PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. cheap boost gauge
  2. mk3 fiesta
  3. escort rs turbo series 1 s1 tow eye cover!
  4. Wanted cosworth kent cam pulleys
  5. Various S2 ERST parts wanted.
  6. cosworth marelli 3 bar map sensor
  7. s2 rst bits in devon
  8. 3 dr cossie rear headlining clips
  9. 2wd cosworth paddle clutch wanted
  10. Cosworth iscv
  11. a healthy series 2 bottom end
  12. 4x4 inlet plenum wanted
  13. few bits mainly focus
  14. 3 door handle, passenger side
  15. 4x4 Saph lowering springs
  16. 4x4 Rear Discs **URGENT**
  17. 3dr dash warning light module
  18. L6 ECU wanted for 3dr Cosworth
  19. 3 door cosworth shell wanted
  20. CVH Block NA or Turbo!
  21. st170 spoiler
  22. ofab ecu
  23. recaro seats wanted
  24. Cosworth Stereo Fader Switch **SORTED**
  25. 3dr Coilovers
  26. please delete thread
  27. 4x4 coil-overs
  28. 3 door bonnet release cable
  29. 2wd downpipe mongoose or scorpion
  30. saph ecu cover
  31. S1 escort radiator
  32. Red silicone 2WD hoses wanted !!!
  33. 3 Door Cosworth Clocks
  34. 2wd saph cossy crank shaft pulley and sprocket needed
  35. Area six zetec exhaust manifold
  36. Goodyear Eagle F1 gsd3
  37. Ford Focus Mk1 Bonnet - WANTED
  38. Escort Turbo S2 fuel pump carrier
  39. .5mm piston, std comp
  40. urgently cosworth dizzy cap clip
  41. zs bumpers
  42. fiesta turbo seats
  43. Light blue fitting kit Cosworth
  44. coilovers cosworth 2wd
  45. coilover springs
  46. escort cosworth why ???
  47. DE-CAT for a 1.8 zetec escort
  48. sierra morrete headlights
  49. Small bits needed, Cosworth
  50. 4x4 or ported 2wd head in good condition
  51. cosworth standard oil breather
  52. Frst t2 turbo,samcos & intercooler.
  53. Series 2 air filter box
  54. Compomotive FR, 8x16 wheels
  55. 17" oz ultra leggera alloy for ford
  56. turbo coolant pipes
  57. ps3 or xbox 360
  58. plasma gauge interter
  59. Cosworth crankshaft
  60. 2wd saph cos gearbox cradle and rear beam.
  61. Cosworth 2wd front legs complete
  62. erst koni's
  63. are you breaking a escort rst or xr3i???????
  64. Mondeo Mk3 Estate Tailgate Silver
  65. 3:9 or 4:1
  66. Efi fuel rail wanted
  67. sierra 2wd cosworth braided brake lines wanted
  68. mk1 focus rs parts
  69. escort cosworth wanted why ?? cash waiting.
  70. RS push horn to suit 4 spoke RS steering wheel
  71. Mk4 steering wheel boss to suit RS 4 spoke steering whell boss
  72. Tiltbed car trailer
  73. Tsw evo alloys centre caps wanted
  74. Mk2 mondeo drivers seat
  75. fiesta rst door card
  76. escort cosworth wheels
  77. Focus RS Wanted
  78. Astra alloys
  79. Rs 1600i wanted
  80. Bailey Oil Breather
  81. Fuel Regulator EFI fiesta NEEDED URGENTLY
  82. cat for a ford focus 05
  83. escort cosworth t25 rocker cover
  84. 2WD DIFF
  85. Water Swirl pot
  86. alloy rad and turbo cooler
  87. escort combi
  88. Wanted : Cheap MK2 Fiesta
  89. Cosworth 2WD Inlet
  90. Sierra Cosworth Rear Diffrential 2WD
  91. 2 wheel drive spec r turbo hanger
  92. Under bonnet warning decals/stickers
  93. 3dr Cosworth Bonnet (white)
  94. rs turbo parts
  95. XR2i front bumper
  96. transit van
  97. Sapphire Cosworth 4X4 Bonnet Vents
  98. 4 paddle plate, zvh turbo engine
  99. cosworth parts wanted
  100. FRST trim
  101. Chip for Greys T4 on an L8
  102. RST S2 Alloy Rad
  103. t3 actuater bracket
  104. t34 compressor housing
  105. sierra cosworth standard damper
  106. focus/fiesta/puma rear callipers or slider bolts
  107. Wanted parts for track prep saff
  108. big spec engine wanted
  109. ££££ we buy anycar ££££
  110. Bonnet Catch wanted for Mk3 escort
  111. cheap rs turbo wanted
  112. wanted L8 ECU
  113. Escos shell and i.d NEEDED pls....
  114. Cair-O-Port
  115. Slimline fan
  116. Cheap 2wd sapphire cosworth
  117. Cosworth Turbo Heat Shield ???
  118. Automatic wanted
  119. rst servo
  120. Calling all pf's
  121. Wanted Zetec Black Top Billet Oil Pump Gear
  122. escort cosworth sender unit
  123. Std 2wd Saff front pipe
  124. escort cos headlining
  125. Longshot Renault megane door
  126. mk4 bonus shell
  127. efi loom from a mark 4 xr3i.
  128. 4x4 Cosworth Speedo Drive Cover...
  129. Small turbo rocker cover
  130. saph cosworth front bumper
  131. Berlingo air box
  132. Strut Brace
  133. Small Turbo Escort Cosworth Engine
  134. rs turbo s2 pink fuel pump relay
  135. Focus RS engine wanted
  136. 2wd saph gearbox mount
  137. Escort Cosworth SRS steering wheel
  138. cosworth blue plug leads
  139. Wanted - 3" 2wd downpipe
  140. compomotive cxn's
  141. ARP stud and nut kit for 2wd cossie
  142. fiesta turbo hose needed
  143. 200 bottom or full engine
  144. cosworth 2wd brake resovoir ?
  145. Wanted rst s2 passengers side wing mirror glass
  146. Escort Cosworth Magnex exhaust
  147. afr gauge wanted
  148. Escort Cosworth 4x4 Gear Stick...
  149. Vauxhall astra 1.7 dti engine
  150. 2.0 zetec blacktop wanted
  151. 16" or 17" ford alloy wheels wanted
  152. Tidy Mk5 Fiesta Van Wanted
  153. rs500 inlet
  154. 4wd exhaust valves
  155. Wanted, Cossie 4x4 rubber part ofturbo oil return pipe
  156. s2 master cylinder
  157. 2wd exhaust manifold
  158. Lotus Carlton petrol tank wanted
  159. Ford fiesta Zetec s mk5 1998 - 2002
  160. 3dr Parcel shelf and side supports
  161. Set of good coilovers for 4x4 saff
  162. boost gauge
  163. Bonnet Catch wanted for Mk3 escort
  164. Wanted - 1 Sapphire 4x4 wing badge
  165. HELP!! 1x valve spring retaining collett needed ??!!
  166. mk3 fiesta hubs
  167. Escort rs turbo series 1
  168. rs1800i/130ps xr3i engine wanted near london.
  169. 1.4 puma engine wanted close to middlesbrough
  170. Cosworth ECU L6 or L8
  171. Saff cos bootlid
  172. desperatly wanted, ford 6000 or 6006 cd player for focus
  173. 2wd discs, and 4x4 calipers with carriers
  174. std rs turbo escort air filter box
  175. diff plug
  176. 3 Door Cossie Rear Seat Belts
  177. rs turbo rear drums!
  178. wanted bd14 inlet cam for 4x4 head..
  179. Focus Rs 02 bumper
  180. Escort Cosworth Turbo Heatsheild wanted please
  181. cossie 2wd gearbox/flywheel dust plate
  182. Sierra/escort front shocks
  183. Sapphire Cosworth For Donor...
  184. 3dr cossie front door cards
  185. Focus RS Turbo anyone?
  186. focus bumper
  187. rubbing strip
  188. Wanted Focus Mk1 Boot Strip
  189. rs turbo door cards
  190. efi running gear
  191. Cosworth Rocker Cover Badges
  192. wanted -modded 2wd cos beam - mk3/4 esc loom
  193. focus bumper
  194. wanted ford ranger
  195. 3 door cossie front door cards
  196. bailey breather
  197. saff shell being stripped for the nsf (passenger) wing
  198. rubbing strip
  199. Knackered 4x4 steering rack WANTED
  200. 4x4 Cosworth TCA's (Track Control Arms) and Clutch
  201. mondeo alloys
  202. cosworth engine wanted
  203. saphire parts
  204. 40mm Bilstein inserts
  205. L8 Board
  206. Saff Leather Rear Side Bolsters
  207. pace rst chargecooler kit/grs cooler
  208. no longer reqd
  209. A really nice fry up
  210. need a tial bov or similar please cash waiting
  211. Performance cam for rs turbo
  212. ford fiesta mk2 bonnet catch
  213. wanted 2wd ecu cover for leather
  214. 1x RS Turbo piston
  215. escort rs turbo wanted
  216. Fiesta RS Turbo Boost Hose
  217. Focus Rs
  218. 40mm Bilstein inserts
  219. 3 door focus shell n id wanted
  220. 3dr N/S hubs Wanted !
  221. Car transporter / recovery truck wanted cash waiting
  222. Sierra Estate Load Cover - In Black ???
  223. blacktop zetec bit's
  224. Group A front brakes bracket
  225. Pace or similar intercooler for s1 wanted
  226. Saff Cosworth fog lamp
  227. 2wd rear hubs/flanges/driveshafts complete set up
  228. ERST samcos and intercooler
  229. escort estate passenger window
  230. Sapphire 4x4 standard front springs wanted.
  231. mk4 escort efi fuel pump/sender needed
  232. rs turbo s2 escort lsd gearbox
  233. s2 lsd gearbox wanted:
  234. Starter Motor for MK6 RS2000
  235. wanted focus mondeo ST alloys 18"
  236. cosworth ecu cover
  237. Wanted - Sierra brake light switch + plastic collar
  238. 2wd Cosworth T5 Gearbox
  239. 17" th2's
  240. WANTED: Sierra diff
  241. 3dr cosworth cibie headlight part
  242. wanted! orion 4branch manifold and exhaust system for SEV
  243. 3 Door Sierra Cossie Rear Lights
  244. 2wd cossie turbo
  245. sierra 4WD front big brake kit
  246. 215/40/17 x 4
  247. Mondeo ST220 Wheels
  248. 3dr roof lining required urgently
  249. header tank
  250. Standard Focus Parts
