PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 [78] 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. standard height springs.
  2. standerd springs rs turbo
  3. ford focus TDCI SPORT rear spoiler
  4. Escort 1.6 Zetec K Plate ECU (AGED,ENVY,WIND,RIOT)
  5. any news on any bits of stolen car
  6. stolen!!! white frst
  7. Wanted wiring loom Mk1 mondy '93
  8. idle speed control valve
  9. FRONT DRIVER SIDE JACKIN POINT COVER!SUM1?
  10. Mk6 RS2000 late spec with air con and has to be showable
  11. Wanted lockwood white dials escort series 2 turbo fuel left
  12. WTD - XR2i Center Pipe Section of Exhaust
  13. escort cabby door
  14. s1 fuel pump relay
  15. escort rs turbo
  16. banjo on fuel filter to engine needed
  17. RST S1
  18. Standard Ford Esc Cos Door Speaker
  19. s1/s2 fuel filter clamp needed!!
  20. blue samco/ sfs/ other pipe
  21. fiesta turbo mouldings
  22. got
  23. Set of escort cossie wheels - found some
  24. mate wants a turbo £1200 or under??? car or van??
  25. 4x4 props
  26. mk4 escort 3-door or mk2 fiesta under £200
  27. Escort Cosworth Spare Wheel lock
  28. 130 spec xr3i cams wanted
  29. i.s.c.v.
  30. 4x4 Engine parts
  31. Once again I have run out of stock,RS Cars Wanted
  32. cross member
  33. FOCUS st170 front calipers
  34. 90 spec front bumper
  35. gearbox
  36. Looking for a good S1 turbo
  37. k+n cone filter for a T35 cossie
  38. wanted a s2 rst gearbox or er3i must be good
  39. S2 front mount intercooler
  40. Koni top adjustable front shock for mk4 escort
  41. mk4 escort van petrol tank
  42. s1 rs turbo
  43. WTD: 2wd Saff cos, scorpion back box, - found one
  44. FRST Recaro Doorcards and Sapphire Cos Leather Rear Bench
  45. uprated s2 turbo unit
  46. Wanted - 2wd Cosworth oil cooler bolt.....
  47. MODS PLEASE REMOVE (SORTED)
  48. 2WD SAPPHIRE
  49. COSWORTH LAMP FAILURE ECU
  50. Escort (Mk.5 or Cosworth) Windscreen
  51. 4x4 gearbox wanted
  52. escort cosworth roof lining
  53. 2l zetec head,pistons, rods, arp head bolts
  54. Fiesta xr2i / rs turbo arches and side skirts.
  55. Series2 Uprated clutch
  56. fan/fans for a grs intercooler on a s1
  57. 2wd saph steering shaft between column and rack wanted asap
  58. Chrome Charge Carrier
  59. Complete RST bottom end
  60. 4x4 saph cos ABS sensor
  61. White lockwood dials for series 2 escort turbo
  62. cheap track car
  63. s1 fuel pump relay
  64. mk3/4 escort cabby os/ns doors
  65. EFi XR3i
  66. turbo unit
  67. sorted ta
  68. fiesta turbo interior
  69. Steering Rack for Mark 6
  70. Cosworth Motorsport Steering wheel boss
  71. escort lowering springs
  72. p100 wanted
  73. WTD: 1.7 puma or WHY
  74. FRST Starter Motor
  75. Mk3/4 Escort O/S front door glass
  76. Escort Cossy Standard Rims
  77. cosworth 4+4 exhaust cam
  78. S1 RST REQUIRED
  79. Wanted Saph 4x4 Petrol tank !!
  80. COMPOMOTIVE MO, 5 SPOKE
  81. Px wanted RS2K for ST24
  82. fog grille
  83. mk 1 escort parts
  84. T2 turbo unit
  85. s1 s2 rs turbo with the enigine nackered
  86. FRST charge carrier
  87. 2wd sump
  88. S2 or mk4 Escort Rear Speaker Mounts
  89. Sapphire Fibreglass Wings / Doors / Bonnet / Boot
  90. 200 / 4x4 Cossie Block
  91. swap ???
  92. 2wd cossie actuator bracket
  93. OFAC chip
  94. WTD: Mk1 Fiesta
  95. injector pipe
  96. Escort Cosworth or Focus RS
  97. Efi relays
  98. escort gti alloys
  99. Anything YB powered that isnt an original cossie vehicle
  100. any1 breaking white s2, need tailgate and possibly spoiler?
  101. T34 Turbo
  102. 88' Sierra Cosworth owners manual and supplement
  103. escort cosworth
  104. series 2 front speaker covers "in kickwells"
  105. mint 90 spec series 2 passenger seat
  106. Escort RST 2 Wanted - GOT CASH AND NEEDS SPENDING
  107. Bailey escort s2 header tank or similair
  108. FRST Gearbox
  109. COMBIVAN BITS /MK4 ESTATE
  110. .48 housing
  111. wolf
  112. aftermarket exhaust for escos
  113. Rs Turbo - Hose from inlet manifold to brake servo
  114. s1 bits and bobs
  115. Ford Puma 1.4 Engine
  116. wanted escort , fiesta turbo or escort cab or xr2
  117. Wanted "MINT" S1 Escort RS Turbo
  118. rs turbo glass
  119. wanted galaxy 2.0 8v engine
  120. ap caliper 6 pot cp3796 grp a
  121. s2 center caps, recaro seat badge needed!
  122. 2wd alloy engine mounting arms needed asap
  123. 2.8 capri rear axle
  124. ZETEC 1.25 CRANK WANTED!!!!!!
  125. sierra cosworth wanted for swap with my series 1 rs turbo
  126. 3dr front cross-member
  127. escort twinhead lamp LENSE
  128. Carbon Fibre Bonnet
  129. rs2000 disks
  130. wanted mk3/4 esc cab drivers door
  131. focus rs wheels
  132. 4wd front calipers
  133. WANTED - Escort RS Turbo VAN or Modified Van
  134. erst exhaust manifold
  135. modified down pipe for xr2 turbo
  136. s1 superchip
  137. escort rs turbo engine needed ...
  138. mk 1 sierra scuttle panel
  139. sorted please delete!!!!!!!!!!
  140. rs turbo opening quarters
  141. front mount
  142. Tidy little motor
  143. S1 RS TURBO WANTED
  144. A MK4 ESCORT 3 DOOR ESTATE OR COMBI. PLEASE HELP!
  145. s1 bottom boost hose
  146. Wanted MK2 fiesta XR2
  147. 2wd Saff Cosworth, in white, not any more, FOUND ONE!
  148. diesel run around
  149. Blown Engine / CHeap Run Around
  150. 4x4 Escort Cosworth thermostat housing-must be VVGC
  151. Mint Magenta 4x4 Saph Cossie wanted
  152. ofac 195 chip wanted
  153. Polished header tank for 2wd Saph
  154. Fiesta RS1800 Doorcards
  155. 17" rs turbo 5 spoke alloys
  156. cossie amal valve
  157. 18" tyre
  158. Escort gti gearknobs
  159. 4wd Fuel pressure regulator.
  160. Mk 2 wanted
  161. Escort Cosworth Replica
  162. small turbo escos bits
  163. Cosworth 2wd front brake discs
  164. sorted
  165. white escort cab drivers door
  166. mk5/6 escort front seats
  167. mk6 escort bonnet
  168. mk6 escort front bumper
  169. sideskirt jack point cover+standard center cap4 escort rs s2
  170. Greens and map sensor
  171. 3dr silicone hoses
  172. s1 parts wanted
  173. Fuel pump relays
  174. B&M quickshift
  175. 2wd throttle body
  176. MK3 Cortina 2dr please*or a 2.8 capri thats cheap*
  177. s2 bumper
  178. mk3 fiesta van
  179. rst bottom end
  180. 200 block
  181. cosworth stage 3 chip
  182. greys WHY?
  183. power steering
  184. FORD ESCORT S2 WANTED I HAVE CASH BURNING A HOLE IN POCKET!!
  185. Nice 3 Door or RS 500 wanted
  186. focus rs turbo alloys!
  187. 4WD rear diff wanted
  188. WANTED DRIVERS SIDE REAR HUB
  189. erst twin piston dump valve
  190. recaro
  191. Dump valve bung!!
  192. Cosworth 2 Bar Map Sensor
  193. 4 x 4 gear box
  194. WANTED S2 RST ( GOT ONE )
  195. 7,5 inch plate differential
  196. cosworth crank pulley
  197. 17 inch alloys
  198. ECU
  199. 3 door grill wanted
  200. FORD ESCORT GTI WANTED
  201. water hoses
  202. S1 Driver side elec window mechanism
  203. rear disc conversion for mk4
  204. Wanted - Series 2 gearbox
  205. need a 4x4 box asap
  206. lean burn head
  207. cos 4x4 or xr4x4 lowered rear springs
  208. clear rear lights for a mk4
  209. wanted 4x4 cossie scorpion stainless exhaust
  210. Wanted Zetec engine mount from a Focus/Mondeo
  211. series 1 turbo wanted
  212. Wanted 1600 CVH Sump From XR2 or XR3 or Other?
  213. cosworth 4wd saf throttle pedal
  214. Breather/separator
  215. 3 door cossy suspension kit
  216. wanted
  217. RS TURBO/COSWORTH FOR SPARES REPAIRS WANTED
  218. s1 grill
  219. wanted Escort Cosworth Rally Car
  220. Yellow Mk2 escorts
  221. cheap cone filter
  222. 4x4 cossie stainless steel exhaust
  223. wanted mk2 cortina
  224. adjustable TCA's, and compression struts
  225. Sapphire Cosworth 4x4 Momo steering wheel boss
  226. mk4 escort turbo/orion ghia/van spares ,scotland area
  227. morrette quad lights wanted for sierra
  228. power steering pipe for 2wd saff
  229. power steering pipe for 2wd saff
  230. Still Wanted Sapphire Morette Quads
  231. wanted 16's/17's sutible for erst
  232. power steering rack for xr4x4 2.9
  233. Fiesta RS Turbo inlet manifolds wanted
  234. esc cos door pockets
  235. s2 top boost hose wanted
  236. wanted 195 50 15's on or off rims
  237. wanted.....rs turbo s2 smoothed rear bumper
  238. Wanted....Pacifica blue touch up paint
  239. RS 1800 ECU And Cams plus any 3 door fiesta rear qtr trim.
  240. GOT ONE
  241. Considering something different
  242. s1 front part of the body kit
  243. Something around 7K
  244. eco tech and power boost valve for mk 4 fiesta 1.3
  245. Wanted Mk3/4 Cabriolet Hydraulic Roof Ram
  246. Standard ESCORT rst wheels in VGC with or without tyres
  247. saph cossie wanted
  248. 3 door shell wanted... not worried if gen/ Q plate etc etc
  249. Breather system
  250. Need a 2wd sapphire L6 ECU (BUYED)
