View Full Version : Cars & Parts Wanted.
- s2 rs turbo alloy radiator
- MK 4 RST or Xr3i rear shock covers
- wanted rs 500 throttle cable bracket
- s1 crossover pipe
- 3dr Gearbox mount , the Alloy bit on a 2wd gearbox
- HI LONDON CHRIS
- ESCORT COSWORTH BONNET???
- p zero tyres
- RS turbo bonnet vents
- Wanted: Rear- Speakers Premium for Sierra Cosworth 4x4
- Olives
- Cosworth coilpack leads
- Pair of Escort Cosworth headlamps Wanted !
- GGR 305 CHIP,BIG TURBO INTERCOOLER
- ser 2 rurbo
- wanted t3 turbo s1
- focus TDCI mk1 - 3 door or NON ROTTEN FRST!
- FRST green (long) passenger door strip
- Big HP RWD Cosworth Race Gearbox , X-Trac , Getrag etc..
- 200 block wanted
- Looking for mint 3dr Sierra Cossie
- fiesta mk 3 drivers door in red preferably.very urgent
- cosworth engine, box, ecu, wiring, cvh rods
- S1 RS Turbo rear bumper
- Focus RS brakes
- saff cossie mud flaps
- rs steering wheels boss for mk3 fiesta
- MOMO ARROWS MUST BE 17 INCH 4 STUD FORD FIT
- t5
- mk4 escort hatchback
- Esc Cos radiator
- moonstone blue escort cosworth
- turbo timer & head unit
- cossie turbo
- s2 rear suspention bits and adj tca's
- cosworth 63 exhaust housing
- WANTED!!!!!!!!!! ford orion
- Alternator - Starter wiring!
- Ser 2 Stage 2or 3.Req.
- 1x FRST recaro head rest needed 17/4/06
- 225/40/18 tyres
- XR3I EFI loom
- Ford racing puma sparco buckets
- t56 Gearbox
- wanted asap 2wd water hose
- 195/45/16 Tyres
- ford rs500 / three parts
- S2 LSD GEARBOX IN SCOTLAND
- rs 2000 rocker cover
- escort mk3 bodyshell
- jacking point cover
- Ser.2 T.3 Turbo
- WANTED!! sierra sapphire cosworth sunroof
- SAPH COSSIE WANTED IN AUGUST 06
- 2wd thermostat housing
- mk1 xr2
- escort cosowrth back box
- Wanted, simple!!!!!!!
- uprated cossie rear diff mount
- focus rs manifold
- WANTED FORD ESCORT ESTATE TD
- blue boost hoses for ERST
- 12inch kenlowe fan
- mk4 escort EFI clocks
- S1 bottom hose
- Bailey oil breather for ERST
- rs 1600i tappet spanners
- 3 door cossie rear arches
- Super chip, induction kit
- Scorpion Exhaust For S2
- A Few S2 parts needed ASAP
- Fitting For Bosch 044 fuel pump
- sapphire cosworth wanted for swap with uk impreza turbo 2000
- ERST SCUTTLE PANEL RUBBER SEAL...........WANTED
- wanted s1 erst rad
- s2 rst mudflaps
- Sapphire Cosworth Roll Cage
- standard cossie amal valve
- Saph drivers leather seat.
- 2WD Cossie Bottom Pulley
- MK4 XR3i DRIVERS DOOR CARD
- ORIGINAL CARELLO MK4 ESCORT headlight
- WANTED RS500 FRONT SPLITTER FOR 3DR
- 8x18 comp mos for esc cos wanted
- coz 2wd front calipers
- 3dr drivers seat
- mk 3.5 fiesta dash etc... (or whole car)
- Looking for, parts for a series 2 rs turbo.
- S2 RST Gearbox...
- CTS STAGE 2 OR STAGE 2 PLUS GEARBOX
- 90spec Recaro's
- Fiesta Mk2 XR2
- RST in scotland
- s2 rst rollcage
- Mk5 Escort CVH EFi ECU/engine Loom needed!
- std escort rst top boost hose
- sierra 4x4 cos throttle pedal
- desperately need a set of 3door/2wd front calipers
- P100
- 2.1 ZVH RS TURBO
- Sapphire Cossie Leather Drivers Door Card..
- Has anybody got??
- P8 ECU
- 2 escort doors
- Fiesta ST
- cosworth plenum spacer
- escy cos rear and front bumper
- ESCORT COSWORTH SHELL
- rs2000 transfer box
- escort wanted
- door cards
- cossie block
- RST .48 EX HOUSING or FOOKED STG3 TURBO
- Cosworth Rocker Cover , New Powder Coated Red
- looking for a s1 up to 2500 paid cash
- cheap piston dump vale ????
- ERST OR FRST CONROD WANTED
- Sapphire Cossie wanted in exchange for Mazda RX7....
- FULL ENGINE GASKET SET FOR ERST OR FRST WANTED..
- *** urgent help *** escorth cos water pump
- Car transporter trailer
- mk4 escort wanted
- SAPPH COSWORTH REVERSE LIGHT LOOM
- RS500 T4 shaft
- mint,rot free mk 4 shell
- EFI bits n bobs
- Escort Cosworth Front Brakes
- Scrap/unwanted cosworth head
- wanted - cossie T3 turbo.
- Saf 4x4 Bonnet Vents, 2.0 Zetec
- Carwise Alloy fuel Rails for RS 500
- rst van mk6
- RST Series 2 - Throttle cable, screws, clips & bonnet pu
- Escort MK 3 or 4 rear Konis
- Bare 4wd head
- zetec s 1.6 engine desperately...
- Wanted.?? Mk 1 Escort Mexico, RS 2000 etc..
- Wanted.?? Mk 2 Escort Mexico, RS 2000, 1600 Sport etc.
- Speedo sensor for an 88 Granada
- saff cossie wanted
- WANTED-BIG SPEC S1/S2
- 2001 zetec s fiesta door mouldings
- Escos body parts?
- map sensor
- T3 turbo wanted
- SAPHY COS SIDE MOULDING STRIPS
- front rotors
- £££££££££ CARS AND PARTS WANTED £££££££
- M16 Calipers
- Wanted upper and lower splitter for Escos
- Wanted, Escort Cossie Wheels
- RS500 Front Bumper
- 1988 rs turbo petrol tank
- wanted mkl rs2000 centre consol
- Uprated escos gearbox
- Wheels wanted, 2 sets of two,
- wanted series 2,
- Focus ST 170 wanted
- Fiesta mark 3 front bumper and boot in pacifica blue
- SAFF MORRETTES
- FRST T2 MANIFOLD
- 1.4 zetec SE engine or complete bottom end
- EXCELLENT CONDITION BIG SPEC SERIES ONE
- s2 rs turbo escort
- RST Gearbox and other bits...
- Fez turbo interior
- xr2
- WANTED: SAFF SHELL (mint condition)
- need a cheap run about
- ST24 hatchback WANTED
- RST
- s1 rad wanted
- need a cheap run about!
- engine crane / stand
- sorted now
- ERST S2 Coolant Hoses
- WANTED Focus RS. p/x my Escort Cosworth...
- Fiesta MK 1
- s2 white nearside door
- Mk2 XR2 wanted
- escos turbo heatshield
- Driver side bolster
- ISCV Torque Screws!
- 1.8 cvh cylinder head for sierra
- turbo water return pipe.
- WANTED - Lock set
- nice RS1600I wanted
- Wiring loom for late 2.9 XR4x4 (with lambdas, not AFMs)
- wanted pectal 8 injector loom
- cossie front brakes
- LEFT HAND DRIVE escort cosworth wanted
- ERST T3 or Saphire 2wd turbo unit..
- WANTED MK5 RS2000 FRONT BUMPER & N/S HEADLIGHT & SID
- xr3 or rs turbo gearbox
- Fuel Tank For Saph Cossie
- ERST lsd gearbox
- S1 Turbo
- mk3 xr2i
- vent blanking plate
- £6000 for a 3 door cosworth please help me find one.
- FRST Bumpers in Moondust Silver
- mk4 cabby or xr2 UNDER £600
- MK 5 RS 2000 BLACK MINT
- FRST standard fan
- Ford Escort RS Turbo S1 Fuel Pump Relay - Silver (Urgent)
- Honda C70 or C90 engine!
- after market rear bumper
- P8 Ecu
- s2 wanted,not too fussy at all
- Fiesta exhaust downpipe for t3 conversion
- 2wd cossie quad headlights
- 5TH INJECTOR FULL SYSTEM
- intercooler
- EECIV plenum wanted
- Dark roof lining for escort mk4
- wanted zetec 2.0 black top engine
- MK4 Escort Shell
- 2 w/d steering pump
- sunroof
- 17in Diamond Cut RS 7 spokes with tyres - must be mint
- MK6 RS2000 front Recaro seats
- wanted.. 195/40/16
- es cos shell
- mk3 escort BOOT in good condition!!!!!!
- 3 Door front anti roll bar Not Sapphire!
- abs sensors
- OZ SuperTurismo 18" for Escort Cosworth
- T4 turbo
- Escort RST bailey breather and samcos
- s2 wanted
- jacking point covers, bonnet raisers
- power steering pipe
- Escos morrets
- wanted xr3i zorst
- exhaust housing
- MK5 Escort Cabriolet Roof Pump
- WANTED LOCKWOOD WHITE DIALS FOR RS TURBO
- wanted mint s1 or s2 for cossy 4x4??
- S2 Distributor asap
- s1 parts
- adjustable tca and top mount and strut brace
- Cossie Airfilter.
- Fiesta Doors
- RS1600i front x member
- xr2 or mk4 cabriolet under £500
- roll cage.
- t34 uprated turbo wanted for stage 3 saff cossie 2wd
- spotlights
