  187. 130 bhp zetec ecu wanted
  188. Anyone got an engine lift/hoist for sale?
  189. Clutch cable
  190. Wanted. 1 4x4 Cosworth Sharktooth alloy.
  191. Ka turbo engine mount.
  192. Smashed/Rotten FRST
  193. Solid beam mounts
  194. ofab ecu needed
  195. Series 2 magnex downpipe
  196. Standard mild steel cosworth downpipe 2 or 4 wd
  197. Sapphire 2wd suspension
  198. cossie wanted
  199. 2WD Sapphire front abs sensors
  200. RS Turbo S2 Fuel pipe
  201. nav man..s100,s90,s80
  202. Wanted set of 3 door rims
  203. graphite grey rs1600i wanted
  204. 2wd engine please
  205. saff
  206. wanted - 4x4 cos bd 14 camshafts
  207. Siemens injectors
  208. 2wd sierra 2wd Coilovers
  209. escort rs downpipe
  210. Anyone know anyone selling a Golf GT TDI?
  211. drivers side saph morette
  212. Clutch for a 2wd cossie
  213. classic addition rst indoor cover??
  214. Sierra 3 door downpipe
  215. needed ! ford focus alloys , and exhaust
  216. mk 4 escort speedo cable
  217. Cortina mark 3 wings needs
  218. S2 Suspension dampers and springs and LSD Gearbox
  219. 2wd cossie spax front strut
  220. Series 2 parts-please help!
  221. t5 clutch lever clip
  222. big turbo
  223. 16" or 17"
  224. Door mouldings
  225. 4x4 coz oil return pipe
  226. Escort cosworth centre cap!
  227. cossie gearbox
  228. escort mk6
  229. Cheap sapphire cos to px with my rst cab
  230. Urgent* Cosworth parts wanted
  231. vectra 2.2
  232. escort mk6 -60mm springs
  233. 15'' escort gti alloy
  234. Cosworth Crankshaft
  235. has any one got a scrap saff back bumper?
  236. mahle pistons
  237. S2 radiator through Intercooler bolts
  238. 2.0 Zetec Silvertop bottomend.
  239. BMW E39 Alloys
  240. laguna head
  241. escos radiator.
  242. air/fuel gauge
  243. plugleads
  244. crank position sensor setup for my s2 efi
  245. turbo wanted t3
  246. wanted 4x4 cosworth rear brake set up
  247. rear calipers
  248. persperk windows /lexan ect
  249. sierra twin headlights wanted
  250. focus rs wheels
