PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Unwanted Cosworth TCAs and compression struts
  2. 4X4 Drive shafts
  3. escort mk3 inner front wings
  4. wanted,banjo nut that connects to oil feed on a s2 rs turbo
  5. Focus 2.0 gear selector and gearstick
  6. Wanted 1.6 cvh mk4 escort
  7. Bullet Proof Bottom End for RST
  8. wanted cossie seat base
  9. wanted escort rs turbo turbocharger t3 :(
  10. Wanted- Catch tank for a 3dr - Spec R or similar
  11. 4x4 cosworth sharktooth wheel
  12. Series 1 Black silicon hoses.
  13. 2WD Sierra Cosworth Parts Required
  14. mk4 escort xr3i
  15. RS1600i loom
  16. 17 inch team dynamics pro race 1.2 or oz racing super t's
  17. RS500 Intercooler
  18. 4x4 cos driveshaft part needed
  19. WANTED Escort mk5/6 / cossie doors
  20. Momo horn push wanted
  21. one escort cosworth wheel wanted
  22. fiesta 3.5 suspension
  23. few rs turbo parts fiesta and escort
  24. cheap s2 turbo/e30 325i/535i
  25. 2wd idle screw
  26. a few saph cossie bits needed
  27. a couple of 3dr sierra parts wanted
  28. SORTED NOW! ERST Standard Size and CR Piston...
  29. escort rs turbo 90 spec door cards
  30. 2wd Sapphire Cosworth Exhaust
  31. S1 arches and side skirts
  32. 3 door arches
  33. OFAB ECU wanted
  34. Sapphire boot lid in flint grey
  35. Cosworth Group a Gasket/rocker gasket/bolts
  36. wanted urgently
  37. Sierra Sapphire rwd steering coupling
  38. escort cosworth stereos both
  39. wanted 3rd interior
  40. 63 housing wanted
  41. BMW e46 MV2's 18" with tyres??
  42. 16" Mondeo MK3 5 Stud Steel Wheels.....
  43. ERST Front mount intercooler with fans
  44. Wanted Escort Cosworth
  45. Wanted Escort Cosworth
  46. couple of small bits for sierra
  47. sharktooths
  48. wanted mk4 escort
  49. 2wd cloth door cards and interior parts
  50. calling traders..... Need a -34 actuator
  51. RS Turbo / XR3i spot lights
  52. cosworth front seat
  53. sierra idle control valve wanted
  54. Escort rs turbo alloy rad
  55. 3 DOOR COSWORTH jacking point covers
  56. white escort cosworth early big turbo
  57. t4 turbo or similar ???
  58. 3 door parts wanted
  59. Focus WRC rep
  60. escort cosworth stereos
  61. Mk6 escort van rear gearbox mount
  62. Area Six Turbo Manifold for I4 RS2000 ;)
  63. Black cosworth rocker cover
  64. 4x4 flint grey bonnet
  65. Delete
  66. WANTED 16" 5 spoke mondeo wheels ASAP
  67. 2wd cossie sump
  68. cosworth front seat
  69. 02 fiesta zetec s mk5
  70. CTEK Battery maintainer/charger
  71. steering cowling, 3 door sierra
  72. Rondell 122 centre caps x 4
  73. Escort or Sapph 4wd front cross member and steering rack
  74. Small turbo cam cover and spark plug cover
  75. Cosworth rear coilovers urgent
  76. mk4 broken into need parts
  77. wanted escort cosworth alloys
  78. MK3 Orion/Escy saloon bootlid
  79. XR3i efi cabs bits needs
  80. WANTED: Sierra
  81. sorted pls delete
  82. S2 inlet bits
  83. 2wd gearbox
  84. Escort bonus
  85. Escort RST carpet
  86. RST EFI BLOCK Wanted.
  87. Recovery truck wanted
  88. urgently required
  89. GT30 turbo
  90. Cosworth engine for rebuild
  91. Wanted ,Amp & speakers
  92. 97 ford ka coilovers
  93. Fiesta ST front seats and door cards
  94. T25 turbo
  95. wanted mk4 escort 3dr front manual window regulator drivers side and passengers side
  96. Cosworth T34 .55 or .63
  97. Block sorted, now i need a cps holder!
  98. 3.5t car transporter trailer
  99. T4 turbine housing
  100. Propshaft blocks
  101. std escos wheels and poss rear diff/prop
  102. series 1 skirts and arches ( tatty )
  103. xr4i rad
  104. mk6 fiesta/transit connect airbag
  105. sierra sapphire cosworth 2wd in crystal blue
  106. Imperial Blue Escort Cosworth
  107. 1 x beige injector
  108. wanted s2 big front mount intercooler and fans
  109. escort adj tcas
  110. Escort RS Turbo Bailey oil breather/seperator wanted...
  111. WANTED Cheap bottom end
  112. Saph 4x4 speedo clock
  113. S2 90 spec clocks
  114. Sportka - damaged / non runner
  115. top hose
  116. Escos gearbox
  117. 2 bar std map sensor
  118. 2.0 mondeo ecu
  119. S1 Alloys
  120. wanted t34 on cossie 48 housing..
  121. worn saf leather front seats
  122. capri parts neeeded please
  123. Wanted saff 4x4 coilovers or koni's
  124. Cosworth fuel pump cradle
  125. mk 1.5 bumper inserts and side trim 3door
  126. Wanted full s/s exhaust 4x4 saff cossie
  127. 2wd cossie diff 7.5" with 3.9 or more wanted asap
  128. Big Power Rs Turbo Wanted
  129. Sierra CVH/DOHC bits
  130. Escort RS Turbo
  131. high spec and minty mint saph cosworth wanted
  132. CVH Trigger kit
  133. cossie l6 ecu needed !!!
  134. Saph leather doorcards
  135. 3 door cosworth INDICATOR STALK/SWITCH
  136. wanted!!! s1 fuel pump relay
  137. cossie l6 ecu
  138. MK4 Escort/Orion RS Turbo Steering Column
  139. Head unit
  140. cosworth strut brace
  141. amber indicators
  142. Mk3 fiesta flushed boot hatch + bonnet lifter blocks please
  143. t3 turbo
  144. 2wd cosworth uprated fuel pump
  145. cossie l6 ecu needed !!!
  146. 4x4 exhaust
  147. sierra cosworth door body moulding
  148. Cossie rear beam assembly
  149. RS500 rear lower spoiler
  150. this inlet for RS TURBO
  151. S2 RS Turbo LSD Wanted
  152. Series 2 RS bonnet
  153. Focus RS mk1 bits
  154. 2bar Map sensor wanted
  155. Alternator mount for 1.8 cvh sierra wanted.
  156. Sierra 4x4 ABS Master Cylinder needed urgently
  157. mk2 fiesta bits wanted
  158. coil overs for a mk2 fiesta
  159. Mk3 granada 2.8 efi inlet plenum and manifold wanted
  160. Mk3/s1 sunroof
  161. s2 bits i need
  162. Stihl or equivalent long reach hedge trimmer
  163. wanted 1.6 cvh baffled sump.....
  164. 2wd front cossie discs
  165. FRS mk1 bluefin & forge actuator
  166. ford fiesta MK3 front hubs
  167. cosworth restoration spitt
  168. **Wanted Series 1 or Series 2 RS Turbo**
  169. Series 2 Rs Escort
  170. After some parts for my MK4
  171. Escort Turbo Front Coilovers oe koni's wanted
  172. small turbo escos cam cover and spark plug cover
  173. Cosworth side exit exhaust
  174. escort cosworth 16s 8j x4
  175. focus RS mk1 exhaust manifold (standard)
  176. cosworth 4x4 inlet manifold + light blue fitting kit
  177. Anybody get cheap body panels???
  178. Saff center vents
  179. Wanted! V6 sierra flywheel!
  180. wanted sierra sapphire
  181. Wacker plate
  182. 2 poor saf leatherf front seats
  183. EFI CVH Head, Block, Crank and Flywheel.. please!
  184. Efi car loom for a escort mk4
  185. 90spec spoiler caps x4.... escort turbo series 2
  186. yb cylinder head replacement parts - anywhere ??
  187. heat cover for cosworth alternator
  188. S1 Opening rear windows
  189. 2wd gaz gold or better coil overs
  190. Standard BT Escos parts required
  191. fiesta 2.0 parts
  192. XR2/XR3 Twin Choke Weber carb and manifold
  193. td sierra wanted
  194. Gearbox Gaitor
  195. Tarmac Square GpA rear axle beam Wanted
  196. Cosworth T25 or hybrid
  197. Tailored Recaro Seat Cover (3 Door Cosworth)
  198. Escort RS Turbo Gearbox and Actuator...
  199. cheap track car wanted
  200. ST200 Throttle Body
  201. A few series 2 bits
  202. FORD ESCORT GTI 15's wanted
  203. Cosworth Power Steering Pipes
  204. wanted ahmed bayjoo springs
  205. 3 door tailgate wanted
  206. alloy wheel
  207. low miles saph cos 4x4
  208. EFI inlet manifold fittingq
  209. bayjoo springs. for 2wd sierra cosworth
  210. MT75 4x4 Bell-housing
  211. EFI head
  212. Sunroof Assembly for S1 Rs Turbo
  213. Yellow samco hoses
  214. set of 803 green injectors
  215. Wanted s2 black boost hoses
  216. anyone got a spare stand pass and ticket for trax?
  217. st170 head
  218. Wanted : MK1 FRS front callipers.
  219. long studded 200 block
  220. siemens 83ib injectors
  221. 17" RS7 Alloys and dash for mk3 escort
  222. late sapphire wheels
  223. Escort rs turbo bailey oil breather
  224. Concrete sectional garage wanted
  225. please delete
  226. petrol tank filler neck for escort mk4 van
  227. 3dr braided engine bay loom
  228. Fiesta st wheels and bumpers
  229. LHD reverse light for mk 2 focus facelift
  230. White iphone wanted
  231. 3 door scuttle panel - middle section only
  232. wanted l6 ecu standerd
  233. 2wd gearbox and diff wanted !!!
  234. 3dr cosworth elec mirror switch
  235. wanted dizzy fixing bold/plate ?
  236. wanted 17" or 16" alloys
  237. wanted golf gt tdi
  238. cigarette light+loom.... mk4 escort
  239. 4x4 cosworth ss exhaust
  240. bucket seat side mounts.
  241. 3dr cosworth air deflector
  242. 4wd Big wing sump & baffle
  243. Sierra 4wd fuel rail and fuel regulator
  244. 2WD Sapph idle speed control valve
  245. RST Wiring loom needed asap!! lol
  246. S2 gear box
  247. Escort Rs Turbo Coilovers/Koni's Wanted
  248. 2wd cosworth sump
  249. 2.0 Blacktop Zetec wanted
  250. Cosworth leather front seat centre panels wanted
