PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. L8 baby board
  2. Ford Mudflaps
  3. s2 roll cage
  4. focus
  5. Centre hub adapter
  6. rs turbo stainless exhaust.new??
  7. wanted rs turbo engine
  8. Fiesta MK6 1.4 Engine
  9. WANTED MK1 ESCORT rolling shell
  10. wanted part from frst or efi 3i
  11. rs turbo series 1 gearbox
  12. escort mk3 scuttle panel wanted
  13. RS500 inlet wanted
  14. Wanted: Escort GTi / Mondeo Si Cosworth Style Alloys.
  15. Rs turbo water pipes
  16. bottom end needed
  17. 3 door horns
  18. 1 recaro seat wanted
  19. Rear trim parts for Escort Cosworth
  20. throttle bodies and ecu for zetec
  21. rs for winter project/resto
  22. S2 Fuel Pump Relay
  23. Knackered RS Turbo Gearbox
  24. 3dr boot carpit
  25. WANTED! Escort RS Turbo Head
  26. laguna splitter wanted southend area
  27. 3 dr Plastic bulkhead panel??
  28. Swap 1800 ZVH bottom end for 1600 CVH
  29. WANTED
  30. Saph cossie bonnet vent / vents
  31. Saff strut braces,17"alloys,coilovers
  32. 2wd throttle position sensor
  33. 4x4 inlet 0r small turbo escort inlet
  34. wanted seirra brakes for smart project
  35. 4x4 Cossie engine loom needed and...
  36. WANTED: Escort/Orion Front Spoiler
  37. Escort Mk5 Roll Cage
  38. coilovers
  39. Sapphire bulk head panel
  40. s2 turbo master cylinder
  41. big turbo esc FUEL RAIL
  42. Ersturbo S2 front head lights + Clear Indcators!
  43. 2.0 Zetec Blacktop Cylinder Head
  44. OZ 18 x 8 super T
  45. Escort RST S2 Bottom End.
  46. T34 Downpipe
  47. Fiesta Mk3 Coilovers
  48. Series 1 RS Turbo
  49. Wanted! Escort Mk4 Lockwood Clocks
  50. Wanted! Escort Gti 14 Inch Alloy Wheel
  51. focus RS bottom end or pistons
  52. Escos standard seat subframe drivers side(rhd)
  53. cvh power steering pump
  54. Cossie inlet manifold - trumpet section.
  55. Wanted for Esc cos: Rear Quaife, Safety devices bolt in
  56. 2wd cosworth rad
  57. Series2 engine
  58. 3dr front bumper (white)
  59. erst radiator
  60. Rs Turbo ABS sensors
  61. Wanted - Lock set for MK5 Escort.
  62. WANTED Gp A Parts
  63. ford motorsport leads s2?
  64. Focus RS calipers
  65. oil breather system
  66. transit alloy wanted
  67. Dump valve T piece for intercooler cold side pipe
  68. BDA Style Zetec Rocker / Cam Cover
  69. cosworth t3
  70. 3.9 cwp and stepoffs wanted
  71. Xr3i Black Relay (speed sensing relay)
  72. s2 rs turbo lowering springs needed asap cheers
  73. xr3i in grey
  74. cvh power steering pump
  75. frst bottom end
  76. erst charge carrier/crossover pipe
  77. Non standard escort turbocharger
  78. s2 alloy rad
  79. Metro Turbo wanted...
  80. focus 2004 coilovers
  81. sapph cos interior door handles
  82. escort rs turbocharger wanted.in good nick
  83. sapph front bumper urgent!!!
  84. T34 Downpipe
  85. Rear Washer Jet For 3 Dr Cossie
  86. Spec R Headertank High Pressure Cap
  87. Gt3582r
  88. ford racing eletric oil temperature gauge
  89. flocked dash
  90. Saph Rolling Shell
  91. 2.0 zetec t forged pistons
  92. YBP oil spray jet
  93. escort s2 lowering springs
  94. BD16 inlet and BD14 exhaust and verniers
  95. rs turbo roll cage
  96. 3 Dr Cossie Spare Wheel Clamp/screw Down Bolt
  97. WANTED: S2 Mercury Grey Bonnet
  98. Cosworth Plug Leads
  99. bottom rad hose
  100. rs turbo breather
  101. s2 anti roll bar mounts
  102. Early saff recaro
  103. escort cosworth shell
  104. saphire rear spoiler
  105. msd chip for tt38 closed loop
  106. efi inlet
  107. 1x borbet alloy
  108. 2wd Cossie TPS
  109. escos rear bumper
  110. saff leather front seats
  111. oil breather
  112. few mk1 fiesta bits..
  113. Cosworth 2wd Engine[complete]
  114. RS500 Front Splitter
  115. n/s mudflap
  116. s2 RS Turbo fuel pump relay wanted
  117. 90 spec xr3i clocks
  118. 4x4 exhaust mani
  119. idle control valve 3i efi
  120. escort mk4 scuttle panel
  121. wanted: Door switch for cossie
  122. rev limiter wanted
  123. escort rs turbo s2 fuel pump holder wanted
  124. fiesta door mk3
  125. I would love an RS1600i....
  126. focus bumpers
  127. banana pod and wheels
  128. sapphire sunroof
  129. Paddle clutch for YB
  130. mk3 3.5 fiesta
  131. escort s1
  132. mk4 escort van load sensing valve
  133. Rs Turbo bottom end?
  134. Throttle Cable, 1.6si/2i 16v/rs1800
  135. looking for 2wd sierra shocks to keep a shell rolling
  136. 3DR dash part
  137. 16" Alloys Ford Fitment
  138. WANTED: £500ish car....
  139. Wanted XR4i Trip Computer plug/Loom wire
  140. magenta saff shell wanted
  141. After a set of wheel nuts for 4x4 saff
  142. S2 Chrome Roll cage in kent /Essex area
  143. s2 rs turbo idle contol valve screw
  144. 30mm cos 4x4 lowering springs
  145. 7 1/2 " cossie 2wd diff wanted
  146. Wanted XR4TI, Merkur MPG Meter/Clock conection plug
  147. xr3i
  148. xr3i
  149. Focus 3DR MK1 wanted
  150. Mk4 escort tailgate/boot
  151. Uprated 7" rear cossie diff
  152. MINT White 3dr bonnet
  153. Bailey breather
  154. Xr3i speed sensor relay
  155. recirculating dump valve
  156. focus inner wing gear box mount
  157. cheap r.s s2?
  158. various parts for s2 rs turbo
  159. Cosworth windage tray bolts
  160. mk5 rs2000 hex bolt for the brake caliper
  161. Mk2 Escort opening front quarter windows
  162. FRST OFAB Full loom
  163. Anyone Got a Escort Mk6 Rear Show Cage
  164. (Magenta) sapphire cossie panels needed (Magenta)
  165. Parts for Focus Project
  166. Cosworth Crank & Rods Wanted
  167. rot free late fiesta mk3 shell
  168. mk4 escort front bumper
  169. Anyone selling a ported 4x4 yb head ?
  170. Ported 4x4 cossie head
  171. wanted 90 spec mint door cards
  172. 1.8 tddi engine
  173. anyone got a nice mk2 escort for sale
  174. rs turbo handles
  175. mark1 fiesta front indicators
  176. fiesta 1800cc derv gearbox 1989-1995
  177. Degi gauges wanted model STS216B
  178. aftermarket tacho wanted
  179. wanted mk 4 escort carpet.must b mint!!!!
  180. wanted cosworth lattice wheels
  181. Bd 14 Exhaust Cam Wanted
  182. S2 twin/quad headlights
  183. S2 smoothed bumpers wanted
  184. Focus RS gearbox wanted
  185. Left Hand Drive electric mirror trim plate
  186. steering knuckle doughnut (help)
  187. RS500 Style front splitter
  188. mk3 Fiesta RS1800 bits
  189. MINT LOW MILE S1 wanted against Big T Escos
  190. cossie bottom end
  191. 3 door bumper inserts!
  192. Rwd Mt75 gbox mount
  193. Scuttle Panel
  194. 1.8 zetec sump and pick up pipe
  195. Cheap Cossie Exhaust... In Scotland!!!
  196. 1.25 zetec engine
  197. S2 RS Turbo fuel sender unit Wanted!!
  198. s2 indicator/light switch
  199. Escort Cosworth Parts
  200. T3 turbo needed
  201. MK4 Escort RS Turbo REAR SHOCKS!
  202. Mondeo 16inch Alloy
  203. ESCORT XR3i PARTS NEEDED!!!!
  204. escort rs turbo wanted
  205. 90 spec door cards!!!!!!!!!!
  206. oil catch tank
  207. Oil Sump Needed for a mk3 V6 Capri
  208. Rear coilovers for 2wd cossie
  209. Escort 1.8 Zetec
  210. Ford springs & Ford shocks for cosworth.
  211. electric power steering pump
  212. 2wd rolled out Cosworth backbox
  213. mk3 fiesta turbo/xr2i/rs1800 parts wanted
  214. escort cossie grp a mar rear end wanted
  215. Pace intercooler for cossie-wanted(40mm core)
  216. Fog Lamp Grilles Wanted For 3 Dr Cossie
  217. ofab loom
  218. air injectors wanted
  219. T4 and Greys
  220. bailey header tank for s2
  221. cheap oil catch tank
  222. car wanted
  223. vernior pulleys for a cossie i dont care if there taty.
  224. Capri Rollcage
  225. ERST gearbox wanted
  226. 3dr sierra shell
  227. Standard Saph 2wd Wheels
  228. Air injectors wanted
  229. rad hose
  230. Escort Cosworth Wheels
  231. MFI RS Turbo Cylinder Head And Or Pistons
  232. External Cosworth Fuel Pump
  233. cossie fuel pump and cradle
  234. very cheap exhaust for escort gti/rs2000
  235. Front Strut Brace Please
  236. a4 parts
  237. Auto Electrician
  238. Cosworth Fan Loom
  239. good mfi engine loom wanted
  240. morette head lamps
  241. cheap car wanted
  242. boost controller
  243. Efi inlet to mfi head adapter plate.
  244. Coilovers series 2 rs turbo
  245. Gt30 turbo parts
  246. Focus Gearbox
  247. beige injectors / 3 bar map / 195 chip
  248. escort cossie grp a mag peddal box
  249. sapp half roll cage???????????
  250. Mk5-6 Rs 2000 drive shafts
