PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. WANTED : Ford Escort XR3i 1993 1.8 105 engine
  2. 2wd Cosworth Rear Hubs & Outer Driveshaft Joints Wanted
  3. series one bits wanted( dont have to be mint!!)
  4. Under Bonnet Cover
  5. XR2 DONOR CAR!
  6. 3dr rear seat belt mount wanted
  7. saph front leather door cards
  8. wanted 90 spec rocker cover(got 1 now)
  9. Wanted hybrid turbo + 4 pot disc conversion for series 2
  10. want golf,bora or passat tdi px or swap 4x4 saff cossie
  11. Escort WRC front bumper needed also 909 splitter for same
  12. RS 500 Alloy or Modded std Fuel rails , URGENTLY !
  13. Blue silicon hoses for cosworth
  14. CAMKIT
  15. mk3 escort grill and smoked rear lights
  16. COSY 3DR TINTED REAR LIGHTS
  17. 325i sport e30-model
  18. S1 turbo
  19. bucket seats
  20. Standard level 8 board
  21. STARTER MOTOR
  22. T3 0.48 turbine/exhaust housing
  23. Any1 breaking a erst s2
  24. secs mon wanted
  25. t38 turbo!
  26. escort turbo cab,or cheap xr3 cab
  27. WOLF ESCORT COSWORTH
  28. Fiesta Suspension Wanted
  29. paddle clutch, wanted also 1.8 oil and water pumps wanted.
  30. Escort Cosworth Heat shield
  31. escos fuel level sender and pump bracket
  32. Wanted is a sapphire cosworth head/roof linning
  33. frst front and rear green bumper inserts
  34. RS 1800 Genuine alloys needed
  35. RS500 plenum/WRC Siamese and a naughty MT75 gearbox
  36. 3dr cosworth tinted rear lights
  37. Escort Cosworth Amal Valve (Lectron Valve)
  38. Door Lock Blanks
  39. T25 Escort plenum/throttle wanted
  40. RS500 wheels
  41. Escos Part(Now Sorted Thanx)
  42. 2wd exhaust manifold top section
  43. rs tURBO START MOTOR NEEDED
  44. T25 Turbo
  45. EVERYONE LOOK AT THIS WANTED POST
  46. Cosworths and ERST Wanted
  47. 89 series 2 rs master cylinder
  48. MK6 Escort RS 2000
  49. cossie bell housing
  50. electric mirror loom
  51. mk4 escort/mk2 orion all NEW rubbers/plastics-wat u got...
  52. 90 spec door cards
  53. Sierra blower
  54. sapphire cosworth wanted for private collection
  55. s1 turbo
  56. wheel swap
  57. ESCORT COSWORTH ELEC WINDOW BEZEL
  58. Focus RS stuff
  59. RS500 Genuine Front Splitter
  60. standard s1 bits
  61. Gearbox wanted !!!
  62. BUMPER STRIPS!!!!!!!!
  63. Black S2 Escort turbo
  64. Escort Cosworth gear stick with threaded end
  65. S2 Bits & Bobs Wanted Urgently
  66. big front brake kit for 4x4 saff
  67. fiesta rs turbo t2 exhaust housing needed!
  68. big brake's for 3dr
  69. twin coils
  70. sender
  71. Would any one be interested in doing a deal on some wheels??
  72. 3 bar map sensor
  73. superchip or equiv for 1afa ecu code xr3i efi 1990 1.6
  74. boost oil pressure guage and d/v for erst
  75. 2wd cosworth engine mount SORTED NOW
  76. MK3 XR3/RS1600i
  77. mk3 escort rear lights
  78. super cheap cd head unit wanted for my daily driver
  79. Escort RS Turbo s2
  80. 2wd turbo oil return pipe and 2wd exhaust bolts
  81. heated front screen
  82. RS turbo passenger door
  83. air intake 2WD sierra cosworth
  84. boost oil pressure guage and d/v for erst
  85. Small van wanted!!!!!!
  86. A FEW NUTS
  87. 19" ford touring car wheels
  88. Escos WRC rear spoiler & front bumper
  89. Escos leather interior
  90. boost oil pressure guage and d/v for erst
  91. Plastic fuel pipe from pump to filter
  92. Rs 2000 calipers wanted
  93. FRONT INDICATOR
  94. ARB for MK4 escort
  95. cosworth 2wd steering rack needed ASAP
  96. Turbo technics RS 1600i wanted
  97. RS 1600i Turbo technics
  98. WANTED
  99. bell housing
  100. Wanted To Swap.??
  101. traders wanted for Castle combe. 2...online form to download
  102. MK4 Escort combi or 3door estate???
  103. Lead to connect Pectel monitor to Pectel loom
  104. t3 turbo and manifold
  105. 3DR Cosworth wanted
  106. Focus Rs, St220 or St170 Front brake calipers and carriers
  107. 2.0 pinto serria ignition module
  108. Cossie Spec R Twin Strut Brace, 4 Spoke Horn Push, Coilovers
  109. Wanted.?? x2 70's/80's Blue Oval Ford Badges for Mk2 Escort
  110. Wanted.?? Strut Brace Wanted for Escort MK2 RS2000
  111. 2wd cosworth rear brake pressure valve
  112. wanted 2wd uprated engine mounts/ twin fuel pump set up
  113. s2 rollcage
  114. 3.9 7" rear diff
  115. any turbo bits.....
  116. Hi guys wanting a sapphire cosworth
  117. polished chrome alternator for S2 RST
  118. t3 turbo
  119. 2WD Sapphire Cosworth Thermostat Housing
  120. PUMA CALIPERS TO HOUSE 258mm BRAKE DISCS
  121. ESCORT MONTE
  122. ap brakes wanted
  123. 3 door cosworth shell wanted
  124. Fiesta XR2
  125. door cards
  126. a few mk 4 parts
  127. pfo9 4x4 tps wanted
  128. engine to gearbox sandwich plate (southend area)
  129. 2.8i capri gearbox
  130. wanted......decent standard t3 turbo for erst..........
  131. wanted series 1 or fiesta turbo p/x my 4x4 saff
  132. wtd:focus 17inch 7spoke mp3 alloys
  133. Mongoose Exhaust for ERST
  134. 0.48 T3 ERST exhaust housing wanted
  135. mk4 escort 3dr hatch
  136. coil pack driver
  137. Standard hoses and 2wd cossie discs
  138. silver mrk 4 escort bonus
  139. FRST wanted - badly
  140. S2 silicone boost hoses
  141. pillar pods
  142. HELP! Rs 500 fuel rail wanted
  143. Crystal blue 2wd saffy
  144. front abs sensor for 4x4 saff with round plug connection
  145. ford focus TDCI sport in black or imperial blue
  146. Kenwood grills
  147. s1 gearboxe lsd
  148. std chip for red top l8 ecu wanted
  149. Mondeo rearwheel bearings (EstateV6)
  150. Cheap Head Unit
  151. single wiper arm
  152. SAMCO BOOST HOSE
  153. erst d/v
  154. mondeo est rear spoiler
  155. wanted 2wd rs2k or 130bhp rear beam inc brakes
  156. wanted front bumper
  157. fiesta mk1 front opening quarter lights
  158. wanted mongoose or scorpion back box GOT ONE NOW
  159. BUMPER STRIPS!!!!
  160. 3 DOOR SEAT BELTS
  161. !600 X-flow block
  162. diff
  163. saphire cosworth mud flaps
  164. cosssie cam cover
  165. brakes
  166. Wanted escort cossie alloys
  167. Mondeo 2.0 Ecu
  168. S1 towing eye cover
  169. d/v for erst
  170. UPRATED S2 INTERCOOLER
  171. cheap cossie wanted, damaged,rotten etc
  172. escort rs turbo wanted
  173. t28 turbo wanted
  174. s2 rs turbo shell
  175. couple more bits needed
  176. Escort RS Turbo S2 **found 0ne**
  177. WANTED STANDARD SERIES 2 ESCORT RS TURBO ALLOYS
  178. XR2 Front Bumper
  179. S2 RST Intercooler.....
  180. 82 degree thermostat and cossie fan switch
  181. Sierra Cosworth Wanted
  182. XR4x4 K&Ns for non AFM 2.9?
  183. mercury grey series two door wanted
  184. Alloy top fuel rail Carwise or A1 will buy both if available
  185. Rs 2000 Wanted!
  186. lock set required please
  187. TWIN HEADLIGHTS
  188. CVH Block
  189. long shot ?.. bmw e30 parts
  190. 3dr Cosworth Bodykit Arch Needed URGENT!!!!! (Drivers Front)
  191. MK3 ESCORT SMOKED REAR LENSES
  192. FRST Loom...
  193. mk4 escort doors
  194. ERST fuel pressure regulator
  195. drivers side rear interior panel
  196. Sierra Cosworth Throttle Body
  197. S2 Tailgate
  198. ESCORT MK4 underside heatshield
  199. ofab map sensor
  200. URGENT: Metal Matrix to Water Pump Pipe
  201. one wheel please....
  202. Fibreglass 3dr rear spoiler
  203. S2 Bumper...
  204. Spare wheel holder (sierra sapphire)
  205. 4x4 saff alloy wheel
  206. front abs sensor for 4x4 saff
  207. Heatshield saff 2wd
  208. AP Brakes
  209. RST Engine bottom-end Wanted!
  210. t5 cosworth gearbox
  211. FRST engine needed
  212. Series 1 RS turbo...
  213. RS500 Intercooler With 3" Pipes & 2wd Coilovers
  214. 90 spec s2 front bumper
  215. mk4 escort tailgate
  216. lowering springs/ suspension
  217. C20LET ENGINE
  218. 215 35 18's
  219. Zetec Sump for a Escort
  220. zetec cam cover
  221. anyone with rs parts please click here...
  222. escort/fez turbo
  223. Escort LSD and Fiesta turbo/diesel Clutch
  224. t3 metal water pipe HEEEEEEEEELP!!!!!
  225. WANTED SAPPHIRE COSWORTH 4X4
  226. cheap xr2 wanted!!!
  227. Sapphire Cosworth for S2 Rs Turbo
  228. saxo vts/106gti/quickish fiesta or WHY
  229. leather for audi a4 avant
  230. t c a adjustabel for saff cosworth
  231. zetec s throttle cable
  232. COSWORTH SAFF`S FOR £3500 OR LESS.ALL OF INT
  233. zetec engine.......
  234. erst mongoose back box
  235. Small Turbo Escort Cosworth Phase sensor.
  236. s2 turbo unit
  237. Series 1 Rocker Cover
  238. Mondeo mk2 light switch wanted.
  239. 18 manta engine mount
  240. mk 2 escort
  241. series 1 spots and brackets
  242. t3 rs turbo actuator wanted/
  243. Chip for T34 Light blues and L6
  244. 90spec rs turbo, damaged, rotten etc to break
  245. genuine ford wing
  246. Cossie intercooler-throttle pipe- LOCAL- BRISTOL/BATH/GLOS
  247. S1 / S2 Thermostat Housing
  248. sierra cosworth replica
  249. cosworth cam cover
  250. RS Turbo Shell
