PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95
  1. RS500 Intercooler
  2. XR or RS wanted - must be vgc! No rust etc
  3. stage 3 cosworth conversion parts needed 2wd
  4. FRST for SWAP
  5. Flywheel
  6. Escort Si/Gti Bumper wanted
  7. An A Frame.......
  8. Mondeo 16's wanted...
  9. Metering head
  10. waste oil heater wanted
  11. focus wanted
  12. Complete 4x4 sapphire running gear
  13. 4X4 Sapphire preffered, maybe 2wd
  14. cossie discs
  15. Audi 5 cyl Turbo Deisel Engine, The TD version not the Tdi
  16. xr3i part needed badly
  17. one cosworth exhaust valve
  18. rs spoiler needed in black
  19. T2 Manifold
  20. HYBRID T2
  21. White S2 ERST Wanted ASAP
  22. 4x4 cossie loom needed everything apart from engine loom
  23. good t3 or hybid wanted birmingham or surounding area
  24. mk1 escort
  25. SAPH COZ TWIN HEAD LIGHTS !
  26. ERST or FRST Conrod wanted.. URGENTLY!!
  27. Fiesta Rs Turbo Management..
  28. ERST Parts...
  29. granada cossy wheels with tyres, midlands area!
  30. 0.63 TURBO HOUSING
  31. escort turbo boost hose
  32. ht leads [ magnecor ]
  33. 90 spec spoiler
  34. about a tailgate
  35. erst engine close to brimingham
  36. erst blanking plate
  37. Puma Alloys??
  38. l8 and p8 ecu
  39. Sapphire Cosworth
  40. s2 anti roll bar
  41. T3 turbo water pipe banjo bolt&washer
  42. Mk4 Escort Window
  43. WANTED: Fiesta MK5 Zetec S Rear Bumper
  44. outdoor carcoon
  45. Esc Cos Rocker Cover
  46. 90 spec white front bumper wanted
  47. Wanted: 17 Inch Cossie Fitment Wheels for 2WD Saph
  48. Decent Uprated Front and Rear Brake Kit 2WD Saph
  49. 17" wolfrace voodoos
  50. GROUP A SPEC ECU WANTED
  51. ford cd player
  52. 2L Zetec Sump
  53. 2wd strut and hub for cossie must be in birmingham asap plea
  54. cosworth seat brace floor part (under car)
  55. rear cossie calipers
  56. wanted:rwd sapphire cossie
  57. interior door card HANDLES
  58. erst engine close to birmingham
  59. ford split rim wheels
  60. S2 RST Engine Wanted deaperate
  61. twin cam anti roll bar
  62. magenta sapphire non vented bonnet
  63. t3 hybrid wanted, anyone got one local to birmingham
  64. 4x4 throttle cable
  65. 16" 5 spoke Zetec Alloy?
  66. wanted escort cosworth leather seats
  67. saph 2wd wheel needed// CAN ANY ONE ELSE HELP ASAP
  68. engine
  69. Head lining needed for a 4x4 saph
  70. escort RS1600i etc mk3 2 bolt front suspension struts wanted
  71. CHEAP S1 DEAD OR ALIVE
  72. EFI CONVERSION PLATE
  73. WANTED 17" MOMO ARROW FOR 2WD COS
  74. Escort Cosworth Centre console
  75. S2 RS Turbo standard front brake calipers and headlights
  76. RS2000 Rear beam x x x x x
  77. 2wd saph diff needed .... ideally good 1
  78. Steering wheel boss for a S1
  79. help....................
  80. rs turbo for my mk5 cabby
  81. Escort mk4 front heated screen switch and relay
  82. fiesta turbo must be a good one no rust around cap
  83. Rear brake pad's/disc' for saph cos 4x4
  84. Cts stage 2 or 2+ box needed urgently
  85. Mk 4 escort VAN parts
  86. cheap erst turbocharger asap
  87. ESCORT COSWORTH BONNET NEEDED
  88. mint fiesta rs turbo bottom end
  89. s1 or S2 rs thurbo with zetec conversion
  90. 1988 2wd clutch kit
  91. kenlowe fan
  92. **WANTED**lower anti roll bar mrk4 XR3i **WANTED**
  93. rear quarter panel
  94. MOMO ARROW
  95. no longer needed !!!!!!!!!!!!!
  96. Sapphire bonnet - NE England
  97. erst engine close to birmingham
  98. 2wd Cossie Coilovers
  99. Escort mk4 centre vent heater pod
  100. RS2000 alloys wanted
  101. Orion Repairs
  102. wanted a fiesta turbo rocker cover (standard)
  103. injectors
  104. lefthand drive cosworth wanted in spain please
  105. 4x4 cozzy gearbox and transfer box
  106. 90 spec interior.. ERST
  107. desperate for standard hearts and diamonds ecu
  108. s2 or s1 rs turbo wanted (swap my sapphire cosworth )
  109. 4 Spoke Steering Wheel Centre, anyone got one ?
  110. cheap turbo needed. why?? work or no work!!
  111. t25 turbo wanted
  112. 1.6 Efi Flywheel...
  113. mercury gray front bumper
  114. mk3 back lights
  115. ERST / FRST over size pistons
  116. wanted a full set of water & boost hoses for cosse can b
  117. Escort Cossie Dash clocks (speedo, rev, fuel and temp gauge)
  118. wanted esrt engine close to birmingham
  119. xr3i distributor
  120. No longer required
  121. ERST S2 front anti roll bar brackets needed both sides
  122. mk2 mondeo st24/200 estate rear bumper
  123. S1 Standard Boost hoses
  124. Saph Cos 4x4 Bonnet (white)
  125. N.S.F. Cos 4x4 hub assembly .
  126. s1 shell
  127. Cosworth 200 block
  128. mk4 escort sunroof
  129. escort gti gearbox
  130. 4x4 diff
  131. 2wd Cosworth Brakes...
  132. Focus RS badge in RED (Large)
  133. RS Turbo Block
  134. ford 100e wanted
  135. Escort mk4 Pedal box or clutch pedal
  136. rs 200
  137. rear opening quarters from FRST
  138. erst engine local to birmingham
  139. water pipe
  140. escort cosworth ABS sensor....front one.
  141. NEED A S2 IN BLACK OR GREY
  142. XR3i MFi Mixture Screw
  143. t3 turbo wanted?
  144. Uprated fuel pump
  145. MK6 RS 2000 4x4 Transfer box
  146. heated front screen for fiesta rs turbo
  147. roof wire
  148. s1/s2 shell - must need minimal work
  149. Wtd - cosworth turbo engine, box and loom...
  150. '90 Spec RST Recaro's
  151. 1600 rs turbo engine
  152. series 1 full loom
  153. s2 2.1 zvh swap for cossie
  154. S1 parts needed.
  155. Focus RS Rear Brake Calipers
  156. mint s1 rs turbo wanted
  157. NEW escort Cosworth headlights and hockey sticks and spoiler
  158. Wanted: Sierra bonnet magenta
  159. 2wd coilovers
  160. escort cos side skirts/all 4 pieces
  161. Cossie Brakes
  162. cheap erst bottom end
  163. Escort Cosworth undamaged front bumper wanted
  164. RS1800 super chip
  165. ERST WIRING LOOM
  166. Mk6 Escort bodywork
  167. 3dr Cossie roof lining wanted
  168. high pressure oil pump for 4x4
  169. BUDGET BONUS MK4 3DOOR ESCORT
  170. mint budget 3 door mk4 escort
  171. 16in lightweight wheels wanted
  172. koni key
  173. looking for a mk5 3 door escort around glasgow area
  174. looking for xr4x4 scraper must be near cambridge
  175. wanted shell.
  176. cosworth crank
  177. MK 2 XR2 Turbo wanted
  178. Sierra Cosworth 4x4 Turbo
  179. help cossie off the road
  180. s2 rs 4spoke steering wheel boss wanted.
  181. escos fuel tank sender unit
  182. 3DR Cossie/MK1 Sierra kick well panels and head rest cloth.
  183. Cosworth Bonnet Vents Wanted
  184. Wanted - Imperial Blue 1.8 Escort Cabriolet
  185. cosworth
  186. 3dr/RS 500 T5 Gearbox mount
  187. RS500 COMPLETE FRONT BUMPER IN BLACK WANTED
  188. MOUNTUNE WRC 8 INJ PLENUM WANTED
  189. 3DR COSWORTH DRIVERS DOOR WANTED
  190. 3DR COSWORTH GRILLE WANTED
  191. 3DOOR COSWORTH FRONT SEATS WANTED
  192. 3 DR COSWORTH FRONT DOORCARDS WANTED
  193. RS500 WHALETAIL WANTED
  194. Couple of cossie bits and bobs required
  195. FORD WANTED
  196. 4x4 sierra cossie rear calipers
  197. XR2i Engine loom
  198. YB Cossy engine needed !
  199. Pectel monitor
  200. RS wheel arch spats
  201. Chipped Heart And Diamonds ECU
  202. L8 ecu, or any with same wiring plug.
  203. Escort Cosworth Upper spoiler
  204. atlas axle
  205. S1 escort bits needed
  206. saff bonnet
  207. FRST Radiato
  208. Mk3 escort front wings, genuine
  209. Series 1 RS turbo wanted in exchange for 4x4 Cosworth
  210. xr4x4 rear calliper
  211. 4x4 cossie coolant pipe wanted
  212. escos alloys
  213. Heated front screen relays
  214. 3dr bits n bobs
  215. turbo wanted
  216. door handle
  217. s2 sunroof in North West area?
  218. Wanted Parts for S2
  219. standard rs turbo boost hose without DV
  220. rs turbo alloys
  221. mint mint s2
  222. wanted 17 inch momo arrows ford fitment
  223. MK5 escort fuse box
  224. garage or lock up
  225. mk4 xr3 efi loom wanted
  226. 3door pasinger side vent
  227. auxiliary air valve
  228. RST Side skirts Needed ASAP
  229. ball valve needed off cossie pump
  230. S1 escort body kit
  231. compomotive rally wheel needed
  232. RS HORN PUSH
  233. Interior part?
  234. S2 90 spec handbrake console, coilovers??
  235. WRC Rear Wing for Ford Focus wanted
  236. knock sensor, std map sensor, std oil filter sandwich plate
  237. T2 Hybrid
  238. 3dr splitter
  239. Wanted...
  240. Sierra saph wheels
  241. s2 interior door handles
  242. Wated: Sierra Group A dual master pedal box
  243. Down pipe for Cosworth
  244. Mk5 escort CVH gearbox
  245. Mondeo 5 spoke Alloys
  246. wanted mk3 or mk4 escort sunroof
  247. rs wanted
  248. standard cossie brakes
  249. Escort Air Con Knob
  250. wanted 13/5.5 steel wheels old skool
