PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. NEED Fiesta xr2 front brake carriers
  2. 2wd copper brake pipe
  3. Urgently needed... Sapphire shell
  4. Couple of issues of Rallye News
  5. tank strap
  6. 2.0l zetec flywheel
  7. RWD Sequential dog box Wanted
  8. series 2 rs turbo starter
  9. silvertop s1 zetec 1800 piston
  10. Escort Turbo Fuel Tank
  11. mk1 focus lowering springs
  12. Turbo for s2
  13. cossie rear poly diff mount
  14. 2wd Cosworth front brake calipers
  15. 3dr body kit
  16. 4x4 rear hub. SORTED
  17. 4x4 cosworth fuel regulator
  18. Turbo for series 2 bigger the better
  19. T5 box needing rebiuld!!
  20. Wanted: 17" RS7 Softlines
  21. Coilovers
  22. Not a ford part for once, bmw exhaust....
  23. s1 rst rear arches (bodykit)
  24. s2 green tint opening rear quarter glass
  25. URGENT RST head
  26. 2wd brake pins set
  27. cosworth parts wanted
  28. Crashed or Focus Rs running gear wanted!!!!
  29. ka spoiler wanted
  30. 2wd driveshaft bolt
  31. 15'' r888s
  32. mk5 escort rs2000 bonnet bulges
  33. car hi-fi
  34. std sapphire steering wheel
  35. escort mk6 RS accessory Boot spoiler
  36. s1 bodykit and bumpers wanted
  37. **Focus ST170 gearbox - URGENT **
  38. Yb Downpipe triangle bracket
  39. im after a set of lattice alloys
  40. S2 rad
  41. Plastic covers for the rear of Saff headlights.... **sorted now lads cheers**
  42. cosworth 7.5" diff DIFF JACK SHAFTS
  43. Escort mk4 1.6 cvh distributor
  44. WANTED Stack 80mm 4 Bar Boost Gauge. Hav 3 Bar one if wnated to swap ??
  45. Black Apexi AVCR....
  46. Wanted Silver Top
  47. Black Silicon Coolant Hoses (2wd saph)
  48. cosworth sunroof wanted
  49. 2wd top rad hose
  50. Wanted steel wheels
  51. ib5 diesel gear box
  52. A T34 or T3 core in good order,
  53. cossie parts
  54. mint 90 spec drivers seat.
  55. 17 or 18 3dr alloys?
  56. tsw stealths 4x108 ford fitment 16" or 17"
  57. Escort mk3 rear gearbox mount
  58. any mk4 escort
  59. RS WANTED - Somethind Fast & Reliable
  60. Cosworth T5 gearbox/bell housing bolt
  61. corbeau side mounts
  62. iPad 2
  63. zetec forged crank
  64. White or moonstone 3dr wanted!!
  65. 4x4 rear calliper sliders
  66. Fuel sender unit escort cosworth
  67. Pinto and yb parts needed
  68. N/s escort cosworth wing
  69. cooling fans for a saph cosworth
  70. 3dr passenger side front inner wing (FOUND)
  71. Wanted: Focus Mk1 RS wheels
  72. wanted,a couple of s2 bits that people may have laying around
  73. wanted zetec ISCV
  74. Braided pipe to fit Bailey Breather (just a looky looky one)
  75. 1x 17" alloy to fit 2wd sapph-must clear 330mm AP's
  76. Sapphire Bonnet cable and BOA v6 Fan
  77. turbo water feed pipe
  78. FRST breather
  79. T5 Box
  80. XR2i arch
  81. OFAC Stage 2/195 Chip
  82. Is any One Considering Selling....
  83. focus RS disks
  84. used 2 post ramp wanted..
  85. Autoart 1/18 Evo VI - prefferably a TME
  86. R&D gearbox
  87. T5 bell housing
  88. cosworth front diff brace
  89. rs turbo back box 16in tyres
  90. cossie 4x4 bonnet vents wanted
  91. Mk4 Escort Door
  92. is there anyone in the crystal palace area with a bottom hose for a xr3i?
  93. cosworth 52mm temp gauge
  94. r888s
  95. DEFI 60mm oil pressure gauge (amber illumination) with sensor etc
  96. s2 drivers seat
  97. Turbo Damper Hanger Bracket
  98. cosworth con rods
  99. Saph cos side fitments clips 4x4 front bumper
  100. Wanted
  101. Set of Cossie 4x4 Coil overs
  102. shockers
  103. Rear coilovers & exhaust for Sierra 2.0 DOHC
  104. Uprated 2wd gearbox mount
  105. Fiesta ST Radiator, Radiator Fan, A/C Radiator, Slam Panel
  106. Cosworth Crank Sensor
  107. Saff dash switchs early dash type **SORTED THANK YOU EVERYONE**
  108. 3 door cosworth or RS500 splitter
  109. '89 XR3i Cabriolet window weather strips
  110. cossie calipers
  111. Delete
  112. 4x4 wing badge-Saph cos
  113. Cosworth inlet only part that injectors are fitted to needed.
  114. Esc Rs Turbo front coilovers
  115. wanted mk2 xr2 parts
  116. Cos 2wd engine loom for l6 ecu, Bristol area.?
  117. RS2000 wiring loom
  118. WANTED// mk1 Sierra 3dr or possibly sapphire, base spec model, T&T'ed
  119. Cossie AMAL Valve
  120. Escort zetec bits
  121. Revolution RFX in 7x16s and 8x16s for sapphire
  122. Small Turbo Plug lead cover and Cambelt cover
  123. 2wd cosworth parts needed
  124. Wanted cosworth 3dr wiring loom and sunroof
  125. Big Power Rs Turbo Wanted
  126. 3 door spoiler brackets
  127. Draper Fault Code Reader Ford 3 Pin 68082
  128. S2 magnex or mongoose back box
  129. OFAB Wiring loom & ECU & Inlet Manifold Wanted
  130. RS turbo/xr3i front shocks
  131. Turbo needed
  132. Wanted Escort S2 RST mint condition with big
  133. Sapphire Cosworth external window seals **all sorted thanks everyone**
  134. Wanted S1 must be mint with 200bhp - no set budget... Cash waiting!
  135. Cosworth gearbox spares
  136. playstation 3 wanted
  137. Focus rs bootlid
  138. S2 RST rear disc conversion set up
  139. Track tyres
  140. 2wd cossie front brakes (uprated)
  141. Escort Cosworth centre console bit
  142. Need top rad hose in blue (roose, sfs, samco)
  143. Wanted ps3 slimline
  144. S2 gearbox
  145. cosworth clutch
  146. Fiesta rs turbo t2 actuator
  147. mk4 escort auto help
  148. Sierra Running Gear
  149. WANTED -6 & -8 braided hose
  150. Wanted fuel regulator
  151. 215 40 17 tyres
  152. Escort cos headlamps
  153. Wanted escort series 1 rs turbo must be in a1 condition.
  154. 2.0 black top Zetec head...
  155. Wanted!! escort series 1 rs turbo mint big bhp
  156. Mk4 escort xr3i efi full loom
  157. Rs turbo alloys 16" or 17" wanted
  158. 330mm brake rotors
  159. T5, C/R, CTS BOX or similar
  160. Cosworth 4x4 pistons STD size
  161. cosworth bottom end
  162. focus stereo
  163. fiesta rs turbo bumper pin stipes
  164. 3door fuel tank sender unit?
  165. Cosworth skirt clips
  166. 3.5" front pipe.
  167. S2 RST rear stub axle
  168. wanted yokohama a539
  169. Sierra cosworth central locking module
  170. 17 or 18 std offset escos wheels gpa inserts
  171. 18" oz super t alloys
  172. 3dr cossie rocker cover wanted
  173. saph boot lid
  174. sorted - Please delete
  175. Front and side ambers
  176. Size 4 Carcoon.
  177. T5 parts wanted
  178. sorted please delete
  179. Yamaha Raptor 700
  180. Defi Control unit
  181. YB Inlet Valves
  182. Standard Mondeo ST24 wheels/tyres
  183. FRST/2i wiring loom
  184. saph sunroof wanted
  185. Granada cosworth map sensor
  186. fiesta EFI cross over pipe
  187. Efi conversion parts
  188. wanted: Sierra diff
  189. FOCUS ST ALLOY 18 inch WHEEL
  190. Cosworth bulkhead gromets
  191. help i need one 803 green injector and a 2wd prop
  192. 2wd coilovers
  193. Outdoor cover for sapph
  194. please remove - sorted
  195. Cosworth parts needed please, can swap/px
  196. Cosworth Alloy rad
  197. escort rst top boost hose
  198. Drivers door loom S1
  199. cosworth valves
  200. mk4 escort bits
  201. Top of the range Kenwood Head Unit
  202. Wanted Focus 98-2001 front n rear bumpers
  203. Wanted:Mint 3dr/2wd sapp cossie original steering wheel
  204. 4x4 eng mounts
  205. 1x 17"x7.5" Alloy - Any condition
  206. wanted sierra rear seats
  207. S2 brake bias valve
  208. WANTED Main caps for 200 block
  209. mk5 xr3i/rs2000 foglights
  210. 3door nearside smoked indicator
  211. cosworth bailey breather wanted, 2wd bottom pulley
  212. Stainless Exhaust for 4x4 Saff in newcastle/durham/sunderland
  213. Cosworth 2wd suspension... konis etc
  214. wanted 044 fuel pump
  215. N/s front saph jacking cover
  216. Rs sender unit
  217. Escort Cosworth Turbo Heat Shield
  218. FRST Fuel line
  219. Brake lines + Clutch fork
  220. escos power steering pump/ digital dashboard clock
  221. xr2i wanted
  222. Standard exhaust cam for 4x4 head please
  223. Rs turbo block
  224. Rear sapphire window seals new
  225. 18 inch old style or new compomotives (GOT A SET)
  226. any performance engine parts for 1.7 puma engine
  227. Ford CD 6000 Player
  228. MK1 Focus RS engine
  229. hi spec 2wd saph or 3dr px 4 my 26k escos
  230. Jeep Grand Cherokee Engine 4.7 V8
  231. 3dr Sierra NON sunroof'd roof panel wanted
  232. 3.9 9inch cwp, stack st400b 4bar boost and hens teeth wanted
  233. 8 injector cosworth loom
  234. Urgently require a ickle headlight part which someone will have lying about
  235. 2WD Saph Cosworth Powersteering Hose
  236. s2 headlight intake
  237. 3 door bonnet vents
  238. 2wd diff top bolt
  239. sparco pro 2000 seat
  240. focus st 170 brake disk
  241. O/s front cosworth jacking caps/covers
  242. OMP rear strut brace
  243. Escort estate wanted
  244. ERST
  245. 2wd cosworth bits
  246. Wanting some
  247. 3 door cosworth bonnet - idealy near sunderland
  248. Escort Cosworth morette headlight adjusters
  249. 2wd coilovers wanted
  250. Sky HD Box
