- Rear interior courtesey light escort mk4
- 200 block cosworth wanted for export
- 90 spec s2 spoiler
- mk3/4 xr3i full exhuarst
- sum 2wd bits
- 2wd cossie loom and T Body...
- 2WD exhaust manifold intermediate part
- Nova gte/gsi
- wanted a clean erst
- Escort Cossie Big Turbo Samco Ancillery Set
- stuff for my 94 escort
- wanted rear beam and arms for sappy 2wd also front hubs and
- focus 1.8 or 2.0
- Rouse Rear Spoiler for Sapphire
- S2 Bonnet
- dial surround
- zetec s engine
- L8 or L6 ecu
- wanted crashed/rotten 2wd cossie
- MK2 st200 (mondeo) twin exit rear bumper
- S2 Interior Carpet?
- scrap turbos wanted
- Fiesta RS Turbo green stripes and Mercury Grey bonnet.
- stainless cvh cam cover
- 2.3 scorpio flywheel
- mint fiesta turbo alloy rad
- 1600I REAR ADJUSTABLE TIE BARS
- FRST RADIATOR ASAP
- drive shaft
- 4x4 Saff Boot Latch
- Flint grey boot lid and spoiler wanted
- 4x4 rear calipers wanted
- Wanted 2WD Sapphire Washer Bottle Level Sensor
- L6 ECU wanted
- t2 turbo or complete t3 conv for fiesta
- Water Pump pulley 4x4
- Escort GTi Alloys
- 4x4 cosworth fuel pressure regulater needed anyone got one?
- RS1600I ANTI ROLL BAR clamp
- rs turbo brake servo
- Rear Bumper for my Escort
- Bumper Needed
- Sierra Sapphire Cosworth
- 4wd Cosworth Thermostat housing
- carbon fibre dash inserts, vents, radio...
- .48 exhaust housing for ERST needed!
- Standard Mk4 Escort Parts Wanted
- wanted S1 rst bodykit
- Saph Cossie Spoiler
- Standard ERST Exhaust Housing for Turbo
- cheap run around
- Fiesta Trims
- Zetec rocker cover (crome or mallard green)
- Series2 RS Turbo wanted
- HELP Thermostathousing needed
- T5
- mk4 escort rs gear linkage (b&m if poss)
- urgently wanted for series2
- Gearbox for S2 rst
- 3 bar map sensor
- S2 wanted - Deal now in progress
- 1800 Zetec Escort Water Hose
- Black top 2 ltr Zetec Head Wanted
- cosworth 7.5" CWP needed all ratio's ... or cheap diff
- Need a T3 Downpipe off ERST
- Good 4x4 box wanted for escos
- speedline RL7
- Screen Washer bottle Level Sensor 1990 2WD Sapphire Wanted
- s1 fuel relay needed urgently
- 2wd Header Tank Wanted
- radiator
- st200 gearknob
- Cosworth YB engine
- good shell - s1....s2....xr2....mk3/4 cabriolet
- Strut brace (zetec rs1800)
- Imperial Blue Escort Cosworth - Small Turbo, FSH, Under 50K
- Escort WRC grill
- COSWORTH 2wd Rear Axle Tightening Kit
- s2 rs turbo shell
- 90 spec s2 rst in grey or black
- urgently needed
- Sapphire Cosworth
- 2wd saffy brakes wanted 4 pots any thing concidered
- lower splitter for escos
- s2 magnex flexi..........or may consider full scorpion etc
- MK 3 Capri Door Speakers Wanted
- Wanted: Series 1 RS Turbo
- Inlet Cam for 4x4 Cossie
- Strut braces for 4wd Cosworth and adj top mounts / tcas
- 2wd intercoolers
- Centre cap locks wanted for 3dr std. wheels
- Imperial Blue Escort Cosworth....
- RS500 Front Bumper
- Need RS16OOi Head
- SERIES 2 ESCORT RST TAILGATE & BONNET
- turbo damper bolts
- st200 gearknob
- Gray 90's spec ERST Spoiler
- Escort Cosworth Gearbox
- 4x4 cosworth manifold
- Rs Knock Sensor and Alternator Heatshield?
- rs1600i rocker cover wanted
- FRST to swap with my ERST?!
- 2WD Saphirre Cosworth 1990 Front Bumper Wanted
- ERST ENGINE MINE JUST GONE BANG
- Good Cosworth Block and Pistons - NE England
- escort cosworth carpet wanted for boot
- Escos front bumper & bonnet wanted.
- Breaking Fiesta ST
- RS 4 Spoke horn push
- Tyres wanted
- escort gti gear box 96wt-7fo96-ba
- Mods - why can I start a post in here, but not reply to one?
- 2wd cossie coilovers and RS500 style I/cooler
- tyres
- Escort Mark 6/7 Parts
- 90 spec s2 spotlamp brackets
- c20let pistons wanted
- P8 ECU
- 2wd cosworth fuel pump cradle
- s2 rst prefer red
- **T3 Exhuast Housing PLEASE**
- swap 3.5'' mongoose back box for a 3'' for series2
- 90 spec ERST spoiler in red ASAP
- S1 Turbo wanted
- l8 ecu required
- Radiator FRST ASAP!
- Escort Cosworth Rally Shell
- stage 3 parts 2wd cossie
- turbo for frst
- S2 Big Brakes+GRS/Radtec Intercooler+Adj. suspension
- mk 3 ers 1600i lower fog brackets
- 17 inch momo arrors
- aircon for saffy cos?
- frst bonnet vents
- 2wd saff
- 4wd rear saffy brake calipers and 2wd front caliper wanted
- Transfer box rs2000
- Focus ST Interior/full black ghia interior
- HEADLIGHT SCOOP
- esc cos amal valve and iscv
- Wanted Panels for Mk3 Escort
- BLING COSSIE CAM BELT COVER
- LHD Escos bodyshell
- 90 spec front recaros
- Roll cage for S2
- series 2 double capacity intercooler
- cossie alloys wanted
- Special hose wanted
- swap my s2 Red escort Rs Turbo for a fiesta Rs1800 or Rs Tu
- FRST Charge Carrier
- ****Wanted******Compomotive Mo (Classic Style) Evo Fitment
- 2 Wheeler Saff-Turbo water pipes
- 15" alloys
- Fiesta turbo
- wanted sporty escort
- Want to Swap my BMW M3 Evo Convert. for a Escorth Cos
- 3 DOOR COSSIE
- alcon six paddle clutch for rs turbo
- RS Cars and Parts Wanted
- Alloy wheels
- WANTED: 4X4 SAPPHIRECOSWORTH
- coilovers for a frst
- turbo exhaust manifold zetec
- needed bracket that goes round cossis idle control valve
- 2wd saff cossie
- RS1800 XR2i RST Wanted - Any in Scotland?
- 2wd cosworth front calipers
- Used 2wd Cossie Coilovers
- small turbo throttle body *wanted*
- 1998 Escort Rear Bumper
- WANTED! Ford Escort RS Cosworth Wheels, 16x8 genuine jobs x4
- ERST STANDARD T3 TURBO & POSSIBLY ENGINE
- RS 1600i Sunroof
- fiesta rsturbo
- FRST Engine Wanted!
- few bits and bobs wanted
- Carbon Bonnet
- series 1 rs arches wanted
- Wanted Mk 4 Escort Cabriolet
- New Injectors
- need the bracket to hold cosworth idle control valve on
- MULTI PLUG
- does anyone have
- got one now , closed
- rs front arch
- Fiesta RS Turbo Top Boost Hose
- escort cosworth parts wanted
- turbo units wanted,....
- escort z-tec sump &oil pick up
- MK 6 Escort Bits
- XR2i
- Escort Zetec Forged or mahle Pistons Wanted
- SERIES ONE SHELL
- MK1 Mexico Wanted
- WANTED: MK1 Supersport or XR2...
- .63 Exhaust housing
- Fuel swirl pot
- s2 escort turbo bits needed
- A decent set of Spark plugs
- 3dr Cossie parts
- series1 opening rears windows seals
- SERIES 1 RST WANTED
- frst bonnet
- BIG BRAKES
- WANTED 17"MOMO ARROW for saff
- chipped hearts and diamonds ecu
- small run around for £1000
- 4x4 COSWORTH GEARBOX
- escos hockey sticks
- Mk6/7 Escort RS2 Morette headlamps wrc front bumper spoiler
- s2 gearbox needed asap
- Cobra Imola Bucket Seats
- rs turbo
- Engine
- PLEASE PLEASE PLEASE need standard 1600 cvh turbo engine
- 3dr cos alloys will pay upto £350.
- wanted: escos lower splitter with bolts
- S2 Recaro's....don't have to be perfect!
- cheap rs turbo fiesta/escort wanted
- Fiesta RS Turbo
- fiesta and escort parts wanted
- Moonstone 3 Door bits
- mk3 back lights
- cvh fiesta engine mounts
- 4 x MFi Injectors
- 3 DOOR WANTED
- S1 RS Turbo Spotlights.
- S2 RS BONNET
- Mk3 Wheel nut COLLETS
- Would anyone like a free set of clover leafs?
- needed asap.
- wanted any rwd crazy fords
- Fiesta turbo breather
- fiesta rs turbo water/ancillary silicone hoses
- Escort RST Standard Exhaust Housing
- modny breaks
- s2 RST
- s2 wheels
- ESC COS FUEL/TEMP GAUGE
- S2 Parts
- ESCOS ABS SENSORS
- safety devices roll cage for sapp cos
- MK3 Ford Escort Front Headlamp Covers Needed....
- fuel seder unit for a series1
- de catpipe for rs1800 + chip
- wrc frontbumper and grill wanted to escort cosworth
- hi spec yb head grpa ect
