View Full Version : Cars & Parts Wanted.
- 2wd Crank pulley....
- ofac or ofab ecu for fiesta turbo
- escort mk6 headlamps
- WANTED:15" or 16" alloys in Scotland (or posted)
- MK III Escort van wanted
- Fiesta Rs turbo OFAB map sensor wanted asap !
- Coil pack multiplug FRST
- RS TURBO METERING UNIT IN WORKING ORDER WANTED PLEASE!!!
- Wanted - 3 studs/bolts for the rear mount on a RST gearbox
- lower boot spoiler for escort cosworth...
- pair 6 pot ap callipers
- snap on tool box
- zetec valve collets
- **WANTED\\series two carbon fibre bonnet//WANTED**
- Pillar pod for a 3 door
- xr2i wanted px escort gti
- 1 x 3dr alloy wheel centre cap lock
- xr2i 8v
- Wanted: Escort Cos Bits - Escort Bits
- Nitrous kit
- 2.0 engine wanted urgently
- pump carrier
- FORD FIESTA XR2
- escort coworth front bumper
- cosworth yb bottom end
- MK2 Orion Turbo
- Cosworth 4x4 front brakes
- Broken Cossie ECU Wanted - Anything will do!!!!
- fiesta rs turbo/ xr2i/ rs1800 front bumper
- G Reg S2 Metering Unit
- Cordless Impact Driver
- car wanted to swap for gsxr 1000
- standard header tank and cap for a cossie
- Sierra Sapphire Cosworth Replica
- series 1
- MSD Closed Loop Chip for greens ESCOS
- 3 door bonnet - any colour
- black plastic inlet bit
- ERST Complete Car Loom!
- 2WD LOWERING SPRINGS [REAR NEW] WANTED COSWORTH 3DR.
- zetec turbo engine
- sos engine-gearbox
- wanted rst gearbox northeast.
- help! with escort rst
- rs turbo petro tank sender unit and pump.
- shell mk3 or s1
- uprated front diff
- fiesta turbo engine loom
- escort cosworth power steering rack
- beige injectors
- rst wanted in nov
- small turbo escos air box
- 2wd saph lower dash (passenger side) and speedo surround
- Series 2 RS Turbo Complete Loom
- ERST 90's spec recaros.
- ERST S2 SUNROOF
- cossie t34 exhaust houseing
- sorted
- Spare Cosworth Cam Covers for Powder Coating??
- 3 door nearside inner arch splashguard
- 30mm s2 rs springs
- 2wd starter motor
- 2wd or 4wd crank
- 4x4 COS Quaife Gearbox
- transit recovery flatbed truck wanted
- Need: COSWORTH RS500 INTERCOOLER
- 5th injector kit
- turbo
- s2 box
- fiesta 1.25 zetec engine wanted.............................
- efi tank
- Wanted Escort RS Turbo Series 2
- xr4X4 2.9 throttle cable
- 3dr floor sound deadning
- Need: Sierra cosworth 2WD Boost and ancillary Hose kits
- 3 door parts needed
- Cossie 2wd Turbo Water Hose
- FRST header tank
- Mk2 Fiesta Washer Bottle
- s1 grill urgent
- Fusebox and Bonnet MK5a
- rs turbo parts
- gear linkage
- Sierra 2WD Cosworth Standard Cam Pulleys
- weber fuel presure regulator for frst
- 2wd saph cos steering rack,cosworth wheels
- racing puma front brakes
- Rear Half Roll Cage for a MK3 escort
- Saf rear bumper in white.
- Wanted Mint 2wd gear knob
- Need: Quaife ATB diff for 2wd Sierra Cosworth!
- Series 2 master cylinder
- rs turbo fuel tank, fuel pump and bracket and sender unit
- centre caps and a few other bits....
- RWD/4wd Cossie powered Focus- URGENT!
- 2wd cossie big wing sump
- delete this, ive nicked my mates.
- Fiesta rear wiper arm ****sorted pls delete****
- RS1800 alloys
- FRST bits
- sorted
- H plate Escort RS Turbo Shell and ID WANTED
- Sapphire cosworth rad, uprated alloy etc etc
- fiesta turbo ofab ecu
- Cam Cover Studs to suppport Plastic Cambelt Cover
- 2.0 Zetec Engine
- 2wd cosworth
- 24V Sierra
- WANTED 1989 onwards XR3i or RST S2 steering rack
- Focus Rs Front Seats
- Stage 2+ CTS Gearbox Or 300+BHP Gearbox (BC)
- really need 1 of these
- compmotive alloys
- Sorted!!
- Decent after market rev gauge 80-100m pref white face
- S1 RS TURBO ARCHES AND SKIRTS WANTED EVEN IF DAMAGED!!
- S2 RS Turbo passenger side skirt
- p8 ecu
- Wanted** Splitter for sierra cosworth
- odd one, pug 306 cab bumpers
- 1.6 Escort
- Steering wheel boss
- sierra cosworth fuel pump wanted
- fiesta mk4 1.25 zetec engine wanted
- Series 1 Body kit
- 200 block
- 1/2 leather recaros
- Carbon cam belt cover
- COMPOMOTIVE MO,S WITH TYRES
- 17 inch comps wanted
- beige injectors
- cheap ford orion or combi
- s1 boot seal
- cosworth suspention
- Polished turbo damper for 2wd cos (pref Bailey or simlar)
- 6x9 speakers
- 2wd gearstick
- frst wanted
- fiesta rs turbo coilovers
- Mk3 FRST Lock Set
- wanted fiesta rs turbo engine loom ofab
- s2 knock sensor
- 4X4 Cosworth -31 actuator wanted
- Sapphire Cosworth drivers side O/S headlight glass required
- Focus 1.6 wanted
- wanted ST24 ALLOY - TURBINE/WINDMILL TYPE
- Electronic Boost Controller... (+omex 600 ecu on off chance)
- RS Turbo/XR3i Fuel pump bracket
- pf01 saph cosssie 2wd tps
- 2wd t38
- looking for a saphire cosworth shell
- S1 parcel shelf support
- paint gun + air tools
- STANDARD RS TURBO AIRBOX
- Fiesta RS Turbo parts
- Needed asap S2 Fuel line
- Mk2 Orion Clear Rear Lights
- 88 spec standard rocker cover
- 4X4 SAFF COSSY CALIPERS(FRONT) AND 2WD SAFF COSSY DISKS!
- Centre cap for rs500/3 dr wheel
- bolt in safety devices roll cage for mk5 escort
- BIG brakes wanted for 4x4 sapph cossie
- Wanted 4x4 Cosworth Exhaust!
- 3 door/rs500 parcel shelf wanted
- T2 Turbo & standard Fiesta RST airbox please, urgent
- Series 1 RS Turbo
- -31 Actuator
- rs 1600i wanted
- Escos 4x4 SAMCO Hoses in Blue
- Air filter box for 4wd saph cossie.
- *** SHOW CAGE FOR Escort MK 4 ***
- xr2i cam (1.6 8v) and cvh vernier pulley! wanted!
- Rear View Mirror for FRST
- fuel pressure regulator
- alarm or keyless entry system
- Mk4 RS Turbo/XR3i Rear springs
- cosworth 4x4 oil pickup
- mk3 cortina
- 18" wheels for 4x4 Saph WANTED!
- rs turbo gearbox asap
- series 2 grey 88 spec front bumper..
- big turbo for 2wd
- Escort MK4 Door Rubbers ( window )
- Single 90 spec recaro.
- 2wd manifold and 4x4 MT75...anything considered
- RS1600i interior and front spoiler
- looking for 2.0l zetec engines money waitin 4 right engine
- cossie 4x4 ecu wanted
- Wanted, broken T3 water pipe
- s2 front anti roll bar
- RS1800 Kent or piper cams
- cossie intercooler wanted
- Escort RS Turbo Fuel pump bracket
- xr2 suspension
- Roll Cage for S2 wanted
- escos fog lights
- wanted stg 3 chip
- mountune YB roller barrel intake
- mk5/6 rs2000
- Recaro seat handle
- Three door cossie wheels
- EFI CVH Worked head
- Fiesta Rs Turbo efi fuel pump electrical connector plug
- PLEASE DELETE - NO LONGER NEEDED
- series 1 turbo
- 4*4 Rear left brake caliper and 4*4 throttle body
- 2wd Sierra Cosworth Drive Shafts
- wanted escort s1 full lock set
- st 170 cams
- pink/purple fuel relay
- Windscreen, 90spec bumper, 90spec spoiler
- mk 3 escort shell
- focus 3 door
- RS turbo Fuel Sender
- saph rear bumper
- 2wd front caliper
- 4wd Cossie EXhaust camshaft
- Cosworth 2wd exhaust manifold trousers wanted (neck)
- RS TURBO EXHAUST
- Hybrid turbo
- Magenta boot and spoiler!
- SERIES 1 ANY CONDITION CONSIDERD ??
- mk4 escort bonus
- Escort door locks
- Civic Type R GOT ONE
- 2wd T5 cosworth gearbox SORTED NOW
- cosworth stuff wanted for my latest project
- front seats
- fiesta rs turbo rad
- S1 bodykit and front recaro's wanted.
- ESCORT COSWORTH WANTED W.H.Y CASH WAITING
- Wanted: Pair of Cossie Rad Fans
- 4x4 front passenger hub
- 3dr rear lights
- S2 RS Turbo Windscreen
- NUTS FOR TURBO
- wiring loom
- s2 lsd gearbox
- 2 litre mondeo zetec engine
- ERST HELP!!!!
- 2wd Coilovers
- Escort cosworth wanted
- never mind
- Koni shocks + springs (Rear only)
- L8 with MSD chip and Closed loop and Wasted spark driver
- ofac chip
- strange part wanted
- 2wd mongoose/ scorpion exhaust
- FIESTA TURBO CHARGE CARRIER/CROSSOVER PIPE
