PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 [94] 95
  1. 200 block
  2. escort cosworth handbrake console
  3. zetec exhaust manifold
  4. Wanted 3DR Door moulding "black strips"
  5. Escos rear seats
  6. Non smoking standard turbo for S2
  7. 2wd breather kit/seperator + 3 bar map sensor
  8. Intercooler deflector plate for 3 door cosworth.
  9. Connector pins
  10. Full frontal PACE intercooler with fans for ERST
  11. erst scorpion stainless wanted
  12. light blue injectors
  13. Looking for a low miles genuine 2WD Sappy or 4WD redtop
  14. saph cossie wanted
  15. RS500 Airbox scoop Wanted
  16. mk2 orion any spec
  17. WANTED, 3door escort
  18. rs1600i or chrome non turbo rocker cover
  19. mk3 cabriolet tonneau cover
  20. MONDEO pas pump
  21. 17"s wanted for sierra saff
  22. Escort cosworth engine mount
  23. L8 or P8 mapped for 500+bhp wanted
  24. S1 MASTER CYLINDER
  25. Small K&N air filter
  26. WANTED FORD FIESTA SI 16V
  27. Swb /Mwb Van wanted
  28. s1 bodykit
  29. zetec turbo engine wanted
  30. Big exhaust to fit a Sapphire 2000E
  31. FRST Standard ECU
  32. SAPPHIRE 4X4 STANDARD EXHAUST DOWNPIPE
  33. Good nick saff 2wd front coilovers wanted
  34. 205/50/15 Goodyear Eagle F1's
  35. front brake caliper hoses
  36. mk3 xr3i/rs1600 wanted
  37. 1.9/1.6 uprated cvh block urgently needed
  38. Drivers side bodykit sill, 90 spec spoiler/bumper ERST
  39. wanted frst mongoose
  40. Light blue or grey injectors
  41. NOT HAPPY GUYS
  42. Girlfriend WANTED
  43. RS Turbo engine wanted
  44. 4x4 Saph Rear brake calipers & carriers
  45. turbo pre cooler
  46. 2wd saff wanted
  47. Escort RS Turbo Clocks
  48. Samco T34 hose
  49. 2wd tickover screw wanted
  50. biege injectors
  51. locking oil filler cap preferably shiny-shiny
  52. 2wd Heatsheild
  53. Saph 4x4 Calipers/Disks
  54. Escoss AP clutch kit
  55. 17" diamond cut 7 spoke alloy
  56. FRST RAD,INTERCOOLER,ECU, TURBO AND MANIFOLD
  57. "ESCORT RS TURBO FUEL COMPUTER & WIRING"
  58. 2wd Cosworth Alloy rad
  59. mk4 escort front bumper
  60. Mk4 escort brake booster pipe
  61. AP BRAKE SETUP 4x4
  62. RS Turbo enngine
  63. WANTED - Charge Carrier/Xover and Rocker cover
  64. Focus Rear hubs, disks & calipers
  65. rs turbo/cosworth wanted
  66. Mk4 escort stuff
  67. 2wd cossie std chip, and map sensor
  68. Wanted: Masitaly VT5 18 x 7.5 - Escort Mk4 fitment
  69. escossie lhd scuttle panel
  70. Cosworth Fogs n Indicators
  71. Fuel ECU wanted.
  72. Wanted , Alpine stereo stuff , other's considered
  73. wanted s1 rst rotten crashed blown up
  74. wanted frst mongoose
  75. wanted s1 rotten crashed blowen up ?
  76. 88 spec erst door cards
  77. Magenta sapp cosworth n/s/f door
  78. Roll Cage wanted for 3 door Cossie
  79. ESCORT COSSIE WHITE BONNET
  80. buggered 2wd t3 needed (bracket that turbo damper bolts too)
  81. MOMO ARROWS WANTED!!!!
  82. MK2 XR2 DRIVERS DOOR AND BONNET WANTED!!!!
  83. wanted T4 ACTUATOR BRACKET
  84. escort cosworth rear uper fin
  85. Turbo Wanted..!
  86. S2 Airbox/Metering Unit Seal
  87. White S2 90 Spec Rear Tailgate & Spoiler
  88. Coil pack , leads, samco blue Water set for 2wd Cosworth
  89. Lower Cossie Spoiler
  90. Beige (701) injectors & MSD Evo chip
  91. Sapphy leather interior wanted
  92. 3dr wanted
  93. L8 ECU WITHOUT CHIP
  94. S2 Radiator needed
  95. S2 INTERCOOLER NEEDED
  96. suspension/shock absorbers for series 2 escort
  97. saff 2wd g/box
  98. Ford 302 5.0L V8
  99. Mondeo ST24 with RSAP kit
  100. -31 actuator for Cossie T34.
  101. Cheapish single cd player
  102. WANTED : Central Locking
  103. wanted series 1 loom
  104. Power Steering Pipes
  105. BLACK S2/FRST
  106. THREE DOOR CENTRE CAPS WANTED
  107. GGR 305 bhp(phase2) chip for small turbo escort cosworth
  108. L8 or P8 mapped for 500+bhp wanted
  109. T34 wanted for my future S2 project
  110. wanted mk5 b rs/si rear bumper
  111. 200 block
  112. focus RS rad fan cowling
  113. MK4 Escort Roof Clock ~ In Black !!
  114. 2wd rear diff needed
  115. cossie fuel pump wanted asap
  116. esc cos b/head/firewall panel [now sorted]
  117. phone n loose change tray pocket dash radio DIN sized thing
  118. s2
  119. -31 Actuator for 2WD COSSIE **
  120. sapphire cosworth 4x4
  121. escort cosworth bits needed
  122. bilstein
  123. high ratio diff ie. 4.4, 5.1 etc
  124. Ford Sierra Sapphire Cosworth Lookalike
  125. cossie bottom pulley
  126. 403 Grey Injectors + Fitting Kit
  127. MK 3/4 XR3I OR XR2/OR DIESEL/OR 1.1
  128. FULL SET OF SAMCO / ROOSE HOSES
  129. Crystal blue saff wanted or flint grey!
  130. fuel lines,for xr2 with 40's
  131. black 3 door
  132. a T3 turdo for escort RS TURBO
  133. escort cosworth steering wheel
  134. Pace/ProAlloy/Redtec intercooler wanted for RST Series 2
  135. 3dr cossie
  136. L6 ECU and 4wd fuel regulator.
  137. MK4 Zetec turbo bits and bobs
  138. Mk1 Sierra lowering springs
  139. Exhaust system urgently needed for MK6 RS2000
  140. Mk4 Escort van fuel filler neck needed
  141. Mk5 Escort XR3i 130 - in Met. Blue
  142. black XR4i!
  143. rs 16i wanted
  144. Saff lattice wheels wanted
  145. A few bits needed 2wd Cosworth 3 dR/ RS 500
  146. 4wd saff Track control arm
  147. Escort mk 3/4 35mm or 40mm lowering springs?
  148. Cosworth or V6 Exhaust hanger wanted
  149. Sapphire Center Console
  150. FRONT DIFF STRENGTHENING PLATE??
  151. Sierra cos spacers for prop centre bearing
  152. Speaker for n/s/r RST 90 spec
  153. Mk6 GTI/RS1800 or XR3i Wanted
  154. xr3i metering head
  155. Crankshaft and Conrods
  156. 9" Diff wanted, low ratio....
  157. 3 door original front wings
  158. COSSIE 4X4 GEARBOX
  159. Type 9 or MT75 V6 G/box Rwd wanted , RWD Prop Sierra wanted
  160. t4 turbo damper wanted
  161. MOMO Apache steering wheel
  162. gearbox mount
  163. Quaife ATB for 7,5" Sierra Cosworth 2wd -new Wanted
  164. cosworth engine wanted
  165. **TSW Evo's ** Maybe Part Ex**
  166. T3 turbo for S2 RST + other bits needed asap!
  167. 2WD Saff rear disks + calipers!
  168. Turbo damper wanted
  169. 2wd Cossie Interior + anti roll bar
  170. sapphire cos bootlid wanted
  171. SUMP NEEDED ASAP!!!
  172. S2 Intercooler
  173. escort cossie steering wheel
  174. OE Ford Jubilee clip wanted
  175. mkIII XR3i front seats
  176. wanted 2litre bottom end
  177. mk6 escort 3 dr 1.6
  178. closed
  179. 2wd sapphire cosworth wanted
  180. big turbo escort cosworth
  181. sierra xr 4x4 wanted
  182. Mk5/6 Escort RS2000 wanted
  183. Wanted Saph cossie (2wd)
  184. Wanted: Escort Series 2 Turbo Any Colour
  185. MK1/2 Escort Rolling Shell
  186. cheapish escort cossie
  187. bike for swop
  188. Sierra Cossie or RS Turbo S1 NOW SORTED
  189. escort cosworth leather interior wanted
  190. Sierra sapp Cosworth
  191. 3dr cosworth wanted
  192. swap 3.5 rs1800 for FRST
  193. big power s2rst, s1rst or frst,
  194. ka rolling shell, or cheap full car.
  195. A swap!
  196. Escort Si
  197. Wanted Mint Series 2
  198. s1 with or with out mot unfinnished project w.h.y?
  199. COSWORTH WANTED PX MINE?
  200. Black Capri - 2.8i
  201. XR2 MUST HAVE TAX AND MOT NO ENGINE NEEDED!
  202. st24 wanted asap
  203. Ford Fiesta Zetec s in blue
  204. damaged or rotton s2 or frst wanted will part x a n reg esco
  205. mint s2 erst
  206. Sierra XR4x4 2,9 Wanted
  207. radiant red sapphire cosworth wanted
  208. Xr2i
  209. Cheapish G or H reg 90spec mercury grey s2 wanted
  210. Wanted Ford RS Track car
  211. S1 or S2 car for project, Rolling shells or Complete car
  212. Sierra Cossie or RS Turbo S1 wanted
  213. cheap car wanted for project and doing up
  214. saff cossie
  215. Series 2 RS Turbo
  216. Escort cosworth wanted
  217. cheap xr3i to replace all the stolen parts of my turbo
  218. Series 1 RS turbo wanted. Top money CASH paid 4 right car
  219. RS500 or 3dr Cossie
  220. S2 WANTED FOR RESTORATION PROJECT!!
  221. mk3.5 rs1800
  222. I need a mk2 xr2 asap ~CASH WAITING~
  223. wanted-capri pref 2.0 laser
  224. escort van/combi or p 100 wanted
  225. Escort S2 rs turbo
  226. xr2 mk1
  227. escort van wanted
  228. fiesta wanted
  229. mint S1 Shell Needed!
  230. wanted desperatly.
  231. 1996 rs2000 wtd
  232. FORD PUMA WANTED
  233. s1 rs turbo wanted
  234. MkII Escort
  235. rs200 replica
  236. rs200 replica
  237. MK2 XR2
  238. s2 turbo body cond unimportant
  239. xr3 / mk3 escort wanted
  240. frst or fiesta xr2i 1.6 or 1.8
  241. 2wd Magenta sapphire Cosworth. SORTED NOW
  242. saff cos replica
  243. wanted p/x for cossie
  244. puma racing
  245. wanted 2wd cossie or FRST for national day track session
  246. MK1 XR2 WANTED
  247. 3 door cosworth and s1 turbo wanted
  248. Mk4 escort shell - mk3 also considered
  249. anyone got a mk3 escort to swap for a 19 16v???
  250. wtd escort turbo or rs2000 or fiesta turbo to part ex on....
