PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 3 door interior bits wtd
  2. rs focus pads and disks front
  3. 2wd saph cossie heater matrix please
  4. ERST Gearbox Needed as been let down big time
  5. SOLD
  6. Wanted, YB head cam cap No 5 please or ruined head
  7. RST Parts.....
  8. Urgent - Focus Flywheel and Clutch
  9. cosworth rear hub
  10. 2wd brake pipes
  11. *WANTED* 2wd Cosworth 283mm discs
  12. *WANTED* Front Cosworth Calipers
  13. Abs sensors , for saph 4x4 front hubs ??
  14. Mk4 escort driveshaft
  15. front wheel spacers
  16. White Fiesta Rs Turbo Front Bumper
  17. escort cosworth front abs sensor
  18. white colour code tag for erst
  19. Rear Bladed arb Escort / Sierra cossie
  20. 4x4 Cooler
  21. OLD Lambretta or Vespa scooter
  22. ERST bailey breather kit
  23. .63 housing
  24. Turbo inlet & Outlet Water Pipes wanted
  25. 195 45 16/205 40/45 16 tyres
  26. Wanted: XR2 Mk2
  27. flint grey spary can
  28. Zetec S Door Cards (MK5)
  29. mexico
  30. wanted escort rs1600i
  31. sierra 1.8 cvh bottom pully,alt pully,cps + bracket
  32. ofac map sensor any one got one ???
  33. Littermaid litter tray(s)
  34. front koni's for 4x4?
  35. #
  36. Brake Discs
  37. Rs 2000 14 engine! bottom end and head!
  38. Mk4/5 moondust mirrors + mk5 front headlights
  39. Zetec 2l cylinder head
  40. CVH Stage 3 Head
  41. Cheap cheap 4x4 fourtrack sj vitara ect ect
  42. *WANTED* RS Turbo Front Brakes!
  43. Standard ERST front Hubs and Brakes...
  44. damaged 3 door bonnet
  45. 4x4 floor pan & strut tops
  46. rs turbo fuel cap
  47. mk 3 fiesta rear wheel spacers
  48. bolt in cage for a sapph with sunroof
  49. rs turbo parst s1 and s2
  50. escos o/s bonnet vent prefferably mallard
  51. sierra cosworth motorcraft white/clear battery
  52. Wanted 4x4 cosworth cylinder head
  53. wanted ap 6 pot callipers
  54. escort cosworth crank pulley
  55. outer rear arm bush needed. genuine ford.
  56. 4x4 quickshift
  57. roose splitter or rs500
  58. intercooler rs turbo
  59. WANTED: T4 Turbo rs500
  60. mk4 cvh dipstick
  61. 2wd Cosworth belhousing
  62. 16" Fiesta Turbo Alloys
  63. 4wd T3 and 2wd gearbox wanted
  64. T5 Gearbox and Good T34
  65. mk2 xr2 cage +
  66. Three door front drivers doorcard!!!!
  67. 3 door bumper light clips
  68. solenoid,tempriture fan switch and jackin point cover
  69. Cossie ISCV & TPS
  70. 044 fuel pump, rewire loom, swedish manifold, 2wd big, inlet cam wing sump
  71. fuel pump
  72. CVH Rocker Arms, inserts and Shims.
  73. Centre horn button to fit RS wheel
  74. L6 wanted
  75. Cycle carrier wanted
  76. 3 Door Sunroof
  77. ecos tyres
  78. Sierra Shell
  79. 2wd red hoses
  80. Escos engine undertray/shield
  81. St170 parts needed
  82. 215/45/17 tyres
  83. mondeo st200 near sussex
  84. wanted set of late mk3 fiesta wing mirrors
  85. wanted rs7 spoke diamond cut alloy wheel 17inch
  86. 2wd Power Steering
  87. Mk4 escort xr3i downpipe
  88. 4x4 BD14 INLET CAM
  89. Looking for an rs1600i mint or project not fussed. (black prefered)
  90. chip for l8 running seimens 55's
  91. plenum spacer and rs500 tb
  92. 2WD dip stick
  93. s1 rs turbo 15" wheels
  94. Escort Cosworth Alloy Radiator
  95. 4x4 coilovers
  96. escort springs
  97. escort series 2 88 expantion bottle
  98. wanted, RST recaro seat widers
  99. frst engine mount
  100. Focus Alloys Wanted
  101. 215/45/17 tyres
  102. 3 Door Front Bumper moulding/insert
  103. Ford Racing boost gauge
  104. mk3 escort panels needed
  105. scrap rs turbo bonnet
  106. Saff leather front seats for my van.
  107. erst wiper motor back plate
  108. A few cossie 2wd Bits needed
  109. Mk1 Focus Zetec rim and tyre needed
  110. MK4 Escort Panels Needed
  111. efi rs turbo or xr3i/xr2i head
  112. Escort Diesel Engine
  113. standard ford tape headunit
  114. Part needed.....
  115. Wasted spark conversion parts
  116. rs turbo pistons
  117. area 6 tubular zetec manifold + 750cc injectors
  118. sump for v5 golf
  119. Ka engine mount for CVH turbo
  120. Escort cosworth heater box and controls
  121. OFAC loom & ecu / RS Turbo fuel tank
  122. Rs turbo wanted anythin considered
  123. s2 chrome rocker cover
  124. 3 Door parts
  125. sapphire cosworth front bumper+grill
  126. Escort mk6 driver 's door
  127. RL7's
  128. mk3 escort bumpers
  129. sorted
  130. cosworth yb head
  131. various s1 rs turbo parts needed
  132. PUMA os rear shock
  133. EFi Fuel Pump
  134. four point harness's
  135. wanted mk1
  136. s2 mounts
  137. kent timing disc
  138. Mods Please Delete
  139. Esc Rst rear hubs
  140. turbo heath sheild
  141. Rear inner wheel arch liners for Sapphire
  142. 2wd oil pump
  143. fiesta rs turbo head
  144. front coilovers/sump for 2wd saph
  145. 3 door..drivers side door card??
  146. standard 2wd inlet cam
  147. L8 babyboard wanted
  148. 3door Cossy front fogs and indicators wanted
  149. Snap on or mac tools screw drivers wanted
  150. 2 front spax PSX for mk4 rs turbo
  151. Wanted XR4x4 Hubs and Calipers
  152. Another Turbo for an escort rst!
  153. Fuel Filter to Metering Unit Hose
  154. s1 rs turbo floor carpet
  155. Corsa B
  156. mondeo alloys
  157. White saph coz o/sr door and boot lid
  158. cossie throttle body and blanking bung for iscv
  159. Hose for rs turbo
  160. 3dr washer bottle pump
  161. wanted a set of escort cosworth coilovers
  162. looking for a esc system
  163. Still need a turbo for my escort RST!
  164. SEC Monitor?
  165. Front bumper and bonnet......
  166. 4x4 BD 14 inlet cam wanted
  167. 2wd Cossy sump
  168. Wanted: rs turbo modine
  169. aeromotive fuel pressure regulator
  170. escort gti front bumper,water and aircon rad
  171. looking for a saff cossie needing tinkering to deal for my p38 rangerover dse
  172. wanted 1.9 american tall block
  173. ap 2wd cos bells
  174. Aux Air Device to Manifold Hose Insert
  175. wanted 2.8 engine
  176. ERST S2 MFI engine loom.
  177. Knackered T5
  178. 4x4 saph aftermarket air filter
  179. bucket seat
  180. escos abs sensors
  181. Turbo for my escort rst
  182. escort cosworth scuttle panel
  183. heath sheild
  184. anyone got a sky digital box they dont want.?
  185. focus diesel
  186. Turbo oil feed bolt
  187. inlet manifold for xr3 to fit twin 40s
  188. cosworth rocker cover.
  189. rs turbo alloy header tank
  190. fiesta turbo radiator
  191. Orange 3 door front indicators
  192. Spring Clip S2 ERST Pic Attached!
  193. rs 2000 mk5 alloys
  194. Early Cosworth oil cap
  195. 4x4 cossie rear arms WANTED
  196. l8 or p8 ecu
  197. momo arrows for a series 2
  198. mfi 2 efi converter plate quick...red open mouth s2 bumper
  199. Wanted: Focus RS TB Elbow
  200. Saph headlight wipers/motors
  201. 18" Focus ST 2 alloy wheels.
  202. wanted momo arrows 16" or 17"s
  203. WANTED 3 door wheels
  204. Wantedddd..3 door parts!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  205. mfi tooo efi adapter plate needed
  206. saff cos rear beam complete, diff
  207. sierra cosworth anti roll bar clamps and diff oil level plug
  208. 3 Door Cossy fogs and indicators
  209. Wanted RS500/saff cossie front bumper
  210. mk4 escort non abs reservoir needed
  211. Unusual Request - 3 Wheeler
  212. 18s for a Focus
  213. Cossie 3" downpipe.
  214. mfi to efi adaptor plate
  215. Escort Rs Turbo Wanted, Anything up to £5,500
  216. Mk6 rs2000 cheap
  217. <WANTED> mk6 fiesta options 16" alloy
  218. Escort Cosworth heater box
  219. focus rs rear bench and door cards
  220. 2.0 zetec, turbo or n/a
  221. Needing a ecu for a fiesta st150 anyone have one ?
  222. Wanted!!! Orion rear bumper
  223. 3dr cosworth engine lifting eyes
  224. Escort rs turbo t3 water pipe for turbo
  225. Heatshield and Suspension
  226. Help!!! Parts needed!
  227. Cosworth Silicon hose
  228. superchips piggy back chip for zetec and powerboost valve
  229. Sharktooth rims
  230. RS1600i. series one turbo rolling shell
  231. Escort cosworth Drivers seat subframe
  232. splitter
  233. Cosworth MAP sensor bracket
  234. 2wd suspension kit or springs
  235. ST200 n/s fog light surround
  236. cheap rs turbo with knackered engine
  237. cosworth rocker cover
  238. 2wd vibratec engine mounts wanted.
  239. Mondeo Mk3 Standard or Lowering Springs
  240. Plug for CPS - 1.6 CVH EFi
  241. Spax/Koni/G Max suspension kit for S2
  242. Escort cosworth coilovers wanted
  243. cosworth throttle body and red induction hose
  244. late saph snowflake alloys
  245. saph 4x4 koni set up
  246. escos steering wheel
  247. 4x4 plenum
  248. heated screen switch cossie wanted
  249. m3 mirrors
  250. 88 spec rs turbo interior
