PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. S1 Pop Out Window Rubbers
  2. S2 RST SPEEDO CABLE
  3. small turbo cossie turbo unit or core
  4. s2 engine parts
  5. Need T2 FRST Turbo
  6. 1800 zetec four branch
  7. 2 x 90 spec escort recaros
  8. XR2I radiator
  9. LARGE DIESEL ESTATE CAR
  10. Original Sapphire Cosworth wheel nuts? Door cards?
  11. cosworth bias pedal box with hydraulic clutch.
  12. sierra cosworth rear valance
  13. Cossie 2wd head anything considered
  14. RS turbo gearbox with quaffe atb diff
  15. WANTED: GTi/RS2000 bumper spats, or complete bumper
  16. xr4x4 front drive shafts wanted
  17. t34 turbo damper+bracket and exhaust manifold studs and nuts
  18. REAR OPENING WINDOWS IN GREEN TINT
  19. Gen ford passenger outer front wing, saph
  20. .63 hosuing for cossie
  21. 2WD SAFF TRIM AND ENGINE PARTS
  22. after quads for a saph
  23. 3 door trailing arms
  24. Cossie GpA diff mount
  25. WANTED S1/S2 RST turbo oil return pipe
  26. st170 front bumper PLEASE!!!
  27. wanted 3dr cossie wheel
  28. cossie head
  29. Volvo S40 T4
  30. 4x4 saph cosworth
  31. Saphire Cosworth Wanted 3-4k
  32. 88 Spec Rear Seat and Door cards
  33. st 170 hubs
  34. Replacement fuel cap for ERST
  35. yellow boost hoses....
  36. MF2 Fifth Injector
  37. LWB - High Top Transit Van 1000- 1500
  38. boost gauge
  39. s2 carbon bonnet ?
  40. snap on scanner
  41. oil dipstick tube
  42. ELE BOOST CONTROLLER
  43. Wanted blue samco t34 boost hose..........
  44. Focus gearbox wanted
  45. s1/rs1600i parcel shelf supports
  46. Wanted Mondeo 2.0 TDCi Ghia
  47. s2 gearbox
  48. ESCOS carbon parts
  49. rs turbo mods
  50. Front Deflector for Escort Cosworth?
  51. Chargecooler wanted please
  52. 4x4 Propshaft rubber donut
  53. Cossie GRP or Carbon Bonnet
  54. WANTED: Cossie Clutch Pressure Plate
  55. baileys oil breather pot (separator)
  56. t3/t04e 50 trim with stage 3 wheel and .63 ar
  57. drivers side morrete for saph
  58. 205 GTI 1.9 ECU
  59. mesh for 3dr grill
  60. Standard Springs for S2
  61. Rear Suspension Arms
  62. Sierra 4*4 Cosworth Front Brake Calipers
  63. Wanted - 4x4 Cossy Power steering pipe (pump to rack)
  64. MK4 Escort Van
  65. Spec R/ GGR Dump Valve
  66. 04 PLATE FOCUS RS. LOW MILES
  67. 3dr cossie springs
  68. cheap bit of rubbish to get back and forward to work in
  69. Xr3i Ignition Distributor
  70. Cossie 4x4 front calipers Series Two lower rear bench
  71. Wanted S2 cossie rear disk conversion! SORTED NOW
  72. RECARO'S FOR AN XR2i
  73. Fuel Tank
  74. plain black leather rear seat....
  75. URGENTLY WANTED S1 SHELL
  76. small turbo escos uprated fuel pump
  77. black OR white frst
  78. 4" 4x4 cossie mongoose/scorpion backbox
  79. different cossie trim wanted
  80. frst charge carrier
  81. air injectors wanted
  82. xr2i parts
  83. Zetec Si 16v Cylinder Head
  84. Fiesta MK3 RS Accesory Front and Rear Bumpers.
  85. good to mint black/moonstone blue 3 door
  86. Moonstone 3 door wanted cash waiting
  87. mk3 fiesta suspension
  88. 2wd turbo actuator bracket
  89. clock for escos
  90. FRST SHELL
  91. rubber pads that goe round fuel pump cossie
  92. 2wd cosworth bits ( need asap )
  93. S1 SHELL
  94. inertia switch
  95. Alloy rad for 4x4 saph cossie
  96. T25 Ecossie Cam cover
  97. OIL COOLER KIT & BIG WING SUMP TO SUIT 4X4 COSSIE
  98. 3 door cosworth electric ariel
  99. 4.4 ratio cosworth rear diff or CWP
  100. Mk3 Fiesta Van
  101. BD14 inlet ( 2WD)
  102. Zetec Series 1 or 2 Rocker in black
  103. Cheap 5 spoke 17's pref with tyres
  104. escort gti jacking point covers
  105. rs turbo exhaust
  106. Set of RS 7's
  107. Escort Rs Turbo 88spec black??
  108. 90 Spec RST lower centre consol parts!!!! GOT THE PARTS NOW!
  109. Mondeo ST200
  110. desperatly wanted mk2 Fiesta clear lights, front and rear
  111. escort orion mk4 or fiesta mk2
  112. saph cos wanted must be 2wd and mint
  113. WANTED ERST T3 turbo/-31actuator and elbow W.H.Y?
  114. WANTED - BROKEN COSSIE ECU'S
  115. CHEAP FIESTA/ ESCORT FOR CHARITY PLEASE READ
  116. RS500 Wanted
  117. Radiant Red RS turbo 90 spec bumper
  118. good spec 3door or 2wd sapph wanted
  119. Original radio for 90 spec RST!!!! GOT ONE!!!!
  120. WANTED ESCORT COSWOTH FUEL PUMP
  121. escort mk5 rs2000 bottom crank pully
  122. XR3i MFi inlet manifold wanted
  123. Fiesta Mk4 Si or similar
  124. S1 Turbo rear ARB set up
  125. frst ofac or ofab ecu and loom
  126. RS Turbo Big Valve Head
  127. Cossie head gasket
  128. Escort MK4 XR3I EFI
  129. frst bits needed
  130. WANTED S1 RS TURBO STANDARD EXHAUST GENIUNE FORD
  131. WANTED OFAC fiesta rs turbo map sensor
  132. rs turbo or si bonnet
  133. Escos/RS2000/XR3i Mk5 Headlamps and side lamps!
  134. 3door pillow pod
  135. 4" rs turbo back box
  136. TSW IMOLA CENTER CAP and NUT
  137. 3dr Cosworth O.E Front Bumper (White)
  138. Late Spec Saph or Escos Alternator (Multi-V Type)
  139. loads of S2 bits please
  140. shpphire clocks 170mph
  141. A long shot but , Pug 205 GTi complete dashboard
  142. saff 4x4 rear diff
  143. Fiesta XR2
  144. ERST CVH sump
  145. 3 door TCA's and or Ball joints
  146. focus rs bits
  147. Wanted - RS500 IC, Radtec/pro alloy/genuine
  148. wanted mk3/4 van lowered
  149. wanted T34 .63 housing
  150. wanted RADTEC or PRO ALLOY RS500 cooler (4x4 saff)
  151. T3 for Series 2 Escort
  152. GRS INTERCOOLER FOR FIESTA RS
  153. oil drain pipe for 2wd turbo
  154. Passenger Side Electric Window Switch
  155. -31 Actuator for Rs turbo
  156. coil and leads for cossie distributorless
  157. Mint series 2 black or red
  158. kent cvh36 cam & vernier pulley.
  159. anti pump lifters.
  160. mk4 combi van
  161. 4x4 Saff Bonnet
  162. 88 spec s2 recaro seat needed..
  163. cheap escort cosworth fuel pump
  164. XR3I S2 TURBO
  165. Spec R alloy washer bottle for cossie
  166. Xr3i/Rs Turbo Backbox
  167. cosworth low comp pistons
  168. i want stage 3 or gunship
  169. escort cosworth
  170. Mk4 Fiesta 1.4 Zetec
  171. Pace intercooler to escort rs turbo mk4
  172. RDS 6000 Standard Ford Stereo
  173. reversed rst charge carrier
  174. escort cosworth carbon/stainless/alloy bits
  175. Cheap RS 500 Style Intercooler
  176. Cosworth 4x4 Exhaust Manifold Need in Birmingham **GOT ONE**
  177. rs turbo xr3i mk4 spares will trade for rs1600i gear
  178. wanted saff head lining
  179. WANTED t2/25 Hyrbid or uprated turbo to fit FRSt manifold
  180. Doors sills & under arch shields for 3dr cosworth
  181. ALLOY BELLHOUSING –For Hydraulic Clutch
  182. i want a gunship for 4x4 sapphire
  183. Chip for L8 light and blues
  184. MK4 seat frames wanted
  185. knackered banana pod gauges
  186. Coswoth L6 ecu wanted
  187. wanted escort cosworth turbo heat shield
  188. Cossie lattice alloys
  189. Alloys
  190. rs turbo cam
  191. xr3i efi loom
  192. 19'' superleggeras
  193. Focus RS
  194. sunroof
  195. S2 Wheel Bolts
  196. Orion Exhaust!
  197. standard s2 turbo
  198. rs7 softspoke alloys 17''
  199. weber carb
  200. fiesta,escort or orion
  201. Pace intercooler wanted
  202. 4x4 cos discs and calipers
  203. Escort Cosworth seatbelt pillar trims
  204. URGENTLY NEEDED!!
  205. mk4 escort uprated shocks
  206. ERST Outboard CV to driveshaft retaining circlip
  207. t25 escos bottom pulley and phase sensor PLEASE!
  208. tyres
  209. 18" Comp Mo - Old Type
  210. rs turbo steering wheel boss
  211. 4x4 Vernier cam pulleys
  212. Wanted- 4x4 AP 6 POT 356mm kit or similar
  213. Escort Cos wheels
  214. Mk3 escort ashtray and switch blanks?
  215. Wanted 3dr Cosworth interior bits
  216. FRST Boost hose
  217. wanted mk3 fiesta rear shocks or complete kit
  218. mk4 escort van wanted
  219. 2wd gear box
  220. T5 gearbox & bell housing torx bolts needed...
  221. series 1 front seats any condition
  222. injector
  223. S1 various parts
  224. FORD TYPE E GEARBOX
  225. Cossie T3 water pipes
  226. Fiesta RS Turbo Manifold t2 Fittement excellent condition
  227. Level 6/8 ECU, greens, 3 bar map sensor, PF09 TPS
  228. Calliper bkts to fit FRS Brembos to an S2
  229. red rs turbo (s2) kit, suspension,rear cage and backbox!!!!
  230. Wanted - 2wd Cossie rear beam / Diff / drive shafts
  231. WANTED: RS 1600i
  232. Search to buy Sierra Cosworth FLANGES!
  233. 17 or 18" RL7 or old style MO's WANTED
  234. 2WD cossie box T5 and starter motor
  235. Cosworth Centre Caps
  236. S2 loom needed
  237. cossie ICV
  238. Pectel boost pot
  239. Escort Mk6 Electric Mirrors wanted - pepper red if poss!
  240. 3DR/RS500 REAR SPOILER
  241. std T3 turbo
  242. rst camshaft
  243. focus rs (must be mint)
  244. swirl pot for cosworth
  245. 2.0 Zetec Throttle Body
  246. RS Turbo stuff
  247. Spec R alloy washer tank for cossie
  248. Where to source a new 1.8 Zetec Oil Pump?
  249. bias pedal box
  250. wanted.. standard 4x4 exhaust cam and middle box.
