PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 [66] 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. CVH EFI 4 Branch manifold wanted
  2. Wanted RS2000 MK5
  3. 90 spec escort bumper
  4. WANTED POWER ENGINEERING ALLOY CVH ROCKER COVER
  5. Stage 3 MFi Head ERST S2
  6. MK 2 XR2 SEAT WANTED
  7. 9 Inch diff!
  8. Rally lamps
  9. head unit
  10. 500 style intercooler
  11. green chip wanted
  12. escort cos small turbo air box
  13. 4x4 cossie rear prop
  14. Morettes for a LHD saph cosworth 4x4
  15. Lamp pod for a sapphire Cosworth 4x4
  16. frst engine
  17. ISCV for fiesta 1.25lx R redg
  18. 90 spec front bumper for s2
  19. 4x4 cos bits needed...
  20. 2wd dip stick
  21. 17" Rondells
  22. Rs Turbo
  23. fiesta rst down pipe
  24. xr2 turbo mk2...
  25. 2wd gearbox
  26. 3 door dash and
  27. Erst wanted
  28. T34 TURBO
  29. * 1 x GENUINE ESC COS ALLOY. *
  30. 330 MM BRAKE CALIPER BRACKETS WANTED
  31. 3 door hub , asap
  32. 4x4 cossie front calipers or caliper carier brackets
  33. WANTED S2 REAR WISHBONES
  34. Escort S2 Uprated Head
  35. alloys wanted with tyres for 2wd saff
  36. gti jacking cover
  37. anyone breaking a s1,16i,3i or any non abs mk4
  38. ford 17" 7 spokes diamond cut
  39. MK3 XR2i Fiesta Bootlid/Heater Matrix
  40. RETRO RWD CAR
  41. 2wd Cosworth sump?
  42. l8 stage 3 setup
  43. MK4 FuelTank Strap
  44. 16" MONDEO 5 SPOKES WANTED
  45. Chip for Escort Rs turbo Efi
  46. ford motorsport bottom splitter for escort series 2 !!!!!
  47. rs 7 softspoke alloys
  48. Saph Front Fog Lights
  49. fuel pump carrier for s2
  50. something rs
  51. Cossy 3door passenger front wing
  52. S1 clutch ratchet
  53. RS2000 4x4 rear bushes
  54. S1 TCA's
  55. 5ts 3" seat harmness FIA homologated
  56. s1 turbo
  57. s1 turbo gmax front springs & shocks
  58. dump valve t piece
  59. escort gearbox
  60. 0.48 turbo exhaust housing
  61. Petrol Tank Filler Neck Series 2
  62. escort gti front bumper
  63. RS500 Elbow WANTED! - FOUND!!!
  64. Recirculating Dump valve
  65. Sorted now
  66. wanted rs 4 spoke horn pad
  67. cossie engine
  68. escort cos splitter
  69. small turbo escort cosworth phase sensor & 4x4sapph doug
  70. 1.8 mk2 mondeo engine needed silver top zetec please.
  71. mk 4 bootlid
  72. S2 Escort downpipe that suits cosworth T3/34
  73. saff rear bumper
  74. ££££££££££££RS Cars Wanted££££££££££££££
  75. frst engine
  76. caps for s1 body kit
  77. 2wd stage 3 kit wanted
  78. STILL WANTED
  79. Gunship Chip for 4x4 Cosworth...
  80. wanted RS1600i or maybe series one turbo
  81. MK4 ESCORT SHELL
  82. ESCORT RS TURBO METERING UNIT
  83. STAGE2/3 HEAD ESCORT RS TURBO
  84. Window regulator
  85. ST24 or 200 or 24v saff??
  86. mk2 xr2 steering wheel
  87. Escort Windscreen S2
  88. Escy GTI or SI or FINESESS
  89. cosworth bd14 ex cam used or new
  90. rear wheel arch liners
  91. exhaust manifold for a mk5 xr3i 130bhp
  92. saph cossie
  93. Zetec S Air flow meter X reg
  94. Wanted: Escort MK3/Mk4 Estate
  95. Rear Drivers Cosworth 2wd caliper
  96. 4x4 bonnet
  97. 2wd Cossie T3
  98. CVH 1.6 80.5mm Low Comp Turbo Pistons
  99. bare 200 block wanted
  100. Cossie Standard Ford Splitter
  101. anyone Breaking a mk2 Fez???
  102. 1, 2 or 3 x escort cosworth rims only
  103. Roll cage
  104. escort front seats mk6
  105. Rotten or crash damaged Series 1 escort WANTED
  106. Window switch cover
  107. cosworth rocker cover
  108. 17 or 18 inch alloy
  109. 3 door spoiler screw caps
  110. set of ford focus alloys
  111. UPRATED COSSIE CAMS, DIFF, ST2220 PARTS.
  112. Standard fiesta turbo spring's
  113. L8 ECU
  114. Peugeot 306
  115. Bailey power steering tank
  116. wanted red samcos due to sum coning get on here dartcrab
  117. S2 Front Roll bar/Suspension Bar
  118. esc cosworth safety devices bolt in roll cage wanted
  119. s2 turbo
  120. 3 door cosworth lower rear spoiler,500 grills,500 spliter,
  121. shell
  122. Fiesta Mk3
  123. **********urgent s1 roll bar block clamp urgent ************
  124. Any RS Turbo...
  125. zetec managment,carbs,bodies etc
  126. zetec s 4-2-1 manifold and straght through
  127. rs turbo jacking point covers
  128. escort rst wanted s1 or s2
  129. Trip Computer
  130. wanted mk4 escort front screen cheep close to cambridge
  131. Passenger side RS500 foglight grill
  132. BIG BHP 2WD SAPH..........
  133. Escort RST wanted
  134. WANTED - FRST to swap with my ERSTs2
  135. more s1 bits wanted
  136. Gear surround
  137. small turbo escos crank pulley
  138. Series 1 interior
  139. Sparco Rev fixation system Gr.A
  140. series one parts wanted
  141. Sparco Ring Steering Wheel in SUEDE
  142. MK4 ESCORT 1.4 4 DOOR E reg and older
  143. Top rad pipe with temp sensor from mk5 xr3i
  144. 2 left hand side doors for a sapp *URGENT*
  145. cossie brakes, s2 spot plamps, 90 spec spoiler
  146. 2 rear sapphire doors in white
  147. Genuine RS500 Hose WANTED
  148. escos raer shaft output of gearbox
  149. S2 Roll Cage
  150. 16" MONDEO RIMS OR STANDARD SAFF COS RIMS SWAP 17"
  151. S2 Shafts, MK 4 Escort Door (O/S)
  152. sierra estate rear hatch
  153. 4x4 saff prop donut wanted
  154. escort mk 6 saloon bootlid
  155. XR2I Bodykit
  156. wanted big brakes setup 2wd cossy..GOT SOME NOW!!!!!!
  157. XR2i
  158. escort cosworth tail gate
  159. Mk2 XR2 bodykit in north west
  160. FIA Bucket seats for a fatty!
  161. wanted escort cosworth cheapish
  162. DIA CUT RS 7 SPOKES
  163. 2wd Cosworth plastic header tank
  164. mk4 escort passenger side headlamp and s2 arch
  165. 2wd throttle body
  166. 2wd 7.5" diff back plate
  167. WTD, WHITE 2wd Saph
  168. series1 sunroof
  169. MONDEO ST200 EXHAUST SYSTEM
  170. delete.
  171. Fiesta rs turbo bits wanted
  172. rs 500 splitter or replica wanted for saff
  173. MK5 3DR Escort.....
  174. Escort Cosworth bits
  175. Looking for XR4I
  176. Rear Lights Bulb Holders
  177. T5 Gearbox 'Trumpet' Wanted
  178. 4" Exhaust Backbox
  179. xr2 seat
  180. Series 2 Erst camshaft
  181. erst s2 chipped ecu
  182. fiesta turbo air temp sensor
  183. standard 95 escort cosworth headlights
  184. MK 4 SHELL REQUIRED
  185. in need of MINT MK4 ESCORT ROLLING SHELL
  186. MONDEO ST220 ESTATE PARTS
  187. Group a. or rs500 widetrack adjustable round beam,steel
  188. Chip to run greens for a P8
  189. sunroof panel
  190. Top wing for escort cossie
  191. Zetec S/S cam belt cover
  192. stage 1 or 2 Turbo for S1
  193. Cabriolet parts & RS Turbo sideskirts
  194. Bodykit parts
  195. WANTED.......crap mk3 fiesta's, MOT failures or just nackerd
  196. s2 uprated gearbox needed for p/x with mint mk1
  197. 4x4 throttle position sensor
  198. 4WD 0.5 COSSIE PISTONS
  199. Early cosworth water pump ulley
  200. escort rs turbo wanted
  201. hi spec zvh turbo
  202. Escort Cabriolet Parts needed
  203. 3door parts
  204. Im after..............
  205. series 2 heater matrix
  206. SAPPHIRE COSWORTH TRIM WANTED
  207. saff 4x4 cossie heater matrix
  208. 3 door cosworth wanted
  209. FRST radiator and standard S2 escort intercooler...
  210. N/S (passenger) door mirror Fiesta (01) year
  211. Escort Bits
  212. MOONSTONE SIERRA RS500
  213. fuel hose
  214. Throttle Bodies for zetec
  215. wanted xr2i 8v or 16v
  216. Fiesta RS 1800 throttle Wanted
  217. 3 DOOR WINDOWS , original
  218. Escort Mk3 parts wanted
  219. RS500 LOWER REAR SPOILER!
  220. cosworth 4x4 front o/s abs sesnsor
  221. s2 rs turbo wanted
  222. PLEASE DELETE!
  223. zetec turbo engine
  224. FRST front wheel hub
  225. erst parts needed
  226. Cossie engine. Anything considered.
  227. grill from cossie/cossie bumper
  228. gertrag gearbox
  229. a few 4x4 sff parts
  230. Black/smoked rear lights to mk4
  231. Black A Pillar mount to house 52mm Gauge to fit 2WD Saph
  232. STANDARD S1 RS TURBO EXHAUST.HELP ME PLEASE!!!!!!!!!!!!!!!!!
  233. URGENT! Standard 2WD Exhaust Cam
  234. rs seven spokes
  235. MY SKYLINE R33GTR V-SPEC, MAY SWAP/PX AGAINST COSSIE
  236. white 90's spec S2 front bumper
  237. .
  238. wanted 4x4 inlet cam got one now thanks
  239. Transmission tunnel for 4WD Cosworth
  240. replica
  241. 2nd bulkhead for 4wd cossie must be VVGC
  242. 3DR FIBER GLASS BONNET
  243. cheap car!
  244. new amal valve
  245. Escort cosworth flywheels
  246. Series 1 wanted, lots of cash waiting ;-)
  247. Rs1600i inlet + rocker cover
  248. Brand New in the Box RS 4 Spoke Steering Wheel...
  249. fuel pressure regulator
  250. S1 Boot Rubber Seal
