PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Any good saffs breaking??
  2. Lattice cosworth alloys - Good/mint condition
  3. sierra window switch
  4. mk4 escort inner wing coolant hose clip
  5. mk4 escort rollover jig wanted to buy or rent
  6. Osf Saff Cos side skirt
  7. Mk6 fiesta dash electrical plugs with length of wire.
  8. escort rs turbo fuel filler neck.
  9. T5 gearbox
  10. Escort mk3 bumper overriders
  11. wanted cosworth heatshield
  12. 3DR 5 speed
  13. Mk3 or Mk4 diesel Escort van
  14. Corsa C Haynes Manual or Workshop manual to suit 2003 car
  15. Wanted MT75 909 quick shift
  16. cosworth T5 gearbox wanted!!
  17. Paying for and receiving goods(please read)
  18. cosworth power steering pipes
  19. Yb adjustable cam pulleys
  20. Mk3 escort hatchback bootlock and assembly
  21. Long shot
  22. Focus st mk2 quickshift wanted
  23. Saff cossie door glass
  24. Cosworth billet fuel rail
  25. 4x4 Cossie oil return pipe
  26. e
  27. cossie diff
  28. mk1 3 door sierra cosworth replica or standard 3 door wanted
  29. Mk1 Sierra front splitter
  30. Cosworth 4x4 exhaust manifold
  31. rs turbo s2 exhaust and intercooler
  32. S1 rs turbo wanted
  33. 3dr rear dirt sheild/wheel arch liner
  34. Transit Sport Alloy Wanted
  35. Mk2 focus rs or escort rs cosworth wanted
  36. Escort Cosworth / Sapphire Cosworth 4x4 Front Upright/hub carrier
  37. Sierra interior door handle/latch mechanisms
  38. Wanted, sierra sapphire Cosworth, must be GOOD!
  39. Escort cosworth alloys
  40. S2 rs turbo original light grey ht leads and nos master cylinder
  41. mk5 rs2000 altenator
  42. Mk6 escort gear surround
  43. Sapphire cosworth 4x4 vents
  44. Wanted gaz gold's 4x4 escos
  45. Wanted quaife 7.5 rear lsd 4x4 escos
  46. Escort cos washer bottle
  47. 3 door sunroof needed
  48. various sierra 3 door bits wanted
  49. ford sierra s/wheel boss[rs/ford type]
  50. efi ported / big valve head wanted
  51. Saff cosworth side skirt wing supports... Pic inside
  52. Saph boot striker plate
  53. escort cosworth gauges
  54. Fully trimmed Escort Cosworth shell
  55. efi oil breather and pipe from inlet to map sensor
  56. rs turbo bailey oil breather wanted
  57. Escort cosworth /rs2000 tailgate trim
  58. 3 door cosworth carpet and door panels wanted
  59. Sharktooth centre caps
  60. rs turbo lsd gearbox
  61. WANTED: Sapphire Cosworth Leather Door Cards
  62. Power Steering lines
  63. Supra diff fitting kit wanted
  64. Wanted!!
  65. Pectel monitor wanted
  66. S1 standard boost turbo actuator
  67. Tinted side lights Escort Cos
  68. Focus RS MK2 19" wheels
  69. MK4 Escort Stealthbox wanted.
  70. 9x18 comp six spokes
  71. Ford Sierra shell wanted
  72. Wanted 909 g/box
  73. Escort Cosworth rolling shell wanted
  74. Wheels wanted rs7s!!
  75. cosworth 4x4 dogbox or similar
  76. WANTED lower grille plastic panels
  77. Mk1 Escort Cosworth Wanted
  78. WANTED Escort 4x4 gearbox wanted (options)
  79. wanted 3 door/ 2wd front spring cups
  80. Abs pump block loom
  81. Bucket seats wanted
  82. 3dr cosworth xr4i cage
  83. 3 door cosworth rear bumper wanted
  84. Aircon equipment Escort cos
  85. Anyone breaking a mk4 escort in or near Luton?
  86. 24v cosworth boa
  87. focus rs parts
  88. no longer req
  89. ghia conversion bolts
  90. Clutch alignment tool
  91. escort rs turbo s2 shed clear out
  92. WANTED Escort Cos soundproofing
  93. WANTED Escort Cos Morrette's
  94. escort cosworth alloy wanted
  95. Escort mk5 / mk6 big brakes ap, wilwood, high spec cosworth etc
  96. 3dr cosworth front right arch
  97. magnex 4" backbox
  98. Standard S2 shifter P/X for my B&M.
  99. wanted escort mk3/4 rear link kit mef etc
  100. t3/34 turbo parts
  101. Laguna splitter !
  102. S1 RS Turbo Anto roll bar Brackets and Suspension
  103. Series 2 RST Fuel Tank
  104. Wanted Morette's escort cos
  105. ofab ecu and edis
  106. Wanted standard st170 exhaust system
  107. WANTED 4x4 Cosworth Quaife gearbox or rally g/box
  108. Cosworth 4x4 thermostat housing
  109. wanted cossie 3 door or 2wd suspension
  110. S2
  111. WANTED standard air box for big turbo escort cos
  112. WANTED compomotive Mo6 18x8
  113. one for the passionbmw peeps and breakers
  114. Cheap black car wanted.
  115. 2wd s/s exhsust system & saff rear bumper
  116. SCRAP YB block/head other parts wanted
  117. Rs1800 or 1.8 xr2i wanted!!
  118. WANTED sunroof mk4 escort
  119. WANTED - carbon fibre roof and bonnet
  120. RS 16i wanted , cash waiting
  121. 2wd sapph parts needed asap please!!!
  122. Mondeo brake servo, zetec turbo conversion parts
  123. full efi turbo set up
  124. Full Saff raven leather wanted.
  125. Cosworth plug lead block required
  126. Pro race 1.2s 9x18 wanted
  127. M10 fan switch metric with plug
  128. T5 gearbox front nose/cover
  129. S1 & S2 parts wanted
  130. laguna splitter
  131. wanted scrap cosworth head
  132. E60 BMW 535d M Sport (saloon or touring)
  133. wanted. zetec turbo engine and parts
  134. Mondeo brake servo
  135. Cossie T5 speedo drive - knackered will be OK
  136. Mk5 escort rs/xr tailgate
  137. RS500 bumper and spoilers
  138. mk3 escort genuine front wings
  139. 4x4 engine loom
  140. Mk1 Sierra tailgate
  141. S2 RST Turbo Technics ARB Wanted.
  142. Focus rs parts
  143. escort cosworth battery area bracket
  144. Mk2 mondeo complete driveshafts
  145. Series 2 ABS Loom/Sensors
  146. antilag valve
  147. Broken fog light 3 door cos
  148. Modified downpipe for running a 2wd manifold on a 4x4?
  149. Zetec camshaft cap bolt!!!
  150. T4 Turbo
  151. Anyone breaking a saph?
  152. Escort / Sierra Cosworth rear spring pads
  153. water injection
  154. Ofab setup wanted
  155. wanted.anyone have this radio/cassette holder?
  156. Erst exhaust manifold
  157. cossie bits mk3 bits
  158. fiesta mk3 2 door shell
  159. Ford Racing White Water Temp Gauge
  160. Rs turbo bits
  161. master cylinder
  162. T5 gearbox oil seal
  163. Trim
  164. Non genuine RS500 lower boot spoiler.
  165. Scrap 4x4 Cosworth head.
  166. Zetec turbo bits and bobs
  167. Escort Rs Cosworth WANTED
  168. Focus RS MK1 Hybrid Turbo
  169. Series 1 tow eye cover
  170. 2wd sapph steering rack
  171. Cosworth Map Sensor bracket
  172. MK4 Escort bootlock
  173. Injectors and turbo
  174. 2WD Blue rad hoses
  175. 2wd sapph front anti roll bar
  176. Cosworth track car
  177. cvh starter motor heat shield
  178. 17 inch , Hocks, RL7 , Comps
  179. Sierra central locking rods
  180. Wanted xr2/mk2 fiesta steering wheel hub/boss adapter
  181. Escort Cosworth dipstick
  182. WANTED - Escort Cosworth n/s (passenger) front hub assembly
  183. WANTED - MK5 bits
  184. Escort cosworth finishing bits
  185. 3dr lower bulkhead matt wanted
  186. Escort or 3dr indicator bumper clips
  187. door card
  188. Escort rs turbo mk4 silicone hose kit ancillary,coolant,boost
  189. Mk6 escort carbon/fibre glass bonnet
  190. wanted Ahmed track spec springs for a 3 door.
  191. Escort cosworth center consol
  192. rs turbo bits needed
  193. MTX 75 Quaife LSD
  194. 3 BAR map sensor
  195. v6 turbo conversion engine turbo technics????
  196. Cosworth clutch cover
  197. 2wd Coilovers
  198. escort combi van shell wanted
  199. Mk1 focus rs disc front, anything considered!
  200. 2WD ABS pump
  201. Escort cosworth straight through stainless exhaust.
  202. escos/sierra Cossie 4x4 calipers + carriers
  203. 4x4 Mahle cosworth pistons
  204. Cosworth Group A ARB and Support
  205. Mtx rs turbo drive shafts
  206. Ap 355 2wd bells
  207. 17s or 18s for saphire cosworth ?
  208. Rs Fiesta
  209. 3dr cosworth interior wanted complete !
  210. Focus rs mk1 chargecooler pump and scangauge wanted
  211. T5 input shaft
  212. T34 Turbo with .48 Exhaust Housing
  213. Single Mahle 4x4 piston with cut out
  214. Inserts for zetec silvertop rocker cover
  215. 2wd cossie front anti roll bar wanted
  216. Escort cosworth A Pillow cover & ash tray
  217. Mk6 Escort Van Rear Bumpers
  218. fiesta rst cross over pipe charge pipe
  219. 3dr header tank cap
  220. mdf parcel shelf
  221. Mint condition mk4 escort window rubbers
  222. Wanted T5 2wd gearbox
  223. Wheels for saph
  224. Rear bumper mount (drivers side)
  225. Rouse front and rear spoilers
  226. few small interoia bits needed for escort cosworth
  227. Saph jacking cover
  228. Fog Light passenger side for Saff
  229. Mk5 escort door & tailgate
  230. Alloy rad for a s2 please
  231. T34.63/t38/t4
  232. ERST2 Metering Unit
  233. XR2 Steel wheels
  234. Saph 4x4 front door speaker holder
  235. 10mm wheel spacers
  236. 3dr door rubber moulding set needed
  237. MK4 fiesta central locking motor
  238. L8 ecu
  239. Sapphire 4x4 Saff AC wiring
  240. Cosworth alternator drop bracket
  241. steel wheels
  242. 3 door grill rubber seal
  243. 3dr cosworth headlights
  244. xr4i or 3dr cosworth grey carpet
  245. WANTED: rough saph interior (just seats)
  246. 5 stud 4x4 granada hubs
  247. anyone breaking a connect ?
  248. Disclok Large
  249. Old style flat spoke Compomotive Mo's
  250. 4x4 saphire rear prop the front part
